[GRASS-SVN] r41748 - grass/branches/develbranch_6/gui/wxpython/xml
svn_grass at osgeo.org
Tue Apr 6 15:26:56 EDT 2010
Author: martinl
Date: 2010-04-06 15:26:56 -0400 (Tue, 06 Apr 2010)
New Revision: 41748
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
synchronize item labels
(merge r41747 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2010-04-06 19:18:38 UTC (rev 41747)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2010-04-06 19:26:56 UTC (rev 41748)
@@ -51,31 +51,31 @@
</menu>
<separator />
<menu>
- <label>Import raster map</label>
+ <label>Import raster data</label>
<items>
<menuitem>
- <label>Import raster data using GDAL</label>
<help>Import GDAL supported raster file into a binary raster map layer.</help>
<keywords>raster,import</keywords>
<handler>OnMenuCmd</handler>
<command>r.in.gdal</command>
</menuitem>
<menuitem>
- <label>Multiple raster data import using GDAL</label>
- <help>Converts selected GDAL layers to GRASS raster maps using r.in.gdal</help>
+ <label>Bulk import of raster data</label>
+ <help>Converts multiple GDAL supported layers to GRASS raster maps.</help>
<handler>OnImportGdalLayers</handler>
</menuitem>
<separator />
<menuitem>
- <label>Link to GDAL</label>
- <help>Link GDAL supported raster file to a binary raster map layer.</help>
+ <label>Link raster data</label>
+ <help>Link GDAL supported raster data as a pseudo GRASS raster map layer.</help>
<command>r.external</command>
</menuitem>
<menuitem>
- <label>Multiple link to GDAL</label>
- <help>Link GDAL supported raster files to a binary raster map layers</help>
+ <label>Bulk link of raster data</label>
+ <help>Link multiple GDAL supported raster maps as pseudo GRASS raster map layers.</help>
<handler>OnLinkGdalLayers</handler>
</menuitem>
<separator />
@@ -159,31 +159,31 @@
</items>
</menu>
<menu>
- <label>Import vector map</label>
+ <label>Import vector data</label>
<items>
<menuitem>
- <label>Import vector data using OGR</label>
<help>Convert OGR vector layers to GRASS vector map.</help>
<keywords>vector,import</keywords>
<command>v.in.ogr</command>
</menuitem>
<menuitem>
- <label>Multiple vector data import using OGR</label>
+ <label>Bulk import of vector data</label>
<help>Converts selected OGR layers to GRASS vector maps using v.in.ogr</help>
<handler>OnImportOgrLayers</handler>
</menuitem>
<separator />
<menuitem>
- <label>Link to OGR</label>
- <help>Creates a new vector as a read-only link to OGR layer.</help>
- <keywords>vector</keywords>
+ <label>Link vector data</label>
+ <help>Creates a new pseudo-vector map as a link to an OGR-supported layer.</help>
+ <keywords>vector,external,ogr</keywords>
<command>v.external</command>
</menuitem>
<menuitem>
- <label>Multiple link to OGR</label>
- <help>Creates a new vectors as a read-only link to OGR layers</help>
+ <label>Bulk link of vector data</label>
+ <help>Creates multiple new pseduo-vector maps as a read-only links using OGR.</help>
<handler>OnLinkOgrLayers</handler>
</menuitem>
<separator />
@@ -217,8 +217,8 @@
<command>v.in.dxf</command>
</menuitem>
<menuitem>
- <label>Multiple DXF layers import</label>
- <help>Converts selected DXF layers to GRASS vector maps (using v.in.dxf)</help>
+ <label>Bulk import of DXF</label>
+ <help>Converts multiple DXF layers to GRASS vector maps.</help>
<handler>OnImportDxfFile</handler>
</menuitem>
<separator />
@@ -267,7 +267,7 @@
</items>
</menu>
<menu>
- <label>Import grid 3D volume</label>
+ <label>Import 3D raster data</label>
<items>
<menuitem>
<label>ASCII 3D import</label>
@@ -302,7 +302,7 @@
<label>Export raster map</label>
<items>
<menuitem>
- <label>Multiple export formats using GDAL</label>
+ <label>Common export formats</label>
<help>Exports GRASS raster maps into GDAL supported formats.</help>
<keywords>raster,export</keywords>
@@ -416,7 +416,7 @@
<label>Export vector map</label>
<items>
<menuitem>
- <label>Multiple export formats using OGR</label>
<help>Converts to one of the supported OGR vector formats.</help>
<keywords>vector,export</keywords>
@@ -468,7 +468,7 @@
</items>
</menu>
<menu>
- <label>Export grid 3D volume</label>
+ <label>Export 3D raster maps</label>
<items>
<menuitem>
<label>ASCII 3D export</label>
