[GRASS-SVN] r41734 - in grass/trunk: lib/init mswindows
svn_grass at osgeo.org
Mon Apr 5 13:20:38 EDT 2010
Author: martinl
Date: 2010-04-05 13:20:38 -0400 (Mon, 05 Apr 2010)
New Revision: 41734
grass/trunk/lib/init/grass.py
grass/trunk/mswindows/GRASS-Installer.nsi
use GISBASE if defined
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2010-04-05 16:05:29 UTC (rev 41733)
+++ grass/trunk/lib/init/grass.py 2010-04-05 17:20:38 UTC (rev 41734)
@@ -31,7 +31,10 @@
# Variables substituted during build process
# Set the GISBASE variable
-gisbase = "@GISBASE@"
+if os.getenv("GISBASE"):
+ gisbase = os.getenv("GISBASE")
+else:
+ gisbase = "@GISBASE@"
cmd_name = "@START_UP@"
grass_version = "@GRASS_VERSION_NUMBER@"
ld_library_path_var = '@LD_LIBRARY_PATH_VAR@'
Modified: grass/trunk/mswindows/GRASS-Installer.nsi
--- grass/trunk/mswindows/GRASS-Installer.nsi 2010-04-05 16:05:29 UTC (rev 41733)
+++ grass/trunk/mswindows/GRASS-Installer.nsi 2010-04-05 17:20:38 UTC (rev 41734)
@@ -610,7 +610,7 @@
FileWrite $0 'rem *******Environment variables***********$\r$\n'
FileWrite $0 '$\r$\n'
FileWrite $0 'rem Set GRASS Installation Directory Variable$\r$\n'
- FileWrite $0 'set GRASSDIR=$INSTALL_DIR$\r$\n'
+ FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
FileWrite $0 'rem Directory where your .grass7/rc file will be stored$\r$\n'
FileWrite $0 'set HOME=%USERPROFILE%$\r$\n'
@@ -619,24 +619,24 @@
FileWrite $0 'set GRASS_WISH=wish.exe$\r$\n'
FileWrite $0 'rem Path to the shell command$\r$\n'
- FileWrite $0 'set GRASS_SH=%GRASSDIR%\msys\bin\sh.exe$\r$\n'
+ FileWrite $0 'set GRASS_SH=%GISBASE%\msys\bin\sh.exe$\r$\n'
FileWrite $0 'rem Set Path to utilities (libraries and bynaries) used by GRASS$\r$\n'
- FileWrite $0 'set PATH=%GRASSDIR%\msys\bin;%PATH%$\r$\n'
- FileWrite $0 'set PATH=%GRASSDIR%\extrabin;%GRASSDIR%\extralib;%PATH%$\r$\n'
- FileWrite $0 'set PATH=%GRASSDIR%\tcl-tk\bin;%GRASSDIR%\sqlite\bin;%GRASSDIR%\gpsbabel;%PATH%$\r$\n'
+ FileWrite $0 'set PATH=%GISBASE%\msys\bin;%PATH%$\r$\n'
+ FileWrite $0 'set PATH=%GISBASE%\extrabin;%GISBASE%\extralib;%PATH%$\r$\n'
+ FileWrite $0 'set PATH=%GISBASE%\tcl-tk\bin;%GISBASE%\sqlite\bin;%GISBASE%\gpsbabel;%PATH%$\r$\n'
FileWrite $0 'rem Set Path to default web browser$\r$\n'
FileWrite $0 'set GRASS_HTML_BROWSER=explorer$\r$\n'
FileWrite $0 'rem Path to the proj files (notably the epsg projection list)$\r$\n'
- FileWrite $0 'set GRASS_PROJSHARE=%GRASSDIR%\proj$\r$\n'
+ FileWrite $0 'set GRASS_PROJSHARE=%GISBASE%\proj$\r$\n'
FileWrite $0 'rem Path to the python directory$\r$\n'
- FileWrite $0 'set PYTHONHOME=%GRASSDIR%\Python25$\r$\n'
+ FileWrite $0 'set PYTHONHOME=%GISBASE%\Python25$\r$\n'
FileWrite $0 'if "x%GRASS_PYTHON%" == "x" set GRASS_PYTHON=python$\r$\n'
- FileWrite $0 'set WINGISBASE=%GRASSDIR%$\r$\n'
+ FileWrite $0 'set WINGISBASE=%GISBASE%$\r$\n'
FileWrite $0 '%GRASS_PYTHON% "%WINGISBASE%\grass70.py" %*'
FileClose $0
done_create_grass_command.bat:
