[GRASS-SVN] r41751 -
grass/branches/develbranch_6/raster/r.li/r.li.edgedensity
svn_grass at osgeo.org
Thu Apr 8 04:16:38 EDT 2010
Author: neteler
Date: 2010-04-08 04:16:36 -0400 (Thu, 08 Apr 2010)
New Revision: 41751
grass/branches/develbranch_6/raster/r.li/r.li.edgedensity/description.html
HTML fixes
Modified: grass/branches/develbranch_6/raster/r.li/r.li.edgedensity/description.html
--- grass/branches/develbranch_6/raster/r.li/r.li.edgedensity/description.html 2010-04-08 08:16:32 UTC (rev 41750)
+++ grass/branches/develbranch_6/raster/r.li/r.li.edgedensity/description.html 2010-04-08 08:16:36 UTC (rev 41751)
@@ -26,12 +26,16 @@
To calculate edge density index on map my_map, using
my_conf configuration file and saving results in
my_out file run:<br>
-<B>r.li.edgedensity map=</B>my_map <B>conf=</B>my_conf <B>output=</B>my_out <br><br>
+<div class="code"><pre>
+r.li.edgedensity map=my_map conf=my_conf output=my_out
+</pre></div>
To calculate edge density index of patch_type 34, using
my_conf configuration file and on map my_map, saving results in my_out
file run:<br>
-<B>r.li.edgedensity map=</B>my_map <B>conf=</B>my_conf <B>output=</B>my_out <B>patch_type=</B>34
-<br>
+r.li.edgedensity map=my_map conf=my_conf output=my_out patch_type=34
+</pre></div>
<h2>NOTES</h2>
Do not use absolute path names for output files. They are raster if
@@ -43,7 +47,9 @@
If area is 0 r.li.edgedensity returns -1; this is possible only if input
raster is masked.
If you want to have null values instead run <br>
-<B>r.null setnull=-1 map=</B>my_map <br>
+r.null setnull=-1 map=my_map
+</pre></div>
after index calculation.
<h2>SEE ALSO</h2>
