[GRASS-SVN] r41681 - in grass-addons/raster: r.fuzzy r.fuzzy.logic r.fuzzy.system
Sat Apr 3 04:59:38 EDT 2010
Author: hamish
Date: 2010-04-03 04:59:38 -0400 (Sat, 03 Apr 2010)
New Revision: 41681
   grass-addons/raster/r.fuzzy.logic/local_proto.h
   grass-addons/raster/r.fuzzy.logic/logic.c
   grass-addons/raster/r.fuzzy.logic/main.c
   grass-addons/raster/r.fuzzy.system/fuzzylogic.c
   grass-addons/raster/r.fuzzy.system/helpers.c
   grass-addons/raster/r.fuzzy.system/io.c
   grass-addons/raster/r.fuzzy.system/local_proto.h
   grass-addons/raster/r.fuzzy.system/main.c
   grass-addons/raster/r.fuzzy.system/map_parser.c
   grass-addons/raster/r.fuzzy.system/rule_parser.c
   grass-addons/raster/r.fuzzy.system/system.c
   grass-addons/raster/r.fuzzy/fuzzy.c
   grass-addons/raster/r.fuzzy/local_proto.h
   grass-addons/raster/r.fuzzy/main.c
run grass_indent.sh
Modified: grass-addons/raster/r.fuzzy/fuzzy.c
--- grass-addons/raster/r.fuzzy/fuzzy.c	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy/fuzzy.c	2010-04-03 08:59:38 UTC (rev 41681)
@@ -1,52 +1,53 @@
 #include <grass/glocale.h>
 #include "local_proto.h"
-float fuzzy (FCELL cell) {
+float fuzzy(FCELL cell)
-	float x, m;
-	if (!side) { /* both left and right */
-			if (cell <= p[0] || cell >= p[3])
-		return 0.;
-			if (cell >= p[1] && cell <= p[2])
-		return 1.;
+    float x, m;
-		x = (cell<p[1]) ? (cell-p[0])/(p[1]-p[0])
-				: (p[3]-cell)/(p[3]-p[2]);
-	if (side) { /* left: 1 OR right: 2 */
+    if (!side) {		/* both left and right */
-			if (cell <= p[0])
-		return (side == 1) ? 0. : 1.;
-			if (cell >= p[1])
-		return (side == 1) ? 1. : 0.;
-		x = (side == 1) ? (cell-p[0])/(p[1]-p[0])
-				: (p[1]-cell)/(p[1]-p[0]);
+	if (cell <= p[0] || cell >= p[3])
+	    return 0.;
+	if (cell >= p[1] && cell <= p[2])
+	    return 1.;
-		if (type == LINEAR)
+	x = (cell < p[1]) ? (cell - p[0]) / (p[1] - p[0])
+	    : (p[3] - cell) / (p[3] - p[2]);
+    if (side) {			/* left: 1 OR right: 2 */
+	if (cell <= p[0])
+	    return (side == 1) ? 0. : 1.;
+	if (cell >= p[1])
+	    return (side == 1) ? 1. : 0.;
+	x = (side == 1) ? (cell - p[0]) / (p[1] - p[0])
+	    : (p[1] - cell) / (p[1] - p[0]);
+    if (type == LINEAR)
 	return x;
-		if (type == JSHAPE) {
-	m = (shape < 0) ? pow(2,1+shape)
-			: pow(2,exp(2*shape));
-	return pow(tan(x * PI4),m);
-		if (type == GSHAPE) {
-	m = (shape > 0) ? pow(2,1-shape)
-			: pow(2,exp(-2*shape));
-	return pow(tan(x * PI4),1/m);
-			if(type==SSHAPE) {
-		m =  pow(2,exp(2*abs(shape)));
-		return (shape < 0) ? pow(1-cos(x*PI2),m)
-			: pow(sin(x*PI2),m);
-return -1; /* error */
+    if (type == JSHAPE) {
+	m = (shape < 0) ? pow(2, 1 + shape)
+	    : pow(2, exp(2 * shape));
+	return pow(tan(x * PI4), m);
+    if (type == GSHAPE) {
+	m = (shape > 0) ? pow(2, 1 - shape)
+	    : pow(2, exp(-2 * shape));
+	return pow(tan(x * PI4), 1 / m);
+    if (type == SSHAPE) {
+	m = pow(2, exp(2 * abs(shape)));
+	return (shape < 0) ? pow(1 - cos(x * PI2), m)
+	    : pow(sin(x * PI2), m);
+    return -1;			/* error */
Modified: grass-addons/raster/r.fuzzy/local_proto.h
--- grass-addons/raster/r.fuzzy/local_proto.h	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy/local_proto.h	2010-04-03 08:59:38 UTC (rev 41681)
@@ -5,18 +5,18 @@
 #include <grass/gis.h>
-PI2= PI/2
-PI4= PI/4
+   PI2= PI/2
+   PI4= PI/4
 #ifndef PI2
-	#define PI2 (2*atan(1))
+#define PI2 (2*atan(1))
 #endif
 #ifndef PI4
-	#define PI4 (atan(1))
+#define PI4 (atan(1))
 #endif
 #define LINEAR 0
 #define SSHAPE 1
 #define JSHAPE 2
@@ -29,7 +29,7 @@
 char *input, *output;
 float shape, height;
 int type, side;
-double p[4]; /* inflection points */
+double p[4];			/* inflection points */
 int num_points;
-float fuzzy (FCELL cell);
+float fuzzy(FCELL cell);
Modified: grass-addons/raster/r.fuzzy/main.c
--- grass-addons/raster/r.fuzzy/main.c	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy/main.c	2010-04-03 08:59:38 UTC (rev 41681)
@@ -19,228 +19,227 @@
 int main(int argc, char *argv[])
-	struct GModule *module;
-	struct Option *par_input,
-								*par_output,
-								*par_points,
-								*par_side,
-								*par_type,
-								*par_height,
-								*par_shape;
-	struct Cell_head cellhd;
-  struct History history;
-	char *mapset;
-	int nrows, ncols;
-  int row, col;
-  int infd, outfd;
-  void *in_buf;
-	unsigned char *out_buf;
-  RASTER_MAP_TYPE raster_type;
-  FCELL tmp=0;
-	G_gisinit(argv[0]);
-	par_input = G_define_standard_option(G_OPT_R_INPUT);
-  par_input->description = _("Raster map to be fuzzified");
-  par_output = G_define_standard_option(G_OPT_R_OUTPUT);
-	par_output->description = _("Membership map");
-	par_points=G_define_option();
-	par_points->key = "points";
-	par_points->type = "TYPE_STRING";
-	par_points->answer = "a,b[,c,d]";
-	par_points->multiple = YES;
-	par_points->required = YES;
-	par_points->description = _("Inflection points: a,b[,c,d]");
-	par_side=G_define_option();
-	par_side->key = "side";
-	par_side->type = "TYPE_STRING";
-	par_side->options = "both,left,right";
-	par_side->answer = "both";
-	par_side->multiple = NO;
-	par_side->required = YES;
-	par_side->description = _("Fuzzy range");
-	par_type=G_define_option();
-	par_type->key = "boundary";
-	par_type->type = "TYPE_STRING";
-	par_type->options = "Linear,S-shaped,J-shaped,G-shaped";
-	par_type->answer = "S-shaped";
-	par_type->multiple = NO;
-	par_type->required = YES;
-	par_type->description = _("Type of fuzzy boundaries");
-	par_type->guisection = _("Default options");
-	par_shape=G_define_option();
-	par_shape->key = "shape";
-	par_shape->type = "TYPE_FLOAT";
-	par_shape->options = "-1 to 1";
-	par_shape->answer = "0.";
-	par_shape->multiple = NO;
-	par_shape->required = YES;
-	par_shape->description = _("Shape modifier: -1 to 1");
-	par_shape->guisection = _("Default options");
-	par_height=G_define_option();
-	par_height->key = "height";
-	par_height->type = "TYPE_FLOAT";
-	par_height->options = "0 to 1";
-	par_height->answer = "1";
-	par_height->multiple = NO;
-	par_height->required = YES;
-	par_height->description = _("Membership height: 0 to 1");
-	par_height->guisection = _("Default options");
-	    if (G_parser(argc, argv))
+    struct GModule *module;
+    struct Option *par_input,
+	*par_output,
+	*par_points, *par_side, *par_type, *par_height, *par_shape;
+    struct Cell_head cellhd;
+    struct History history;
+    char *mapset;
+    int nrows, ncols;
+    int row, col;
+    int infd, outfd;
+    void *in_buf;
+    unsigned char *out_buf;
+    RASTER_MAP_TYPE raster_type;
+    FCELL tmp = 0;
+    G_gisinit(argv[0]);
+    par_input = G_define_standard_option(G_OPT_R_INPUT);
+    par_input->description = _("Raster map to be fuzzified");
+    par_output = G_define_standard_option(G_OPT_R_OUTPUT);
+    par_output->description = _("Membership map");
+    par_points = G_define_option();
+    par_points->key = "points";
+    par_points->type = "TYPE_STRING";
+    par_points->answer = "a,b[,c,d]";
+    par_points->multiple = YES;
+    par_points->required = YES;
+    par_points->description = _("Inflection points: a,b[,c,d]");
+    par_side = G_define_option();
+    par_side->key = "side";
+    par_side->type = "TYPE_STRING";
+    par_side->options = "both,left,right";
+    par_side->answer = "both";
+    par_side->multiple = NO;
+    par_side->required = YES;
+    par_side->description = _("Fuzzy range");
+    par_type = G_define_option();
+    par_type->key = "boundary";
+    par_type->type = "TYPE_STRING";
+    par_type->options = "Linear,S-shaped,J-shaped,G-shaped";
+    par_type->answer = "S-shaped";
+    par_type->multiple = NO;
+    par_type->required = YES;
+    par_type->description = _("Type of fuzzy boundaries");
+    par_type->guisection = _("Default options");
+    par_shape = G_define_option();
+    par_shape->key = "shape";
+    par_shape->type = "TYPE_FLOAT";
+    par_shape->options = "-1 to 1";
+    par_shape->answer = "0.";
+    par_shape->multiple = NO;
+    par_shape->required = YES;
+    par_shape->description = _("Shape modifier: -1 to 1");
+    par_shape->guisection = _("Default options");
+    par_height = G_define_option();
+    par_height->key = "height";
+    par_height->type = "TYPE_FLOAT";
+    par_height->options = "0 to 1";
+    par_height->answer = "1";
+    par_height->multiple = NO;
+    par_height->required = YES;
+    par_height->description = _("Membership height: 0 to 1");
+    par_height->guisection = _("Default options");
+    if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-	input=par_input->answer;
-	output=par_output->answer;
-		if (!strcmp(par_type->answer, "Linear"))
-	type=LINEAR;
-		else if (!strcmp(par_type->answer, "S-shaped"))
-	type=SSHAPE;
-		else if (!strcmp(par_type->answer, "J-shaped"))
-	type=JSHAPE;
-		else if (!strcmp(par_type->answer, "G-shaped"))
-	type=GSHAPE;
-			if (!strcmp(par_side->answer, "both"))
-	side=BOTH;
-		else if (!strcmp(par_side->answer, "left"))
-	side=LEFT;
-		else if (!strcmp(par_side->answer, "right"))
-	side=RIGHT;
-	shape = atof(par_shape->answer);
-		if(shape<-1. || shape>1.)
+    input = par_input->answer;
+    output = par_output->answer;
+    if (!strcmp(par_type->answer, "Linear"))
+	type = LINEAR;
+    else if (!strcmp(par_type->answer, "S-shaped"))
+	type = SSHAPE;
+    else if (!strcmp(par_type->answer, "J-shaped"))
+	type = JSHAPE;
+    else if (!strcmp(par_type->answer, "G-shaped"))
+	type = GSHAPE;
+    if (!strcmp(par_side->answer, "both"))
+	side = BOTH;
+    else if (!strcmp(par_side->answer, "left"))
+	side = LEFT;
+    else if (!strcmp(par_side->answer, "right"))
+	side = RIGHT;
+    shape = atof(par_shape->answer);
+    if (shape < -1. || shape > 1.)
 	G_fatal_error(_("Shape modifier must be between -1 and 1"));
-	height = atof(par_height->answer);
-		if(height>1 || height<0)
+    height = atof(par_height->answer);
+    if (height > 1 || height < 0)
 	G_fatal_error(_("Heght modifier must be between 0 and 1"));
-	num_points=sscanf(par_points->answer,
-			"%lf,%lf,%lf,%lf",
-			&p[0], &p[1], &p[2], &p[3]);
-		if(!side && num_points != 4)
+    num_points = sscanf(par_points->answer,
+			"%lf,%lf,%lf,%lf", &p[0], &p[1], &p[2], &p[3]);
+    if (!side && num_points != 4)
 	G_fatal_error(_("Wrong number of values: got %d but need 4"),
 		      num_points);
-			if(side && num_points != 2)
+    if (side && num_points != 2)
 	G_fatal_error(_("Wrong number of values: got %d but need 2"),
 		      num_points);
-	if (num_points==2) {
-			if(	p[0]>p[1])
-		G_fatal_error(_("Point sequence must be: a <= b"));
-	} else {
-			if(	p[0]>p[1]
-			||p[1]>p[2]
-			||p[2]>p[3])
-		G_fatal_error(_("Point sequence must be: a <= b; b <= c; c <= d;"));
-	/* end of interface */
+    if (num_points == 2) {
+	if (p[0] > p[1])
+	    G_fatal_error(_("Point sequence must be: a <= b"));
+    else {
+	if (p[0] > p[1]
+	    || p[1] > p[2]
+	    || p[2] > p[3])
+	    G_fatal_error(_("Point sequence must be: a <= b; b <= c; c <= d;"));
-	mapset = G_find_cell2(input, "");
-	    if (mapset == NULL)
+    /* end of interface */
+    mapset = G_find_cell2(input, "");
+    if (mapset == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), input);
-	    if ((infd = G_open_cell_old(input, mapset)) < 0)
+    if ((infd = G_open_cell_old(input, mapset)) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), input);
-	    if (G_get_cellhd(input, mapset, &cellhd) < 0)
+    if (G_get_cellhd(input, mapset, &cellhd) < 0)
 	G_fatal_error(_("Unable to read file header of <%s>"), input);
-	nrows = G_window_rows();
-	ncols = G_window_cols();
-	raster_type = G_get_raster_map_type(infd);
-	   if ((outfd = G_open_raster_new(output, FCELL_TYPE)) < 0)
+    nrows = G_window_rows();
+    ncols = G_window_cols();
+    raster_type = G_get_raster_map_type(infd);
+    if ((outfd = G_open_raster_new(output, FCELL_TYPE)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), output);
-	in_buf = G_allocate_raster_buf(raster_type);
-	out_buf = G_allocate_raster_buf(FCELL_TYPE);
-	/* processing */
-	for (row = 0; row < nrows; row++) {
-		G_percent(row, nrows, 2);
-		CELL c;
-		FCELL f;
-		DCELL d;
-		if (G_get_raster_row(infd, in_buf, row, raster_type)<0) {
-			G_close_cell(infd);
-			G_fatal_error(_("Cannot to read <%s> at row <%d>"), input,row);
-		for (col = 0; col < ncols; col++) {
-			switch (raster_type) {
+    in_buf = G_allocate_raster_buf(raster_type);
+    out_buf = G_allocate_raster_buf(FCELL_TYPE);
-				case CELL_TYPE:
-			c = ((CELL *) in_buf)[col];
-				if(G_is_null_value(&c,CELL_TYPE))
-			G_set_f_null_value(&tmp, 1);
-				else {
-					if(0>(tmp = fuzzy ((FCELL) c)))
-			G_warning("Cannot determine memebership at row %d, col %d", row,col);
-			((FCELL *) out_buf)[col] = tmp;
-			break;
+    /* processing */
+    for (row = 0; row < nrows; row++) {
+	G_percent(row, nrows, 2);
+	CELL c;
+	FCELL f;
+	DCELL d;
-				case FCELL_TYPE:
-			f = ((FCELL *) in_buf)[col];
-				if(G_is_null_value(&f,FCELL_TYPE))
-				else {
-				tmp = fuzzy((FCELL) f);
-				if(0>(tmp = fuzzy((FCELL) f)))
-			break;
+	if (G_get_raster_row(infd, in_buf, row, raster_type) < 0) {
+	    G_close_cell(infd);
+	    G_fatal_error(_("Cannot to read <%s> at row <%d>"), input, row);
-				case DCELL_TYPE:
-			d = ((DCELL *) in_buf)[col];
-				if(G_is_null_value(&d,DCELL_TYPE))
-				else {
-				if(0>(tmp = fuzzy ((FCELL) d)))
-			break;
+	for (col = 0; col < ncols; col++) {
+	    switch (raster_type) {
+	    case CELL_TYPE:
+		c = ((CELL *) in_buf)[col];
+		if (G_is_null_value(&c, CELL_TYPE))
+		    G_set_f_null_value(&tmp, 1);
+		else {
+		    if (0 > (tmp = fuzzy((FCELL) c)))
+			G_warning
+			    ("Cannot determine memebership at row %d, col %d",
+			     row, col);
+		    ((FCELL *) out_buf)[col] = tmp;
-				if (G_put_raster_row(outfd, out_buf, FCELL_TYPE) < 0)
+		break;
+	    case FCELL_TYPE:
+		f = ((FCELL *) in_buf)[col];
+		if (G_is_null_value(&f, FCELL_TYPE))
+		else {
+		    tmp = fuzzy((FCELL) f);
+		    if (0 > (tmp = fuzzy((FCELL) f)))
+			G_warning
+			     row, col);
+		break;
+	    case DCELL_TYPE:
+		d = ((DCELL *) in_buf)[col];
+		if (G_is_null_value(&d, DCELL_TYPE))
+		else {
+		    if (0 > (tmp = fuzzy((FCELL) d)))
+			G_warning
+			     row, col);
+		break;
+	if (G_put_raster_row(outfd, out_buf, FCELL_TYPE) < 0)
 	    G_fatal_error(_("Failed writing raster map <%s>"), output);
-	} /* end for */
-  G_free(in_buf);
-  G_free(out_buf);
+    }				/* end for */
-	G_close_cell(outfd);
+    G_free(in_buf);
+    G_free(out_buf);
-	G_short_history(output, "raster", &history);
-	G_command_history(&history);
-	G_write_history(output, &history);
-	exit(EXIT_SUCCESS);
+    G_close_cell(outfd);
+    G_short_history(output, "raster", &history);
+    G_command_history(&history);
+    G_write_history(output, &history);
+    exit(EXIT_SUCCESS);
Modified: grass-addons/raster/r.fuzzy.logic/local_proto.h
--- grass-addons/raster/r.fuzzy.logic/local_proto.h	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy.logic/local_proto.h	2010-04-03 08:59:38 UTC (rev 41681)
@@ -11,7 +11,7 @@
 #define _IMP	4
 #define ZADEH 			1
-#define PRODUCT			2
+#define PRODUCT			2
 #define DRASTIC			3
 #define LUKASIEWICZ	4
 #define FODOR				5
@@ -25,4 +25,3 @@
 float f_or(float cellx, float celly, int family);
 float f_imp(float cellx, float celly, int family);
 float f_not(float cellx, int family);
Modified: grass-addons/raster/r.fuzzy.logic/logic.c
--- grass-addons/raster/r.fuzzy.logic/logic.c	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy.logic/logic.c	2010-04-03 08:59:38 UTC (rev 41681)
@@ -2,104 +2,107 @@
-float f_and(float x, float y, int family) {
+float f_and(float x, float y, int family)
-	switch (family) {
-			case ZADEH:
-		return MIN(x,y);
-			break;
-			case PRODUCT:
-		return x*y;
-			break;
-			case DRASTIC:
-		return MAX(x, y) == 1 ? MIN(x, y) : 0;
-			break;
-			case LUKASIEWICZ:
-		return MAX((x+y-1),0);
-			break;
-			case FODOR:
-		return (x+y)>1 ? MIN(x,y) : 0;
-			break;
-			case HAMACHER:
-		return (x==y==0) ? 0 : (x*y)/((x+y)-x*y);
-			break;
+    switch (family) {
-	return -1; /* error */
+    case ZADEH:
+	return MIN(x, y);
+	break;
-float f_or(float x, float y, int family) {
-			float b;
-	switch (family) {
-			case ZADEH:
-		return MAX(x,y);
-			break;
-			case PRODUCT:
-		return x + y -x * y;
-			break;
-			case DRASTIC:
-		return (MIN(x, y) == 0) ? MAX(x, y) : 1;
-			break;
-			case LUKASIEWICZ:
-		return MIN((x+y),1);
-			break;
-			case FODOR:
-		return (x+y<1) ? MAX(x,y) : 1;
-			break;
-			case HAMACHER:
-		return (x+y)/(1+x*y);
-			break;
+    case PRODUCT:
+	return x * y;
+	break;
+    case DRASTIC:
+	return MAX(x, y) == 1 ? MIN(x, y) : 0;
+	break;
+    case LUKASIEWICZ:
+	return MAX((x + y - 1), 0);
+	break;
+    case FODOR:
+	return (x + y) > 1 ? MIN(x, y) : 0;
+	break;
+    case HAMACHER:
+	return (x == y == 0) ? 0 : (x * y) / ((x + y) - x * y);
+	break;
-float f_imp(float x, float y, int family) {
-	switch (family) {
-			case ZADEH:
-		return (x <= y) ? 1 : y;
-			break;
+float f_or(float x, float y, int family)
+    float b;
-			case PRODUCT:
-		return MIN(y/x,1);
-			break;
-			case DRASTIC:
-		return -1; /* not avaialble */
-			break;
-			case LUKASIEWICZ:
-		return MIN((1-x+y),1);
-			break;
-			case FODOR:
-		return (x<=y) ? 1 : MAX(1-x,y);
-			break;
+    switch (family) {
+    case ZADEH:
+	return MAX(x, y);
+	break;
+    case PRODUCT:
+	return x + y - x * y;
+	break;
+    case DRASTIC:
+	return (MIN(x, y) == 0) ? MAX(x, y) : 1;
+	break;
+    case LUKASIEWICZ:
+	return MIN((x + y), 1);
+	break;
+    case FODOR:
+	return (x + y < 1) ? MAX(x, y) : 1;
+	break;
+    case HAMACHER:
+	return (x + y) / (1 + x * y);
+	break;
-float f_not(float x, int family) {
-		if (family==HAMACHER)
-	return (1-x)/(1+x);
-		else
-	return ((1-x)<0 || (1-x)>1) ? -1 : 1-x;
+float f_imp(float x, float y, int family)
+    switch (family) {
+    case ZADEH:
+	return (x <= y) ? 1 : y;
+	break;
+    case PRODUCT:
+	return MIN(y / x, 1);
+	break;
+    case DRASTIC:
+	return -1;		/* not avaialble */
+	break;
+    case LUKASIEWICZ:
+	return MIN((1 - x + y), 1);
+	break;
+    case FODOR:
+	return (x <= y) ? 1 : MAX(1 - x, y);
+	break;
+float f_not(float x, int family)
+    if (family == HAMACHER)
+	return (1 - x) / (1 + x);
+    else
+	return ((1 - x) < 0 || (1 - x) > 1) ? -1 : 1 - x;
Modified: grass-addons/raster/r.fuzzy.logic/main.c
--- grass-addons/raster/r.fuzzy.logic/main.c	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy.logic/main.c	2010-04-03 08:59:38 UTC (rev 41681)
@@ -3,7 +3,7 @@
  * MODULE:       r.fuzzy.logic
  * AUTHOR(S):    Jarek Jasiewicz <jarekj amu.edu.pl>
  * PURPOSE:      Peroforms logical operatations on membership images created with
- * 							 r.fuzzy or dofferent method. Use families for fuzzy logic
+ *                                                       r.fuzzy or dofferent method. Use families for fuzzy logic
  * COPYRIGHT:    (C) 1999-2010 by the GRASS Development Team
  *               This program is free software under the GNU General Public
@@ -21,232 +21,237 @@
-	struct Option *par_inputx,
-								*par_inputy,
-								*par_output,
-								*par_operation,
-								*par_family;
-	struct Cell_head cellhdx;
-	struct Cell_head cellhdy;
-  struct Range membership_range;
+    struct Option *par_inputx,
+	*par_inputy, *par_output, *par_operation, *par_family;
-	char *mapsetx, *mapsety;
-	char *inputx, *inputy;
-	char *output;
-	int nrows, ncols;
-	int row, col;
-	int infdx, infdy, outfd;
-	void *in_bufx, *in_bufy;
-	float tmp;
-	FCELL c_min, c_max;
-	int family, operator;
-	par_inputx = G_define_standard_option(G_OPT_R_INPUT);
-  par_inputx->description = _("x operand (membership map)");
-  par_inputx->key = "xmap";
-  par_inputy = G_define_standard_option(G_OPT_R_INPUT);
-  par_inputy->description = _("y operand (membership map)");
-  par_inputy->key = "ymap";
-  par_inputy->required = NO;
-	par_output->description = _("Resulting map");
+    struct Cell_head cellhdx;
+    struct Cell_head cellhdy;
+    struct Range membership_range;
-	par_operation=G_define_option();
-	par_operation->key = "operator";
-	par_operation->type = "TYPE_STRING";
-	par_operation->options = "AND,OR,NOT,IMP";
-	par_operation->answer = "AND";
-	par_operation->multiple = NO;
-	par_operation->required = YES;
-	par_operation->description = _("Fuzzy logic operation");
-	par_family=G_define_option();
-	par_family->key = "family";
-	par_family->type = "TYPE_STRING";
-	par_family->options = "Zadeh,product,drastic,Lukasiewicz,Fodor,Hamacher";
-	par_family->answer = "Zadeh";
-	par_family->multiple = NO;
-	par_family->required = YES;
-	par_family->description = _("Fuzzy logic family");
+    char *mapsetx, *mapsety;
+    char *inputx, *inputy;
+    char *output;
+    int nrows, ncols;
+    int row, col;
+    int infdx, infdy, outfd;
+    void *in_bufx, *in_bufy;
+    float tmp;
+    FCELL c_min, c_max;
+    int family, operator;
+    par_inputx = G_define_standard_option(G_OPT_R_INPUT);
+    par_inputx->description = _("x operand (membership map)");
+    par_inputx->key = "xmap";
+    par_inputy = G_define_standard_option(G_OPT_R_INPUT);
+    par_inputy->description = _("y operand (membership map)");
+    par_inputy->key = "ymap";
+    par_inputy->required = NO;
+    par_output->description = _("Resulting map");
+    par_operation = G_define_option();
+    par_operation->key = "operator";
+    par_operation->type = "TYPE_STRING";
+    par_operation->options = "AND,OR,NOT,IMP";
+    par_operation->answer = "AND";
+    par_operation->multiple = NO;
+    par_operation->required = YES;
+    par_operation->description = _("Fuzzy logic operation");
+    par_family = G_define_option();
+    par_family->key = "family";
+    par_family->type = "TYPE_STRING";
+    par_family->options = "Zadeh,product,drastic,Lukasiewicz,Fodor,Hamacher";
+    par_family->answer = "Zadeh";
+    par_family->multiple = NO;
+    par_family->required = YES;
+    par_family->description = _("Fuzzy logic family");
 	exit(EXIT_FAILURE);
-	inputx=par_inputx->answer;
-	inputy=par_inputy->answer;
-			if (!strcmp(par_operation->answer, "AND"))
-	operator=_AND;
-		else if (!strcmp(par_operation->answer, "OR"))
-	operator=_OR;
-		else if (!strcmp(par_operation->answer, "NOT"))
-	operator=_NOT;
-		else if (!strcmp(par_operation->answer, "IMP"))
-	operator=_IMP;
-  		if (!strcmp(par_family->answer, "Zadeh"))
-	family=ZADEH;
-		else if (!strcmp(par_family->answer, "product"))
-	family=PRODUCT;
-		else if (!strcmp(par_family->answer, "drastic"))
-	family=DRASTIC;
-		else if (!strcmp(par_family->answer, "Lukasiewicz"))
-	family=LUKASIEWICZ;
-		else if (!strcmp(par_family->answer, "Fodor"))
-	family=FODOR;
-			else if (!strcmp(par_family->answer, "Hamacher"))
-	family=HAMACHER;
-		if(operator == _NOT && inputy)
+    inputx = par_inputx->answer;
+    inputy = par_inputy->answer;
+    if (!strcmp(par_operation->answer, "AND"))
+	operator= _AND;
+    else if (!strcmp(par_operation->answer, "OR"))
+	operator= _OR;
+    else if (!strcmp(par_operation->answer, "NOT"))
+	operator= _NOT;
+    else if (!strcmp(par_operation->answer, "IMP"))
+	operator= _IMP;
+    if (!strcmp(par_family->answer, "Zadeh"))
+	family = ZADEH;
+    else if (!strcmp(par_family->answer, "product"))
+	family = PRODUCT;
+    else if (!strcmp(par_family->answer, "drastic"))
+	family = DRASTIC;
+    else if (!strcmp(par_family->answer, "Lukasiewicz"))
+	family = LUKASIEWICZ;
+    else if (!strcmp(par_family->answer, "Fodor"))
+	family = FODOR;
+    else if (!strcmp(par_family->answer, "Hamacher"))
+	family = HAMACHER;
+    if (operator == _NOT && inputy)
 	G_warning("Negation is unary operaton ymap is ignored");
-		if(operator != _NOT && !inputy)
+    if (operator != _NOT && !inputy)
 	G_fatal_error("For binary operation (AND, OR, IMP) ymap is required");
-		if(family == DRASTIC && operator == _IMP)
-  G_fatal_error("implication is not available for <drastic> family");
-	mapsetx = G_find_cell2(inputx, "");
-	  if (mapsetx == NULL)
+    if (family == DRASTIC && operator == _IMP)
+	G_fatal_error("implication is not available for <drastic> family");
+    mapsetx = G_find_cell2(inputx, "");
+    if (mapsetx == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), inputx);
-	  if ((infdx = G_open_cell_old(inputx, mapsetx)) < 0)
+    if ((infdx = G_open_cell_old(inputx, mapsetx)) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), inputx);
-	  if (G_get_cellhd(inputx, mapsetx, &cellhdx) < 0)
+    if (G_get_cellhd(inputx, mapsetx, &cellhdx) < 0)
 	G_fatal_error(_("Unable to read file header of <%s>"), inputx);
-		if (G_raster_map_type(inputx, mapsetx) != FCELL_TYPE)
-	 G_fatal_error(_("<%s> is not of type CELL"), inputx);
-	G_init_fp_range(&membership_range);
-	G_read_fp_range(inputx,mapsetx,&membership_range);
-	G_get_fp_range_min_max(&membership_range, &c_min, &c_max);
-		if(c_min<0 || c_max>1)
+    if (G_raster_map_type(inputx, mapsetx) != FCELL_TYPE)
+	G_fatal_error(_("<%s> is not of type CELL"), inputx);
+    G_init_fp_range(&membership_range);
+    G_read_fp_range(inputx, mapsetx, &membership_range);
+    G_get_fp_range_min_max(&membership_range, &c_min, &c_max);
+    if (c_min < 0 || c_max > 1)
 	G_fatal_error("Membership out of range");
-	in_bufx = G_allocate_raster_buf(FCELL_TYPE);
-		if(inputy) {
+    in_bufx = G_allocate_raster_buf(FCELL_TYPE);
+    if (inputy) {
 	mapsety = G_find_cell2(inputy, "");
-	  if (mapsety == NULL)
-	G_fatal_error(_("Raster map <%s> not found"), inputy);
-	  if ((infdy = G_open_cell_old(inputy, mapsety)) < 0)
-	G_fatal_error(_("Unable to open raster map <%s>"), inputy);
-	  if (G_get_cellhd(inputy, mapsety, &cellhdy) < 0)
-	G_fatal_error(_("Unable to read file header of <%s>"), inputy);
-		if (G_raster_map_type(inputy, mapsety) != FCELL_TYPE)
-	G_fatal_error(_("<%s> is not of type CELL"), inputy);
+	if (mapsety == NULL)
+	    G_fatal_error(_("Raster map <%s> not found"), inputy);
+	if ((infdy = G_open_cell_old(inputy, mapsety)) < 0)
+	    G_fatal_error(_("Unable to open raster map <%s>"), inputy);
+	if (G_get_cellhd(inputy, mapsety, &cellhdy) < 0)
+	    G_fatal_error(_("Unable to read file header of <%s>"), inputy);
+	if (G_raster_map_type(inputy, mapsety) != FCELL_TYPE)
+	    G_fatal_error(_("<%s> is not of type CELL"), inputy);
-	G_read_fp_range(inputy,mapsety,&membership_range);
+	G_read_fp_range(inputy, mapsety, &membership_range);
-	G_fatal_error("Membership out of range");
+	    G_fatal_error("Membership out of range");
 	in_bufy = G_allocate_raster_buf(FCELL_TYPE);
-		} /* end if inputy */
+    }				/* end if inputy */
-	/* binary processing */
-		FCELL fx, fy=0;
-		if (G_get_raster_row(infdx, in_bufx, row, FCELL_TYPE)<0) {
-			G_close_cell(infdx);
-			G_fatal_error(_("Cannot to read <%s> at row <%d>"), inputx,row);
-			if(inputy)
-		if (G_get_raster_row(infdy, in_bufy, row, FCELL_TYPE)<0) {
-			G_close_cell(infdy);
-			G_fatal_error(_("Cannot to read <%s> at row <%d>"), inputy,row);
-				fx = ((FCELL *) in_bufx)[col];
-					if(inputy)
-				fy = ((FCELL *) in_bufy)[col];
-				 if (G_is_f_null_value(&fx) || G_is_f_null_value(&fy))
-				 else
-			switch (operator) {
-				case _AND:
-					//if((row+col)%100==0)
-						if(0>(tmp = f_and(fx,fy,family)))
-					G_warning("Cannot determine result at row %d, col %d", row,col);
-					break;
-				case _OR:
-						if(0>(tmp=f_or(fx,fy,family)))
-					break;
-				case _IMP:
-						if((tmp=f_imp(fx,fy,family))<0)
-					break;
-				case _NOT:
-						if((tmp=f_not(fx, family))<0)
-					break;
-			} /* end switch */
-	   G_fatal_error(_("Failed writing raster map <%s>"), output);
-	} /* end for row */
-  G_free(in_bufx);
-		if(inputy) {
-  G_free(in_bufy);
+    /* binary processing */
+	FCELL fx, fy = 0;
+	if (G_get_raster_row(infdx, in_bufx, row, FCELL_TYPE) < 0) {
+	    G_close_cell(infdx);
+	    G_fatal_error(_("Cannot to read <%s> at row <%d>"), inputx, row);
-	G_free(out_buf);
+	if (inputy)
+	    if (G_get_raster_row(infdy, in_bufy, row, FCELL_TYPE) < 0) {
+		G_close_cell(infdy);
+		G_fatal_error(_("Cannot to read <%s> at row <%d>"), inputy,
+			      row);
+	    fx = ((FCELL *) in_bufx)[col];
+	    if (inputy)
+		fy = ((FCELL *) in_bufy)[col];
+	    if (G_is_f_null_value(&fx) || G_is_f_null_value(&fy))
+	    else
+		switch (operator) {
+		case _AND:
+		    //if((row+col)%100==0)
+		    if (0 > (tmp = f_and(fx, fy, family)))
+			G_warning("Cannot determine result at row %d, col %d",
+				  row, col);
+		    break;
+		case _OR:
+		    if (0 > (tmp = f_or(fx, fy, family)))
+				  row, col);
+		    break;
+		case _IMP:
+		    if ((tmp = f_imp(fx, fy, family)) < 0)
+				  row, col);
+		    break;
+		case _NOT:
+		    if ((tmp = f_not(fx, family)) < 0)
+				  row, col);
+		    break;
+		}		/* end switch */
+	    G_fatal_error(_("Failed writing raster map <%s>"), output);
+    }				/* end for row */
+    G_free(in_bufx);
+    if (inputy) {
+	G_free(in_bufy);
+    G_free(out_buf);
Modified: grass-addons/raster/r.fuzzy.system/fuzzylogic.c
--- grass-addons/raster/r.fuzzy.system/fuzzylogic.c	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy.system/fuzzylogic.c	2010-04-03 08:59:38 UTC (rev 41681)
@@ -1,118 +1,136 @@
-float fuzzy(FCELL cell, SETS* set) {
+float fuzzy(FCELL cell, SETS * set)
-	float x;
-	if (!set->side) { /* both left and right */
-			if (cell <= set->points[0] || cell >= set->points[3])
-		return 0.;
-			if (cell >= set->points[1] && cell <= set->points[2])
-		return 1.;
+    float x;
-		x = (cell < set->points[1]) ? (cell - set->points[0])/(set->points[1] - set->points[0])
-				: (set->points[3] - cell)/(set->points[3] - set->points[2]);
-	if (set->side) { /* left: 1 OR right: 2 */
+    if (!set->side) {		/* both left and right */
-			if (cell <= set->points[0])
-		return (set->side == 1) ? 0. : 1.;
-			if (cell >= set->points[1])
-		return (set->side == 1) ? 1. : 0.;
-		x = (set->side == s_LEFT) ? (cell - set->points[0])/(set->points[1] - set->points[0])
-				: (set->points[1] - cell)/(set->points[1]-set->points[0]);
+	if (cell <= set->points[0] || cell >= set->points[3])
+	    return 0.;
+	if (cell >= set->points[1] && cell <= set->points[2])
+	    return 1.;
-		switch (set->shape) {
-			case s_LINEAR: break;
-			case s_SSHAPE: x= pow(sin(x*PI2),2); break;
-			case s_JSHAPE: x= pow(tan(x * PI4),2); break;
-			case s_GSHAPE: x= pow(tan(x * PI4),1/2.); break;
-		if(set->hedge)
-	x= (set->hedge>0)	? pow(x,pow(2,set->hedge)) : pow(x,pow(0.5,(-set->hedge)));
+	x = (cell <
+	     set->points[1]) ? (cell - set->points[0]) / (set->points[1] -
+							  set->points[0])
+	    : (set->points[3] - cell) / (set->points[3] - set->points[2]);
-		if(set->height<1)
-	x= x * set->height;
+    if (set->side) {		/* left: 1 OR right: 2 */
-return (x>=0 && x<=1) ? x : -1;
+	if (cell <= set->points[0])
+	    return (set->side == 1) ? 0. : 1.;
+	if (cell >= set->points[1])
+	    return (set->side == 1) ? 1. : 0.;
+	x = (set->side ==
+	     s_LEFT) ? (cell - set->points[0]) / (set->points[1] -
+						  set->points[0])
+	    : (set->points[1] - cell) / (set->points[1] - set->points[0]);
+    switch (set->shape) {
+    case s_LINEAR:
+	break;
+    case s_SSHAPE:
+	x = pow(sin(x * PI2), 2);
+	break;
+    case s_JSHAPE:
+	x = pow(tan(x * PI4), 2);
+	break;
+    case s_GSHAPE:
+	x = pow(tan(x * PI4), 1 / 2.);
+	break;
+    if (set->hedge)
+	x = (set->hedge > 0) ? pow(x, pow(2, set->hedge)) : pow(x,
+								pow(0.5,
+								    (-set->
+								     hedge)));
+    if (set->height < 1)
+	x = x * set->height;
+    return (x >= 0 && x <= 1) ? x : -1;
-	switch (family) {
-			case l_ZADEH:
-		return MIN(x,y);
-			break;
-			case l_PRODUCT:
-		return x*y;
-			break;
-			case l_DRASTIC:
-			break;
-			case l_LUKASIEWICZ:
-			break;
-			case l_FODOR:
-			break;
-			case l_HAMACHER:
-			break;
+    switch (family) {
+    case l_ZADEH:
+	return MIN(x, y);
+	break;
+    case l_PRODUCT:
+	return x * y;
+	break;
+    case l_DRASTIC:
+	break;
+    case l_LUKASIEWICZ:
+	break;
+    case l_FODOR:
+	break;
+    case l_HAMACHER:
+	break;
-			float b;
-	switch (family) {
-			case l_ZADEH:
-		return MAX(x,y);
-			break;
-			case l_PRODUCT:
-			break;
-			case l_DRASTIC:
-			break;
-			break;
-			case l_FODOR:
-			break;
-			case l_HAMACHER:
-			break;
+    float b;
+    switch (family) {
+    case l_ZADEH:
+	return MAX(x, y);
+	break;
+    case l_PRODUCT:
+	break;
+    case l_DRASTIC:
+	break;
+	break;
+    case l_FODOR:
+	break;
+    case l_HAMACHER:
+	break;
-		if (family==l_HAMACHER)
-		else
+    if (family == l_HAMACHER)
+    else
Modified: grass-addons/raster/r.fuzzy.system/helpers.c
--- grass-addons/raster/r.fuzzy.system/helpers.c	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy.system/helpers.c	2010-04-03 08:59:38 UTC (rev 41681)
@@ -1,81 +1,85 @@
-int get_nsets(FILE* fd, fpos_t position) {
-	int nsets=0;
-	fsetpos (fd, &position);
-	char buf[500];
+int get_nsets(FILE * fd, fpos_t position)
-	fgetpos (fd, &position);
+    int nsets = 0;
-	while (fgets(buf, sizeof buf, fd)) {
-			G_strip(buf);
+    fsetpos(fd, &position);
+    char buf[500];
-			if (*buf == '#' || *buf == 0 || *buf=='\n')
-		continue;
-			if (*buf == '$')
-		nsets++;
-			if (*buf == '%')
-		break;
-	return nsets;
+    fgetpos(fd, &position);
+    while (fgets(buf, sizeof buf, fd)) {
+	G_strip(buf);
+	if (*buf == '#' || *buf == 0 || *buf == '\n')
+	    continue;
+	if (*buf == '$')
+	    nsets++;
+	if (*buf == '%')
+	    break;
+    return nsets;
 int char_strip(char *buf, char rem)
-	register char *a, *b;
-		for (a = b = buf; *a == rem || *a == ' ' || *a == ' \t'; a++) ;
-			if (a != b)
+    register char *a, *b;
+    for (a = b = buf; *a == rem || *a == ' ' || *a == ' \t'; a++) ;
+    if (a != b)
 	while ((*b++ = *a++)) ;
-  return 0;
+    return 0;
 int char_copy(const char *buf, char *res, int start, int stop)
-	register int i,j;
-		for(i=start,j=0;i<stop;res[j++] = buf[i++]);
-			res[j]='\0';
+    register int i, j;
-  return 0;
+    for (i = start, j = 0; i < stop; res[j++] = buf[i++]) ;
+    res[j] = '\0';
+    return 0;
-int get_universe (void) {
-	int i,j;
-	float min=100000000., max=0;
+int get_universe(void)
+    int i, j;
+    float min = 100000000., max = 0;
-	resolution +=1;
-			for (i=0;i<nmaps;++i) {
-		if (s_maps[i].output)
-			break;
-	output_index=i;
-		for (j=0;j<s_maps[i].nsets;++j) {
-	min = (s_maps[i].sets[j].points[0]<min) ?
-		s_maps[i].sets[j].points[0] : min;
-		if (s_maps[i].sets[j].side)
-	max = (s_maps[i].sets[j].points[1]>max) ?
-		s_maps[i].sets[j].points[1] : max;
-		else
-	max = (s_maps[i].sets[j].points[3]>max) ?
-	s_maps[i].sets[j].points[3] : max;
-	 	universe =(float*) G_calloc(resolution, sizeof(float));
-		for (i=0;i<resolution;++i)
-	universe[i]= min + ((max-min)/resolution) * i;
+    resolution += 1;
-	return 0;
+    for (i = 0; i < nmaps; ++i) {
+	if (s_maps[i].output)
+	    break;
+    output_index = i;
+    for (j = 0; j < s_maps[i].nsets; ++j) {
+	min = (s_maps[i].sets[j].points[0] < min) ?
+	    s_maps[i].sets[j].points[0] : min;
+	if (s_maps[i].sets[j].side)
+	    max = (s_maps[i].sets[j].points[1] > max) ?
+		s_maps[i].sets[j].points[1] : max;
+	else
+	    max = (s_maps[i].sets[j].points[3] > max) ?
+		s_maps[i].sets[j].points[3] : max;
+    universe = (float *)G_calloc(resolution, sizeof(float));
+    for (i = 0; i < resolution; ++i)
+	universe[i] = min + ((max - min) / resolution) * i;
+    return 0;
Modified: grass-addons/raster/r.fuzzy.system/io.c
--- grass-addons/raster/r.fuzzy.system/io.c	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy.system/io.c	2010-04-03 08:59:38 UTC (rev 41681)
@@ -1,156 +1,170 @@
-int open_maps(void) {
-	int i;
-	char* mapset;
-			if (s_maps[i].output) {
-		s_maps[i].in_buf=NULL;
-		continue;
-		mapset = G_find_cell2(s_maps[i].name, "");
-		G_fatal_error(_("Raster map <%s> not found"), s_maps[i].name);
-	    if ((s_maps[i].cfd = G_open_cell_old(s_maps[i].name, mapset)) < 0)
-		G_fatal_error(_("Unable to open raster map <%s>"), s_maps[i].name);
-	    if (G_get_cellhd(s_maps[i].name, mapset, &cellhd) < 0)
-		G_fatal_error(_("Unable to read file header of <%s>"), s_maps[i].name);
-		s_maps[i].raster_type = G_get_raster_map_type(s_maps[i].cfd);
-		s_maps[i].in_buf = G_allocate_raster_buf(s_maps[i].raster_type);
+int open_maps(void)
+    int i;
+    char *mapset;
+	if (s_maps[i].output) {
+	    s_maps[i].in_buf = NULL;
+	    continue;
-return 0;
+	mapset = G_find_cell2(s_maps[i].name, "");
+	    G_fatal_error(_("Raster map <%s> not found"), s_maps[i].name);
+	if ((s_maps[i].cfd = G_open_cell_old(s_maps[i].name, mapset)) < 0)
+			  s_maps[i].name);
+	if (G_get_cellhd(s_maps[i].name, mapset, &cellhd) < 0)
+			  s_maps[i].name);
+	s_maps[i].raster_type = G_get_raster_map_type(s_maps[i].cfd);
+	s_maps[i].in_buf = G_allocate_raster_buf(s_maps[i].raster_type);
+    return 0;
-int get_rows (int row) {
-	int i;
+int get_rows(int row)
-		continue;
+    int i;
-		if (G_get_raster_row(s_maps[i].cfd, s_maps[i].in_buf, row, s_maps[i].raster_type)<0) {
-			G_close_cell(s_maps[i].cfd);
-			G_fatal_error(_("Cannot to read <%s> at row <%d>"), s_maps[i].name,row);
+	    continue;
+	    (s_maps[i].cfd, s_maps[i].in_buf, row,
+	     s_maps[i].raster_type) < 0) {
+	    G_close_cell(s_maps[i].cfd);
+			  s_maps[i].name, row);
-return 0;
+    return 0;
-int get_cells (int col) {
-	int i;
-	CELL c;
-	FCELL f;
-	DCELL d;
+int get_cells(int col)
+    int i;
+    CELL c;
+    FCELL f;
+    DCELL d;
-		continue;
-			switch (s_maps[i].raster_type) {
-				case CELL_TYPE:
-				c = ((CELL *) s_maps[i].in_buf)[col];
-					if (G_is_null_value(&c,CELL_TYPE))
-				return 1;
-					else
-				s_maps[i].cell = (FCELL) c;
-					break;
+	    continue;
-				case FCELL_TYPE:
-				f = ((FCELL *) s_maps[i].in_buf)[col];
-					if (G_is_null_value(&f,FCELL_TYPE))
-				return 1;
-					else
-				s_maps[i].cell =  (FCELL) f;
-			break;
+	switch (s_maps[i].raster_type) {
-				case DCELL_TYPE:
-			d = ((DCELL *) s_maps[i].in_buf)[col];
-					if (G_is_null_value(&d,DCELL_TYPE))
-				return 1;
-					else
-				s_maps[i].cell =  (FCELL) d;
-			break;
-		} /* end for */
+	case CELL_TYPE:
+	    c = ((CELL *) s_maps[i].in_buf)[col];
+		return 1;
+	    else
+		s_maps[i].cell = (FCELL) c;
+	    break;
-return 0;
+	case FCELL_TYPE:
+	    f = ((FCELL *) s_maps[i].in_buf)[col];
+		return 1;
+	    else
+		s_maps[i].cell = (FCELL) f;
+	    break;
+	case DCELL_TYPE:
+	    d = ((DCELL *) s_maps[i].in_buf)[col];
+		return 1;
+	    else
+		s_maps[i].cell = (FCELL) d;
+	    break;
+    }				/* end for */
+    return 0;
-int create_output_maps(void) {
-	STRING connector="_";
-	int i;
-	m_outputs = (OUTPUTS* )G_malloc(nrules * sizeof (OUTPUTS));
+int create_output_maps(void)
-	for (i=0;i<nrules;++i) {
-		strcpy(m_outputs[i].output_name,output);
-		strcat(m_outputs[i].output_name,connector);
-		strcat(m_outputs[i].output_name,s_rules[i].outname);
-			if ((m_outputs[i].ofd = G_open_raster_new(m_outputs[i].output_name, FCELL_TYPE)) < 0)
-		G_fatal_error(_("Unable to create raster map <%s>"), m_outputs[i].output_name);
-		m_outputs[i].out_buf = G_allocate_f_raster_buf();
+    STRING connector = "_";
+    int i;
+    m_outputs = (OUTPUTS *) G_malloc(nrules * sizeof(OUTPUTS));
+    for (i = 0; i < nrules; ++i) {
+	strcpy(m_outputs[i].output_name, output);
+	strcat(m_outputs[i].output_name, connector);
+	strcat(m_outputs[i].output_name, s_rules[i].outname);
+	if ((m_outputs[i].ofd =
+	     G_open_raster_new(m_outputs[i].output_name, FCELL_TYPE)) < 0)
+	    G_fatal_error(_("Unable to create raster map <%s>"),
+			  m_outputs[i].output_name);
+	m_outputs[i].out_buf = G_allocate_f_raster_buf();
-int process_coors (char *answer) {
+int process_coors(char *answer)
-	struct Cell_head window;
-	double x, y;
-	int i, j;
-	int r,c;
-	int num_points;
-	float result;
-	G_get_window(&window);
-	num_points=sscanf(answer,"%lf,%lf", &x, &y);
+    struct Cell_head window;
+    double x, y;
+    int i, j;
+    int r, c;
+    int num_points;
+    float result;
-  r= (int) G_easting_to_col	(	x, &window);
-  c= (int) G_northing_to_row	(	y, &window);
-	get_rows(r);
-	get_cells(c);
-	result=implicate();
-		fprintf(stdout,"ANTECEDENT %s: %5.3f\n",s_rules[i].outname,antecedents[i]);
-		fprintf(stdout,"RESULT (deffuzified):  %5.3f\n",result);
-	fprintf(stdout,"UNIVERSE,");
-		fprintf(stdout,"%s,",s_rules[i].outname);
-	fprintf(stdout,"AGREGATE \n");
-		for (j=0;j<nrules+2;++j) {
-			fprintf(stdout,"%5.3f",visual_output[i][j]);
-				if (j<nrules+1)
-			fprintf(stdout,",");
-				else
-			fprintf(stdout,"\n");
+    G_get_window(&window);
+    num_points = sscanf(answer, "%lf,%lf", &x, &y);
+    r = (int)G_easting_to_col(x, &window);
+    c = (int)G_northing_to_row(y, &window);
+    get_rows(r);
+    get_cells(c);
+    result = implicate();
+	fprintf(stdout, "ANTECEDENT %s: %5.3f\n", s_rules[i].outname,
+		antecedents[i]);
+    fprintf(stdout, "RESULT (deffuzified):  %5.3f\n", result);
+    fprintf(stdout, "UNIVERSE,");
+	fprintf(stdout, "%s,", s_rules[i].outname);
+    fprintf(stdout, "AGREGATE \n");
+	for (j = 0; j < nrules + 2; ++j) {
+	    fprintf(stdout, "%5.3f", visual_output[i][j]);
+	    if (j < nrules + 1)
+		fprintf(stdout, ",");
+	    else
+		fprintf(stdout, "\n");
Modified: grass-addons/raster/r.fuzzy.system/local_proto.h
--- grass-addons/raster/r.fuzzy.system/local_proto.h	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy.system/local_proto.h	2010-04-03 08:59:38 UTC (rev 41681)
@@ -12,15 +12,15 @@
 #endif
-PI2= PI/2
-PI4= PI/4
+   PI2= PI/2
+   PI4= PI/4
 #ifndef PI2
 #endif
 #ifndef PI4
 #endif
 #define STACKMAX 50
@@ -30,154 +30,166 @@
 #define MIN(a,b) ((a) < (b) ? (a) : (b))
-typedef char* STRING;
+typedef char *STRING;
-typedef enum {
-l_ZADEH,
-l_PRODUCT,
-l_DRASTIC,
-l_LUKASIEWICZ,
-l_FODOR,
-l_HAMACHER
+typedef enum
+    l_ZADEH,
+    l_PRODUCT,
+    l_DRASTIC,
+    l_LUKASIEWICZ,
+    l_FODOR,
+    l_HAMACHER
 } logics;
-typedef enum {
-s_LINEAR,
-s_SSHAPE,
-s_JSHAPE,
-s_GSHAPE
+typedef enum
+    s_LINEAR,
+    s_SSHAPE,
+    s_JSHAPE,
+    s_GSHAPE
 } shapes;
-typedef enum {
-	s_BOTH,
-	s_LEFT,
-	s_RIGHT
-} sides;
+typedef enum
+    s_BOTH,
+    s_LEFT,
+    s_RIGHT
+} sides;
-typedef enum {
-	i_MIN,
-	i_PROD
-} implications;
+typedef enum
+    i_MIN,
+    i_PROD
+} implications;
-typedef enum {
-	d_CENTEROID,
-	d_BISECTOR,
-	d_MINOFHIGHEST,
-	d_MAXOFHIGHEST,
-	d_MEANOFHIGHEST
+typedef enum
+    d_CENTEROID,
+    d_BISECTOR,
+    d_MINOFHIGHEST,
+    d_MAXOFHIGHEST,
+    d_MEANOFHIGHEST
 } defuzz;
-typedef enum {
-	E, /* ERROR */
-	S, /* SHIFT */
-	R, /* REDUCE */
-	A  /* ACCEPT */
+typedef enum
+    E,				/* ERROR */
+    S,				/* SHIFT */
+    R,				/* REDUCE */
+    A				/* ACCEPT */
 } actions;
-typedef enum {
-	t_START,	/* { */
-	t_AND,		/* & */
-	t_OR,			/* | */
-	t_IS_NOT,		/* ~ */
-	t_IS,			/* = */
-	t_LBRC,		/* ( */
-	t_RBRC,		/* ) */
-	t_STOP,		/* } */
-	t_size,		/* number of tokens */
-	t_VAL		/* value a product of MAP and VARIABLE */
+typedef enum
+    t_START,			/* { */
+    t_AND,			/* & */
+    t_OR,			/* | */
+    t_IS_NOT,			/* ~ */
+    t_IS,			/* = */
+    t_LBRC,			/* ( */
+    t_RBRC,			/* ) */
+    t_STOP,			/* } */
+    t_size,			/* number of tokens */
+    t_VAL			/* value a product of MAP and VARIABLE */
 } tokens;
-typedef struct _sets { /* membership definition */
-	char setname[21];
-	sides side;
-	float points[4];
-	shapes shape;
-	int hedge;
-	float height;
-}SETS;
+typedef struct _sets
+{				/* membership definition */
+    char setname[21];
+    sides side;
+    float points[4];
+    shapes shape;
+    int hedge;
+    float height;
+} SETS;
-typedef struct map {
-	char name[30];
-	int nsets;
-	int output; /* is output map? */
-	fpos_t position;
-	void *in_buf;
-	float cell;
-	int cfd; /* file descriptor */
-	SETS *sets;
+typedef struct map
+    char name[30];
+    int nsets;
+    int output;			/* is output map? */
+    fpos_t position;
+    void *in_buf;
+    float cell;
+    int cfd;			/* file descriptor */
+    SETS *sets;
 } MAPS;
-typedef struct valuestacks {
-	float* value;
-	SETS* set;
-	char oper;
-	} VALUES;
+typedef struct valuestacks
+    float *value;
+    SETS *set;
+    char oper;
+} VALUES;
-typedef struct rule {
-	char outname[20];
-	int output_set_index;
-	char parse_stack[STACKMAX][VARMAX];
-	int work_stack[STACKMAX];
-	VALUES value_stack[STACKMAX];
-	float weight;
+typedef struct rule
+    char outname[20];
+    int output_set_index;
+    char parse_stack[STACKMAX][VARMAX];
+    int work_stack[STACKMAX];
+    VALUES value_stack[STACKMAX];
+    float weight;
 } RULES;
-typedef struct _outs {
-	char output_name[52];
-	int ofd; /* output file descriptor */
-	float* out_buf;
-} OUTPUTS;
+typedef struct _outs
+    char output_name[52];
+    int ofd;			/* output file descriptor */
+    float *out_buf;
+} OUTPUTS;
 STRING var_name_file;
 STRING rule_name_file;
 STRING output;
-MAPS* s_maps;
-RULES* s_rules;
-OUTPUTS* m_outputs;
-float** visual_output;
-float* universe;
-float* antecedents;
+MAPS *s_maps;
+RULES *s_rules;
+OUTPUTS *m_outputs;
+float **visual_output;
+float *universe;
+float *antecedents;
 int nmaps, nrules, output_index, multiple, coor_proc;
 int resolution;
 implications implication;
 defuzz defuzzyfication;
 logics family;
-char** rules;
+char **rules;
 int char_strip(char *buf, char rem);
 int char_copy(const char *buf, char *res, int start, int stop);
-int get_nsets(FILE* fd, fpos_t position);
-int get_universe (void);
+int get_nsets(FILE * fd, fpos_t position);
+int get_universe(void);
-int parse_map_file (STRING file);
-int parse_rule_file (STRING file);
-int parser (void);
+int parse_map_file(STRING file);
+int parse_rule_file(STRING file);
+int parser(void);
 int open_maps(void);
 int create_output_maps(void);
 int get_rows(int row);
 int get_cols(int col);
-int parse_sets (SETS* set, char buf[], const char mapname[]);
-int parse_rules (int rule_num, int n, char buf[]);
-int process_coors (char *answer);
+int parse_sets(SETS * set, char buf[], const char mapname[]);
+int parse_rules(int rule_num, int n, char buf[]);
+int process_coors(char *answer);
-float implicate (void);
+float implicate(void);
 float parse_expression(int n);
-float defuzzify(float *agregate,int defuzzification, float max_antecedent);
+float defuzzify(float *agregate, int defuzzification, float max_antecedent);
 float f_and(float cellx, float celly, int family);
-float fuzzy(FCELL cell, SETS* set);
+float fuzzy(FCELL cell, SETS * set);
 int parse(void);
-void display (void);
+void display(void);
Modified: grass-addons/raster/r.fuzzy.system/main.c
--- grass-addons/raster/r.fuzzy.system/main.c	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy.system/main.c	2010-04-03 08:59:38 UTC (rev 41681)
@@ -3,7 +3,7 @@
  * MODULE:       r.fuzzy.system
  * PURPOSE:      Full fuzzy logic standalone classification system with few fuzzy logic families
- * 							 implication and defuzzification and methods.
+ *                                                       implication and defuzzification and methods.
@@ -17,221 +17,221 @@
 int main(int argc, char **argv)
-	struct Option *file_vars,
-								*file_rules,
-								*par_family,
-								*par_resolution,
-								*par_defuzzify,
-								*par_implication,
-								*in_coor_opt,
-								*opt_output;
-	struct Flag *out_multiple;
-	int nrows, ncols;
-	int row, col;
-	int outfd;
-	float tmp;
-	FCELL *out_buf;
-	int i,j, n;
+    struct Option *file_vars,
+	*file_rules,
+	*par_family,
+	*par_resolution,
+	*par_defuzzify, *par_implication, *in_coor_opt, *opt_output;
-  file_vars = G_define_standard_option(G_OPT_F_INPUT);
-  file_vars->key = "maps";
-  file_vars->required = NO;
-  file_vars->description = _("Name of fuzzy variable file");
-  file_rules = G_define_standard_option(G_OPT_F_INPUT);
-  file_rules->key = "rules";
-  file_rules->required = NO;
-  file_rules->description = _("Name of rules file");
-	par_family->type = TYPE_STRING;
-	par_family->guisection = _("Advanced options");
-	par_defuzzify=G_define_option();
-	par_defuzzify->key = "defuz";
-	par_defuzzify->type = TYPE_STRING;
-	par_defuzzify->options = "centeroid,bisector,min,max,mean";
-	par_defuzzify->answer = "bisector";
-	par_defuzzify->required = YES;
-	par_defuzzify->description = _("Defuzzyfication method");
-	par_defuzzify->guisection = _("Advanced options");
-	par_implication=G_define_option();
-	par_implication->key = "imp";
-	par_implication->type = TYPE_STRING;
-	par_implication->options = "minimum, product";
-	par_implication->answer = "minimum";
-	par_implication->required = YES;
-	par_implication->description = _("Implication method");
-	par_implication->guisection = _("Advanced options");
-	par_resolution=G_define_option();
-	par_resolution->key = "res";
-	par_resolution->type = TYPE_INTEGER;
-	par_resolution->answer = "100";
-	par_resolution->required = YES;
-	par_resolution->description = _("Universe resolution");
-	par_resolution->guisection = _("Advanced options");
-	in_coor_opt = G_define_option();	/* input coordinates de outlet */
-  in_coor_opt->key = "coors";
-  in_coor_opt->type = TYPE_STRING;
-  in_coor_opt->key_desc = "x,y";
-  in_coor_opt->answer = NULL;
-  in_coor_opt->required = NO;
-  in_coor_opt->multiple = NO;
-  in_coor_opt->description = "Coordinate of cell for witch output  detail data";
-  in_coor_opt->guisection = _("Visual Output");
+    struct Flag *out_multiple;
-  out_multiple = G_define_flag();
-  out_multiple->key = 'm';
-  out_multiple->description = _("Create addational fuzzy output maps for every rule");
-  opt_output = G_define_standard_option(G_OPT_R_OUTPUT);
-  opt_output->description = _("Name of output file");
+    int nrows, ncols;
+    int row, col;
+    int outfd;
+    float tmp;
+    FCELL *out_buf;
+    int i, j, n;
+    file_vars = G_define_standard_option(G_OPT_F_INPUT);
+    file_vars->key = "maps";
+    file_vars->required = NO;
+    file_vars->description = _("Name of fuzzy variable file");
+    file_rules = G_define_standard_option(G_OPT_F_INPUT);
+    file_rules->key = "rules";
+    file_rules->required = NO;
+    file_rules->description = _("Name of rules file");
+    par_family->type = TYPE_STRING;
+    par_family->guisection = _("Advanced options");
+    par_defuzzify = G_define_option();
+    par_defuzzify->key = "defuz";
+    par_defuzzify->type = TYPE_STRING;
+    par_defuzzify->options = "centeroid,bisector,min,max,mean";
+    par_defuzzify->answer = "bisector";
+    par_defuzzify->required = YES;
+    par_defuzzify->description = _("Defuzzyfication method");
+    par_defuzzify->guisection = _("Advanced options");
+    par_implication = G_define_option();
+    par_implication->key = "imp";
+    par_implication->type = TYPE_STRING;
+    par_implication->options = "minimum, product";
+    par_implication->answer = "minimum";
+    par_implication->required = YES;
+    par_implication->description = _("Implication method");
+    par_implication->guisection = _("Advanced options");
+    par_resolution = G_define_option();
+    par_resolution->key = "res";
+    par_resolution->type = TYPE_INTEGER;
+    par_resolution->answer = "100";
+    par_resolution->required = YES;
+    par_resolution->description = _("Universe resolution");
+    par_resolution->guisection = _("Advanced options");
+    in_coor_opt = G_define_option();	/* input coordinates de outlet */
+    in_coor_opt->key = "coors";
+    in_coor_opt->type = TYPE_STRING;
+    in_coor_opt->key_desc = "x,y";
+    in_coor_opt->answer = NULL;
+    in_coor_opt->required = NO;
+    in_coor_opt->multiple = NO;
+    in_coor_opt->description =
+	"Coordinate of cell for witch output  detail data";
+    in_coor_opt->guisection = _("Visual Output");
+    out_multiple = G_define_flag();
+    out_multiple->key = 'm';
+    out_multiple->description =
+	_("Create addational fuzzy output maps for every rule");
+    opt_output = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt_output->description = _("Name of output file");
 	exit(EXIT_FAILURE);
-	var_name_file=file_vars->answer;
-	rule_name_file=file_rules->answer;
-	output = opt_output->answer;
-	multiple = (out_multiple->answer != 0);
-	coor_proc = (in_coor_opt->answer) ? 1 : 0;
-	resolution = atoi(par_resolution->answer);
-		if(resolution<10)
+    var_name_file = file_vars->answer;
+    rule_name_file = file_rules->answer;
+    output = opt_output->answer;
+    multiple = (out_multiple->answer != 0);
+    coor_proc = (in_coor_opt->answer) ? 1 : 0;
+    resolution = atoi(par_resolution->answer);
+    if (resolution < 10)
 	G_fatal_error(_("Universe resolution too small, choose greater value"));
-			if(resolution>500)
+    if (resolution > 500)
 	G_warning(_("Universe resolution is very high, computation may take a long time"));
-	family=l_ZADEH;
-	family=l_PRODUCT;
-	family=l_DRASTIC;
-	family=l_LUKASIEWICZ;
-	family=l_FODOR;
-	family=l_HAMACHER;
-				 if (!strcmp(par_implication->answer, "minimum"))
-	implication=i_MIN;
-		else if (!strcmp(par_implication->answer, "product"))
-	implication=i_PROD;
+	family = l_ZADEH;
+	family = l_PRODUCT;
+	family = l_DRASTIC;
+	family = l_LUKASIEWICZ;
+	family = l_FODOR;
+	family = l_HAMACHER;
-	  		if (!strcmp(par_defuzzify->answer, "centeroid"))
-	defuzzyfication=d_CENTEROID;
-		else if (!strcmp(par_defuzzify->answer, "bisector"))
-	defuzzyfication=d_BISECTOR;
-		else if (!strcmp(par_defuzzify->answer, "min_of_heightest"))
-	defuzzyfication=d_MINOFHIGHEST;
-		else if (!strcmp(par_defuzzify->answer, "max_of_heightest"))
-	defuzzyfication=d_MAXOFHIGHEST;
-		else if (!strcmp(par_defuzzify->answer, "mean_of_heightest"))
-	defuzzyfication=d_MEANOFHIGHEST;
-	parse_map_file (var_name_file);
-	parse_rule_file (rule_name_file);
-	get_universe();
-	open_maps();
-		if(coor_proc)
-	process_coors (in_coor_opt->answer);
+    if (!strcmp(par_implication->answer, "minimum"))
+	implication = i_MIN;
+    else if (!strcmp(par_implication->answer, "product"))
+	implication = i_PROD;
+    if (!strcmp(par_defuzzify->answer, "centeroid"))
+	defuzzyfication = d_CENTEROID;
+    else if (!strcmp(par_defuzzify->answer, "bisector"))
+	defuzzyfication = d_BISECTOR;
+    else if (!strcmp(par_defuzzify->answer, "min_of_heightest"))
+	defuzzyfication = d_MINOFHIGHEST;
+    else if (!strcmp(par_defuzzify->answer, "max_of_heightest"))
+	defuzzyfication = d_MAXOFHIGHEST;
+    else if (!strcmp(par_defuzzify->answer, "mean_of_heightest"))
+	defuzzyfication = d_MEANOFHIGHEST;
+    parse_map_file(var_name_file);
+    parse_rule_file(rule_name_file);
+    get_universe();
+    open_maps();
+    if (coor_proc)
+	process_coors(in_coor_opt->answer);
-	out_buf = G_allocate_f_raster_buf();
-		if(multiple)
+    out_buf = G_allocate_f_raster_buf();
+    if (multiple)
 	create_output_maps();
-		G_message("Calculate...");
-		for (row=0;row<nrows;++row) {
-			get_rows(row);
-				for (col=0; col<ncols;++col) {
-					if(get_cells(col)) {
-						G_set_f_null_value(&out_buf[col],1);
-							if(multiple) {
-								G_set_f_null_value(&m_outputs[i].out_buf[col],1);
-					}	else {
-						out_buf[col]=implicate();
-							if (out_buf[col]==-9999)
-							if(multiple) {
-								m_outputs[i].out_buf[col]=antecedents[i];
+    G_message("Calculate...");
-	    G_fatal_error(_("Failed writing raster map <%s> at row <%d>"), output,row);
-						if(multiple)
-						if (G_put_raster_row(m_outputs[i].ofd, m_outputs[i].out_buf, FCELL_TYPE) < 0)
-	    G_fatal_error(_("Failed writing raster map <%s> at row <%d>"), m_outputs[i].output_name,row);
+    for (row = 0; row < nrows; ++row) {
+	get_rows(row);
+	for (col = 0; col < ncols; ++col) {
+	    if (get_cells(col)) {
+		G_set_f_null_value(&out_buf[col], 1);
+		if (multiple) {
+			G_set_f_null_value(&m_outputs[i].out_buf[col], 1);
+	    else {
+		out_buf[col] = implicate();
+		if (out_buf[col] == -9999)
-	G_message("Close...");
-		continue;
-		G_free(s_maps[i].in_buf);
+		if (multiple) {
+			m_outputs[i].out_buf[col] = antecedents[i];
-	G_free(out_buf);
-			if(multiple)
-		G_free(m_outputs[i].out_buf);
-		G_close_cell(m_outputs[i].ofd);
-		G_short_history(m_outputs[i].output_name, "raster", &history);
-		G_write_history(m_outputs[i].output_name, &history);
-G_message("Done!");
-exit(EXIT_SUCCESS);
+	    G_fatal_error(_("Failed writing raster map <%s> at row <%d>"),
+			  output, row);
+	if (multiple)
+		    (m_outputs[i].ofd, m_outputs[i].out_buf, FCELL_TYPE) < 0)
+				  m_outputs[i].output_name, row);
+    G_message("Close...");
+	    continue;
+	G_free(s_maps[i].in_buf);
+    G_free(out_buf);
+    if (multiple)
+	    G_free(m_outputs[i].out_buf);
+	    G_close_cell(m_outputs[i].ofd);
+	    G_short_history(m_outputs[i].output_name, "raster", &history);
+	    G_write_history(m_outputs[i].output_name, &history);
+    G_message("Done!");
Modified: grass-addons/raster/r.fuzzy.system/map_parser.c
--- grass-addons/raster/r.fuzzy.system/map_parser.c	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy.system/map_parser.c	2010-04-03 08:59:38 UTC (rev 41681)
@@ -1,213 +1,216 @@
-	FILE* fd;
-	int line=0;
-	char buf[500];
-	STRING mapset;
-	char map[30];
-	int nmaps2=0, nsets=0;
-	fpos_t init;
-	fpos_t position;
-	int set_num;
-	int i;
-	fd = fopen(file, "r");
-			if (!fd)
+    FILE *fd;
+    int line = 0;
+    char buf[500];
+    STRING mapset;
+    char map[30];
+    int nmaps2 = 0, nsets = 0;
+    fpos_t init;
+    fpos_t position;
+    int set_num;
+    int i;
+    fd = fopen(file, "r");
+    if (!fd)
 	G_fatal_error(_("Cannot open varaible file '%s'"), file);
-	fgetpos (fd, &init);
-	nmaps=0;
-	/* number of maps */
-		G_strip(buf);
-				if (*buf != '%')
-		continue;
-		nmaps++;
-	s_maps=(MAPS*)G_malloc(nmaps * sizeof(MAPS));
-	fsetpos (fd, &init); /* reset position */
-			line++;
+    fgetpos(fd, &init);
+    nmaps = 0;
+    /* number of maps */
 	G_strip(buf);
-	continue;
-		if (*buf != '%' && *buf !='$')
-	G_fatal_error(_("Wrong syntax at line %d: line must start with #, % or $ or be empty line"), line);
-		if (*buf == '%') {
+	if (*buf != '%')
+	    continue;
+	nmaps++;
+    s_maps = (MAPS *) G_malloc(nmaps * sizeof(MAPS));
+    fsetpos(fd, &init);		/* reset position */
-			sscanf(buf, "%[^\n]", map);
-			char_strip(map,'%');
-			G_strip(map);
-			mapset = G_find_cell2(map, "");
+	line++;
-				if (mapset == NULL && strcmp(map,output))
-			G_fatal_error(_("Raster map <%s> not found"), map);
-			G_strcpy(s_maps[nmaps2].name,map);
-			s_maps[nmaps2].position=position;
-			s_maps[nmaps2].nsets=get_nsets(fd,position);
-			s_maps[nmaps2].output= (strcmp(map,output)) ? 0 : 1;
-				if (!s_maps[nmaps2].nsets)
-			G_warning(_("map <%s> has no rules"),s_maps[nmaps2].name);
+	G_strip(buf);
+	    continue;
-					if (s_maps[nmaps2].nsets)
-			s_maps[nmaps2].sets = (SETS *)G_malloc(s_maps[nmaps2].nsets * sizeof(SETS));
-			set_num=0;
-				G_strip(buf);
+	if (*buf != '%' && *buf != '$')
+	    G_fatal_error(_("Wrong syntax at line %d: line must start with #, % or $ or be empty line"),
+			  line);
-				continue;
-						if (*buf == '%')
-				break;
+	if (*buf == '%') {
-				parse_sets(&s_maps[nmaps2].sets[set_num++],buf,s_maps[nmaps2].name);
+	    sscanf(buf, "%[^\n]", map);
+	    char_strip(map, '%');
+	    G_strip(map);
+	    mapset = G_find_cell2(map, "");
-				if (nmaps2++ > nmaps)
-			G_fatal_error(_("number of maps do not match"));
-	} /* end while */
-	fclose(fd);
-	return 0;
+	    if (mapset == NULL && strcmp(map, output))
+		G_fatal_error(_("Raster map <%s> not found"), map);
+	    G_strcpy(s_maps[nmaps2].name, map);
+	    s_maps[nmaps2].position = position;
+	    s_maps[nmaps2].nsets = get_nsets(fd, position);
+	    s_maps[nmaps2].output = (strcmp(map, output)) ? 0 : 1;
+	    if (!s_maps[nmaps2].nsets)
+		G_warning(_("map <%s> has no rules"), s_maps[nmaps2].name);
+	    if (s_maps[nmaps2].nsets)
+		s_maps[nmaps2].sets =
+		    (SETS *) G_malloc(s_maps[nmaps2].nsets * sizeof(SETS));
+	    set_num = 0;
+		G_strip(buf);
+		    continue;
+		if (*buf == '%')
+		    break;
+		parse_sets(&s_maps[nmaps2].sets[set_num++], buf,
+			   s_maps[nmaps2].name);
+	    if (nmaps2++ > nmaps)
+		G_fatal_error(_("number of maps do not match"));
+    }				/* end while */
+    fclose(fd);
+    return 0;
-int parse_sets (SETS* set, char buf[], const char mapname[]) {
-	char tmp[20];
-	int i;
-	char_strip(buf,'$');
-	{ /* check length of fuzzy value (cannot be longer than 20) */
-	sscanf(buf, "%[^{] %[^\n]",tmp,buf);
+    char tmp[20];
+    int i;
+    char_strip(buf, '$');
+    {				/* check length of fuzzy value (cannot be longer than 20) */
+	sscanf(buf, "%[^{] %[^\n]", tmp, buf);
 	G_strip(tmp);
-		if(strlen(tmp)<21)
-	G_strcpy(set->setname,tmp);
-		else
-	G_fatal_error(_("Map: <%s>, Membership: <%s>: Value name cannot be longer than 20 chars, but has %d chars"),
-		mapname,tmp,strlen(tmp));
-	} /* check length of fuzzy value */
+	if (strlen(tmp) < 21)
+	    G_strcpy(set->setname, tmp);
+	else
+	    G_fatal_error(_("Map: <%s>, Membership: <%s>: Value name cannot be longer than 20 chars, but has %d chars"),
+			  mapname, tmp, strlen(tmp));
+    }				/* check length of fuzzy value */
-	{ /* check if side is valid (both,left,right) */
-	int done=1;
-	STRING sides[]={"both","left","right"};
-	char_strip(buf,'{');
-	sscanf(buf, "%[^;] %[^\n]", tmp,buf);
-	done=0;
-		for(i=0;i<3;++i)
-	if(strcmp(tmp,sides[i])==0) {
-		done=1;
+    {				/* check if side is valid (both,left,right) */
+	int done = 1;
+	STRING sides[] = { "both", "left", "right" };
+	char_strip(buf, '{');
+	sscanf(buf, "%[^;] %[^\n]", tmp, buf);
+	done = 0;
+	for (i = 0; i < 3; ++i)
+	    if (strcmp(tmp, sides[i]) == 0) {
+		done = 1;
 		break;
-		if (done)
-	set->side=i;
-		else
-	G_fatal_error(_(" Map: <%s>, Membership: <%s>:  <side> parameter must be:  <left,right,both> but is: <%s>"),
-		mapname, set->setname, tmp);
-	} /* end check if side is valid */
-		{ /* check number of points and order.  Point number limited to 10 chars including coma*/
+	if (done)
+	    set->side = i;
+	else
+	    G_fatal_error(_(" Map: <%s>, Membership: <%s>:  <side> parameter must be:  <left,right,both> but is: <%s>"),
+			  mapname, set->setname, tmp);
+    }				/* end check if side is valid */
+    {				/* check number of points and order.  Point number limited to 10 chars including coma */
 	char p[11];
 	int npoints;
-	char_strip(buf,';');
-	char_strip(tmp,';');
-	npoints= set->side ? 2 : 4;
-		for (i=0;i<npoints;++i) {
-	sscanf(tmp, "%[^,] %[^\n]", p,tmp);
-			if(tmp[0]!=',' && i<(npoints-1))
-	G_fatal_error(_("Map: <%s>, Variable: <%s>: Require %d points but has %d"),
-		mapname, set->setname, npoints,  i+1);
-			if(sscanf(p,"%f",&set->points[i])!=1)
+	char_strip(buf, ';');
+	char_strip(tmp, ';');
+	npoints = set->side ? 2 : 4;
+	for (i = 0; i < npoints; ++i) {
+	    sscanf(tmp, "%[^,] %[^\n]", p, tmp);
+	    if (tmp[0] != ',' && i < (npoints - 1))
+		G_fatal_error(_("Map: <%s>, Variable: <%s>: Require %d points but has %d"),
+			      mapname, set->setname, npoints, i + 1);
+	    if (sscanf(p, "%f", &set->points[i]) != 1)
 		G_fatal_error(_("Map: <%s>, Variable: <%s>: Points must be numeric  but is: %s or space between '-' and digit"),
-		mapname, set->setname, p);
-	char_strip(tmp,',');
-		if (i>0 && (set->points[i] < set->points[i-1]))
-	G_fatal_error(_("Map: <%s>, Membership: <%s>: Points sequence must be non-declining"),
-		mapname, set->setname);
-	} /* check number of points and order */
-	{ /* check if shape is valid (linear,sshaped,jshaped,gshaped) */
-	int done=1;
-	STRING shapes[]={"linear","sshaped","jshaped", "gshaped"};
-	done=0;
-		for(i=0;i<4;++i)
-	if(strcmp(tmp,shapes[i])==0) {
-		done=1;
+			      mapname, set->setname, p);
+	    char_strip(tmp, ',');
+	    if (i > 0 && (set->points[i] < set->points[i - 1]))
+		G_fatal_error(_("Map: <%s>, Membership: <%s>: Points sequence must be non-declining"),
+			      mapname, set->setname);
+    }				/* check number of points and order */
+    {				/* check if shape is valid (linear,sshaped,jshaped,gshaped) */
+	int done = 1;
+	STRING shapes[] = { "linear", "sshaped", "jshaped", "gshaped" };
+	done = 0;
+	for (i = 0; i < 4; ++i)
+	    if (strcmp(tmp, shapes[i]) == 0) {
+		done = 1;
 		break;
-		if (done)
-	set->shape=i;
-		else
-	G_fatal_error(_(" Map: <%s>, Variable: <%s>:  <shape> parameter must be: <linear,sshaped,jshaped,gshaped> but is: <%s>"),
-	} /* end check if shape is valid */
-	{ /* check if hedge is valid  (integer) */
-			if(sscanf(tmp,"%d",&set->hedge)!=1)
-	G_fatal_error(_("Map: <%s>, variable: <%s>: Hedge must be numeric  but is: %s or space between '-' and digit"),
-	} /* end check if hedge is valid */
-		{ /* check if height is valid  (float 0-1) */
-	sscanf(buf, "%[^}] %[^\n]", tmp,buf);
-			if(sscanf(tmp,"%f",&set->height)!=1)
-	G_fatal_error(_("Map: <%s>, Variable: <%s>: Height must be  non-negative numeric lesser than 1 but is: %s"),
-			if(set->height<=0 || set->height>1)
-	G_fatal_error(_("Map: <%s>, Variable: <%s>: Height must be  non-negative numeric lesser than 1 but is: %f"),
-		mapname, set->setname, set->height);
-	} /* end check if height is valid */
+	if (done)
+	    set->shape = i;
+	else
+	    G_fatal_error(_(" Map: <%s>, Variable: <%s>:  <shape> parameter must be: <linear,sshaped,jshaped,gshaped> but is: <%s>"),
+    }				/* end check if shape is valid */
-return 0;
+    {				/* check if hedge is valid  (integer) */
+	if (sscanf(tmp, "%d", &set->hedge) != 1)
+	    G_fatal_error(_("Map: <%s>, variable: <%s>: Hedge must be numeric  but is: %s or space between '-' and digit"),
+    }				/* end check if hedge is valid */
+    {				/* check if height is valid  (float 0-1) */
+	sscanf(buf, "%[^}] %[^\n]", tmp, buf);
+	if (sscanf(tmp, "%f", &set->height) != 1)
+	    G_fatal_error(_("Map: <%s>, Variable: <%s>: Height must be  non-negative numeric lesser than 1 but is: %s"),
+	if (set->height <= 0 || set->height > 1)
+	    G_fatal_error(_("Map: <%s>, Variable: <%s>: Height must be  non-negative numeric lesser than 1 but is: %f"),
+			  mapname, set->setname, set->height);
+    }				/* end check if height is valid */
+    return 0;
Modified: grass-addons/raster/r.fuzzy.system/rule_parser.c
--- grass-addons/raster/r.fuzzy.system/rule_parser.c	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy.system/rule_parser.c	2010-04-03 08:59:38 UTC (rev 41681)
@@ -1,277 +1,306 @@
 #include "local_proto.h"
-int parse_rule_file(STRING file) {
-		FILE* fd;
-	char buf[800];
-	char tmp[30];
-	STRING mapset;
-	char map[30];
-	fpos_t init;
-	int rule_num=0;
-	int n=0, i;
-			if (!fd)
+    FILE *fd;
+    char buf[800];
+    char tmp[30];
+    STRING mapset;
+    char map[30];
+    fpos_t init;
+    int rule_num = 0;
+    int n = 0, i;
+    if (!fd)
 	G_fatal_error(_("Cannot open rules file '%s'"), file);
-		G_strip(buf);
-				if (*buf != '$')
-		continue;
-		nrules++;
-	s_rules =(RULES *) G_malloc((nrules)* sizeof(RULES));
-	rules =  (char** )G_malloc ((nrules)* sizeof(char*));
-	rules[i]=(char* )G_malloc (21* sizeof(char*));
-	for (n=nmaps;n>0;--n)
-			if (!strcmp(s_maps[n-1].name,output))
-		break; /*max index of output map */
-		if(n==0)
-	G_fatal_error (_("No defininition for output map: <%s> in map file"), output);
-		G_strip(buf);
-			if (*buf != '$')
-		continue;
-		parse_rules(rule_num++,n,buf);
+	G_strip(buf);
+	if (*buf != '$')
+	    continue;
+	nrules++;
-	 /* next rule */
+    s_rules = (RULES *) G_malloc((nrules) * sizeof(RULES));
+    rules = (char **)G_malloc((nrules) * sizeof(char *));
+	rules[i] = (char *)G_malloc(21 * sizeof(char *));
-	fclose(fd);
-	return 0;
-} /* END parse_rule_file */
+    for (n = nmaps; n > 0; --n)
+	if (!strcmp(s_maps[n - 1].name, output))
+	    break;		/*max index of output map */
+    if (n == 0)
+	G_fatal_error(_("No defininition for output map: <%s> in map file"),
+		      output);
-int parse_rules(int rule_num, int n, char buf[]) {
+	G_strip(buf);
+	if (*buf != '$')
+	    continue;
-	int i,j,l,o;
-	int done=1;
-	int stack_top;
-	char tmp[30];
-	char opr[] = {'=','&','|',';','~','(',')','{','}'};
-		i=j=stack_top=0; /* variables of the while loop */
+	parse_rules(rule_num++, n, buf);
-{ /* check the name of fuzzy value (must be defined in rules) */
-	int s,p;
+	/* next rule */
+    fclose(fd);
+    return 0;
+}				/* END parse_rule_file */
+    int i, j, l, o;
+    int done = 1;
+    int stack_top;
+    char tmp[30];
+    char opr[] = { '=', '&', '|', ';', '~', '(', ')', '{', '}' };
+    i = j = stack_top = 0;	/* variables of the while loop */
+    {				/* check the name of fuzzy value (must be defined in rules) */
+	int s, p;
 	G_strip(buf);
 	G_strip(tmp);
-			done=1;
-			for (s=0;s<=s_maps[n-1].nsets;++s) {/* output map */
-				if(!strcmp(s_maps[n-1].sets[s].setname,tmp)) {
-								for (p=0;p<=rule_num;++p) /* check if values are unique */
-							if(!strcmp(tmp,rules[p]))
-						G_fatal_error(_("Variable value <%s> exist, Variable values must be unique"),tmp);
-						strcpy(rules[rule_num],tmp);
-						done=0;
-						break;
-		if(done)
-	G_fatal_error(_("Output map do not have variable value <%s>"),tmp);
-	strcpy(s_rules[rule_num].outname,tmp);
-	s_rules[rule_num].output_set_index=s;
+	done = 1;
+	for (s = 0; s <= s_maps[n - 1].nsets; ++s) {	/* output map */
-} /* check the name of fuzzy value */
+	    if (!strcmp(s_maps[n - 1].sets[s].setname, tmp)) {
-{	/* parse rule expression and create parse stack */
+		for (p = 0; p <= rule_num; ++p)	/* check if values are unique */
+		    if (!strcmp(tmp, rules[p]))
+			G_fatal_error(_("Variable value <%s> exist, Variable values must be unique"),
+				      tmp);
+		strcpy(rules[rule_num], tmp);
+		done = 0;
+		break;
+	if (done)
+	    G_fatal_error(_("Output map do not have variable value <%s>"),
+			  tmp);
+	strcpy(s_rules[rule_num].outname, tmp);
+	s_rules[rule_num].output_set_index = s;
+    }				/* check the name of fuzzy value */
+    {				/* parse rule expression and create parse stack */
 	do {
-		for(o=0;o<(sizeof opr);++o) {
-			if(buf[i]==opr[o]) {
-				char_copy(buf,tmp,j,i);
-				if (i>0) {
-					char_strip(tmp,buf[j]);
-					s_rules[rule_num].parse_stack[stack_top][0]=buf[j];
-					s_rules[rule_num].parse_stack[stack_top++][1]='\0';
-					G_strip(tmp);
-					if(strlen(tmp)) /* is not blank */
-				strcpy(s_rules[rule_num].parse_stack[stack_top++],tmp);
-				j=i;
-				break;
-			if(i>799)
+	    for (o = 0; o < (sizeof opr); ++o) {
+		if (buf[i] == opr[o]) {
+		    char_copy(buf, tmp, j, i);
+		    if (i > 0) {
+			char_strip(tmp, buf[j]);
+			s_rules[rule_num].parse_stack[stack_top][0] = buf[j];
+			s_rules[rule_num].parse_stack[stack_top++][1] = '\0';
+			G_strip(tmp);
+		    if (strlen(tmp))	/* is not blank */
+			strcpy(s_rules[rule_num].parse_stack[stack_top++],
+			       tmp);
+		    j = i;
+		    break;
+	    if (i > 799)
 		G_fatal_error(_("rule string is too long or lack of closing element"));
-	}	while (buf[i++]!='}');  		/* rule is rot */
-	strcpy(s_rules[rule_num].parse_stack[stack_top++],"}"); /* add closing element only if OK*/
+	} while (buf[i++] != '}');	/* rule is rot */
-} /* end parse rule expression and create parse stack */
+	strcpy(s_rules[rule_num].parse_stack[stack_top++], "}");	/* add closing element only if OK */
+    }				/* end parse rule expression and create parse stack */
-{	/* adding weight */
-char local[900];
-char weight[10];
-sscanf(buf, "%[^}] %[^;]",local,weight);
-char_strip(weight,'}');
-G_strip(weight);
-	if(strlen(weight)==0)
-strcpy(weight,"1");
-s_rules[rule_num].weight=atof(weight);
-	if(s_rules[rule_num].weight<=0.)
-G_fatal_error(_("Weight must be grater than 0 or non-number character"));
+    {				/* adding weight */
+	char local[900];
+	char weight[10];
-{ /* check if rule syntax is proper and map names and vars values exist*/
-int k;
-int work_stack_pos=0;
-int lbrc=0, rbrc=0; /* left and right brackets */
+	sscanf(buf, "%[^}] %[^;]", local, weight);
+	char_strip(weight, '}');
+	G_strip(weight);
+	if (strlen(weight) == 0)
+	    strcpy(weight, "1");
+	s_rules[rule_num].weight = atof(weight);
+	if (s_rules[rule_num].weight <= 0.)
+	    G_fatal_error(_("Weight must be grater than 0 or non-number character"));
-		done=1;
-		for (i=0;i<stack_top;++i) { /* most external loop */
-//if(i>0)
-//G_message("PARSE STACK %d %d",s_rules[rule_num].work_stack[i-1],i-1)	;
-			if(*s_rules[rule_num].parse_stack[i]=='{') {
-				s_rules[rule_num].work_stack[work_stack_pos]= t_START;
-					if (i>0)
-				G_fatal_error(_("line %d Syntax error near <%s %s>"),
-					rule_num+1, s_rules[rule_num].parse_stack[i-1],	s_rules[rule_num].parse_stack[i]);
-				work_stack_pos++;
-				continue;
-			} /* END { */
-			if(*s_rules[rule_num].parse_stack[i]=='=' ||
-					*s_rules[rule_num].parse_stack[i]=='~')  { /* =, ~ */
-				for (j=0;j<nmaps;++j) {
-					if(!strcmp(s_rules[rule_num].parse_stack[i-1],s_maps[j].name)) {
-						for(k=0;k<s_maps[j].nsets;++k) {
-							if(!strcmp(s_rules[rule_num].parse_stack[i+1],s_maps[j].sets[k].setname)) {
+    {				/* check if rule syntax is proper and map names and vars values exist */
+	int k;
+	int work_stack_pos = 0;
+	int lbrc = 0, rbrc = 0;	/* left and right brackets */
-								s_rules[rule_num].work_stack[work_stack_pos]= t_VAL;
-								s_rules[rule_num].value_stack[work_stack_pos].value=&s_maps[j].cell;
-								s_rules[rule_num].value_stack[work_stack_pos].set  =&s_maps[j].sets[k];
-								s_rules[rule_num].value_stack[work_stack_pos].oper =*s_rules[rule_num].parse_stack[i];
-								done=0;
-								break;
-				}	/* END for j */
-					if(done)
-				G_fatal_error(_("There is no map <%s> or variable <%s>"),s_rules[rule_num].parse_stack[i-1],
-					s_rules[rule_num].parse_stack[i+1]);
-					 /* end for j */
-					if (s_rules[rule_num].work_stack[work_stack_pos-1] != t_AND &&
-						s_rules[rule_num].work_stack[work_stack_pos-1] != t_OR &&
-						s_rules[rule_num].work_stack[work_stack_pos-1] != t_START &&
-						s_rules[rule_num].work_stack[work_stack_pos-1] != t_LBRC )
-				work_stack_pos++;
-				continue;
-			} /* END =, ~ */
-				if(*s_rules[rule_num].parse_stack[i]=='&' ||
-					*s_rules[rule_num].parse_stack[i]=='|') { /* &, | */
+	done = 1;
+	for (i = 0; i < stack_top; ++i) {	/* most external loop */
+	    //if(i>0)
+	    //G_message("PARSE STACK %d %d",s_rules[rule_num].work_stack[i-1],i-1)  ;
+	    if (*s_rules[rule_num].parse_stack[i] == '{') {
-					(*s_rules[rule_num].parse_stack[i]=='|') ? t_OR : t_AND;
+		s_rules[rule_num].work_stack[work_stack_pos] = t_START;
-					if (s_rules[rule_num].work_stack[work_stack_pos-1] != t_VAL &&
-							s_rules[rule_num].work_stack[work_stack_pos-1] != t_RBRC)
-				work_stack_pos++;
-				continue;
-			} /* END &, | */
-			if(*s_rules[rule_num].parse_stack[i]=='(') {
-				s_rules[rule_num].work_stack[work_stack_pos]= t_LBRC;
-				lbrc++;
-				work_stack_pos++;
-				continue;
-			} /* END ( */
+		if (i > 0)
+		    G_fatal_error(_("line %d Syntax error near <%s %s>"),
+				  rule_num + 1,
+				  s_rules[rule_num].parse_stack[i - 1],
+				  s_rules[rule_num].parse_stack[i]);
-			if(*s_rules[rule_num].parse_stack[i]==')') {
+		work_stack_pos++;
+		continue;
+	    }			/* END { */
-					s_rules[rule_num].work_stack[work_stack_pos]= t_RBRC;
-					rbrc++;
-				work_stack_pos++;
-				continue;
-			} /* END ) */
-			if(*s_rules[rule_num].parse_stack[i]=='}') {
+	    if (*s_rules[rule_num].parse_stack[i] == '=' || *s_rules[rule_num].parse_stack[i] == '~') {	/* =, ~ */
-					s_rules[rule_num].work_stack[work_stack_pos]= t_STOP;
-				work_stack_pos++;
-				continue;
-			} /* END } */
+		for (j = 0; j < nmaps; ++j) {
+		    if (!strcmp
+			(s_rules[rule_num].parse_stack[i - 1],
+			 s_maps[j].name)) {
+			for (k = 0; k < s_maps[j].nsets; ++k) {
+			    if (!strcmp
+				(s_rules[rule_num].parse_stack[i + 1],
+				 s_maps[j].sets[k].setname)) {
-		} /* most external loop */
+				    t_VAL;
+				s_rules[rule_num].value_stack[work_stack_pos].
+				    value = &s_maps[j].cell;
+				    set = &s_maps[j].sets[k];
+				    oper = *s_rules[rule_num].parse_stack[i];
+				done = 0;
+				break;
+		}		/* END for j */
-	if (lbrc!=rbrc)
-G_fatal_error(_("line %d Left and right of brackets do not match"),rule_num+1);
-} /* END check if rule syntax is proper and map names and vars values exist*/
+		if (done)
+		    G_fatal_error(_("There is no map <%s> or variable <%s>"),
+				  s_rules[rule_num].parse_stack[i + 1]);
+		/* end for j */
-return 0;
-} /* END parse_rules */
+		if (s_rules[rule_num].work_stack[work_stack_pos - 1] != t_AND
+		    && s_rules[rule_num].work_stack[work_stack_pos - 1] !=
+		    t_OR &&
+		    s_rules[rule_num].work_stack[work_stack_pos - 1] !=
+		    t_START &&
+		    t_LBRC)
+				  rule_num + 1,
+		work_stack_pos++;
+		continue;
+	    }			/* END =, ~ */
+	    if (*s_rules[rule_num].parse_stack[i] == '&' || *s_rules[rule_num].parse_stack[i] == '|') {	/* &, | */
+		    (*s_rules[rule_num].parse_stack[i] == '|') ? t_OR : t_AND;
+		if (s_rules[rule_num].work_stack[work_stack_pos - 1] != t_VAL
+		    t_RBRC)
+				  rule_num + 1,
+		work_stack_pos++;
+		continue;
+	    }			/* END &, | */
+	    if (*s_rules[rule_num].parse_stack[i] == '(') {
+		s_rules[rule_num].work_stack[work_stack_pos] = t_LBRC;
+		lbrc++;
+		    t_OR &&
+		    t_START &&
+		    t_LBRC)
+				  rule_num + 1,
+		work_stack_pos++;
+		continue;
+	    }			/* END ( */
+	    if (*s_rules[rule_num].parse_stack[i] == ')') {
+		s_rules[rule_num].work_stack[work_stack_pos] = t_RBRC;
+		rbrc++;
+		    t_RBRC)
+				  rule_num + 1,
+		work_stack_pos++;
+		continue;
+	    }			/* END ) */
+	    if (*s_rules[rule_num].parse_stack[i] == '}') {
+		s_rules[rule_num].work_stack[work_stack_pos] = t_STOP;
+		    t_RBRC)
+				  rule_num + 1,
+		work_stack_pos++;
+		continue;
+	    }			/* END } */
+	}			/* most external loop */
+	if (lbrc != rbrc)
+	    G_fatal_error(_("line %d Left and right of brackets do not match"),
+			  rule_num + 1);
+    }				/* END check if rule syntax is proper and map names and vars values exist */
+    return 0;
+}				/* END parse_rules */
Modified: grass-addons/raster/r.fuzzy.system/system.c
--- grass-addons/raster/r.fuzzy.system/system.c	2010-04-03 08:49:00 UTC (rev 41680)
+++ grass-addons/raster/r.fuzzy.system/system.c	2010-04-03 08:59:38 UTC (rev 41681)
@@ -1,186 +1,200 @@
-float implicate (void) {
-int i, j;
-float* agregate=NULL;
-int set_index;
-float consequent;
-float max_antecedent=0;
-agregate =(float*) G_calloc(resolution, sizeof(float));
-antecedents=(float*) G_malloc(nrules * sizeof(float));
+    int i, j;
+    float *agregate = NULL;
+    int set_index;
+    float consequent;
+    float max_antecedent = 0;
-	if(coor_proc)
-visual_output= (float**) G_malloc (resolution * sizeof(float*));
+    agregate = (float *)G_calloc(resolution, sizeof(float));
+    antecedents = (float *)G_malloc(nrules * sizeof(float));
-	for (j=0;j<nrules;++j) {
-		antecedents[j]=parse_expression(j);
-		max_antecedent=(max_antecedent > antecedents[j]) ? max_antecedent : antecedents[j];
+    if (coor_proc)
+	visual_output = (float **)G_malloc(resolution * sizeof(float *));
+    for (j = 0; j < nrules; ++j) {
+	antecedents[j] = parse_expression(j);
+	max_antecedent =
+	    (max_antecedent >
+	     antecedents[j]) ? max_antecedent : antecedents[j];
+    if (max_antecedent == 0.)
+	return -9999;		/* for all rules value is 0 */
+    if (coor_proc)
+	for (i = 0; i < resolution; ++i) {
+	    visual_output[i] = (float *)G_calloc(nrules + 2, sizeof(float));
+	    visual_output[i][0] = universe[i];
-				if(max_antecedent==0.)
-		return -9999; /* for all rules value is 0 */
-			if(coor_proc)
-	for (i=0;i<resolution;++i) {
-		visual_output[i]= (float*) G_calloc (nrules+2, sizeof(float));
-		visual_output[i][0]=universe[i];
+	if (defuzzyfication > d_BISECTOR && antecedents[j] < max_antecedent)
+	    continue;
+	    consequent = fuzzy(universe[i],
+			       &s_maps[output_index].sets[set_index]);
+	    set_index = s_rules[j].output_set_index;
+	    consequent = (!implication) ? MIN(antecedents[j], consequent) :
+		antecedents[j] * consequent;
+	    agregate[i] = MAX(agregate[i], consequent);
+	    if (coor_proc)
+		visual_output[i][j + 1] = consequent;
-			if(defuzzyfication > d_BISECTOR && antecedents[j]< max_antecedent)
-		continue;
+    if (coor_proc)
+	    visual_output[i][j + 1] = agregate[i];
+    return defuzzify(agregate, defuzzyfication, max_antecedent);
-			consequent=fuzzy(universe[i],
-				&s_maps[output_index].sets[set_index]);
-			set_index=s_rules[j].output_set_index;
-			consequent=(!implication) ? MIN(antecedents[j],consequent) :
-				antecedents[j]*consequent;
-			agregate[i]=MAX(agregate[i],consequent);
+float parse_expression(int n)
-				if(coor_proc)
-			visual_output[i][j+1]=consequent;
+    /*  tokens and actions must heve the same order */
+    actions parse_tab[t_size][t_size] = {
+	/* stk -----------INPUT------------------ */
+	   /* { */ {E, S, S, E, E, S, E, A},
+	/* & */ {E, R, R, E, E, S, R, R},
+	/* | */ {E, R, R, E, E, S, R, R},
+	/* ~ */ {E, E, E, E, E, E, E, E},
+	/* = */ {E, E, E, E, E, E, E, E},
+	/* ( */ {E, S, S, E, E, S, S, E},
+	/* ) */ {E, R, R, E, E, E, R, R},
+	/* } */ {E, E, E, E, E, E, E, E}
+    tokens operator_stack[STACKMAX];
+    float values_stack[STACKMAX];
+    int i = 0, k = 0;
+    int opr_top = 0;
+    int val_top = 0;
+    int set_index;
+    float f_value;
+    do {
+	if (s_rules[n].work_stack[i] == t_START) {	/* first token */
+	    if (i > 0)
+		G_fatal_error("operator stack error, contact author");
+	    operator_stack[opr_top] = t_START;
+	    continue;
+	if (s_rules[n].work_stack[i] == t_VAL) {
+	    f_value =
+		fuzzy(*s_rules[n].value_stack[i].value,
+		      s_rules[n].value_stack[i].set);
+	    values_stack[++val_top] =
+		(s_rules[n].value_stack[i].oper == '~') ? f_not(f_value,
+								family) :
+		f_value;
+	    continue;
+	if (s_rules[n].work_stack[i] < t_size) {
+	    switch (parse_tab[operator_stack[opr_top]]
+		    [s_rules[n].work_stack[i]]) {
+	    case E:		/* error */
+		G_fatal_error("Stack error, contact author");
+		break;
+	    case S:		/* shift */
+		operator_stack[++opr_top] = s_rules[n].work_stack[i];
+		break;
+	    case R:		/* reduce */
+		switch (operator_stack[opr_top]) {
+		case t_AND:
+		    values_stack[val_top - 1] =
+			f_and(values_stack[val_top],
+			      values_stack[val_top - 1], family);
+		    val_top--;
+		    break;
+		case t_OR:
+			f_or(values_stack[val_top], values_stack[val_top - 1],
+			     family);
+		    val_top--;
+		    break;
+		case t_RBRC:
+		    opr_top--;
+		    break;
-					if(coor_proc)
-		visual_output[i][j+1]=agregate[i];
-		return defuzzify(agregate,defuzzyfication,max_antecedent);
+		opr_top--;
+		i--;
+		break;
+	    case A:		/* accept */
+		if (!val_top)
+		    G_fatal_error("Last Stack error, contact autor");
+		return values_stack[val_top];
+    } while (s_rules[n].work_stack[i++] != t_STOP);
-float parse_expression(int n) {
-/*  tokens and actions must heve the same order */
-actions parse_tab[t_size][t_size] ={
-/* stk -----------INPUT------------------*/
-/* { */ { E,   S,   S,   E,   E,   S,   E,   A  },
-/* & */	{ E,   R,   R,   E,   E,   S,   R,   R  },
-/* | */	{ E,   R,   R,   E,   E,   S,   R,   R  },
-/* ~ */	{ E,   E,   E,   E,   E,   E,   E,   E  },
-/* = */	{ E,   E,   E,   E,   E,   E,   E,   E  },
-/* ( */	{ E,   S,   S,   E,   E,   S,   S,   E  },
-/* ) */	{ E,   R,   R,   E,   E,   E,   R,   R  },
-/* } */	{ E,   E,   E,   E,   E,   E,   E,   E  }
-tokens operator_stack[STACKMAX];
-float values_stack[STACKMAX];
-int i=0, k=0;
-int opr_top=0;
-int val_top=0;
-int set_index;
-float f_value;
-		do {
+    int i;
+    float d_value = 0;
+    float sum_agregate = 0;
+    float tmp;
-			if(s_rules[n].work_stack[i]==t_START) {/* first token */
-						if (i>0)
-					G_fatal_error("operator stack error, contact author");
-				operator_stack[opr_top]=t_START;
-				continue;
-			if(s_rules[n].work_stack[i]==t_VAL) {
-				f_value=fuzzy(*s_rules[n].value_stack[i].value, s_rules[n].value_stack[i].set);
-				values_stack[++val_top]=(s_rules[n].value_stack[i].oper=='~') ?
-					f_not(f_value,family) : f_value;
-				continue;
+    for (i = 0; i < resolution; sum_agregate += agregate[i++]) ;
-			if (s_rules[n].work_stack[i]<t_size) {
-				switch (parse_tab[operator_stack[opr_top]][s_rules[n].work_stack[i]]) {
-						case E: /* error */
-					G_fatal_error ("Stack error, contact author");
-					break;
-						case S: /* shift */
-					operator_stack[++opr_top]=s_rules[n].work_stack[i];
-					break;
-						case R: /* reduce */
-							switch (operator_stack[opr_top]) {
-								case t_AND :
-							values_stack[val_top-1]=f_and(values_stack[val_top],values_stack[val_top-1],family);
-							val_top--;
-							break;
-								case t_OR :
-							values_stack[val_top-1]=f_or(values_stack[val_top],values_stack[val_top-1],family);
-							val_top--;
-							break;
-							case t_RBRC :
-						opr_top--;
-						break;
-					opr_top--;
-					i--;
-					break;
-						case A: /* accept */
-							if(!val_top)
-					G_fatal_error("Last Stack error, contact autor");
-					return values_stack[val_top];
-		} while(s_rules[n].work_stack[i++]!=t_STOP);
+    switch (defuzzification) {
+    case d_CENTEROID:
+	    d_value += (universe[i] * agregate[i]);
+	return d_value / sum_agregate;
+    case d_BISECTOR:
+	for (i = 0, tmp = 0; (tmp += agregate[i]) < sum_agregate / 2; ++i) ;
+	return universe[i];
+    case d_MINOFHIGHEST:
+	for (i = 0; agregate[i++] < max_antecedent;) ;
-float defuzzify(float *agregate,int defuzzification, float max_antecedent) {
-	int i;
-	float d_value=0;
-	float sum_agregate=0;
-	float tmp;
+    case d_MAXOFHIGHEST:
+	for (i = resolution; agregate[i--] < max_antecedent;) ;
-	for (i=0;i<resolution;sum_agregate += agregate[i++]);
-	switch (defuzzification) {
-		case d_CENTEROID :
-			d_value += (universe[i] * agregate[i]);
-			return d_value/sum_agregate;
-		case d_BISECTOR :
-			for (i=0, tmp=0;(tmp+= agregate[i])<sum_agregate/2;++i);
-			return universe[i];
-		case d_MINOFHIGHEST :
-			for (i=0; agregate[i++]<max_antecedent;);
-		case d_MAXOFHIGHEST :
-			for (i=resolution; agregate[i--]<max_antecedent;);
-		case d_MEANOFHIGHEST :
-			sum_agregate=0;
-					if(agregate[i]<max_antecedent)
-				continue;
-				sum_agregate += agregate[i];
+    case d_MEANOFHIGHEST:
+	sum_agregate = 0;
+	    if (agregate[i] < max_antecedent)
+		continue;
+	    sum_agregate += agregate[i];
-	return -9999;
+    return -9999;
