[GRASS-SVN] r41659 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Apr 2 06:37:10 EDT 2010
Author: martinl
Date: 2010-04-02 06:37:09 -0400 (Fri, 02 Apr 2010)
New Revision: 41659
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI/gmodeler: run/validate model
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2010-04-02 10:23:18 UTC (rev 41658)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2010-04-02 10:37:09 UTC (rev 41659)
@@ -66,20 +66,32 @@
if msgType == 'error':
caption = _('Error')
style = wx.OK | wx.ICON_ERROR | wx.CENTRE
+ elif msgType == 'info':
+ caption = _('Message')
+ style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE
+ elif msgType == 'warning':
+ caption = _('Warning')
+ style = wx.OK | wx.ICON_WARNING | wx.CENTRE
- exception = traceback.format_exc()
- reason = exception.split('\n')[-2].split(':', 1)[-1].strip()
+ if msgType != 'error':
+ wx.MessageBox(parent = parent,
+ message = message,
+ caption = caption,
+ style = style)
+ else:
+ exception = traceback.format_exc()
+ reason = exception.split('\n')[-2].split(':', 1)[-1].strip()
- if Debug.get_level() > 0:
- sys.stderr.write(exception)
+ if Debug.get_level() > 0:
+ sys.stderr.write(exception)
- wx.MessageBox(parent = parent,
- message = message + '\n\n%s: %s\n\n%s' % \
- (_('Reason'),
- reason, exception),
- caption = caption,
- style = style)
+ message = message + '\n\n%s: %s\n\n%s' % \
+ (_('Reason'),
+ reason, exception),
+ style = style)
class GException(Exception):
"""!Generic exception"""
def __init__(self, message, title=_("Error"), parent=None):
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-04-02 10:23:18 UTC (rev 41658)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-04-02 10:37:09 UTC (rev 41659)
@@ -204,6 +204,24 @@
def OnRunModel(self, event):
"""!Run entire model"""
+ if len(self.actions) < 1:
+ GMessage(parent = self,
+ message = _('Model is empty. Nothing to run.'),
+ msgType = 'info')
+ return
+ errList = self._validateModel()
+ if errList:
+ dlg = wx.MessageDialog(parent = self,
+ message = _('Model is not valid. Do you want to '
+ 'run the model anyway?\n\n%s') % '\n'.join(errList),
+ caption=_("Run model?"),
+ style = wx.YES_NO | wx.NO_DEFAULT |
+ wx.ICON_QUESTION | wx.CENTRE)
+ ret = dlg.ShowModal()
+ if ret != wx.ID_YES:
+ return
for action in self.actions:
self.SetStatusText(_('Running model...'), 0)
self.goutput.RunCmd(command = action.GetLog(string = False),
@@ -213,11 +231,38 @@
"""!Computation finished"""
self.SetStatusText('', 0)
- def OnValidateModel(self, event):
+ def OnValidateModel(self, event, showMsg = True):
"""!Validate entire model"""
- for s in self.actions:
- print s
+ message = _('Model is empty. Nothing to validate.'),
+ msgType = 'info')
+ return
+ if errList:
+ message = _('Model is not valid.\n\n%s') % '\n'.join(errList),
+ msgType = 'warning')
+ else:
+ message = _('Model is valid.'),
+ msgType = 'info')
+ def _validateModel(self):
+ """!Validate model"""
+ self.SetStatusText(_('Validating model...'), 0)
+ errList = list()
+ for action in self.actions:
+ task = menuform.GUI().ParseCommand(cmd = action.GetLog(string = False),
+ show = None)
+ errList += task.getCmdError()
+ self.SetStatusText('', 0)
+ return errList
def OnRemoveItem(self, event):
"""!Remove item from model"""
pass
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-04-02 10:23:18 UTC (rev 41658)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2010-04-02 10:37:09 UTC (rev 41659)
@@ -426,7 +426,22 @@
return
param['value'] = aValue
+ def getCmdError(self):
+ """!Get error string produced by getCmd(ignoreErrors = False)
+ @return list of errors
+ errorList = list()
+ for p in self.params:
+ if p.get('value', '') == '' and p.get('required', 'no') != 'no':
+ if p.get('default', '') == '':
+ errorList.append(_("Parameter '%(name)s' (%(desc)s) is missing.") % \
+ {'name' : p['name'], 'desc' : p['description']})
+ return errorList
def getCmd(self, ignoreErrors = False):
"""!Produce an array of command name and arguments for feeding
into some execve-like command processor.
@@ -436,9 +451,7 @@
for GRASS.
cmd = [self.name]
- errors = 0
- errStr = ""
for flag in self.flags:
if 'value' in flag and flag['value']:
if len(flag['name']) > 1: # e.g. overwrite
@@ -451,16 +464,13 @@
cmd += [ '%s=%s' % ( p['name'], p['default'] ) ]
elif ignoreErrors is False:
cmd += [ '%s=%s' % ( p['name'], _('<required>') ) ]
- errStr += _("Parameter %(name)s (%(desc)s) is missing.\n") % \
- {'name' : p['name'], 'desc' : p['description']}
- errors += 1
elif p.get('value','') != '' and p['value'] != p.get('default','') :
# Output only values that have been set, and different from defaults
cmd += [ '%s=%s' % ( p['name'], p['value'] ) ]
- if errors and not ignoreErrors:
- raise ValueError, errStr
+ if ignoreErrors is False:
+ raise ValueError, '\n'.join(self.getCmdError())
return cmd
def set_options(self, opts):
@@ -910,7 +920,7 @@
def OnApply(self, event):
"""!Apply the command"""
- if self.parent.GetName() == 'Modeler':
+ if self.parent and self.parent.GetName() == 'Modeler':
cmd = self.createCmd(ignoreErrors = True)
else:
cmd = self.createCmd()
@@ -1848,7 +1858,7 @@
cmd = self.task.getCmd(ignoreErrors=ignoreErrors)
except ValueError, err:
dlg = wx.MessageDialog(parent=self,
- message=utils.UnicodeString(err),
+ message=unicode(err),
caption=_("Error in %s") % self.task.name,
style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
dlg.ShowModal()
@@ -1933,14 +1943,13 @@
def ParseCommand(self, cmd, gmpath=None, completed=None, parentframe=None,
show=True, modal=False):
- Parse command
+ """!Parse command
Note: cmd is given as list
If command is given with options, return validated cmd list:
- * add key name for first parameter if not given
- * change mapname to mapname at mapset
+ - add key name for first parameter if not given
+ - change mapname to mapname at mapset
start = time.time()
dcmd_params = {}
