[GRASS-SVN] r39229 -
grass/branches/releasebranch_6_4/vector/v.generalize
svn_grass at osgeo.org
Thu Sep 17 09:50:19 EDT 2009
Author: mmetz
Date: 2009-09-17 09:50:18 -0400 (Thu, 17 Sep 2009)
New Revision: 39229
grass/branches/releasebranch_6_4/vector/v.generalize/main.c
added warnings for corrupted areas
Modified: grass/branches/releasebranch_6_4/vector/v.generalize/main.c
--- grass/branches/releasebranch_6_4/vector/v.generalize/main.c 2009-09-17 06:45:33 UTC (rev 39228)
+++ grass/branches/releasebranch_6_4/vector/v.generalize/main.c 2009-09-17 13:50:18 UTC (rev 39229)
@@ -63,7 +63,7 @@
int look_ahead, iterations;
int chcat;
int ret, layer;
- int n_areas, n_lines;
+ int n_areas, n_orig_areas, n_lines;
double x, y;
int simplification, mask_type;
VARRAY *varray;
@@ -342,7 +342,6 @@
varray = NULL;
Vect_copy_head_data(&In, &Out);
Vect_hist_copy(&In, &Out);
Vect_hist_command(&Out);
@@ -436,6 +435,7 @@
/* remove incorrect boundaries
* they may occur only if they were generalized */
if (mask_type & GV_BOUNDARY) {
+ int n_del = 0;
Vect_build_partial(&Out, GV_BUILD_ATTACH_ISLES);
n_lines = Vect_get_num_lines(&Out);
for (i = 1; i <= n_lines; i++) {
@@ -446,8 +446,14 @@
if (left == 0 || right == 0) {
Vect_delete_line(&Out, i);
total_output -= Points->n_points;
+ n_del++;
+ if (n_del)
+ G_warning(_("%d boundaries were deleted, input areas are not preserved"), n_del);
+ /* make sure that clean topo is built at the end */
+ Vect_build_partial(&Out, GV_BUILD_NONE);
@@ -462,6 +468,8 @@
/* skip dead area */
if (!Vect_area_alive(&Out, i))
continue;
+ /* area i in Out is not necessarily equal to area i in In! */
Vect_get_area_cats(&In, i, Cats);
ret = Vect_get_point_in_area(&Out, i, &x, &y);
if (ret < 0) {
@@ -472,12 +480,16 @@
Vect_append_point(Points, x, y, 0.0);
Vect_write_line(&Out, GV_CENTROID, Points, Cats);
+ G_warning(_("New centroids were calculated, attribute attachment may be changed"));
/* remove small areas */
if (rs_flag->answer && simplification && (mask_type & GV_AREA)) {
Vect_build_partial(&Out, GV_BUILD_CENTROIDS);
Vect_remove_small_areas(&Out, thresh, NULL, &slide);
Vect_build(&Out);
@@ -491,6 +503,12 @@
total_input, total_output,
(total_output * 100) / total_input);
+ /* warning about area corruption */
+ if (mask_type & GV_BOUNDARY && (n_orig_areas = Vect_get_num_areas(&In)) > 0) {
+ G_warning(_("Areas may have disappeared and/or area attribute attachment may have changed"));
+ G_warning(_("Try v.clean tool=prune thresh=%f"), thresh);
Vect_close(&In);
Vect_close(&Out);
