[GRASS-SVN] r39198 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Mon Sep 14 09:04:28 EDT 2009
Author: martinl
Date: 2009-09-14 09:04:28 -0400 (Mon, 14 Sep 2009)
New Revision: 39198
grass/trunk/display/d.vect/main.c
grass/trunk/display/d.vect/plot1.c
d.vect: print number of plotted features in verbose mode
direct OGR support activated
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2009-09-14 12:18:53 UTC (rev 39197)
+++ grass/trunk/display/d.vect/main.c 2009-09-14 13:04:28 UTC (rev 39198)
@@ -84,7 +84,6 @@
int size;
int default_width;
double width_scale;
- int verbose = FALSE;
double minreg, maxreg, reg;
char map_name[128];
struct GModule *module;
@@ -359,9 +358,6 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if (G_verbose() > G_verbose_std())
- verbose = TRUE;
G_get_set_window(&window);
if (D_open_driver() != 0)
@@ -439,7 +435,7 @@
Clist->field = atoi(field_opt->answer);
/* open vector */
- level = Vect_open_old(&Map, map_name, "");
+ level = Vect_open_old2(&Map, map_name, "", field_opt->answer);
if (where_opt->answer) {
if (Clist->field < 1)
@@ -585,8 +581,7 @@
D_setup(0);
- if (verbose)
- G_message(_("Plotting ..."));
+ G_verbose_message(_("Plotting..."));
if (level >= 2)
Vect_get_map_box(&Map, &box);
@@ -682,8 +677,7 @@
D_close_driver();
- if (verbose)
- G_done_msg(" ");
+ G_done_msg(" ");
Vect_close(&Map);
Vect_destroy_cat_list(Clist);
Modified: grass/trunk/display/d.vect/plot1.c
--- grass/trunk/display/d.vect/plot1.c 2009-09-14 12:18:53 UTC (rev 39197)
+++ grass/trunk/display/d.vect/plot1.c 2009-09-14 13:04:28 UTC (rev 39198)
@@ -58,7 +58,8 @@
dbCatVal *cv_rgb = NULL, *cv_width = NULL, *cv_size = NULL, *cv_rot = NULL;
int nrec_rgb = 0, nrec_width = 0, nrec_size = 0, nrec_rot = 0;
int nerror_rgb;
+ int n_points, n_lines, n_centroids, n_boundaries, n_faces;
int open_db;
int custom_rgb = FALSE;
char colorstring[12]; /* RRR:GGG:BBB */
@@ -263,6 +264,9 @@
nlines = Vect_get_num_lines(Map);
line = 0;
+ n_points = n_lines = 0;
+ n_centroids = n_boundaries = 0;
+ n_faces = 0;
while (1) {
line++;
if (Vect_level(Map) >= 2) {
@@ -582,13 +586,44 @@
else /*use different user defined render methods */
D_polyline_abs(x, y, Points->n_points);
+ switch (ltype) {
+ case GV_POINT:
+ n_points++;
+ break;
+ case GV_LINE:
+ n_lines++;
+ break;
+ case GV_CENTROID:
+ n_centroids++;
+ break;
+ case GV_BOUNDARY:
+ n_boundaries++;
+ break;
+ case GV_FACE:
+ n_faces++;
+ break;
+ default:
+ break;
if (nerror_rgb > 0) {
G_warning(_("Error in color definition column '%s': %d features affected"),
rgb_column, nerror_rgb);
+ if (n_points > 0)
+ G_verbose_message(_("%d points plotted"), n_points);
+ if (n_lines > 0)
+ G_verbose_message(_("%d lines plotted"), n_lines);
+ if (n_centroids > 0)
+ G_verbose_message(_("%d centroids plotted"), n_centroids);
+ if (n_boundaries > 0)
+ G_verbose_message(_("%d boundaries plotted"), n_boundaries);
+ if (n_faces > 0)
+ G_verbose_message(_("%d faces plotted"), n_faces);
Vect_destroy_line_struct(Points);
Vect_destroy_cats_struct(Cats);
