[GRASS-SVN] r41657 - grass-web/trunk/download
svn_grass at osgeo.org
Fri Apr 2 04:16:45 EDT 2010
Author: neteler
Date: 2010-04-02 04:16:41 -0400 (Fri, 02 Apr 2010)
New Revision: 41657
grass-web/trunk/download/addons.inc
cleanup; all moved to wiki
Modified: grass-web/trunk/download/addons.inc
--- grass-web/trunk/download/addons.inc 2010-04-02 06:38:41 UTC (rev 41656)
+++ grass-web/trunk/download/addons.inc 2010-04-02 08:16:41 UTC (rev 41657)
@@ -8,107 +8,22 @@
<ul>
<li> <a href="http://grass.osgeo.org/wiki/GRASS_AddOns">GrassAddOns</a>:
-This WIKI page contains references to user contributions and add-ons for GRASS 6
+This WIKI page contains references to numerous user contributions and add-ons for GRASS GIS
</li>
</ul>
-<h2>Addons in the GRASS SVN repository</h2>
-<ul>
-<li> <a href="http://svn.osgeo.org/grass/grass-addons/">GRASS Addons SVN repository</a></li>
-<li> Command line:<br>
-<tt> svn checkout https://svn.osgeo.org/grass/grass-addons/ grass-addons</tt><br>
-or specifically a module (example):<br>
-<tt> svn checkout https://svn.osgeo.org/grass/grass-addons/gipe grass-addons/gipe</tt>
-</li>
-</ul>
<h2>GRASS outgoing directory</h2>
<ul>
-<li>This directory contains code submissions to the GRASS Development Team.
+<li>This directory contains some code submissions to the GRASS Development Team.
So far no team member found the time to integrate these submissions.
Feel free to pick code up, and, if needed, adapt it for a seamless integration
-into the latest GRASS 5 version (if the code is of general interest):<br>
-<a href="http://grass.itc.it/outgoing/">http://grass.itc.it/outgoing/</a>
+into the latest GRASS version (if the code is of general interest):<br>
+<a href="http://grass.osgeo.org/outgoing/">http://grass.osgeo.org/outgoing/</a>
</li>
</ul>
-<h2>GUI (Graphical User Interfaces)</h2>
-<ul>
-<li>
-<a href="http://www.qgis.org/">QGIS & GRASS</a>: Quantum GIS comes with
-plugins for GRASS raster and vector data + application interface
-+ vector digitizer</li>
-<li>
-<a href="http://www.navicon.dk/grassqt/">Qt/GRASS</a>:
-GRASS/Qt is a C++ library that intends to make it easy to use the GRASS GIS
-system from within the Qt GUI framework to create applications needing GIS
-functionality. (C. Madsen, Navicon, Denmark)</li>
-<li>
-<a href="http://www.jgrass.org">JAVAGRASS</a>:
-JGrass, a Java based framework for the GRASS Geographic Information System</li>
-</ul>
-<h2>CLI (Command Line Interface)</h2>
-<ul>
-<li>
-<a href="http://www.sorokine.info/grass-complete/">GRASS shell completions scripts</a>
- (the package is for GRASS 5)
-</ul>
-<h2>Image processing modules</h2>
-<ul>
-<li>
-<a href="http://www.cs.sun.ac.za/~caz/projects.html">i.atcorr: 6S atmospheric
-correction program</a> (Christo Zietsman, South Africa)</li>
-</ul>
-<h2>
-Raster modules</h2>
-<ul>
-<li>
-<a href="http://www.ucl.ac.uk/~tcrnmar/">r.boxcount</a>:
-fractal dimension (Dr. M. Lake, London, U.K.)</li>
-<li>
-<a href="http://www.ucl.ac.uk/~tcrnmar/">r.cva</a>:
-Cumulative viewshed analysis program. (Dr. M. Lake, London, U.K.)</li>
-<li>
-<a
-href="http://www.hydrosciences.org/index.asp?frame=fuzzy_index">r.fuzzy: Fuzzy logic tools</a> (François Delclaux)</li>
-<li>
-<a href="http://www.ing.unitn.it/~grass/software.html">r.obstruction,
-r.planning.static, r.planning.cinematic</a>: r.obstruction creates a polar
-obstruction map from a DTM. r.planning.static performs a static planning
-for GPS and Glonass surveys using the obstruction map created with r.obstruction.
-r.planning.cinematic performs a cinematic planning for GPS and Glonass
-surveys. (University of Trento, Faculty of Engineering)</li>
-<li>
-<a href="http://www.ing.unitn.it/~grass/software.html">r.wavelets</a>: This
-package contains wavelets decomposition and reconstruction modules for the
-GRASS GIS:
-r.owave.dec computes the orthogonal wavelet transform of a raster map.
-r.owave.rec reconstructs a raster map from an orthogonal wavelet transform.
-r.biowave.dec computes the biorthogonal wavelet transform of a raster map.
-r.biowave.rec reconstructs a raster map from a biorthogonal wavelet
-transform. (University of Trento, Faculty of Engineering)</li>
-<li>
-<a href="http://www.ucl.ac.uk/~tcrnmar/">r.rifs</a>:
-r.rifs generates a raster map and/or image of a fractal by means of the
-specified random iterated function system. (Dr. M. Lake, London, U.K.)</li>
-</ul>
<div align="right">
<i>Last change: $Date$ </i><br>
<i>$Author$</i>
