[GRASS-SVN] r39255 - grass/branches/develbranch_6/lib/init
svn_grass at osgeo.org
Sat Sep 19 17:04:35 EDT 2009
Author: hamish
Date: 2009-09-19 17:04:34 -0400 (Sat, 19 Sep 2009)
New Revision: 39255
grass/branches/develbranch_6/lib/init/init.sh
grass/branches/develbranch_6/lib/init/lock.c
move lockfile detection to exit(2) to allow G_fatal_error() to occupy exit(1) alone (trac #755; merge from trunk)
Modified: grass/branches/develbranch_6/lib/init/init.sh
--- grass/branches/develbranch_6/lib/init/init.sh 2009-09-19 19:30:45 UTC (rev 39254)
+++ grass/branches/develbranch_6/lib/init/init.sh 2009-09-19 21:04:34 UTC (rev 39255)
@@ -731,7 +731,7 @@
"$ETC/lock" "$lockfile" $$
case $? in
0) ;;
- 1)
+ 2)
echo "$USER is currently running GRASS in selected mapset (file $lockfile found). Concurrent use not allowed."
cleanup_tmp
exit 1 ;;
Modified: grass/branches/develbranch_6/lib/init/lock.c
--- grass/branches/develbranch_6/lib/init/lock.c 2009-09-19 19:30:45 UTC (rev 39254)
+++ grass/branches/develbranch_6/lib/init/lock.c 2009-09-19 21:04:34 UTC (rev 39255)
@@ -15,8 +15,9 @@
* 1. if file exists, the pid is read out of the file. if this
* process is still running, the file is considered locked.
-* exit(1)
-* 2. if file does not exist, or if file exists but process is not
+* exit(2).
+* 2. something weird happened. G_fatal_error() aka exit(1)
+* 3. if file does not exist, or if file exists but process is not
* running (ie, lock was not removed), the file is locked for
* process pid by writing pid into the file.
* exit(0).
@@ -49,7 +50,7 @@
close(lock);
if (locked)
- exit(1);
+ exit(2);
if ((lock = creat(file, 0666)) < 0) {
perror(file);
