[GRASS-SVN] r39337 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Sep 29 14:22:37 EDT 2009
Author: martinl
Date: 2009-09-29 14:22:37 -0400 (Tue, 29 Sep 2009)
New Revision: 39337
grass/trunk/gui/wxpython/gui_modules/utils.py
wxGUI: support multi-line map names (useful for rgb, his)
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py 2009-09-29 18:07:39 UTC (rev 39336)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py 2009-09-29 18:22:37 UTC (rev 39337)
@@ -71,7 +71,7 @@
layerType=None):
"""!Get map name from GRASS command
- @param dcmd GRASS command (given as tuple)
+ @param dcmd GRASS command (given as list)
@param fullyQualified change map name to be fully qualified
@param force parameter otherwise 'input'/'map'
@param update change map name in command
@@ -82,7 +82,7 @@
mapname = ''
- if not dcmd:
+ if len(dcmd) < 1:
return mapname
if 'd.grid' == dcmd[0]:
@@ -94,41 +94,54 @@
elif 'labels=' in dcmd[0]:
mapname = dcmd[idx].split('=')[1]+' labels'
else:
+ params = list()
for idx in range(len(dcmd)):
- if param and param in dcmd[idx]:
+ try:
+ p, v = dcmd[idx].split('=')
+ except ValueError:
+ continue
+ if p == param:
+ params.append((idx, p, v))
break
- elif not param:
- if 'map=' in dcmd[idx] or \
- 'input=' in dcmd[idx] or \
- 'red=' in dcmd[idx] or \
- 'h_map=' in dcmd[idx] or \
- 'reliefmap' in dcmd[idx]:
- break
- if idx < len(dcmd):
- try:
- mapname = dcmd[idx].split('=')[1]
- except IndexError:
- return ''
+ if p in ('map', 'input',
+ 'red', 'blue', 'green',
+ 'h_map', 's_map', 'i_map',
+ 'reliefmap'):
- if fullyQualified and '@' not in mapname:
- if layerType in ('raster', 'vector', '3d-raster'):
- try:
- if layerType == 'raster':
- findType = 'cell'
- else:
- findType = layerType
- result = grass.find_file(mapname, element=findType)
- except AttributeError, e: # not found
- return ''
- if result:
- mapname = result['fullname']
+ if len(params) < 1:
+ return mapname
+ mapname = params[0][2]
+ mapset = ''
+ if fullyQualified and '@' not in mapname:
+ if layerType in ('raster', 'vector', '3d-raster'):
+ try:
+ if layerType == 'raster':
+ findType = 'cell'
else:
- mapname += '@' + grass.gisenv()['MAPSET']
+ findType = layerType
+ result = grass.find_file(mapname, element=findType)
+ except AttributeError, e: # not found
+ return ''
+ if result:
+ mapset = result['mapset']
else:
- dcmd[idx] = dcmd[idx].split('=')[0] + '=' + mapname
+ mapset = grass.gisenv()['MAPSET']
+ else:
+ # update dcmd
+ for i, p, v in params:
+ dcmd[i] = p + '=' + v + '@' + mapset
+ maps = list()
+ maps.append(dcmd[i].split('=')[1])
+ mapname = '\n'.join(maps)
return mapname
def GetValidLayerName(name):
