[GRASS-SVN] r39364 - in grass/trunk: include include/vect
lib/vector/Vlib vector/v.in.ascii vector/v.out.ascii
svn_grass at osgeo.org
Wed Sep 30 16:32:12 EDT 2009
Author: martinl
Date: 2009-09-30 16:32:12 -0400 (Wed, 30 Sep 2009)
New Revision: 39364
Added:
grass/trunk/lib/vector/Vlib/ascii.c
Removed:
grass/trunk/vector/v.in.ascii/a2b.c
grass/trunk/vector/v.in.ascii/head.c
grass/trunk/vector/v.out.ascii/b2a.c
grass/trunk/vector/v.out.ascii/head.c
grass/trunk/vector/v.out.ascii/local_proto.h
grass/trunk/include/vect/dig_defines.h
grass/trunk/include/vector.h
grass/trunk/lib/vector/Vlib/merge_lines.c
grass/trunk/vector/v.in.ascii/local_proto.h
grass/trunk/vector/v.in.ascii/main.c
grass/trunk/vector/v.out.ascii/main.c
move read/write GRASS ASCII vector format functionality to Vlib
Modified: grass/trunk/include/vect/dig_defines.h
--- grass/trunk/include/vect/dig_defines.h 2009-09-30 19:27:00 UTC (rev 39363)
+++ grass/trunk/include/vect/dig_defines.h 2009-09-30 20:32:12 UTC (rev 39364)
@@ -223,4 +223,8 @@
/*! \brief Maximum category value */
#define GV_CAT_MAX PORT_INT_MAX
+/*! \brief GRASS ASCII vector format */
+#define GV_ASCII_FORMAT_POINT 0
+#define GV_ASCII_FORMAT_ALL 1
#define HEADSTR 50
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h 2009-09-30 19:27:00 UTC (rev 39363)
+++ grass/trunk/include/vector.h 2009-09-30 20:32:12 UTC (rev 39364)
@@ -407,6 +407,14 @@
void Vect_spatial_index_del_item(struct spatial_index *, int, const struct bound_box *);
int Vect_spatial_index_select(const struct spatial_index *, const struct bound_box *, struct ilist *);
+/* GRASS ASCII vector format */
+int Vect_read_ascii(FILE *, struct Map_info *);
+int Vect_read_ascii_head(FILE *, struct Map_info *);
+int Vect_write_ascii(FILE *, FILE *, struct Map_info *, int,
+ int, int, char *, int,
+ int, char*, char **);
+void Vect_write_ascii_head(FILE *, struct Map_info *);
* Internal functions, MUST NOT be used in modules
Added: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c (rev 0)
+++ grass/trunk/lib/vector/Vlib/ascii.c 2009-09-30 20:32:12 UTC (rev 39364)
@@ -0,0 +1,594 @@
+ \file vector/Vlib/ascii.c
+ \brief Vector library - GRASS ASCII vector format
+ Higher level functions for reading/writing/manipulating vectors.
+ (C) 2001-2009 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Original author CERL
+#include <stdio.h>
+#include <grass/vector.h>
+#include <grass/dbmi.h>
+#include <grass/glocale.h>
+#define BUFFSIZE 128
+static int srch(const void *, const void *);
+ \brief Read data in GRASS ASCII vector format
+ \param ascii pointer to the ASCII file
+ \param Map pointer to Map_info structure
+ \return 0
+int Vect_read_ascii(FILE *ascii, struct Map_info *Map)
+ char ctype;
+ char buff[BUFFSIZE];
+ double *xarray;
+ double *yarray;
+ double *zarray;
+ double *x, *y, *z;
+ int i, n_points, n_coors, n_cats;
+ int type;
+ int alloc_points;
+ int end_of_file;
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ int catn;
+ int cat;
+ /* Must always use this to create an initialized line_pnts structure */
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ end_of_file = 0;
+ /*alloc_points = 1000 ; */
+ alloc_points = 1;
+ xarray = (double *)G_calloc(alloc_points, sizeof(double));
+ yarray = (double *)G_calloc(alloc_points, sizeof(double));
+ zarray = (double *)G_calloc(alloc_points, sizeof(double));
+ while (G_getl2(buff, BUFFSIZE - 1, ascii) != 0) {
+ n_cats = 0;
+ if (buff[0] == '\0') {
+ G_debug(3, "a2b: skipping blank line");
+ continue;
+ if (sscanf(buff, "%1c%d%d", &ctype, &n_coors, &n_cats) < 2 ||
+ n_coors < 0 || n_cats < 0) {
+ if (ctype == '#') {
+ G_debug(2, "a2b: skipping commented line");
+ continue;
+ G_fatal_error(_("Error reading ASCII file: (bad type) [%s]"),
+ buff);
+ G_debug(2, "a2b: Skipping commented line");
+ continue;
+ switch (ctype) {
+ case 'A':
+ type = GV_BOUNDARY;
+ break;
+ case 'B':
+ break;
+ case 'C':
+ type = GV_CENTROID;
+ break;
+ case 'L':
+ type = GV_LINE;
+ break;
+ case 'P':
+ type = GV_POINT;
+ break;
+ case 'F':
+ type = GV_FACE;
+ break;
+ case 'K':
+ type = GV_KERNEL;
+ break;
+ case 'a':
+ case 'b':
+ case 'c':
+ case 'l':
+ case 'p':
+ type = 0; /* dead -> ignore */
+ break;
+ default:
+ G_fatal_error(_("Error reading ASCII file: (unknown type) [%s]"),
+ buff);
+ G_debug(5, "feature type = %d", type);
+ n_points = 0;
+ x = xarray;
+ y = yarray;
+ z = zarray;
+ /* Collect the points */
+ for (i = 0; i < n_coors; i++) {
+ if (G_getl2(buff, BUFFSIZE - 1, ascii) == 0)
+ G_fatal_error(_("End of ASCII file reached before end of coordinates"));
+ G_debug(3, "a2b: skipping blank line while reading vertices");
+ i--;
+ continue;
+ *z = 0;
+ if (sscanf(buff, "%lf%lf%lf", x, y, z) < 2)
+ G_fatal_error(_("Error reading ASCII file: (bad point) [%s]"),
+ buff);
+ G_debug(5, "coor in: %s -> x = %f y = %f z = %f", G_chop(buff),
+ *x, *y, *z);
+ n_points++;
+ x++;
+ y++;
+ z++;
+ if (n_points >= alloc_points) {
+ alloc_points = n_points + 1000;
+ xarray =
+ (double *)G_realloc((void *)xarray,
+ alloc_points * sizeof(double));
+ yarray =
+ (double *)G_realloc((void *)yarray,
+ zarray =
+ (double *)G_realloc((void *)zarray,
+ x = xarray + n_points;
+ y = yarray + n_points;
+ z = zarray + n_points;
+ /* Collect the cats */
+ for (i = 0; i < n_cats; i++) {
+ G_fatal_error(_("End of ASCII file reached before end of categories"));
+ G_debug(3,
+ "a2b: skipping blank line while reading category info");
+ i--;
+ continue;
+ if (sscanf(buff, "%u%u", &catn, &cat) != 2)
+ G_fatal_error(_("Error reading categories: [%s]"), buff);
+ Vect_cat_set(Cats, catn, cat);
+ /* Allocation is handled for line_pnts */
+ if (0 >
+ Vect_copy_xyz_to_pnts(Points, xarray, yarray, zarray, n_points))
+ G_fatal_error(_("Out of memory"));
+ if (type > 0)
+ Vect_write_line(Map, type, Points, Cats);
+ Vect_reset_cats(Cats);
+ return 0;
+ \brief Read header of GRASS ASCII vector format
+ \param dascii pointer to the ASCII file
+ \return 0 on success
+ \return -1 on error
+int Vect_read_ascii_head(FILE *dascii, struct Map_info *Map)
+ char buff[1024];
+ char *ptr;
+ for (;;) {
+ if (0 == G_getl2(buff, sizeof(buff) - 1, dascii))
+ return (0);
+ /* Last line of header */
+ if (strncmp(buff, "VERTI:", 6) == 0)
+ return (0);
+ if (!(ptr = G_index(buff, ':')))
+ G_fatal_error(_("Unexpected data in vector head:\n[%s]"), buff);
+ ptr++; /* Search for the start of text */
+ while (*ptr == ' ')
+ ptr++;
+ if (strncmp(buff, "ORGANIZATION:", 12) == 0)
+ Vect_set_organization(Map, ptr);
+ else if (strncmp(buff, "DIGIT DATE:", 11) == 0)
+ Vect_set_date(Map, ptr);
+ else if (strncmp(buff, "DIGIT NAME:", 11) == 0)
+ Vect_set_person(Map, ptr);
+ else if (strncmp(buff, "MAP NAME:", 9) == 0)
+ Vect_set_map_name(Map, ptr);
+ else if (strncmp(buff, "MAP DATE:", 9) == 0)
+ Vect_set_map_date(Map, ptr);
+ else if (strncmp(buff, "MAP SCALE:", 10) == 0)
+ Vect_set_scale(Map, atoi(ptr));
+ else if (strncmp(buff, "OTHER INFO:", 11) == 0)
+ Vect_set_comment(Map, ptr);
+ else if (strncmp(buff, "ZONE:", 5) == 0 ||
+ strncmp(buff, "UTM ZONE:", 9) == 0)
+ Vect_set_zone(Map, atoi(ptr));
+ else if (strncmp(buff, "WEST EDGE:", 10) == 0) {
+ else if (strncmp(buff, "EAST EDGE:", 10) == 0) {
+ else if (strncmp(buff, "SOUTH EDGE:", 11) == 0) {
+ else if (strncmp(buff, "NORTH EDGE:", 11) == 0) {
+ else if (strncmp(buff, "MAP THRESH:", 11) == 0)
+ Vect_set_thresh(Map, atof(ptr));
+ else {
+ G_warning(_("Unknown keyword <%s> in vector head"), buff);
+ /* NOTREACHED */
+ \brief Write data to GRASS ASCII vector format
+ \return 0 on sucess
+int Vect_write_ascii(FILE *ascii,
+ FILE *att, struct Map_info *Map, int ver,
+ int format, int dp, char *fs, int region_flag,
+ int field, char* where, char **columns)
+ int type, ctype, i, cat, proj;
+ double *xptr, *yptr, *zptr, x, y;
+ static struct line_pnts *Points;
+ char *xstring = NULL, *ystring = NULL, *zstring = NULL;
+ struct Cell_head window;
+ struct ilist *fcats;
+ /* where */
+ struct field_info *Fi;
+ dbDriver *driver;
+ dbValue value = {0};
+ dbHandle handle;
+ int *cats, ncats;
+ /* get the region */
+ G_get_window(&window);
+ ncats = 0;
+ cats = NULL;
+ if (where || columns) {
+ Fi = Vect_get_field(Map, field);
+ if (!Fi) {
+ G_fatal_error(_("Database connection not defined for layer %d"),
+ field);
+ driver = db_start_driver(Fi->driver);
+ if (!driver)
+ G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
+ db_init_handle(&handle);
+ db_set_handle(&handle, Fi->database, NULL);
+ if (db_open_database(driver, &handle) != DB_OK)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ Fi->database, Fi->driver);
+ /* select cats (sorted array) */
+ ncats = db_select_int(driver, Fi->table, Fi->key, where, &cats);
+ G_debug(3, "%d categories selected from table <%s>", ncats, Fi->table);
+ if (!columns) {
+ db_close_database(driver);
+ db_shutdown_driver(driver);
+ Points = Vect_new_line_struct(); /* init line_pnts struct */
+ fcats = Vect_new_list();
+ proj = Vect_get_proj(Map);
+ /* by default, read_next_line will NOT read Dead lines */
+ /* but we can override that (in Level I only) by specifying */
+ /* the type -1, which means match all line types */
+ Vect_rewind(Map);
+ while (1) {
+ if (-1 == (type = Vect_read_next_line(Map, Points, Cats))) {
+ if (columns) {
+ return -1;
+ if (type == -2) { /* EOF */
+ if (columns) {
+ return 0;
+ if (format == GV_ASCII_FORMAT_POINT && !(type & GV_POINTS))
+ continue;
+ if (cats) {
+ /* check category */
+ for (i = 0; i < Cats->n_cats; i++) {
+ if ((int *)bsearch((void *) &(Cats->cat[i]), cats, ncats, sizeof(int),
+ srch)) {
+ /* found */
+ break;
+ if (i == Cats->n_cats)
+ continue;
+ if (ver < 5) {
+ Vect_cat_get(Cats, 1, &cat);
+ switch (type) {
+ case GV_BOUNDARY:
+ if (ver == 5)
+ ctype = 'B';
+ else
+ ctype = 'A';
+ break;
+ case GV_CENTROID:
+ if (ver < 5) {
+ if (att != NULL) {
+ if (cat > 0) {
+ G_asprintf(&xstring, "%.*f", dp, Points->x[0]);
+ G_trim_decimal(xstring);
+ G_asprintf(&ystring, "%.*f", dp, Points->y[0]);
+ G_trim_decimal(ystring);
+ fprintf(att, "A %s %s %d\n", xstring, ystring, cat);
+ continue;
+ ctype = 'C';
+ break;
+ case GV_LINE:
+ ctype = 'L';
+ break;
+ case GV_POINT:
+ ctype = 'P';
+ break;
+ case GV_FACE:
+ ctype = 'F';
+ break;
+ case GV_KERNEL:
+ ctype = 'K';
+ break;
+ default:
+ ctype = 'X';
+ G_warning(_("got type %d"), (int)type);
+ break;
+ if (format == GV_ASCII_FORMAT_POINT) {
+ /*fprintf(ascii, "%c", ctype); */
+ if (region_flag) {
+ if ((window.east < Points->x[0]) ||
+ (window.west > Points->x[0]))
+ continue;
+ if ((window.north < Points->y[0]) ||
+ (window.south > Points->y[0]))
+ continue;
+ if (Map->head.with_z && ver == 5) {
+ if ((window.top < Points->z[0]) ||
+ (window.bottom > Points->z[0]))
+ continue;
+ G_asprintf(&zstring, "%.*f", dp, Points->z[0]);
+ G_trim_decimal(zstring);
+ fprintf(ascii, "%s%s%s%s%s", xstring, fs, ystring, fs,
+ zstring);
+ else {
+ fprintf(ascii, "%s%s%s", xstring, fs, ystring);
+ Vect_field_cat_get(Cats, field, fcats);
+ if (fcats->n_values > 0) {
+ if (fcats->n_values > 1) {
+ G_warning(_("Feature has more categories. Only first category (%d) "
+ "is exported."), fcats->value[0]);
+ fprintf(ascii, "%s%d", fs, fcats->value[0]);
+ /* print attributes */
+ if (columns) {
+ for(i = 0; columns[i]; i++) {
+ if (db_select_value(driver, Fi->table, Fi->key, fcats->value[0],
+ columns[i], &value) < 0)
+ G_fatal_error(_("Unable to select record from table <%s> (key %s, column %s)"),
+ Fi->table, Fi->key, columns[i]);
+ if (db_test_value_isnull(&value)) {
+ fprintf(ascii, "%s", fs);
+ else {
+ switch(db_column_Ctype(driver, Fi->table, columns[i]))
+ case DB_C_TYPE_INT: {
+ fprintf(ascii, "%s%d", fs, db_get_value_int(&value));
+ break;
+ case DB_C_TYPE_DOUBLE: {
+ fprintf(ascii, "%s%.*f", fs, dp, db_get_value_double(&value));
+ break;
+ case DB_C_TYPE_STRING: {
+ fprintf(ascii, "%s%s", fs, db_get_value_string(&value));
+ break;
+ case DB_C_TYPE_DATETIME: {
+ break;
+ case -1:
+ G_fatal_error(_("Column <%s> not found in table <%s>"),
+ columns[i], Fi->table);
+ default: G_fatal_error(_("Column <%s>: unsupported data type"),
+ columns[i]);
+ fprintf(ascii, "\n");
+ else {
+ /* FORMAT_STANDARD */
+ if (ver == 5 && Cats->n_cats > 0)
+ fprintf(ascii, "%c %d %d\n", ctype, Points->n_points,
+ Cats->n_cats);
+ else
+ fprintf(ascii, "%c %d\n", ctype, Points->n_points);
+ xptr = Points->x;
+ yptr = Points->y;
+ zptr = Points->z;
+ while (Points->n_points--) {
+ G_asprintf(&xstring, "%.*f", dp, *xptr++);
+ G_asprintf(&ystring, "%.*f", dp, *yptr++);
+ if (ver == 5) {
+ if (Map->head.with_z) {
+ G_asprintf(&zstring, "%.*f", dp, *zptr++);
+ fprintf(ascii, " %-12s %-12s %-12s\n", xstring,
+ ystring, zstring);
+ else {
+ fprintf(ascii, " %-12s %-12s\n", xstring, ystring);
+ } /*Version 4 */
+ else {
+ fprintf(ascii, " %-12s %-12s\n", ystring, xstring);
+ if (ver == 5) {
+ fprintf(ascii, " %-5d %-10d\n", Cats->field[i],
+ Cats->cat[i]);
+ else {
+ if (cat > 0) {
+ if (type == GV_POINT) {
+ fprintf(att, "P %s %s %d\n", xstring, ystring, cat);
+ else {
+ x = (Points->x[1] + Points->x[0]) / 2;
+ y = (Points->y[1] + Points->y[0]) / 2;
+ G_asprintf(&xstring, "%.*f", dp, x);
+ G_asprintf(&ystring, "%.*f", dp, y);
+ fprintf(att, "L %s %s %d\n", xstring, ystring, cat);
+ /* not reached */
+int srch(const void *pa, const void *pb)
+ int *p1 = (int *)pa;
+ int *p2 = (int *)pb;
+ if (*p1 < *p2)
+ return -1;
+ if (*p1 > *p2)
+ return 1;
+ return 0;
+void Vect_write_ascii_head(FILE *dascii, struct Map_info *Map)
+ fprintf(dascii, "ORGANIZATION: %s\n", Vect_get_organization(Map));
+ fprintf(dascii, "DIGIT DATE: %s\n", Vect_get_date(Map));
+ fprintf(dascii, "DIGIT NAME: %s\n", Vect_get_person(Map));
+ fprintf(dascii, "MAP NAME: %s\n", Vect_get_map_name(Map));
+ fprintf(dascii, "MAP DATE: %s\n", Vect_get_map_date(Map));
+ fprintf(dascii, "MAP SCALE: %d\n", Vect_get_scale(Map));
+ fprintf(dascii, "OTHER INFO: %s\n", Vect_get_comment(Map));
+ fprintf(dascii, "ZONE: %d\n", Vect_get_zone(Map));
+ fprintf(dascii, "MAP THRESH: %f\n", Vect_get_thresh(Map));
Property changes on: grass/trunk/lib/vector/Vlib/ascii.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Property changes on: grass/trunk/lib/vector/Vlib/merge_lines.c
+ text/x-csrc
Added: svn:keywords
+ Author Date Id
+ native
Deleted: grass/trunk/vector/v.in.ascii/a2b.c
--- grass/trunk/vector/v.in.ascii/a2b.c 2009-09-30 19:27:00 UTC (rev 39363)
+++ grass/trunk/vector/v.in.ascii/a2b.c 2009-09-30 20:32:12 UTC (rev 39364)
@@ -1,169 +0,0 @@
-#include <stdio.h>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/vector.h>
-#include <grass/glocale.h>
-#define BUFFSIZE 128
-int asc_to_bin(FILE * ascii, struct Map_info *Map)
- char ctype;
- char buff[BUFFSIZE];
- double *xarray;
- double *yarray;
- double *zarray;
- double *x, *y, *z;
- int i, n_points, n_coors, n_cats;
- int type;
- int alloc_points;
- int end_of_file;
- struct line_pnts *Points;
- struct line_cats *Cats;
- int catn;
- int cat;
- /* Must always use this to create an initialized line_pnts structure */
- Points = Vect_new_line_struct();
- Cats = Vect_new_cats_struct();
- end_of_file = 0;
- /*alloc_points = 1000 ; */
- alloc_points = 1;
- xarray = (double *)G_calloc(alloc_points, sizeof(double));
- yarray = (double *)G_calloc(alloc_points, sizeof(double));
- zarray = (double *)G_calloc(alloc_points, sizeof(double));
- while (G_getl2(buff, BUFFSIZE - 1, ascii) != 0) {
- n_cats = 0;
- if (buff[0] == '\0') {
- G_debug(3, "a2b: skipping blank line");
- continue;
- if (sscanf(buff, "%1c%d%d", &ctype, &n_coors, &n_cats) < 2 ||
- n_coors < 0 || n_cats < 0) {
- if (ctype == '#') {
- G_debug(2, "a2b: skipping commented line");
- continue;
- G_fatal_error(_("Error reading ASCII file: (bad type) [%s]"),
- buff);
- G_debug(2, "a2b: Skipping commented line");
- continue;
- switch (ctype) {
- case 'A':
- type = GV_BOUNDARY;
- break;
- case 'B':
- break;
- case 'C':
- type = GV_CENTROID;
- break;
- case 'L':
- type = GV_LINE;
- break;
- case 'P':
- type = GV_POINT;
- break;
- case 'F':
- type = GV_FACE;
- break;
- case 'K':
- type = GV_KERNEL;
- break;
- case 'a':
- case 'b':
- case 'c':
- case 'l':
- case 'p':
- type = 0; /* dead -> ignore */
- break;
- default:
- G_fatal_error(_("Error reading ASCII file: (unknown type) [%s]"),
- buff);
- G_debug(5, "feature type = %d", type);
- n_points = 0;
- x = xarray;
- y = yarray;
- z = zarray;
- /* Collect the points */
- for (i = 0; i < n_coors; i++) {
- if (G_getl2(buff, BUFFSIZE - 1, ascii) == 0)
- G_fatal_error(_("End of ASCII file reached before end of coordinates"));
- G_debug(3, "a2b: skipping blank line while reading vertices");
- i--;
- continue;
- *z = 0;
- if (sscanf(buff, "%lf%lf%lf", x, y, z) < 2)
- G_fatal_error(_("Error reading ASCII file: (bad point) [%s]"),
- buff);
- G_debug(5, "coor in: %s -> x = %f y = %f z = %f", G_chop(buff),
- *x, *y, *z);
- n_points++;
- x++;
- y++;
- z++;
- if (n_points >= alloc_points) {
- alloc_points = n_points + 1000;
- xarray =
- (double *)G_realloc((void *)xarray,
- alloc_points * sizeof(double));
- yarray =
- (double *)G_realloc((void *)yarray,
- zarray =
- (double *)G_realloc((void *)zarray,
- x = xarray + n_points;
- y = yarray + n_points;
- z = zarray + n_points;
- /* Collect the cats */
- for (i = 0; i < n_cats; i++) {
- G_fatal_error(_("End of ASCII file reached before end of categories"));
- G_debug(3,
- "a2b: skipping blank line while reading category info");
- i--;
- continue;
- if (sscanf(buff, "%u%u", &catn, &cat) != 2)
- G_fatal_error(_("Error reading categories: [%s]"), buff);
- Vect_cat_set(Cats, catn, cat);
- /* Allocation is handled for line_pnts */
- if (0 >
- Vect_copy_xyz_to_pnts(Points, xarray, yarray, zarray, n_points))
- G_fatal_error(_("Out of memory"));
- if (type > 0)
- Vect_write_line(Map, type, Points, Cats);
- Vect_reset_cats(Cats);
- return 0;
Deleted: grass/trunk/vector/v.in.ascii/head.c
--- grass/trunk/vector/v.in.ascii/head.c 2009-09-30 19:27:00 UTC (rev 39363)
+++ grass/trunk/vector/v.in.ascii/head.c 2009-09-30 20:32:12 UTC (rev 39364)
@@ -1,60 +0,0 @@
-#include <stdlib.h>
-#include <stdio.h>
-int read_head(FILE * dascii, struct Map_info *Map)
- char buff[1024];
- char *ptr;
- for (;;) {
- if (0 == G_getl2(buff, sizeof(buff) - 1, dascii))
- return (0);
- /* Last line of header */
- if (strncmp(buff, "VERTI:", 6) == 0)
- return (0);
- if (!(ptr = G_index(buff, ':')))
- G_fatal_error(_("Unexpected data in vector head:\n[%s]"), buff);
- ptr++; /* Search for the start of text */
- while (*ptr == ' ')
- ptr++;
- if (strncmp(buff, "ORGANIZATION:", 12) == 0)
- Vect_set_organization(Map, ptr);
- else if (strncmp(buff, "DIGIT DATE:", 11) == 0)
- Vect_set_date(Map, ptr);
- else if (strncmp(buff, "DIGIT NAME:", 11) == 0)
- Vect_set_person(Map, ptr);
- else if (strncmp(buff, "MAP NAME:", 9) == 0)
- Vect_set_map_name(Map, ptr);
- else if (strncmp(buff, "MAP DATE:", 9) == 0)
- Vect_set_map_date(Map, ptr);
- else if (strncmp(buff, "MAP SCALE:", 10) == 0)
- Vect_set_scale(Map, atoi(ptr));
- else if (strncmp(buff, "OTHER INFO:", 11) == 0)
- Vect_set_comment(Map, ptr);
- else if (strncmp(buff, "ZONE:", 5) == 0 ||
- strncmp(buff, "UTM ZONE:", 9) == 0)
- Vect_set_zone(Map, atoi(ptr));
- else if (strncmp(buff, "WEST EDGE:", 10) == 0) {
- else if (strncmp(buff, "EAST EDGE:", 10) == 0) {
- else if (strncmp(buff, "SOUTH EDGE:", 11) == 0) {
- else if (strncmp(buff, "NORTH EDGE:", 11) == 0) {
- else if (strncmp(buff, "MAP THRESH:", 11) == 0)
- Vect_set_thresh(Map, atof(ptr));
- else {
- G_warning(_("Unknown keyword <%s> in vector head"), buff);
- /* NOTREACHED */
Modified: grass/trunk/vector/v.in.ascii/local_proto.h
--- grass/trunk/vector/v.in.ascii/local_proto.h 2009-09-30 19:27:00 UTC (rev 39363)
+++ grass/trunk/vector/v.in.ascii/local_proto.h 2009-09-30 20:32:12 UTC (rev 39364)
@@ -1,25 +1,14 @@
#ifndef __LOCAL_PROTO_H__
#define __LOCAL_PROTO_H__
#include <stdio.h>
-#define FORMAT_POINT 0
-#define FORMAT_ALL 1
int points_analyse(FILE *, FILE *, char *, int *, int *, int *, int *, int **,
int **, int, int, int, int);
int points_to_bin(FILE *, int, struct Map_info *, dbDriver *,
char *, char *, int, int, int *, int, int, int, int, int);
-int read_head(FILE *, struct Map_info *);
-int asc_to_bin(FILE *, struct Map_info *);
#endif /* __LOCAL_PROTO_H__ */
Modified: grass/trunk/vector/v.in.ascii/main.c
--- grass/trunk/vector/v.in.ascii/main.c 2009-09-30 19:27:00 UTC (rev 39363)
+++ grass/trunk/vector/v.in.ascii/main.c 2009-09-30 20:32:12 UTC (rev 39364)
@@ -171,15 +171,15 @@
if (format_opt->answer[0] == 'p')
- format = FORMAT_POINT;
+ format = GV_ASCII_FORMAT_POINT;
else
- format = FORMAT_ALL;
+ format = GV_ASCII_FORMAT_ALL;
skip_lines = atoi(skip_opt->answer);
if (skip_lines < 0)
G_fatal_error(_("Please specify reasonable number of lines to skip"));
- if (zcoorf->answer && format == FORMAT_POINT && !zcol_opt->answer)
+ if (zcoorf->answer && format == GV_ASCII_FORMAT_POINT && !zcol_opt->answer)
G_fatal_error(_("Please specify z column"));
xcol = atoi(xcol_opt->answer) - 1;
@@ -190,7 +190,7 @@
if (zcol >= 0 && !zcoorf->answer)
zcoorf->answer = TRUE;
- if (zcoorf->answer && format == FORMAT_POINT && zcol < 0)
+ if (zcoorf->answer && format == GV_ASCII_FORMAT_POINT && zcol < 0)
G_fatal_error(_("Please specify reasonable z column"));
catcol = atoi(catcol_opt->answer) - 1;
@@ -231,7 +231,7 @@
exit(EXIT_SUCCESS);
- if (format == FORMAT_POINT) {
int i, rowlen, ncols, minncols, *coltype, *coltype2, *collen, nrows;
int n_int = 0, n_double = 0, n_string = 0;
char buf[1000];
@@ -529,9 +529,9 @@
else { /* FORMAT_ALL (standard mode) */
if (!noheader_flag->answer)
- read_head(ascii, &Map);
+ Vect_read_ascii_head(ascii, &Map);
- asc_to_bin(ascii, &Map);
+ Vect_read_ascii(ascii, &Map);
if (ascii != stdin)
Deleted: grass/trunk/vector/v.out.ascii/b2a.c
--- grass/trunk/vector/v.out.ascii/b2a.c 2009-09-30 19:27:00 UTC (rev 39363)
+++ grass/trunk/vector/v.out.ascii/b2a.c 2009-09-30 20:32:12 UTC (rev 39364)
@@ -1,317 +0,0 @@
-#include <grass/dbmi.h>
-#include "local_proto.h"
-static int srch(const void *pa, const void *pb);
-int bin_to_asc(FILE *ascii,
- FILE *att, struct Map_info *Map, int ver,
- int format, int dp, char *fs, int region_flag,
- int field, char* where, char **columns)
- int type, ctype, i, cat, proj;
- double *xptr, *yptr, *zptr, x, y;
- static struct line_pnts *Points;
- char *xstring = NULL, *ystring = NULL, *zstring = NULL;
- struct Cell_head window;
- struct ilist *fcats;
- /* where */
- struct field_info *Fi;
- dbDriver *driver;
- dbValue value = {0};
- dbHandle handle;
- int *cats, ncats;
- /* get the region */
- G_get_window(&window);
- ncats = 0;
- cats = NULL;
- if (where || columns) {
- Fi = Vect_get_field(Map, field);
- if (!Fi) {
- G_fatal_error(_("Database connection not defined for layer %d"),
- field);
- driver = db_start_driver(Fi->driver);
- if (!driver)
- G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
- db_init_handle(&handle);
- db_set_handle(&handle, Fi->database, NULL);
- if (db_open_database(driver, &handle) != DB_OK)
- G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
- Fi->database, Fi->driver);
- /* select cats (sorted array) */
- ncats = db_select_int(driver, Fi->table, Fi->key, where, &cats);
- G_debug(3, "%d categories selected from table <%s>", ncats, Fi->table);
- if (!columns) {
- db_close_database(driver);
- db_shutdown_driver(driver);
- Points = Vect_new_line_struct(); /* init line_pnts struct */
- fcats = Vect_new_list();
- proj = Vect_get_proj(Map);
- /* by default, read_next_line will NOT read Dead lines */
- /* but we can override that (in Level I only) by specifying */
- /* the type -1, which means match all line types */
- Vect_rewind(Map);
- while (1) {
- if (-1 == (type = Vect_read_next_line(Map, Points, Cats))) {
- if (columns) {
- return -1;
- if (type == -2) { /* EOF */
- if (columns) {
- return 0;
- if (format == FORMAT_POINT && !(type & GV_POINTS))
- continue;
- if (cats) {
- /* check category */
- for (i = 0; i < Cats->n_cats; i++) {
- if ((int *)bsearch((void *) &(Cats->cat[i]), cats, ncats, sizeof(int),
- srch)) {
- /* found */
- break;
- if (i == Cats->n_cats)
- continue;
- if (ver < 5) {
- Vect_cat_get(Cats, 1, &cat);
- switch (type) {
- case GV_BOUNDARY:
- if (ver == 5)
- ctype = 'B';
- else
- ctype = 'A';
- break;
- case GV_CENTROID:
- if (ver < 5) {
- if (att != NULL) {
- if (cat > 0) {
- G_asprintf(&xstring, "%.*f", dp, Points->x[0]);
- G_trim_decimal(xstring);
- G_asprintf(&ystring, "%.*f", dp, Points->y[0]);
- G_trim_decimal(ystring);
- fprintf(att, "A %s %s %d\n", xstring, ystring, cat);
- continue;
- ctype = 'C';
- break;
- case GV_LINE:
- ctype = 'L';
- break;
- case GV_POINT:
- ctype = 'P';
- break;
- case GV_FACE:
- ctype = 'F';
- break;
- case GV_KERNEL:
- ctype = 'K';
- break;
- default:
- ctype = 'X';
- G_warning(_("got type %d"), (int)type);
- break;
- /*fprintf(ascii, "%c", ctype); */
- if (region_flag) {
- if ((window.east < Points->x[0]) ||
- (window.west > Points->x[0]))
- continue;
- if ((window.north < Points->y[0]) ||
- (window.south > Points->y[0]))
- continue;
- if (Map->head.with_z && ver == 5) {
- if ((window.top < Points->z[0]) ||
- (window.bottom > Points->z[0]))
- continue;
- G_asprintf(&zstring, "%.*f", dp, Points->z[0]);
- G_trim_decimal(zstring);
- fprintf(ascii, "%s%s%s%s%s", xstring, fs, ystring, fs,
- zstring);
- else {
- fprintf(ascii, "%s%s%s", xstring, fs, ystring);
- Vect_field_cat_get(Cats, field, fcats);
- if (fcats->n_values > 0) {
- if (fcats->n_values > 1) {
- G_warning(_("Feature has more categories. Only first category (%d) "
- "is exported."), fcats->value[0]);
- fprintf(ascii, "%s%d", fs, fcats->value[0]);
- /* print attributes */
- if (columns) {
- for(i = 0; columns[i]; i++) {
- if (db_select_value(driver, Fi->table, Fi->key, fcats->value[0],
- columns[i], &value) < 0)
- G_fatal_error(_("Unable to select record from table <%s> (key %s, column %s)"),
- Fi->table, Fi->key, columns[i]);
- if (db_test_value_isnull(&value)) {
- fprintf(ascii, "%s", fs);
- else {
- switch(db_column_Ctype(driver, Fi->table, columns[i]))
- case DB_C_TYPE_INT: {
- fprintf(ascii, "%s%d", fs, db_get_value_int(&value));
- break;
- case DB_C_TYPE_DOUBLE: {
- fprintf(ascii, "%s%.*f", fs, dp, db_get_value_double(&value));
- break;
- case DB_C_TYPE_STRING: {
- fprintf(ascii, "%s%s", fs, db_get_value_string(&value));
- break;
- case DB_C_TYPE_DATETIME: {
- break;
- case -1:
- G_fatal_error(_("Column <%s> not found in table <%s>"),
- columns[i], Fi->table);
- default: G_fatal_error(_("Column <%s>: unsupported data type"),
- columns[i]);
- fprintf(ascii, "\n");
- else {
- /* FORMAT_STANDARD */
- if (ver == 5 && Cats->n_cats > 0)
- fprintf(ascii, "%c %d %d\n", ctype, Points->n_points,
- Cats->n_cats);
- else
- fprintf(ascii, "%c %d\n", ctype, Points->n_points);
- xptr = Points->x;
- yptr = Points->y;
- zptr = Points->z;
- while (Points->n_points--) {
- G_asprintf(&xstring, "%.*f", dp, *xptr++);
- G_asprintf(&ystring, "%.*f", dp, *yptr++);
- if (ver == 5) {
- if (Map->head.with_z) {
- G_asprintf(&zstring, "%.*f", dp, *zptr++);
- fprintf(ascii, " %-12s %-12s %-12s\n", xstring,
- ystring, zstring);
- else {
- fprintf(ascii, " %-12s %-12s\n", xstring, ystring);
- } /*Version 4 */
- else {
- fprintf(ascii, " %-12s %-12s\n", ystring, xstring);
- if (ver == 5) {
- fprintf(ascii, " %-5d %-10d\n", Cats->field[i],
- Cats->cat[i]);
- else {
- if (cat > 0) {
- if (type == GV_POINT) {
- fprintf(att, "P %s %s %d\n", xstring, ystring, cat);
- else {
- x = (Points->x[1] + Points->x[0]) / 2;
- y = (Points->y[1] + Points->y[0]) / 2;
- G_asprintf(&xstring, "%.*f", dp, x);
- G_asprintf(&ystring, "%.*f", dp, y);
- fprintf(att, "L %s %s %d\n", xstring, ystring, cat);
- /* not reached */
-int srch(const void *pa, const void *pb)
- int *p1 = (int *)pa;
- int *p2 = (int *)pb;
- if (*p1 < *p2)
- return -1;
- if (*p1 > *p2)
- return 1;
- return 0;
Deleted: grass/trunk/vector/v.out.ascii/head.c
--- grass/trunk/vector/v.out.ascii/head.c 2009-09-30 19:27:00 UTC (rev 39363)
+++ grass/trunk/vector/v.out.ascii/head.c 2009-09-30 20:32:12 UTC (rev 39364)
@@ -1,19 +0,0 @@
-#include <stdio.h>
-int write_head(FILE * dascii, struct Map_info *Map)
- fprintf(dascii, "ORGANIZATION: %s\n", Vect_get_organization(Map));
- fprintf(dascii, "DIGIT DATE: %s\n", Vect_get_date(Map));
- fprintf(dascii, "DIGIT NAME: %s\n", Vect_get_person(Map));
- fprintf(dascii, "MAP NAME: %s\n", Vect_get_map_name(Map));
- fprintf(dascii, "MAP DATE: %s\n", Vect_get_map_date(Map));
- fprintf(dascii, "MAP SCALE: %d\n", Vect_get_scale(Map));
- fprintf(dascii, "OTHER INFO: %s\n", Vect_get_comment(Map));
- fprintf(dascii, "ZONE: %d\n", Vect_get_zone(Map));
- fprintf(dascii, "MAP THRESH: %f\n", Vect_get_thresh(Map));
- return (0);
Deleted: grass/trunk/vector/v.out.ascii/local_proto.h
--- grass/trunk/vector/v.out.ascii/local_proto.h 2009-09-30 19:27:00 UTC (rev 39363)
+++ grass/trunk/vector/v.out.ascii/local_proto.h 2009-09-30 20:32:12 UTC (rev 39364)
@@ -1,8 +0,0 @@
-/* b2a.c */
-int bin_to_asc(FILE *, FILE *, struct Map_info *, int ver, int format, int dp,
- char *, int, int, char *, char **);
-/* head.c */
-int write_head(FILE * dascii, struct Map_info *Map);
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c 2009-09-30 19:27:00 UTC (rev 39363)
+++ grass/trunk/vector/v.out.ascii/main.c 2009-09-30 20:32:12 UTC (rev 39364)
@@ -24,7 +24,6 @@
int main(int argc, char *argv[])
@@ -105,11 +104,11 @@
field = atoi(field_opt->answer);
else
- if (format == FORMAT_ALL && column_opt->answer) {
+ if (format == GV_ASCII_FORMAT_ALL && column_opt->answer) {
G_warning(_("Parameter '%s' ignored in standard mode"),
column_opt->key);
@@ -117,7 +116,7 @@
if (verf->answer)
ver = 4;
- if (ver == 4 && format == FORMAT_POINT) {
+ if (ver == 4 && format == GV_ASCII_FORMAT_POINT) {
G_fatal_error(_("Format 'point' is not supported for old version"));
@@ -167,8 +166,8 @@
ascii = stdout;
- if (format == FORMAT_ALL) {
- write_head(ascii, &Map);
+ if (format == GV_ASCII_FORMAT_ALL) {
+ Vect_write_ascii_head(ascii, &Map);
fprintf(ascii, "VERTI:\n");
@@ -183,9 +182,9 @@
output->answer);
- bin_to_asc(ascii, att, &Map, ver, format, dp, fs,
- region_flag->answer, field, where_opt->answer,
- column_opt->answers);
+ Vect_write_ascii(ascii, att, &Map, ver, format, dp, fs,
+ region_flag->answer, field, where_opt->answer,
+ column_opt->answers);
if (ascii != NULL)
fclose(ascii);
