[GRASS-SVN] r41732 - grass/trunk/scripts/v.krige
svn_grass at osgeo.org
Mon Apr 5 11:51:25 EDT 2010
Author: martinl
Date: 2010-04-05 11:51:25 -0400 (Mon, 05 Apr 2010)
New Revision: 41732
grass/trunk/scripts/v.krige/v.krige.py
v.krige: don't use Region global variable
Modified: grass/trunk/scripts/v.krige/v.krige.py
--- grass/trunk/scripts/v.krige/v.krige.py 2010-04-05 15:45:33 UTC (rev 41731)
+++ grass/trunk/scripts/v.krige/v.krige.py 2010-04-05 15:51:25 UTC (rev 41732)
@@ -171,6 +171,7 @@
return Rpointmap
def CreateGrid(self, inputdata):
+ Region = grass.region()
Grid = robjects.r.gmeta2grd()
# addition of coordinates columns into dataframe.
@@ -247,7 +248,8 @@
def Run(self, input, column, output, package, sill, nugget, range, logger, \
overwrite, model, block, output_var, command, **kwargs):
""" Wrapper for all functions above. """
- logger.message(_("Processing %d cells. Computing time raises exponentially with resolution." % Region['cells']))
+ logger.message(_("Processing %d cells. Computing time raises "
+ "exponentially with resolution." % grass.region()['cells']))
logger.message(_("Importing data..."))
if globals()["InputData"] is None:
globals()["InputData"] = self.ImportMap(input, column)
@@ -410,5 +412,4 @@
if len(sys.argv) > 1:
sys.exit(main(argv = grass.parser()))
else:
- Region = grass.region()
main()
