[GRASS-SVN] r41716 -
grass/branches/releasebranch_6_4/raster/r.series
svn_grass at osgeo.org
Sun Apr 4 11:54:59 EDT 2010
Author: martinl
Date: 2010-04-04 11:54:59 -0400 (Sun, 04 Apr 2010)
New Revision: 41716
grass/branches/releasebranch_6_4/raster/r.series/description.html
add note about no of raster maps to be opened
(merge r41714 from devbr6)
Modified: grass/branches/releasebranch_6_4/raster/r.series/description.html
--- grass/branches/releasebranch_6_4/raster/r.series/description.html 2010-04-04 15:53:09 UTC (rev 41715)
+++ grass/branches/releasebranch_6_4/raster/r.series/description.html 2010-04-04 15:54:59 UTC (rev 41716)
@@ -53,7 +53,22 @@
Linear regression (slope, offset, coefficient of determination) assumes equal time intervals.
If the data have irregular time intervals, NULL raster maps can be inserted into time series
to make time intervals equal (see example).
+<p>
+Number of raster maps to be processed is given by the limit of the
+operating system. For example, both the hard and soft limits are
+typically 1024. The soft limit can be changed with e.g. <tt>ulimit -n
+1500</tt> (UNIX-based operating systems) but not higher than the hard
+limit. If it is too low, you can as superuser add an entry in
+<div class="code"><pre>
+/etc/security/limits.conf
+% #<domain> <type> <item> <value>
+% your_username hard nofile 1500
+</pre></div>
+This would raise the hard limit to 1500 file. Be warned that more
+files open need more RAM.
<h2>EXAMPLES</h2>
Using <em>r.series</em> with wildcards:
