[GRASS-SVN] r39345 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Sep 29 17:33:19 EDT 2009
Author: cmbarton
Date: 2009-09-29 17:33:19 -0400 (Tue, 29 Sep 2009)
New Revision: 39345
grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py
Fixes broken map calculator. This should not be ported to releasebranch (6.4) because the map calculator works in that branch.
It should not be backported to trunk either because r.mapcalc functionality has changed in that branch.
However, some improvements to functionality can be implemented in trunk without backporting.
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py 2009-09-29 21:17:48 UTC (rev 39344)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py 2009-09-29 21:33:19 UTC (rev 39345)
@@ -25,6 +25,8 @@
import gcmd
import gselect
+from grass.script import core as grass
import subprocess
imagePath = os.path.join( os.getenv("GISBASE"), "etc", "wxpython")
@@ -120,6 +122,7 @@
self.btn_run = wx.Button(self, -1, "Run")
self.btn_run.SetDefault()
self.btn_close = wx.Button(self, -1, "Close")
+ self.btn_mapinsert = wx.Button(self, -1, "Insert")
self.btn_pow = wx.Button(self, -1, "^")
self.btn_pow.SetToolTipString('exponent')
@@ -134,7 +137,8 @@
self.btn_mult = wx.Button(self, -1, "*")
self.btn_mult.SetToolTipString('multiply')
- self.btn_paren = wx.Button(self, -1, "( )")
+ self.btn_lparen = wx.Button(self, -1, "(")
+ self.btn_rparen = wx.Button(self, -1, ")")
self.btn_lshift = wx.Button(self, -1, "<<")
self.btn_lshift.SetToolTipString('left shift')
@@ -220,7 +224,8 @@
self.btn_or.Bind(wx.EVT_BUTTON, self.AddMark)
self.btn_ornull.Bind(wx.EVT_BUTTON, self.AddMark)
self.btn_cond.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_paren.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_lparen.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_rparen.Bind(wx.EVT_BUTTON, self.AddMark)
self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
self.btn_clear.Bind(wx.EVT_BUTTON, self.OnClear)
@@ -229,12 +234,11 @@
self.newmaptxt.Bind(wx.EVT_TEXT, self.OnNewmap)
- #self.mapselect.Bind(wx.EVT_COMBOBOX, self.OnSelect)
- self.mapselect.Bind(wx.EVT_TEXT, self.OnSelect)
- #self.mapselect.Bind(wx.EVT_TEXT_ENTER, self.OnSelect)
+ self.btn_mapinsert.Bind(wx.EVT_BUTTON, self.OnMapInsert)
self.function.Bind(wx.EVT_COMBOBOX, self.OnSelect)
- #self.function.Bind(wx.EVT_TEXT, self.OnSelect)
self.function.Bind(wx.EVT_TEXT_ENTER, self.OnSelect)
+ self.text_mcalc.Bind(wx.EVT_TEXT, self.OnExprEdit)
self.__doLayout()
@@ -272,15 +276,17 @@
buttonsizer2.Add(self.btn_compl, (5,1))
buttonsizer2.Add(self.btn_not, (4,1))
- buttonsizer3 = wx.GridBagSizer(7, 1)
- buttonsizer3.Add(self.newmaplabel, (0,0), (1,2), wx.ALIGN_CENTER)
- buttonsizer3.Add(self.newmaptxt, (1,0), (1,2), wx.TOP, 4)
- buttonsizer3.Add(self.mapsellabel, (2,0), (1,2), wx.ALIGN_CENTER)
- buttonsizer3.Add(self.mapselect, (3,0), (1,2))
- buttonsizer3.Add(self.functlabel, (4,0), (1,2), wx.ALIGN_CENTER)
- buttonsizer3.Add(self.function, (5,0), (1,2))
- buttonsizer3.Add(self.btn_paren, (6,0), (1,1), wx.ALIGN_CENTER)
- buttonsizer3.Add(self.btn_clear, (6,1), (1,1), wx.ALIGN_CENTER)
+ buttonsizer3 = wx.GridBagSizer(8, 1)
+ buttonsizer3.Add(self.newmaplabel, (0,0), (1,3), wx.ALIGN_CENTER)
+ buttonsizer3.Add(self.newmaptxt, (1,0), (1,3), wx.RIGHT, 15)
+ buttonsizer3.Add(self.mapsellabel, (2,0), (1,3), wx.ALIGN_CENTER)
+ buttonsizer3.Add(self.mapselect, (3,0), (1,3))
+ buttonsizer3.Add(self.btn_mapinsert, (4,2), (1,1), wx.ALIGN_TOP)
+ buttonsizer3.Add(self.functlabel, (5,0), (1,3), wx.ALIGN_CENTER)
+ buttonsizer3.Add(self.function, (6,0), (1,3))
+ buttonsizer3.Add(self.btn_lparen, (7,0), (1,1), wx.ALIGN_LEFT)
+ buttonsizer3.Add(self.btn_rparen, (7,1), (1,1), wx.ALIGN_RIGHT)
+ buttonsizer3.Add(self.btn_clear, (7,2), (1,1), wx.ALIGN_CENTER)
buttonsizer4 = wx.GridSizer(4, 3, 3, 3)
buttonsizer4.Add(self.btn_run,0,wx.RIGHT,5)
@@ -335,11 +341,17 @@
elif event.GetId() == self.btn_and.GetId(): mark = "&&"
elif event.GetId() == self.btn_andnull.GetId(): mark = "&&&"
elif event.GetId() == self.btn_cond.GetId(): mark = "?:"
- elif event.GetId() == self.btn_paren.GetId(): mark = "()"
+ elif event.GetId() == self.btn_lparen.GetId(): mark = "("
+ elif event.GetId() == self.btn_rparen.GetId(): mark = ")"
self.__addSomething(mark)
def OnNewmap(self, event):
self.newmap = event.GetString()
+ def OnMapInsert(self, event):
+ map = self.mapselect.GetValue()
+ self.__addSomething(map)
+ self.text_mcalc.SetFocus()
def OnSelect(self, event):
@@ -348,27 +360,30 @@
item = event.GetString()
self.__addSomething(item)
+ def OnExprEdit(self,event):
+ self.text_mcalc.Update()
def __addSomething(self,what):
Inserts operators, map names, and functions into text area
mcalcstr = self.text_mcalc.GetValue()
newmcalcstr = ''
- position = self.text_mcalc.GetInsertionPoint()
+ position = self.text_mcalc.GetInsertionPoint()
selection = self.text_mcalc.GetSelection()
newmcalcstr = mcalcstr[:position]
try:
if newmcalcstr[-1] != " ":
newmcalcstr += " "
except:
pass
newmcalcstr += what
- position_offset = len(what)
+ position_offset = len(what) + 2
newmcalcstr += " "+mcalcstr[position:]
self.text_mcalc.SetValue(newmcalcstr)
@@ -389,12 +404,19 @@
mctxt = self.text_mcalc.GetValue().strip().replace("\n"," ")
mctxt = mctxt.replace(" ","")
if self.dimension == 3:
- gcmd.RunCommand('r3.mapcalc',
- expression = "%s=%s" % (self.newmap,mctxt))
+ cmdlist = ['r3.mapcalc', "%s=%s" % (self.newmap,mctxt)]
else:
- gcmd.RunCommand('r.mapcalc',
+ cmdlist = ['r.mapcalc', "%s=%s" % (self.newmap,mctxt)]
+ p = subprocess.Popen(cmdlist, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
+ mcerr = p.stderr.read()
+ if mcerr == '':
+ wx.MessageBox('Map %s created successfully' % self.newmap)
+ else:
+ wx.MessageBox(mcerr)
def OnClear(self, event):
