[GRASS-SVN] r41677 - in grass-addons/postscript/ps.output: . examples
Sat Apr 3 04:23:03 EDT 2010
Author: hamish
Date: 2010-04-03 04:23:02 -0400 (Sat, 03 Apr 2010)
New Revision: 41677
Removed:
   grass-addons/postscript/ps.output/ps.out.tmp.html
   grass-addons/postscript/ps.output/Makefile
   grass-addons/postscript/ps.output/cat_val.c
   grass-addons/postscript/ps.output/colors.c
   grass-addons/postscript/ps.output/colors.h
   grass-addons/postscript/ps.output/conversion.h
   grass-addons/postscript/ps.output/description.html
   grass-addons/postscript/ps.output/draws.h
   grass-addons/postscript/ps.output/eps.c
   grass-addons/postscript/ps.output/examples/MAP_2raster.pdf
   grass-addons/postscript/ps.output/examples/MAP_raster.pdf
   grass-addons/postscript/ps.output/fonts.c
   grass-addons/postscript/ps.output/fonts.h
   grass-addons/postscript/ps.output/format.c
   grass-addons/postscript/ps.output/frames.c
   grass-addons/postscript/ps.output/frames.h
   grass-addons/postscript/ps.output/grids.h
   grass-addons/postscript/ps.output/input.c
   grass-addons/postscript/ps.output/legends.c
   grass-addons/postscript/ps.output/legends.h
   grass-addons/postscript/ps.output/lines.c
   grass-addons/postscript/ps.output/lines.h
   grass-addons/postscript/ps.output/load_raster.c
   grass-addons/postscript/ps.output/local_proto.h
   grass-addons/postscript/ps.output/main.c
   grass-addons/postscript/ps.output/notes.h
   grass-addons/postscript/ps.output/palettes.c
   grass-addons/postscript/ps.output/palettes.h
   grass-addons/postscript/ps.output/papers.c
   grass-addons/postscript/ps.output/papers.h
   grass-addons/postscript/ps.output/proj_geo.c
   grass-addons/postscript/ps.output/ps.out_can.jpg
   grass-addons/postscript/ps.output/ps.out_iho.jpg
   grass-addons/postscript/ps.output/ps.out_in.jpg
   grass-addons/postscript/ps.output/ps.out_out.jpg
   grass-addons/postscript/ps.output/ps3_map.c
   grass-addons/postscript/ps.output/ps_info.h
   grass-addons/postscript/ps.output/r_block.c
   grass-addons/postscript/ps.output/r_draw.c
   grass-addons/postscript/ps.output/r_font.c
   grass-addons/postscript/ps.output/r_frame.c
   grass-addons/postscript/ps.output/r_grid.c
   grass-addons/postscript/ps.output/r_line.c
   grass-addons/postscript/ps.output/r_maparea.c
   grass-addons/postscript/ps.output/r_note.c
   grass-addons/postscript/ps.output/r_palette.c
   grass-addons/postscript/ps.output/r_paper.c
   grass-addons/postscript/ps.output/r_raster.c
   grass-addons/postscript/ps.output/r_rlegend.c
   grass-addons/postscript/ps.output/r_scalebar.c
   grass-addons/postscript/ps.output/r_vareas.c
   grass-addons/postscript/ps.output/r_vlabels.c
   grass-addons/postscript/ps.output/r_vlegend.c
   grass-addons/postscript/ps.output/r_vlines.c
   grass-addons/postscript/ps.output/r_vpoints.c
   grass-addons/postscript/ps.output/raster.c
   grass-addons/postscript/ps.output/raster.h
   grass-addons/postscript/ps.output/rlegend.h
   grass-addons/postscript/ps.output/scalebar.h
   grass-addons/postscript/ps.output/scanners.c
   grass-addons/postscript/ps.output/set_draw.c
   grass-addons/postscript/ps.output/set_geogrid.c
   grass-addons/postscript/ps.output/set_grid.c
   grass-addons/postscript/ps.output/set_mask.c
   grass-addons/postscript/ps.output/set_note.c
   grass-addons/postscript/ps.output/set_outline.c
   grass-addons/postscript/ps.output/set_ps.c
   grass-addons/postscript/ps.output/set_raster.c
   grass-addons/postscript/ps.output/set_rlegend.c
   grass-addons/postscript/ps.output/set_scalebar.c
   grass-addons/postscript/ps.output/set_vareas.c
   grass-addons/postscript/ps.output/set_vector.c
   grass-addons/postscript/ps.output/set_vlabels.c
   grass-addons/postscript/ps.output/set_vlegend.c
   grass-addons/postscript/ps.output/set_vlines.c
   grass-addons/postscript/ps.output/set_vpoints.c
   grass-addons/postscript/ps.output/start_map.c
   grass-addons/postscript/ps.output/symbol.c
   grass-addons/postscript/ps.output/val_list.c
   grass-addons/postscript/ps.output/vareas.h
   grass-addons/postscript/ps.output/vector.c
   grass-addons/postscript/ps.output/vector.h
   grass-addons/postscript/ps.output/vlabels.h
   grass-addons/postscript/ps.output/vlegend.h
   grass-addons/postscript/ps.output/vlines.h
   grass-addons/postscript/ps.output/vpoints.h
svn props
Property changes on: grass-addons/postscript/ps.output
___________________________________________________________________
Modified: svn:ignore
   - *.tmp.html
*OBJ*
   + OBJ.*
*.tmp.html
Property changes on: grass-addons/postscript/ps.output/Makefile
Added: svn:mime-type
   + text/x-makefile
Property changes on: grass-addons/postscript/ps.output/cat_val.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/colors.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/colors.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/conversion.h
   + text/x-chdr
Modified: grass-addons/postscript/ps.output/description.html
--- grass-addons/postscript/ps.output/description.html	2010-04-03 08:16:07 UTC (rev 41676)
+++ grass-addons/postscript/ps.output/description.html	2010-04-03 08:23:02 UTC (rev 41677)
@@ -1,6 +1,6 @@
 <H2>DESCRIPTION</H2>
-<EM>ps.out</EM> is a cartographic mapping program for producing high quality
+<EM>ps.output</EM> is a cartographic mapping program for producing high quality
 hardcopy maps in PostScript-3 format. Output can include a combination of two raster maps, any
 number of vector overlays, notes, decorations, and other spatial data.
Property changes on: grass-addons/postscript/ps.output/description.html
   + text/html
Property changes on: grass-addons/postscript/ps.output/draws.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/eps.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/examples/MAP_2raster.pdf
   + application/pdf
Property changes on: grass-addons/postscript/ps.output/examples/MAP_raster.pdf
   + application/pdf
Property changes on: grass-addons/postscript/ps.output/fonts.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/fonts.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/format.c
   + text/x-csrc
Added: svn:eol-style
   + native
Property changes on: grass-addons/postscript/ps.output/frames.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/frames.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/grids.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/input.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/legends.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/legends.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/lines.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/lines.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/load_raster.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/local_proto.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/main.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/notes.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/palettes.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/palettes.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/papers.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/papers.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/proj_geo.c
   + text/x-csrc
Deleted: grass-addons/postscript/ps.output/ps.out.tmp.html
--- grass-addons/postscript/ps.output/ps.out.tmp.html	2010-04-03 08:16:07 UTC (rev 41676)
+++ grass-addons/postscript/ps.output/ps.out.tmp.html	2010-04-03 08:23:02 UTC (rev 41677)
@@ -1,825 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>GRASS GIS manual: ps.out</title>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<link rel="stylesheet" href="grassdocs.css" type="text/css">
-</head>
-<body bgcolor="white">
-<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
-<h2>NAME</h2>
-<em><b>ps.out</b></em>  - PostScript-3 Output.
-<h2>KEYWORDS</h2>
-postscript, map, printing
-<h2>SYNOPSIS</h2>
-<b>ps.out</b><br>
-<b>ps.out help</b><br>
-<b>ps.out</b> [-<b>degs</b>]  [<b>input</b>=<em>string</em>]  <b>output</b>=<em>string</em>  [--<b>verbose</b>]  [--<b>quiet</b>]
-<h3>Flags:</h3>
-<DL>
-<DT><b>-d</b></DT>
-<DD>draf: Create a 1x1cm grid on paper to easy place and drawing</DD>
-<DT><b>-e</b></DT>
-<DD>eps: Create a EPS file to easy include in ps.out (no stand-alone)</DD>
-<DT><b>-g</b></DT>
-<DD>ghostscript: Use the extended PostScript of Ghostscript (for transparent colors</DD>
-<DT><b>-s</b></DT>
-<DD>special: Special number style: lower</DD>
-<DT><b>--verbose</b></DT>
-<DD>Verbose module output</DD>
-<DT><b>--quiet</b></DT>
-<DD>Quiet module output</DD>
-</DL>
-<h3>Parameters:</h3>
-<DL>
-<DT><b>input</b>=<em>string</em></DT>
-<DD>File containing mapping instructions</DD>
-<DT><b>output</b>=<em>string</em></DT>
-<DD>PostScript output file</DD>
-</DL>
-<H2>DESCRIPTION</H2>
-hardcopy maps in PostScript-3 format. Output can include a combination of two raster maps, any
-number of vector overlays, notes, decorations, and other spatial data.
-<P>
-A file of mapping instructions that describes the various spatial and textual
-information to be printed must be prepared prior to running <EM>ps.out</EM>.
-Then, the better use is writing a script file as:
-<PRE>
-ps.out [flags] output=FILE << EOF
-(ps.out commands)
-EOF
-</PRE>
-<P>
-The hash character ('<tt>#</tt>') may be used at the beginning of a line
-to indicate that the line is a comment. Blank lines will also be ignored.
-<H2>NOTES</H2>
-<P>
-The order of commands is generally unimportant but may affect how some layers
-are drawn. <EM>ps.out</EM> first draw the masked areas, lines, points, and labels,
-second the unmasked areas and lines, and finally the grids, unmasked points and unmasked labels.
-Raster maps are always drawn first, and only a raster map command may be used.
-<P>
-Be aware that some mapping instructions require the <i>end</i> command
-and some do not. Any instruction that allows subcommands will require
-it.
-<P>
-The resolution and extent of raster maps plotted with <EM>ps.out</EM> are controlled by the current region settings via the <a href="g.region.html">g.region</a> module. The output filesize is largely a function of the region resolution, so special care should be taken if working with large raster datasets.
-For example if the desired output is Letter sized paper at 300dpi, with 1" margins and the raster filling the entire page, the usable area on the page will be 6.5" x 9", which at 300 dots/inch is equivalent to a region of 1950 columns x 2700 rows (see "<tt>g.region -p</tt>"). Any higher resolution settings will make the output file larger, but with a consumer printer you probably won't be able to resolve any better detail in the hardcopy.
-<P>
-The user can specify negative or greater than 100 percentage values for positioning several map decorations and embedded EPS-files, to move them outside the current map box region (for example to position a caption, barscale, or legend above or below the map box).
-<P>
-One "pixel" is 1/72 of an inch or 127/360 (aprox. 0.35) of a millimetre.
-<P>
-For users wanting to use special characters (such as accented characters) it is important to note that <em>ps.out</em> uses <tt>ISO-8859-1</tt> encoding. This means that your instructions file will have to be encoded in this encoding. If you normally work in a different encoding environment (such as <tt>UTF-8</tt>), you have to transform your file to the <tt>ISO-8859-1</tt> encoding, for example by using the <tt>iconv</tt> utility:
-</P>
-<DIV class="code"><PRE>
-iconv -f UTF-8 -t ISO_8859-1 utf_file > iso_file
-</PRE></DIV>
-<P><P>
-<H2>MAPPING INSTRUCTIONS</H2>
-The mapping instructions allow the user to specify various spatial data to be plotted. These instructions are normally prepared in a regular text file using a system editor. Except <em>scale</em>, all instructions are multiple line followed by a subsection of one or more additional instructions and are terminated with an <i>end</i> instruction.
-<P>
-<H3>Instruction keywords:</H3>
-<a href="#draw">draw</a>&nbsp;<BR>
-<a href="#geogrid">geogrid</a>&nbsp; ERROR IN SOUTH HEMISPHERE?<BR>
-<a href="#grid">grid</a>&nbsp;<BR>
-<a href="#maparea">maparea</a>&nbsp;<BR>
-<a href="#note">note</a>&nbsp;<BR>
-<a href="#palette">palette</a>&nbsp;<BR>
-<a href="#paper">paper</a>&nbsp;<BR>
-<a href="#raster">raster</a>&nbsp;<BR>
-<a href="#rlegend">rlegend</a>&nbsp;<BR>
-<a href="#scale">scale</a>&nbsp;<BR>
-<a href="#scalebar">scalebar</a>&nbsp;<BR>
-<a href="#vareas">vareas</a>&nbsp;<BR>
-<a href="#vlabels">vlabel</a>&nbsp;<BR>
-<a href="#vlines">vlines</a>&nbsp;<BR>
-<a href="#vpoints">vpoints</a>&nbsp;<BR>
-<a href="#vlegend">vlegend</a>&nbsp;<BR>
-<h3>Convention in description of some instructions:</h3>
-<DL>
-<DT><B>#</B> <EM>number without dimension</EM>
-<DD>The number is considered in points.
-</DD><P>
-<DT><B>#-</B> <EM>number with dimension</EM>
-<DD> Acceptable units are <em>mm</em> (millimeters), <em>cm</em> (centimeters), <em>inch</em> (inches), and <em>%</em> (percent of map dimensions).
-</DD><P>
-<DT><B>CAT</B> <EM>List of categories</EM> e.g. 1,3,5-7
-<P>
-<DT><B>SQL</B> <EM>SQL where statement</EM> like: vlastnik = 'Cimrman'
-<P>
-<DT><b>T</b> <em>Text</em>
-<P>
-<DT><b>R</b> <em>Raster</em> file or group name if the first character is ':'
-<P>
-<DT><b>V</b> <em>Vector</em> file name if equal to '(none)' then don't draw but there is present in vlegend.
-<P>
-<DT><b>color</b> <em>Color</em> name
-<DD>The color may be either a standard <a name="NAMED_COLORS">GRASS color</a>, a <tt>R:G:B</tt> triplet (e.g '<tt>255:0:0</tt>'), or <tt>none</tt>. In all cases could be follow by <em>$alpha</em> to set the opacity (if use -g flag).
- The following colors names are accepted by <EM>ps.out</EM>: <tt>aqua, black, blue, brown, cyan, gray, grey, green, indigo, magenta, orange, purple, red, violet, white, yellow</tt>.
-<P>
-<DT><b>COOR</b> <em>Coordinates</em> as pair of <b>east north</b>
-<P>
-</DD>
-<DT><B>font</B> command:
-<PRE>
-font
-    name   [T]
-    size   [#-]
-    color  (color)
-    extend [#]
-end
-</PRE>
-<DD>
-The name of the PostScript font. Fonts present in all PostScript implementations are:
-<tt>
-Times-Roman,
-Times-Italic,
-Times-Bold,
-Times-BoldItalic,
-Helvetica,
-Helvetica-Oblique,
-Helvetica-Bold,
-Helvetica-BoldOblique,
-Courier,
-Courier-Oblique,
-Courier-Bold,
-and
-Courier-BoldOblique
-</tt>.
-</DD><P>
-<DT><B>frame</B> command:
-<PRE>
-frame
-    where  [#- #-]
-    ref    [left|right|center upper|lower|center]
-    offset [# #]
-    border [#-]
-    color  (color)
-    fcolor (color)
-    margin [#-]
-end
-</PRE>
-<DT><B>line</B> command:
-<PRE>
-line
-    width [#-]
-    color (color)
-    style [solid|dashed|dotted|dashdotted|#...]
-    cap   [butt|round|extended_butt]
-end
-</PRE>
-</DL>
-<P>
-<H2>COMPOSE THE MAP</H2>
-<a name="paper"><h3>paper</h3></a> Specifies paper size, margins and orientation.
-<P><PRE>
-USAGE
-<B>paper</B> [paper type]: default A4
-    <B>height</B> [#-]
-    <B>width</B>  [#-]
-    <B>left</B>   [#-]: default 0.5inch
-    <B>right</B>  [#-]: default 0.5inch
-    <B>bottom</B> [#-]: default 1.0inch
-    <B>top</B>    [#-]: default 1.0inch
-    <B>landscape</B> [y|N]: default N
-    <B>draw</B>   (draw)
-    <B>font</B>   (font): set the default font
-<B>end</B>
-</PRE>
-<UL>
-<LI><em>paper types</em>: A0-6, B0-6, Executive, Folio, Ledger, Legal, Letter, Tabloid.</LI>
-<LI><em>left</em> and <em>top</em>: They are referenced to upper-left margin of the paper and they specify the position of the map area (i.e. grids growth outside this limits).
-<LI><em>draw</em>: This paints the features before any part of map. Usefull to draw logos, watermarks...</LI>
-</UL>
-<P><PRE>
-<i>EXAMPLE</i>
-paper A4
-    left 2cm
-    top 4cm
-    landscape y
-    font
-        name Univers
-        size 8
-    end
-end
-</PRE>
-This example set the size of paper to landscape A4 and Univers 8 point as defualt font.
-<P>
-<a name="scale"><h3>scale</h3></a>. Selects a scale for the output map.
-<PRE>
-USAGE
-<B>scale</B> 1:[#]
-</PRE>
-The scale is selected as a relative ratio, e.g. 1:25000. Use maparea to select a specific width of map.
-<PRE>
-<i>EXAMPLE</i>
-    scale 1:25000
-</PRE>
-<P>
-This example would set the scale of the map to 1 unit = 25000 units.
-<a name="maparea"><h3>maparea</h3></a>
-Position of the map area on the page.<BR>
-The upper left corner of the map will be positioned <EM>left</EM> units from the left edge of the page and <EM>top</EM> units from the top of the page. If <EM>width</EM> and <EM>height</EM> are present, the map will be rescaled, if necessary, to fit.
-<P>
-<PRE>
-USAGE
-<B>maparea</B>
-    <B>left</B>   [#-]
-    <B>top</B>    [#-]
-    <B>width</B>  [#-]
-    <B>border</B> [#-]
-    <B>color</B>  [color]
-    <B>fcolor</B> [color]
- <B>end</B>
-</PRE>
-<UL>
-<LI><em>border</em> and <em>color</em>: To control the which and color of the line is drawn around the map area.</LI>
-<LI><em>fcolor</em>: Fill map-area with color (or none), e.g. aqua to sea color.
-</LI>
-<P><PRE>
-<i>EXAMPLE</i>
-maparea
-    left 2cm
-    top 3.5cm
-    border 1mm
-    color black
-    fcolor none
-end
-</PRE>
-This example positions the upper left corner of the map 2.0 cm from the left edge and 3.5 cm from the top edge of the map. And draw a black border of 1 mm of width around the map area.
-<H2>ADDING COMPONENTS</H2>
-<h3>grid</h3>
-<a name="grid"></a>
-Overlays a coordinate grid onto the output map.
-<PRE>
-USAGE
-<B>grid</B>
-    <B>major</B>  [#] (line)
-    <B>minor</B>  [#] (line)
-    <B>cross</B>  [#]
-    <B>font</B>   [font]
-    <B>format</B> ['in', 'out', '+out' or 'iho']
-    <B>cutoff</B> [#]
- <B>end</B>
-</PRE>
-<table border=1 cellspacing=10>
-<td>
-<I>EXAMPLE</I>
-<PRE>
-grid
-    format in
-    major 1000
-        width .1mm
-        color gray
-        style 12
-    end
-    minor 200
-        width .05mm
-        color gray
-        style 12
-    end
-    font
-        name Univers
-        size 7
-        color white
-    end
-    fcolor black
-    cutoff 3
-end
-</PRE>
-</td>
-<td></td>
-<td><image src="ps.out_in.jpg"><br><br>format: in</td>
-<td><image src="ps.out_out.jpg"><br><br>format: out</td>
-<td><image src="ps.out_iho.jpg"><br><br>format: iho</td>
-<td><image src="ps.out_can.jpg"><br><br>format: can</td>
-</table>
-This example would overlay a gray grid with a spacing of 10000 meters (for a metered database, like UTM) onto the output map.  Alternate grid lines would be numbered with white numbers on black boxes.
-<h3>geogrid</h3>
-<a name="geogrid"></a>
-<PRE>
-USAGE
-<B>geogrid</B>
-    <B>format</B> ['in' or 'out' or '+out']
- <B>end</B>
-</PRE>
-<PRE>
-<I>EXAMPLE</I>
-geogrid
-    format out
-    major 30'
-        width .3
-        color magenta
-    end
-    minor 5'
-        width .1
-        color magenta
-        style 1
-    end
-    font
-        name Univers
-        size 5
-        color black
-        extend 1.2
-    end
-    fcolor none
-end
-</PRE>
-<H3>scalebar</H3>
-<a name="scalebar"></a>
-<PRE>
-<I>USAGE</I>
-<B>scalebar</B>   [scalebar type]
-    <B>length</B> [#]
-    <B>units</B>  [code T]
-    <B>major</B>  [# #], divisions and label separation
-    <B>minor</B>  [# #], divisions and label separation
-    <B>frame</B>  [frame]
-<B>end</B>
-</PRE>
-Scalebar types: I F f S s
-<PRE>
-<I>EXAMPLE</I>
-scalebar f
-    frame
-        where 50% 0%
-        offset 0 12
-        ref center upper
-        border 0.5mm
-        color black
-        fcolor gray
-    end
-    font
-        name Univers
-        size 8
-        color black
-    end
-    length 20
-    units km Kilometers
-    major 5 2
-    minor 2 2
-    height 2mm
-end
-</PRE>
-<h3>note</h3>
-<a name="note"></a>
-<PRE>
-USAGE
-<B>note</B> [code T]
-    <B>angle</B> [#] in degrees
-    <B>width</B> [#-]
- <B>end</B>
-</PRE>
-Note codes: :file (filename),
-    :maplim,
-    :dimen,
-    :scale (pre-text)
-    or simple text use '|' to break lines (max 1024 characters)
-<PRE>
-<I>EXAMPLE</I>
-note :scale scale
-    frame
-        where 0% 0%
-        offset -12 -4
-        ref left lower
-        border 0
-        fcolor none
-    end
-    angle 90
-    font
-        name Univers
-        size 6
-        extend 1.25
-        color gray
-    end
-end
-</PRE>
-<a name="palette"><h3>palette</h3></a>
-<a name="draw"><h3>draw</h3></a>
-<PRE>
-USAGE
-<B>draw</B> [free]
-    <b>direct</B> (T)
-    <B>color</B> (color)
-    <B>fcolor</B> (fill color)
-    <B>linewidth</B> line_width
-    <B>linedash</B> line_width
-    <B>font</B> name size [extend]
-    <B>[l,r,c,x,v,]text</B> east north label or -1 angle label
-    <B>textc</B> east north label
-    <B>labels</B> filename
-    <B>moveto</B> east north
-    <B>lineto</B> east north
-    <B>endline</B>
-    <B>line</B> east1 north1 east2 north2
-    <B>rectangle</B> east1 north1 east2 north2 [fillcolor]
-    <B>circle</B> east north radius
-    <B>arc</B> east1, noth1, diameter, east2, north2
-    <B>border</B> width
-    <B>psfile</B> scale east north filename
-    <B>maplimits</B>
-    <b>north</B> east north radius
-    <B>compass</B> east north radius
-    <B>rute</B> east north label
-<B>end</B>
-</PRE>
-<h2>ADDING RASTER MAPS</h2>
-<a name="raster"><H3>raster</H3></a>
-Selects a raster map for output.
-<PRE>
-<I>USAGE</I>
-<B>raster</B> [R|R R R], required: one raster, one group name (:name) or three raster (R G B)
-    <B>grey</B>      [y|N]. Output in shades of grey.
-    <B>maskcolor</B> [color]. Color to be used for mask.
-    <B>maskcell</B>  [R (R)]. Raster used as mask and optionally a raster for background.
-    <B>outline</B>   [line]. Specifications of outline.
-    <B>setcolor</B>  [CAT color]. Overrides the color of cat
-end
-</PRE>
-<PRE>
-<I>EXAMPLE</I>
-raster geology
-    grey n
-    maskcolor none
-    maskcell geo_mask elev_state_500m
-    outline
-        width .01
-        color black
-    end
-    setcolor 28 200:123:200
-end
-</PRE>
-<h2>ADDING VECTOR MAPS</h2>
-<a name="vareas"><H3>vareas</H3></a>
-Draw a vector of areas with optional pattern. Fill or pattern color can be fixed or reed from database.
-A line vector could be drawn as an area when lwidth is not zero (positive or negative).
-If label = "" not block title.
-<PRE>
-USAGE
-<B>vareas</B> [V]
-    <b>lwidth</b> [#-], default: 0 (area).
-    <b>line</b>   (line)
-    <b>fcolor</b> (color | RGBCOL$alpha [IDCOL])
-    <b>pat</b>    [TXT]. Pattern EPS file.
-    <b>pscale</b> [#]. Pattern scale.
-    <b>pwidth</b> [#]. Pattern line width.
-    <b>island</b> [Y|n]. Draw island as normal areas (fill as normal area then hide it).
-    <b>layer</b>  [#], default: 1. Layer number used with cats/where option
-    <b>cats</b>   [CAT]
-    <b>where</b>  [SQL]
-    <b>masked</b> [y|N]. Masked or not by raster mask
-    <b>label</b>  [TXT]. For description or title in vlegend
-    <b>lpos</b>   [# #]. Position where vector is plotted in legend and block
-    <b>setrule</b> [ID.CAT[:ID] TXT]. Set a label for the CAT.
-<b>end</b>
-</PRE>
-<a name="vlines"><H3>vlines</H3></a>
-Perhaps offset dont run well in Lat/Lon
-<PRE>
-USAGE
-<B>vlines</B> [V].
-    <b>type</b>   [line|boundary], default: line
-    <b>rgbcol</b> [T]. Column name with line color data
-    <b>hline</b>  (line)
-    <b>offset</b> [#-]. hline offset, default: 0.
-    <b>cats</b>   [CAT]
-    <b>masked</b> [y|N]. Masked by raster mask
-    <b>label</b>  [T]. For description in vlegend
-<b>end</b>
-</PRE>
-<PRE>
-<i>EXAMPLE</i>
-vlines railroads
-    type line
-    label Rail roads
-    line
-        width .4mm
-        color green
-    end
-    hline
-        width .1mm
-        color black
-    end
-    masked n
-end
-</PRE>
-<a name="vpoints"><H3>vpoints</H3></a>
-Draw a vector of points with a symbol.<br>
-A line vector could be drawn as a lines ...
-<PRE>
-USAGE
-<B>vpoints</B> [V].
-    <b>type</b>   [point|centroid|line|boundary], default: point
-    <b>symbol</b> [T]. Symbol standard or EPS file.
-    <b>fcolor</b> (color). Fillcolor
-    <b>size</b>   [# | SIZECOL #]. Size or size column (and legend size).
-    <b>scale</b>  [#- #-]. Scale and bias to rescale sizecol.
-    <b>rotate</b> [# | ROTATECOL]. Rotate or rotate column.
-    <b>dist</b>   [#-]. Distance between symbol on the cline
-    <b>offset</b> [#-]. Vertical offset of the symbol
-    <b>cline</B> (line). Conection line of the symbols
-    <b>cats</b>   [CAT]
-    <b>setrule</b> [SIZE.CAT[:ID] TXT]. Set a label for the CAT.
-<b>end</b>
-</PRE>
-<PRE>
-<i>EXAMPLE</i>
-vpoints precip_30ynormals
-    type centroid
-    symbol basic/circle
-    fcolor red
-    line
-        width .2
-        color black
-    end
-    size 10 ANNUAL
-    scale .01
-end
-</PRE>
-<a name="vlabels"><H3>vlabels</H3></a>
-<PRE>
-USAGE
-<B>vlabels</B> [V].
-    <b>labelcol</b> [T]
-    <b>font</b>  (font)
-    <b>decimals</b> [#]
-    <b>circled</b> [Y|n]
-    <b>layer</b>  [#]
-    <b>cats</b>   [CAT]
-    <b>label</b>  [T]
-    <b>lpos</b>   [#]
-<b>end</b>
-</PRE>
-<PRE>
-<i>EXAMPLE</i>
-vlabels railroads
-    labelcol cat
-    masked n
-end
-</PRE>
-<h2>ADDING LEGENDS</h2>
-<a name="rlegend"><H3>rlegend</H3></a>
-<PRE>
-USAGE
-<B>rlegend</B>
-    <b>raster</b>
-    <b>title</b>
-    <b>frame</b>
-    <b>font</b>
-    <b>cols</b>
-    <b>swidth</b>
-    <b>height</b>
-    <b>tick</b>
-    <b>order</b>
-    <b>whiteframe</b>
-    <b>gradient</b>
-<b>end</b>
-</PRE>
-<PRE>
-<i>EXAMPLE</i>
-rlegend
-    title Land Class 1996
-        name Univers Bold
-        size 12
-        extend 0.85
-        color black
-    end
-    raster landclass96
-    cols 1 0
-    frame
-        where 100% 100%
-        ref right upper
-        offset 0 0
-        border 2
-        color  black
-        fcolor white
-        margin 8
-    end
-    font
-        name Univers
-        size 9
-        color black
-    end
-    width 8mm
-    height 7cm
-    tick 3
-    whiteframe 1
-end
-</PRE>
-<a name="vlegend"><H3>vlegend</H3></a>
-<PRE>
-USAGE
-<B>vlegend</B> [T] Title of legend
-    <b>frame</b>
-    <b>title_font</b>
-    <b>font</b>
-    <b>cols</b>
-    <b>swidth</b>
-    <b>dy</b>
-<b>end</b>
-</PRE>
-<PRE>
-<i>EXAMPLE</i>
-vlegend
-    title .Leyenda
-        name Univers-Bold
-        size 10
-        extend 1.1
-    end
-    frame
-        where 100% 100%
-        ref left upper
-        offset 10 0
-        border 1
-    end
-    font
-        name Univers
-        size 9
-    end
-end
-</PRE>
-<a name="vlabel"><h3>vlabel</h3></a>
-<PRE>
-USAGE
-<B>vlabel</B> [code T]
-    <B>labelcol</B> [T]
-    <B>decimals</B> [#]
-    <b>cats</b>   [CAT]
-    <b>lpos</b>   [#]. Position vector is plotted in legend
-<B>end</B>
-</PRE>
-<H2>AUTHOR</H2>
-E. Jorge Tizado  (ej.tizado unileon es)<br>
-Dept. Biodiversity and Environmental Management, University of León, Spain<BR>
-<p>
-<i>Last changed: $Date: 2009/05/24 00:00:00 $</i>
-<HR>
-<P><a href="index.html">Main index</a> - <a href="postscript.html">postscript index</a> - <a href="full_index.html">Full index</a></P>
-<P>&copy; 2003-2010 <a href="http://grass.osgeo.org">GRASS Development Team</a></p>
-</body>
-</html>
Property changes on: grass-addons/postscript/ps.output/ps.out_can.jpg
Modified: svn:mime-type
   - application/octet-stream
   + image/jpeg
Property changes on: grass-addons/postscript/ps.output/ps.out_iho.jpg
   + image/jpeg
Property changes on: grass-addons/postscript/ps.output/ps.out_in.jpg
   + image/jpeg
Property changes on: grass-addons/postscript/ps.output/ps.out_out.jpg
   + image/jpeg
Property changes on: grass-addons/postscript/ps.output/ps3_map.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/ps_info.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/r_block.c
   + text/x-csrc
   + native
Property changes on: grass-addons/postscript/ps.output/r_draw.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_font.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_frame.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_grid.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_line.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_maparea.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_note.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_palette.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_paper.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_raster.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_rlegend.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_scalebar.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_vareas.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_vlabels.c
   + text/x-csrc
   + native
Property changes on: grass-addons/postscript/ps.output/r_vlegend.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_vlines.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/r_vpoints.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/raster.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/raster.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/rlegend.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/scalebar.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/scanners.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/set_draw.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/set_geogrid.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/set_grid.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/set_mask.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/set_note.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/set_outline.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/set_ps.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/set_raster.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/set_rlegend.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/set_scalebar.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/set_vareas.c
   + text/x-csrc
   + native
Property changes on: grass-addons/postscript/ps.output/set_vector.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/set_vlabels.c
   + text/x-csrc
   + native
Property changes on: grass-addons/postscript/ps.output/set_vlegend.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/set_vlines.c
   + text/x-csrc
   + native
Property changes on: grass-addons/postscript/ps.output/set_vpoints.c
   + text/x-csrc
   + native
Property changes on: grass-addons/postscript/ps.output/start_map.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/symbol.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/val_list.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/vareas.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/vector.c
   + text/x-csrc
Property changes on: grass-addons/postscript/ps.output/vector.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/vlabels.h
   + text/x-chdr
   + native
Property changes on: grass-addons/postscript/ps.output/vlegend.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/vlines.h
   + text/x-chdr
Property changes on: grass-addons/postscript/ps.output/vpoints.h
   + text/x-chdr
