[GRASS-SVN] r41642 - in grass/trunk: lib/gpde raster/r.gwflow
svn_grass at osgeo.org
Thu Apr 1 05:55:17 EDT 2010
Author: huhabla
Date: 2010-04-01 05:55:16 -0400 (Thu, 01 Apr 2010)
New Revision: 41642
grass/trunk/lib/gpde/N_gwflow.c
grass/trunk/raster/r.gwflow/main.c
Use cell array in r.gwflow to store the boundary conditions
Modified: grass/trunk/lib/gpde/N_gwflow.c
--- grass/trunk/lib/gpde/N_gwflow.c 2010-03-31 20:25:48 UTC (rev 41641)
+++ grass/trunk/lib/gpde/N_gwflow.c 2010-04-01 09:55:16 UTC (rev 41642)
@@ -154,7 +154,7 @@
data->phead = N_alloc_array_2d(cols, rows, 1, DCELL_TYPE);
data->phead_start = N_alloc_array_2d(cols, rows, 1, DCELL_TYPE);
- data->status = N_alloc_array_2d(cols, rows, 1, DCELL_TYPE);
+ data->status = N_alloc_array_2d(cols, rows, 1, CELL_TYPE);
data->hc_x = N_alloc_array_2d(cols, rows, 1, DCELL_TYPE);
data->hc_y = N_alloc_array_2d(cols, rows, 1, DCELL_TYPE);
data->q = N_alloc_array_2d(cols, rows, 1, DCELL_TYPE);
@@ -672,7 +672,7 @@
for (y = 0; y < rows; y++) {
G_percent(y, rows - 1, 10);
for (x = 0; x < cols; x++) {
- stat = (int)N_get_array_2d_d_value(data->status, x, y);
+ stat = N_get_array_2d_c_value(data->status, x, y);
val = 0.0;
Modified: grass/trunk/raster/r.gwflow/main.c
--- grass/trunk/raster/r.gwflow/main.c 2010-03-31 20:25:48 UTC (rev 41641)
+++ grass/trunk/raster/r.gwflow/main.c 2010-04-01 09:55:16 UTC (rev 41642)
@@ -333,7 +333,7 @@
/* Set the inactive values to zero, to assure a no flow boundary */
for (y = 0; y < geom->rows; y++) {
for (x = 0; x < geom->cols; x++) {
if (stat == N_CELL_INACTIVE) { /*only inactive cells */
N_put_array_2d_d_value(data->hc_x, x, y, 0);
N_put_array_2d_d_value(data->hc_y, x, y, 0);
@@ -478,7 +478,7 @@
- stat = (int)N_get_array_2d_d_value(status, x, y);
+ stat = N_get_array_2d_c_value(status, x, y);
if (stat == N_CELL_ACTIVE) { /*only active cells */
d1 = result[count];
val = (DCELL) d1;
