[GRASS-SVN] r39350 - in grass/branches/develbranch_6:
gui/tcltk/gis.m lib/init
svn_grass at osgeo.org
Wed Sep 30 06:57:06 EDT 2009
Author: marisn
Date: 2009-09-30 06:57:05 -0400 (Wed, 30 Sep 2009)
New Revision: 39350
grass/branches/develbranch_6/gui/tcltk/gis.m/gm.tcl
grass/branches/develbranch_6/gui/tcltk/gis.m/gmmenu.tcl
grass/branches/develbranch_6/lib/init/grass.src
grass/branches/develbranch_6/lib/init/init.sh
Close gis.m on exit; Provide exit from GRASS in gis.m
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/gm.tcl
--- grass/branches/develbranch_6/gui/tcltk/gis.m/gm.tcl 2009-09-30 07:21:37 UTC (rev 39349)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/gm.tcl 2009-09-30 10:57:05 UTC (rev 39350)
@@ -513,6 +513,39 @@
+# Provides remote exit call. Used by GRASS exit to close all session's gis.m instances.
+# Argument session_id is exit caller's GIS_LOCK variable.
+proc Gm::remoteExit { session_id } {
+ global env
+ if {$env(GIS_LOCK) == $session_id} Gm::quit
+# Provides exit from gis.m. May also do some clean-up, save-settings et.al.
+proc Gm::quit { {full_exit false} } {
+ global env
+ if { $full_exit } {
+ if { [catch {set spid $env(GRASS_SHELL_PID)}] == 0 } {
+ set leave [tk_dialog .leave [G_msg "End current GRASS session"] \
+ [G_msg "Do You really want to terminate current\
+GRASS session?\n\nThis action will colse all sessions gis.m instances.\n\nIf You have running some \
+GRASS module from comandline, GRASS will terminate after it\
+finishes to run."] warning 1 [G_msg "Terminate current GRASS sesion"] [G_msg "Cancel"]]
+ if { $leave == 0 } {
+ exec kill -SIGINT $env(GRASS_SHELL_PID)
+ } else {
+ return
+ } else {
+ tk_messageBox -type ok -title [G_msg "Not supported"] -message \
+ [G_msg "We sorry. Your shell does not support this feature. \n\
+You have to type 'exit' in terminal manualy."]
+ exit
proc main {argc argv} {
@@ -538,7 +571,7 @@
Gm::SaveFileBox
bind . <$keycontrol-Key-q> {
- exit
+ Gm::quit
bind . <$keycontrol-Key-w> {
GmTree::FileClose {}
@@ -562,6 +595,9 @@
+wm protocol . WM_DELETE_WINDOW {
+ Gm::quit
main $argc $argv
wm geom . [wm geom .]
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/gmmenu.tcl
--- grass/branches/develbranch_6/gui/tcltk/gis.m/gmmenu.tcl 2009-09-30 07:21:37 UTC (rev 39349)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/gmmenu.tcl 2009-09-30 10:57:05 UTC (rev 39350)
@@ -201,7 +201,8 @@
{command {[G_msg "PostScript plot"]} {} "ps.map: Create cartographic PostScript plot" {} -command { execute ps.map }}
{separator}
- {command {[G_msg "E&xit"]} {} "Exit GIS Manager" {} -accelerator $keyctrl-Q -command { exit } }
+ {command {[G_msg "Exit &GRASS"]} {} "End current GRASS session" {} -command { Gm::quit true } }
+ {command {[G_msg "&Quit GIS Manager"]} {} "Exit GIS Manager" {} -accelerator $keyctrl-Q -command { Gm::quit } }
{[G_msg "&Config"]} all options $tmenu {
{cascad {[G_msg "Region"]} {} "" $tmenu {
Modified: grass/branches/develbranch_6/lib/init/grass.src
--- grass/branches/develbranch_6/lib/init/grass.src 2009-09-30 07:21:37 UTC (rev 39349)
+++ grass/branches/develbranch_6/lib/init/grass.src 2009-09-30 10:57:05 UTC (rev 39350)
@@ -40,7 +40,9 @@
( exec xterm -e $0 "$@" ) &>/dev/null
else
# Returning user may have preffered GRASS terminal application
- GRASS_XTERM=`awk '/GRASS_XTERM/ {print $2}' "$GISRCRC" 2>/dev/null`
+ if [ -z "$GRASS_XTERM" ]; then
+ GRASS_XTERM=`awk '/GRASS_XTERM/ {print $2}' "$GISRCRC" 2>/dev/null`
+ fi;
if [ -n "$GRASS_XTERM" ]; then
# User has preffered GRASS terminal app
( exec $GRASS_XTERM -e $0 "$@" ) &>/dev/null
Modified: grass/branches/develbranch_6/lib/init/init.sh
--- grass/branches/develbranch_6/lib/init/init.sh 2009-09-30 07:21:37 UTC (rev 39349)
+++ grass/branches/develbranch_6/lib/init/init.sh 2009-09-30 10:57:05 UTC (rev 39350)
@@ -817,7 +817,10 @@
# Check for tcltk interface
tcltk | gis.m)
- "$GISBASE/scripts/gis.m"
+ if [ $sh -ne bash ] || [ $sh -ne msh ] || [ $sh -ne cygwin ]; then
+ # trap is not supported by csh/tcsh and rc
+ "$GISBASE/scripts/gis.m"
+ fi;
oldtcltk | d.m)
"$GISBASE/scripts/d.m"
@@ -966,6 +969,11 @@
echo "export PATH=\"$PATH\"" >> "$bashrc"
echo "export HOME=\"$USERHOME\"" >> "$bashrc" # restore user home path
+ echo 'export GRASS_SHELL_PID=$$' >> "$bashrc" # can be used to terminate GRASS session from GUI
+ if [ "$GRASS_GUI" == tcltk ] || [ "$GRASS_GUI" == gis.m ]; then
+ echo '$GISBASE/scripts/gis.m' >> "$bashrc" # Start gis.m
+ fi;
+ echo 'trap "echo \"GUI issued an exit\"; exit" SIGINT' >> "$bashrc"
"$ETC/run" "$SHELL"
EXIT_VAL=$?
@@ -1012,6 +1020,16 @@
d.mon stop="$MON"
done
+# Attempt to close any open gis.m instances.
+# Will work only on some systems, still has no harm to others
+if [ $TCLTKGRASSBASE ] ; then
+ echo "Closing open gis.m sessions....."
+ echo 'foreach gwin [lsearch -all -inline [winfo interps] gm_tcl*] {
+ catch {send -async $gwin Gm::remoteExit $env(GIS_LOCK)}
+ exit' | $GRASS_WISH >/dev/null 2>&1
+fi
echo "Cleaning up temporary files ..."
"$ETC/clean_temp" > /dev/null
