[GRASS-SVN] r41701 - grass/branches/develbranch_6/vector/v.out.ogr
Sun Apr 4 07:09:48 EDT 2010
Author: neteler
Date: 2010-04-04 07:09:47 -0400 (Sun, 04 Apr 2010)
New Revision: 41701
   grass/branches/develbranch_6/vector/v.out.ogr/description.html
+3D point export; examples simplified
Modified: grass/branches/develbranch_6/vector/v.out.ogr/description.html
--- grass/branches/develbranch_6/vector/v.out.ogr/description.html	2010-04-04 11:09:00 UTC (rev 41700)
+++ grass/branches/develbranch_6/vector/v.out.ogr/description.html	2010-04-04 11:09:47 UTC (rev 41701)
@@ -32,22 +32,25 @@
 <h3>Export to Shapefile</h3>
 Export lines from GRASS vector map to Shapefile format
- (generates /tmp/testogr.shp and related files):
 <div class="code"><pre>
-v.out.ogr input=multi type=line dsn=/tmp olayer=testogr
+v.out.ogr input=lines type=line dsn=lines.shp
 </pre></div>
-Export areas from GRASS vector map to Shapefile format, preserving islands
+<p>
+Export areas from GRASS vector map to Shapefile format, preserving islands:
-v.out.ogr -c input=multi type=area dsn=/tmp olayer=testogr
+v.out.ogr -c input=areas_islands type=area dsn=areas_islands.shp
 </pre></div>
+<p>
 Export 3D lines from GRASS vector map to Shapefile format
  (use <tt>SHPT=POLYGONZ</tt> for 3D faces):
-v.out.ogr input=lines_3d type=line dsn=/tmp olayer=testogr lco="SHPT=ARCZ"
+v.out.ogr input=lines_3d type=line dsn=lines_3d.shp lco="SHPT=ARCZ"
 </pre></div>
+<p>
+Export 3D points (e.g., Lidar points) from GRASS vector map to Shapefile format
+<div class="code"><pre>
+v.out.ogr points_3d type=point dsn=points_3d.shp lco="SHPT=POINTZ"
+</pre></div>
 <h3>Export to GML</h3>
