[GRASS-SVN] r39204 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Sep 14 13:41:07 EDT 2009
Author: martinl
Date: 2009-09-14 13:41:06 -0400 (Mon, 14 Sep 2009)
New Revision: 39204
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/render.py
better direct OGR support for wxGUI dialogs
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2009-09-14 16:15:36 UTC (rev 39203)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2009-09-14 17:41:06 UTC (rev 39204)
@@ -9,6 +9,7 @@
- TreeCrtlComboPopup
- VectorDBInfo
- LayerSelect
+ - LayerNameSelect
- DriverSelect
- DatabaseSelect
- ColumnSelect
@@ -498,17 +499,20 @@
return self.tables[table]
class LayerSelect(wx.Choice):
- """!Creates combo box for selecting data layers defined for vector.
- The 'layer' terminology is likely to change for GRASS 7
- def __init__(self, parent,
- id=wx.ID_ANY, pos=wx.DefaultPosition,
+ def __init__(self, parent, id = wx.ID_ANY,
size=globalvar.DIALOG_LAYER_SIZE,
- vector=None, choices=[], all=False, default=None):
+ vector = None, choices = [], all = False, default = None):
+ """!Creates widget for selecting vector map layer numbers
- super(LayerSelect, self).__init__(parent, id, pos=pos, size=size,
- choices=choices)
+ @param vector vector map name or None
+ @param choices list of predefined choices
+ @param all adds layer '-1' (e.g., for d.vect)
+ @param default default layer number
+ super(LayerSelect, self).__init__(parent, id, size = size,
+ choices = choices)
self.all = all
self.SetName("LayerSelect")
@@ -543,7 +547,48 @@
if self.default:
self.SetStringSelection(str(self.default))
+class LayerNameSelect(wx.ComboBox):
+ size = globalvar.DIALOG_COMBOBOX_SIZE,
+ vector = None, dsn = None):
+ """!Creates combo box for selecting vector map layer names
+ @param vector vector map name (native or connected via v.external)
+ @param dsn OGR data source name
+ super(LayerNameSelect, self).__init__(parent, id, size = size)
+ self.SetName("LayerNameSelect")
+ if vector:
+ # -> native
+ self.InsertLayers(vector = vector)
+ elif dsn:
+ self.InsertLayers(dsn = dsn)
+ def InsertLayers(self, vector = None, dsn = None):
+ """!Insert layers for a vector into the layer combobox
+ @todo Implement native format
+ layers = list()
+ if vector:
+ # TODO
+ pass
+ elif dsn:
+ ret = gcmd.RunCommand('v.in.ogr',
+ read = True,
+ quiet = True,
+ flags = 'l',
+ dsn = dsn)
+ if ret:
+ layers = ret.splitlines()
+ self.SetItems(layers)
class DriverSelect(wx.ComboBox):
"""!Creates combo box for selecting database driver.
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-09-14 16:15:36 UTC (rev 39203)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-09-14 17:41:06 UTC (rev 39204)
@@ -183,12 +183,11 @@
if prompt == 'vector':
name = p.get('name', '')
if name in ('map', 'input'):
- self.eventId = p['wxId']
+ self.eventId = p['wxId'][0]
if self.eventId is None:
return
p = self.task.get_param(self.eventId, element='wxId', raiseError=False)
if not p or \
not p.has_key('wxId-bind'):
return
@@ -215,15 +214,18 @@
map = layer = None
driver = db = table = None
- if name in ('LayerSelect', 'ColumnSelect'):
- if p.get('element', '') == 'vector': # -> vector
+ if name in ('LayerSelect', 'LayerNameSelect',
+ 'ColumnSelect'):
+ if p.get('element', '') == 'vector': # -> vector
# get map name
map = p.get('value', '')
# get layer
for bid in p['wxId-bind']:
p = self.task.get_param(bid, element = 'wxId', raiseError = False)
if not p:
continue
if p.get('element', '') == 'layer':
layer = p.get('value', '')
if layer != '':
@@ -231,7 +233,7 @@
else:
layer = int(p.get('default', 1))
break
elif p.get('element', '') == 'layer': # -> layer
# get layer
@@ -241,7 +243,7 @@
# get map name
- pMap = self.task.get_param(p['wxId'], element = 'wxId-bind', raiseError = False)
+ pMap = self.task.get_param(p['wxId'][0], element = 'wxId-bind', raiseError = False)
if pMap:
map = pMap.get('value', '')
@@ -261,6 +263,21 @@
if name == 'LayerSelect':
self.data[win.InsertLayers] = { 'vector' : map }
+ elif name == 'LayerNameSelect':
+ # determine format
+ native = True
+ for id in pMap['wxId']:
+ winVec = self.parent.FindWindowById(id)
+ if winVec.GetName() == 'VectorFormat' and \
+ winVec.GetSelection() != 0:
+ native = False
+ break
+ if not native:
+ if map:
+ self.data[win.InsertLayers] = { 'dsn' : map.rstrip('@OGR') }
+ else:
+ self.data[win.InsertLayers] = { }
elif name == 'TableSelect':
self.data[win.InsertTables] = { 'driver' : driver,
'database' : db }
@@ -1061,7 +1078,7 @@
flag=wx.ALIGN_RIGHT | wx.ALIGN_CENTER_VERTICAL)
which_sizer.Add(item=title_sizer, proportion=0,
flag=wx.EXPAND | wx.TOP | wx.LEFT | wx.RIGHT, border=5)
- f['wxId'] = chk.GetId()
+ f['wxId'] = [ chk.GetId(), ]
chk.Bind(wx.EVT_CHECKBOX, self.OnSetValue)
if f['name'] in ('verbose', 'quiet'):
chk.Bind(wx.EVT_CHECKBOX, self.OnVerbosity)
@@ -1148,7 +1165,7 @@
isEnabled[ defval ] = 'yes'
# for multi checkboxes, this is an array of all wx IDs
# for each individual checkbox
- p[ 'wxId' ] = []
+ p[ 'wxId' ] = list()
idx = 0
for val in valuelist:
try:
@@ -1202,7 +1219,7 @@
which_sizer.Add(item=txt2, proportion=0,
flag=style, border=5)
- p['wxId'] = txt2.GetId()
+ p['wxId'] = [ txt2.GetId(), ]
txt2.Bind(wx.EVT_TEXT, self.OnSetValue)
else:
# list of values (combo)
@@ -1214,7 +1231,7 @@
cb.SetValue(p['value']) # parameter previously set
which_sizer.Add( item=cb, proportion=0,
flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border=5)
- p['wxId'] = cb.GetId()
+ p['wxId'] = [ cb.GetId(), ]
cb.Bind( wx.EVT_COMBOBOX, self.OnSetValue)
# text entry
@@ -1249,7 +1266,7 @@
which_sizer.Add(item=txt3, proportion=0,
- p['wxId'] = txt3.GetId()
+ p['wxId'] = [ txt3.GetId(), ]
# element selection tree combobox (maps, icons, regions, etc.)
@@ -1304,6 +1321,7 @@
style = wx.RA_SPECIFY_ROWS,
size = (100, -1),
choices = [_("Native"), _("OGR")])
+ rbox.SetName('VectorFormat')
rbox.Bind(wx.EVT_RADIOBOX, self.OnVectorFormat)
hsizer.Add(item=rbox,
@@ -1318,10 +1336,12 @@
dialogTitle = _('Choose OGR data source'),
buttonText = _('Browse'),
startDirectory = os.getcwd())
- ogrSelection.SetName('OgrSelect')
+ for win in ogrSelection.GetChildren():
+ win.SetName('OgrSelect')
ogrSelection.Enable(False)
+ ogrSelection.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
ogrSelection.Bind(wx.EVT_TEXT, self.OnSetValue)
hsizer.Add(item=wx.StaticText(parent = which_panel, id = wx.ID_ANY,
label = _("Name of OGR data source:")),
flag=wx.ALIGN_BOTTOM | wx.LEFT,
@@ -1336,8 +1356,7 @@
which_sizer.Add(item = hsizer, proportion = 0)
p['wxId'].append(rbox.GetId())
- p['wxId'].append(ogrSelection.GetId())
- p['wxId'].append(ogrSelection.GetChildren()[1].GetId()) # fix
+ p['wxId'].append(ogrSelection.GetChildren()[1].GetId())
else:
which_sizer.Add(item=selection, proportion=0,
flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.TOP | wx.ALIGN_CENTER_VERTICAL,
@@ -1365,23 +1384,29 @@
all = True
else:
all = False
+ win = wx.BoxSizer(wx.HORIZONTAL)
if p.get('age', 'old_layer') == 'old_layer':
- win = gselect.LayerSelect(parent=which_panel,
+ win1 = gselect.LayerSelect(parent=which_panel,
all=all,
default=p['default'])
- p['wxGetValue'] = win.GetStringSelection
- win.Bind(wx.EVT_CHOICE, self.OnUpdateSelection)
- win.Bind(wx.EVT_CHOICE, self.OnSetValue)
+ win1.Bind(wx.EVT_CHOICE, self.OnUpdateSelection)
+ win1.Bind(wx.EVT_CHOICE, self.OnSetValue)
else:
- win = wx.SpinCtrl(parent=which_panel, id=wx.ID_ANY,
+ win1 = wx.SpinCtrl(parent=which_panel, id=wx.ID_ANY,
min=1, max=100, initial=int(p['default']))
- win.Bind(wx.EVT_SPINCTRL, self.OnSetValue)
+ win1.Bind(wx.EVT_SPINCTRL, self.OnSetValue)
+ win2 = gselect.LayerNameSelect(parent = which_panel)
+ win2.Bind(wx.EVT_TEXT, self.OnSetValue)
+ p['wxId'] = [ win1.GetId(), win2.GetId() ]
+ win.Add(item = win1, proportion = 0)
+ win.Add(item = win2, proportion = 0,
+ flag = wx.LEFT | wx.ALIGN_CENTER_VERTICAL,
+ border = 5)
elif p.get('prompt', '') == 'dbdriver':
win = gselect.DriverSelect(parent=which_panel,
choices=p['values'],
value=p['default'])
win.Bind(wx.EVT_COMBOBOX, self.OnUpdateSelection)
win.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
elif p.get('prompt', '') == 'dbname':
@@ -1392,7 +1417,6 @@
elif p.get('prompt', '') == 'dbtable':
if p.get('age', 'old_dbtable') == 'old_dbtable':
win = gselect.TableSelect(parent=which_panel)
else:
@@ -1401,10 +1425,12 @@
win.Bind(wx.EVT_TEXT, self.OnSetValue)
elif p.get('prompt', '') == 'dbcolumn':
win = gselect.ColumnSelect(parent=which_panel)
- p['wxId'] = win.GetId()
+ try:
+ p['wxId'] = [ win.GetId(), ]
+ except AttributeError:
+ pass
which_sizer.Add(item=win, proportion=0,
@@ -1460,7 +1486,7 @@
# A file browse button is a combobox with two children:
# a textctl and a button;
# we have to target the button here
- p['wxId'] = fbb.GetChildren()[1].GetId()
+ p['wxId'] = [ fbb.GetChildren()[1].GetId(), ]
if title_txt is not None:
# create tooltip if given
@@ -1477,8 +1503,8 @@
title_txt.SetToolTipString(tooltip)
if p == first_param:
- if type(p['wxId']) == type(1):
- self.FindWindowById(p['wxId']).SetFocus()
+ if len(p['wxId']) > 0:
+ self.FindWindowById(p['wxId'][0]).SetFocus()
# set widget relations for OnUpdateSelection
@@ -1503,7 +1529,7 @@
if id:
if not p.has_key('wxId-bind'):
p['wxId-bind'] = list()
- p['wxId-bind'].append(pOpt['wxId'])
+ p['wxId-bind'] += pOpt['wxId']
continue
prompt = p.get('element', '')
@@ -1525,26 +1551,25 @@
# collect ids
pColumnIds = []
for p in pColumn:
- pColumnIds.append(p['wxId'])
+ pColumnIds += p['wxId']
pLayerIds = []
for p in pLayer:
- pLayerIds.append(p['wxId'])
+ pLayerIds += p['wxId']
# set wxId-bindings
if pMap:
pMap['wxId-bind'] = copy.copy(pColumnIds)
if pLayer:
pMap['wxId-bind'] += pLayerIds
if len(pLayer) == 1:
# TODO: fix modules with more 'layer' options
pLayer[0]['wxId-bind'] = copy.copy(pColumnIds)
if pDriver and pTable:
- pDriver['wxId-bind'] = [pTable['wxId'], ]
+ pDriver['wxId-bind'] = pTable['wxId']
if pDatabase and pTable:
- pDatabase['wxId-bind'] = [pTable['wxId'], ]
+ pDatabase['wxId-bind'] = pTable['wxId']
if pTable and pColumnIds:
pTable['wxId-bind'] = pColumnIds
@@ -1597,7 +1622,7 @@
if name == 'Select':
winNative = self.FindWindowById(id + 1) # fix the mystery (also in nviz_tools.py)
elif name == 'OgrSelect':
- winOgr = self.FindWindowById(id)
+ winOgr = self.FindWindowById(id + 2)
# enable / disable widgets & update values
if sel == 0: # -> native
@@ -1610,6 +1635,7 @@
p['value'] = winOgr.GetValue()
self.OnUpdateValues()
+ self.OnUpdateSelection(event)
def OnUpdateDialog(self, event):
for fn, kwargs in event.data.iteritems():
@@ -1617,8 +1643,8 @@
def OnVerbosity(self, event):
"""!Verbosity level changed"""
- verbose = self.FindWindowById(self.task.get_flag('verbose')['wxId'])
- quiet = self.FindWindowById(self.task.get_flag('quiet')['wxId'])
+ verbose = self.FindWindowById(self.task.get_flag('verbose')['wxId'][0])
+ quiet = self.FindWindowById(self.task.get_flag('quiet')['wxId'][0])
if event.IsChecked():
if event.GetId() == verbose.GetId():
if quiet.IsChecked():
@@ -1651,7 +1677,7 @@
def OnColorChange( self, event ):
myId = event.GetId()
for p in self.task.params:
- if 'wxId' in p and type( p['wxId'] ) == type( [] ) and myId in p['wxId']:
+ if 'wxId' in p and myId in p['wxId']:
has_button = p['wxId'][1] is not None
if has_button and wx.FindWindowById( p['wxId'][1] ).GetValue() == True:
p[ 'value' ] = 'none'
@@ -1683,7 +1709,7 @@
me = event.GetId()
theParam = None
- if 'wxId' in p and type( p['wxId'] ) == type( [] ) and me in p['wxId']:
+ if 'wxId' in p and me in p['wxId']:
theParam = p
myIndex = p['wxId'].index( me )
@@ -1718,26 +1744,28 @@
for selectors.
- me = wx.FindWindowById( myId )
+ me = wx.FindWindowById(myId)
+ name = me.GetName()
for porf in self.task.params + self.task.flags:
if 'wxId' in porf:
found = False
porf['wxId']
- if type(porf['wxId']) == types.IntType:
- if porf['wxId'] == myId:
+ for id in porf['wxId']:
+ if id == myId:
found = True
- else: # -> list
- for id in porf['wxId']:
- if id == myId:
- found = True
- break
+ break
if found:
- if porf.has_key('wxGetValue') and porf['wxGetValue']:
- porf['value'] = porf['wxGetValue']()
+ if name in ('LayerSelect', 'DriverSelect', 'TableSelect',
+ 'ColumnSelect'):
+ porf['value'] = me.GetStringSelection()
else:
porf['value'] = me.GetValue()
+ if name == 'OgrSelect':
+ porf['value'] += '@OGR'
event.Skip()
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2009-09-14 16:15:36 UTC (rev 39203)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2009-09-14 17:41:06 UTC (rev 39204)
@@ -159,12 +159,13 @@
os.environ["GRASS_PNG_READ"] = "FALSE"
else:
- ret = gcmd.RunCommand(self.cmd[0],
- quiet = True,
- **self.cmd[1])
+ ret, msg = gcmd.RunCommand(self.cmd[0],
+ getErrorMsg = True,
+ quiet = True,
+ **self.cmd[1])
if ret != 0:
- #clean up after probley
+ print >> sys.stderr, msg
+ # clean up after problem
try:
os.remove(self.mapfile)
os.remove(self.maskfile)
