[GRASS-SVN] r39209 - in grass/trunk: gui/wxpython
gui/wxpython/gui_modules lib/init macosx/app
svn_grass at osgeo.org
Mon Sep 14 19:31:23 EDT 2009
Author: kyngchaos
Date: 2009-09-14 19:31:22 -0400 (Mon, 14 Sep 2009)
New Revision: 39209
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/utils.py
grass/trunk/gui/wxpython/wxgui.py
grass/trunk/lib/init/functions.sh
grass/trunk/lib/init/variables.html
grass/trunk/macosx/app/Makefile
grass/trunk/macosx/app/grass.sh.in
use pythonw directly, instead of re-exec'ing
workaround problem when 32bit python needed but 64bit runs default on OSX (from dev6 r39207)
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-09-14 22:58:50 UTC (rev 39208)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-09-14 23:31:22 UTC (rev 39209)
@@ -103,8 +103,6 @@
except:
from compat import subprocess
-utils.reexec_with_pythonw()
wxUpdateDialog, EVT_DIALOG_UPDATE = NewEvent()
# From lib/gis/col_str.c, except purple which is mentioned
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py 2009-09-14 22:58:50 UTC (rev 39208)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py 2009-09-14 23:31:22 UTC (rev 39209)
@@ -437,13 +437,6 @@
return path
-def reexec_with_pythonw():
- """!Re-execute Python on Mac OS"""
- if sys.platform == 'darwin' and \
- not sys.executable.endswith('MacOS/Python'):
- print >> sys.stderr, 're-executing using pythonw'
- os.execvp('pythonw', ['pythonw', __file__] + sys.argv[1:])
def ReadEpsgCodes(path):
"""!Read EPSG code from the file
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2009-09-14 22:58:50 UTC (rev 39208)
+++ grass/trunk/gui/wxpython/wxgui.py 2009-09-14 23:31:22 UTC (rev 39209)
@@ -1604,11 +1604,6 @@
def main(argv=None):
- # reexec for MacOS
- utils.reexec_with_pythonw()
# process command-line arguments
if argv is None:
Modified: grass/trunk/lib/init/functions.sh
--- grass/trunk/lib/init/functions.sh 2009-09-14 22:58:50 UTC (rev 39208)
+++ grass/trunk/lib/init/functions.sh 2009-09-14 23:31:22 UTC (rev 39209)
@@ -163,8 +163,12 @@
# GRASS_PYTHON
if [ ! "$GRASS_PYTHON" ] ; then
- GRASS_PYTHON=python
- export GRASS_PYTHON
+ if [ "$MACOSX" ] ; then
+ GRASS_PYTHON=pythonw
+ else
+ fi
+ export GRASS_PYTHON
fi
# GRASS_GNUPLOT
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2009-09-14 22:58:50 UTC (rev 39208)
+++ grass/trunk/lib/init/variables.html 2009-09-14 23:31:22 UTC (rev 39209)
@@ -231,7 +231,8 @@
<dt>GRASS_PYTHON</dt>
<dd>[wxGUI, Python SWIG]<br>
- set to override Python executable.</dd>
+ set to override Python executable.<br>
+ On Mac OS X this should be the pythonw executable for the wxGUI to work.</dd>
<dt>GRASS_WXBUNDLED</dt>
<dd>[wxGUI]<br>
Modified: grass/trunk/macosx/app/Makefile
--- grass/trunk/macosx/app/Makefile 2009-09-14 22:58:50 UTC (rev 39208)
+++ grass/trunk/macosx/app/Makefile 2009-09-14 23:31:22 UTC (rev 39209)
@@ -25,6 +25,11 @@
endif
# get python version - use python in path, should be config'd python
PYVER = `python -V 2>&1 | cut -d \ -f 2 | cut -d . -f 1,2`
+ifneq ($(filter ppc64 x86_64,$(MACOSX_ARCHS_WXPYTHON)),)
+WX64BIT = 1
+else
+WX64BIT = 0
+endif
NIBSRC := $(wildcard English.lproj/MainMenu.nib/*)
NIBDST := $(patsubst English.lproj/%,$(APPDIR)/Resources/English.lproj/%,$(NIBSRC))
@@ -97,6 +102,7 @@
-e "s, at PROJ_BIN_PATH@,$(PROJ_BIN)," \
-e "s, at X11@,$(USE_X11),g" \
-e "s, at PYVER@,$(PYVER),g" \
+ -e "s, at WX64BIT@,$(WX64BIT),g" \
grass.sh.in > $(OBJDIR)/grass.sh
clean:
Modified: grass/trunk/macosx/app/grass.sh.in
--- grass/trunk/macosx/app/grass.sh.in 2009-09-14 22:58:50 UTC (rev 39208)
+++ grass/trunk/macosx/app/grass.sh.in 2009-09-14 23:31:22 UTC (rev 39209)
@@ -24,6 +24,9 @@
GRASS_OS_STARTUP="Mac.app"
export GRASS_OS_STARTUP
+SYSARCH=`uname -p`
+SYSVER=`uname -r | cut -d . -f 1`
GISBASE=`dirname "$0"`
export GISBASE
grass_ver=`cut -d . -f 1-2 "$GISBASE/etc/VERSIONNUMBER"`
@@ -133,22 +136,32 @@
# change GRASS_WXBUNDLED and pyver_want here from bundle.make, or manually
GRASS_WXBUNDLED=
export GRASS_WXBUNDLED
+pyexe="pythonw"
pyver_want="@PYVER@"
-if [ -d "$GISBASE/etc/wxpython" ] && [ "$GRASS_WXBUNDLED" = "1" ] ; then
+wx64bit="@WX64BIT@"
# make sure python version used matches what wxpython wants
py=""
-# did user set GRASS_PYTHON already? check it
+# did user set GRASS_PYTHON already? check it (must have pythonw)
if [ "$GRASS_PYTHON" ] ; then
- pyver=`$GRASS_PYTHON -V 2>&1 | grep " $pyver_want"`
- if [ "$pyver" ] ; then
- py="$GRASS_PYTHON"
+ py=`echo "$GRASS_PYTHON" | grep pythonw`
+ if [ "$py" ] ; then
+ case $GRASS_PYTHON in
+ /*) py="$GRASS_PYTHON" ;;
+ *) py=`type -p $GRASS_PYTHON`
+ esac
+ pyver=`$py -V 2>&1 | grep " $pyver_want"`
+ if [ ! "$pyver" ] ; then
+ py=""
+ fi
+ else
+ py=""
fi
fi # GRASS_PYTHON
# try in shell path
if [ ! "$py" ] ; then
- py=`type -p python`
+ py=`type -p pythonw$pyver_want`
if [ "$py" ] ; then
- pyver=`python -V 2>&1 | grep " $pyver_want"`
py=""
fi
@@ -163,7 +176,7 @@
fi
# try system (may be the same as in shell path)
- py="/usr/bin/python"
+ py="/usr/bin/pythonw$pyver_want"
py=""
@@ -173,11 +186,22 @@
if [ "$py" ] ; then
echo "$pyver found."
GRASS_PYTHON="$py"
+ # can't run python 64bit if wx not 64bit, assume OSX 10.6+ 64bit
+ if [ $(($SYSVER)) -gt 9 ] && [ "$wx64bit" = "0" ] ; then
+ case $SYSARCH$wx64bit in
+ powerpc0) pyarch="ppc" ;;
+ i3860) pyarch="i386" ;;
+ *) pyarch="" ;;
+ esac
+ # make copy of pythonw 32bit because g.gui can't spawn multi-arg prog
+ ditto -arch $pyarch "$py" "$GISBASE_USER/Modules/bin/pythonw"
+ GRASS_PYTHON="pythonw"
+ fi
else
echo "Warning: No Python $pyver_want found, needed by wxPython."
echo " The wxPython GUI may not work properly."
fi
-fi # bundled wx
# if grassrc has text startup, switch back to Terminal (gotta duplicate some init.sh stuff)
# only applies to Tiger - Leopard X11 opens automatically as needed
