[GRASS-SVN] r39317 - grass-addons/raster/r.burn.frict
Mon Sep 28 17:14:50 EDT 2009
Author: benducke
Date: 2009-09-28 17:14:48 -0400 (Mon, 28 Sep 2009)
New Revision: 39317
   grass-addons/raster/r.burn.frict/description.html
Enhancements to HTML docs
Modified: grass-addons/raster/r.burn.frict/description.html
--- grass-addons/raster/r.burn.frict/description.html	2009-09-28 19:30:21 UTC (rev 39316)
+++ grass-addons/raster/r.burn.frict/description.html	2009-09-28 21:14:48 UTC (rev 39317)
@@ -12,7 +12,23 @@
 If those features are represented by vector lines (e.g. road networks), then it must be ensured that the conversion to raster cells will not leave "gaps" between
 diagonal cells as this would allow simulated movement to "slip" through them.
 This module performs simple gap closing in a 2x2 cell window. It replaces gaps with the average of two neighbouring cells (on one side only), which results in the same friction for crossing cells, no matter in which direction.
+<p>
+Rasterization without anti-aliasing ("1"=a cell that is crossed by a vector line):
+<div class="code"><pre>
+   0100
+   0010
+   0001
+</pre></div>
+Rasterization using r.burn.frict:
+   0100
+   0110
+   0011
+</pre></div>
 <h2>AUTHOR</h2>
 Benjamin Ducke, benjamin.ducke AT oadigital.net
 <p>
