[GRASS-SVN] r39325 - grass-addons/raster/r.stream.basins
Tue Sep 29 06:43:08 EDT 2009
Author: jarekj71
Date: 2009-09-29 06:43:08 -0400 (Tue, 29 Sep 2009)
New Revision: 39325
   grass-addons/raster/r.stream.basins/io.c
removing bug
Modified: grass-addons/raster/r.stream.basins/io.c
--- grass-addons/raster/r.stream.basins/io.c	2009-09-29 10:42:47 UTC (rev 39324)
+++ grass-addons/raster/r.stream.basins/io.c	2009-09-29 10:43:08 UTC (rev 39325)
@@ -98,17 +98,17 @@
     char *cur_mapset;
     CELL c_min, c_max;
-    struct Range *stream_range;
+    struct Range stream_range;
-    G_init_range(stream_range);
+    G_init_range(&stream_range);
     cur_mapset = G_find_cell2(in_streams, "");
-    G_read_range(in_streams, cur_mapset, stream_range);
-    G_get_range_min_max(stream_range, &c_min, &c_max);
+    G_read_range(in_streams, cur_mapset, &stream_range);
+    G_get_range_min_max(&stream_range, &c_min, &c_max);
     return c_max;
 }				/* end_max_link       */
-int write_chatchment()
+int write_chatchment(void)
     int r;
     int fdo = 0;
