[GRASS-SVN] r39222 - grass/trunk/lib/vector
Tue Sep 15 05:13:28 EDT 2009
Author: martinl
Date: 2009-09-15 05:13:25 -0400 (Tue, 15 Sep 2009)
New Revision: 39222
   grass/trunk/lib/vector/vectorlib.dox
vector feature type list updated (see trac #542)
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox	2009-09-15 09:05:33 UTC (rev 39221)
+++ grass/trunk/lib/vector/vectorlib.dox	2009-09-15 09:13:25 UTC (rev 39222)
@@ -117,17 +117,32 @@
 support on modules level are implemented. Z-coordinate is optional and
 both 2D and 3D files may be written.
-The following vector features are defined (see \ref vlibFeatureTypes):
+The following vector feature types (primitives) are defined by the
+vector library (and holds by the coor file; see also \ref
+vlibFeatureTypes):
-- point: a point;
-- line: a directed sequence of connected vertices with two endpoints called nodes;
-- boundary: the border line to describe an area;
-- centroid: a point within a closed boundary;
-- area: the topological composition of centroid and boundary;
-- face: a 3D area;
-- kernel: a 3D centroid in a volume;
-- volume: a 3D corpus, the topological composition of faces and kernel.
+- point: a point (2D or 3D);
+- line: a directed sequence of connected vertices with two endpoints
+  called nodes (2D or 3D);
+- boundary: the border line to describe an area (2D only);
+- centroid: a point within a closed boundary(ies) to describe an area
+  (2D only);
+- edge: a 3D boundary (not implemented yet)
+- kernel: a 3D centroid in a volume.
+From vector feature types mentioned above are derived:
+- node: endpoint of a line (2D or 3D);
+- area: the topological composition of centroid and boundary(ies) (2D
+  only);
+- isle: an area within area, not touching the boundaries of the outer
+  area (2D only);
+- face: a 3D area (not implemented yet);
+- volume: a 3D corpus, the topological composition of faces and kernel
+  (not implemented yet);
+- hole: a volume within volume, 3D equivalent to isle within area (not
+  implemented yet).
 Note that all lines and boundaries can consist of multiple segments.
 Topology also holds information about isles. Isles are located within an area, not
