[GRASS-SVN] r39295 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Sep 26 18:10:59 EDT 2009
Author: cmbarton
Date: 2009-09-26 18:10:59 -0400 (Sat, 26 Sep 2009)
New Revision: 39295
grass/trunk/gui/wxpython/gui_modules/profile.py
Further fixes to profile bugs. Backported from develbranch_6 r39294
Modified: grass/trunk/gui/wxpython/gui_modules/profile.py
--- grass/trunk/gui/wxpython/gui_modules/profile.py 2009-09-26 22:07:47 UTC (rev 39294)
+++ grass/trunk/gui/wxpython/gui_modules/profile.py 2009-09-26 22:10:59 UTC (rev 39295)
@@ -134,6 +134,9 @@
# first (default) profile line
self.raster[idx]['pline'] = None
self.raster[idx]['prop'] = UserSettings.Get(group='profile', key='raster' + str(idx))
+ # changing color string to tuple
+ colstr = str(self.raster[idx]['prop']['pcolor'])
+ self.raster[idx]['prop']['pcolor'] = tuple(int(colval) for colval in colstr.strip('()').split(','))
# set raster map name (if given)
for idx in range(len(rasterList)):
@@ -170,8 +173,15 @@
wx.FONTWEIGHT_NORMAL)
self.properties['marker'] = UserSettings.Get(group='profile', key='marker')
+ colstr = str(self.properties['marker']['color'])
+ self.properties['marker']['color'] = tuple(int(colval) for colval in colstr.strip('()').split(','))
self.properties['grid'] = UserSettings.Get(group='profile', key='grid')
+ colstr = str(self.properties['grid']['color'])
+ self.properties['grid']['color'] = tuple(int(colval) for colval in colstr.strip('()').split(','))
self.properties['x-axis'] = {}
self.properties['x-axis']['prop'] = UserSettings.Get(group='profile', key='x-axis')
@@ -351,7 +361,6 @@
else:
self.ylabel = self.ylabel.rstrip(',')
def SetGraphStyle(self):
Set plot and text options
@@ -424,12 +433,12 @@
region = grass.region()
curr_res = min(float(region['nsres']),float(region['ewres']))
transect_rec = 0
- print "transect length=",self.transect_length
- print "current res=",curr_res
+ print "transect length = "+str(self.transect_length)
+ print "current resolution = "+str(curr_res)
if self.transect_length / curr_res > 500:
transect_res = self.transect_length / 500
else: transect_res = curr_res
- print "transect res=",transect_res
+ print "transect resolution = "+str(transect_res)
try:
ret = gcmd.RunCommand("r.profile",
@@ -492,6 +501,18 @@
# graph the distance, value pairs for the transect
self.plotlist = []
+ if len(self.seglist) > 0 :
+ self.ppoints = plot.PolyMarker(self.seglist,
+ legend=' ' + self.properties['marker']['legend'],
+ colour=wx.Color(self.properties['marker']['color'][0],
+ self.properties['marker']['color'][1],
+ self.properties['marker']['color'][2],
+ 255),
+ size=self.properties['marker']['size'],
+ fillstyle=self.ptfilldict[self.properties['marker']['fill']],
+ marker=self.properties['marker']['type'])
+ self.plotlist.append(self.ppoints)
for r in self.raster.itervalues():
if len(r['datalist']) > 0:
col = wx.Color(r['prop']['pcolor'][0],
@@ -506,18 +527,6 @@
self.plotlist.append(r['pline'])
- if len(self.seglist) > 0 :
- self.ppoints = plot.PolyMarker(self.seglist,
- legend=' ' + self.properties['marker']['legend'],
- colour=wx.Color(self.properties['marker']['color'][0],
- self.properties['marker']['color'][1],
- self.properties['marker']['color'][2],
- 255),
- size=self.properties['marker']['size'],
- fillstyle=self.ptfilldict[self.properties['marker']['fill']],
- marker=self.properties['marker']['type'])
- self.plotlist.append(self.ppoints)
self.profile = plot.PlotGraphics(self.plotlist,
self.ptitle,
self.xlabel,
@@ -705,7 +714,11 @@
dlg = OptDialog(parent=self, id=wx.ID_ANY, title=_('Profile settings'))
btnval = dlg.ShowModal()
- if btnval == wx.ID_SAVE or btnval == wx.ID_CANCEL:
+ if btnval == wx.ID_SAVE:
+ dlg.UpdateSettings()
+ self.SetGraphStyle()
+ dlg.Destroy()
+ elif btnval == wx.ID_CANCEL:
dlg.Destroy()
def PrintMenu(self, event):
