[GRASS-SVN] r41753 - in grass/trunk/raster/r.li: r.li.cwed r.li.dominance r.li.edgedensity r.li.mpa r.li.mps r.li.padcv r.li.padrange r.li.padsd r.li.patchdensity r.li.patchnum r.li.richness r.li.shannon r.li.shape r.li.simpson
Thu Apr 8 04:24:36 EDT 2010
Author: neteler
Date: 2010-04-08 04:24:34 -0400 (Thu, 08 Apr 2010)
New Revision: 41753
   grass/trunk/raster/r.li/r.li.cwed/cwed.c
   grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html
   grass/trunk/raster/r.li/r.li.dominance/dominance.c
   grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html
   grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c
   grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
   grass/trunk/raster/r.li/r.li.mpa/mpa.c
   grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html
   grass/trunk/raster/r.li/r.li.mps/mps.c
   grass/trunk/raster/r.li/r.li.mps/r.li.mps.html
   grass/trunk/raster/r.li/r.li.padcv/padcv.c
   grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html
   grass/trunk/raster/r.li/r.li.padrange/padrange.c
   grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html
   grass/trunk/raster/r.li/r.li.padsd/padsd.c
   grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html
   grass/trunk/raster/r.li/r.li.patchdensity/main.c
   grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
   grass/trunk/raster/r.li/r.li.patchnum/main.c
   grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html
   grass/trunk/raster/r.li/r.li.richness/r.li.richness.html
   grass/trunk/raster/r.li/r.li.richness/richness.c
   grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html
   grass/trunk/raster/r.li/r.li.shannon/shannon.c
   grass/trunk/raster/r.li/r.li.shape/main.c
   grass/trunk/raster/r.li/r.li.shape/r.li.shape.html
   grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html
   grass/trunk/raster/r.li/r.li.simpson/simpson.c
parameter name consistency fixes
Modified: grass/trunk/raster/r.li/r.li.cwed/cwed.c
--- grass/trunk/raster/r.li/r.li.cwed/cwed.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.cwed/cwed.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -51,7 +51,7 @@
     /* define options */
-    raster = G_define_standard_option(G_OPT_R_MAP);
+    raster = G_define_standard_option(G_OPT_R_INPUT);
     conf = G_define_option();
     conf->key = "conf";
Modified: grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html
--- grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -23,7 +23,7 @@
 my_conf configuration file and saving results in
 my_out file run:<BR>
 <div class="code"><pre>
-r.li.cwed map=my_map conf=my_conf path=my_file output=my_out
+r.li.cwed input=my_map conf=my_conf path=my_file output=my_out
 </pre></div>
 <BR>Example of input file:<BR>
Modified: grass/trunk/raster/r.li/r.li.dominance/dominance.c
--- grass/trunk/raster/r.li/r.li.dominance/dominance.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.dominance/dominance.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -46,7 +46,7 @@
     conf->key = "conf";
Modified: grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html
--- grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -14,7 +14,7 @@
 To calculate dominance's diversity index on map my_map, using
 my_conf configuration file and saving results in my_out file run:<br>
-r.li.dominance map=my_map conf=my_conf output=my_out
+r.li.dominance input=my_map conf=my_conf output=my_out
 </pre></div>
 <h2>NOTES</h2>
Modified: grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c
--- grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -43,7 +43,7 @@
     conf->key = "conf";
Modified: grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
--- grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -26,12 +26,16 @@
 To calculate edge density index on map my_map, using
-<B>r.li.edgedensity map=</B>my_map <B>conf=</B>my_conf <B>output=</B>my_out <br><br>
+<div class="code"><pre>
+r.li.edgedensity input=my_map conf=my_conf output=my_out
+</pre></div>
 To calculate edge density index of patch_type 34, using
 my_conf configuration file and on map my_map, saving results in my_out
 file run:<br>
-<B>r.li.edgedensity map=</B>my_map <B>conf=</B>my_conf <B>output=</B>my_out <B>patch_type=</B>34
-<br>
+r.li.edgedensity input=my_map conf=my_conf output=my_out patch_type=34
+</pre></div>
 <h2>NOTES</h2>
 Do not use absolute path names for output files. They are raster if
@@ -43,7 +47,9 @@
 If area is 0 r.li.edgedensity returns -1; this is possible only if input
 raster is masked.
 If you want to have null values instead run <br>
-<B>r.null setnull=-1 map=</B>my_map <br>
+r.null setnull=-1 map=my_map
+</pre></div>
 after index calculation.
 <h2>SEE ALSO</h2>
Modified: grass/trunk/raster/r.li/r.li.mpa/mpa.c
--- grass/trunk/raster/r.li/r.li.mpa/mpa.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.mpa/mpa.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -43,7 +43,7 @@
     G_add_keyword(_("patch index"));
     conf->key = "conf";
Modified: grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html
--- grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -18,7 +18,7 @@
-r.li.mpa map=my_map conf=my_conf output=my_out
+r.li.mpa input=my_map conf=my_conf output=my_out
 </pre></div>
 <h2>NOTES</h2>
Modified: grass/trunk/raster/r.li/r.li.mps/mps.c
--- grass/trunk/raster/r.li/r.li.mps/mps.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.mps/mps.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -44,7 +44,7 @@
     conf->key = "conf";
Modified: grass/trunk/raster/r.li/r.li.mps/r.li.mps.html
--- grass/trunk/raster/r.li/r.li.mps/r.li.mps.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.mps/r.li.mps.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -16,7 +16,7 @@
-r.li.mps map=my_map conf=my_conf output=my_out
+r.li.mps input=my_map conf=my_conf output=my_out
 </pre></div>
Modified: grass/trunk/raster/r.li/r.li.padcv/padcv.c
--- grass/trunk/raster/r.li/r.li.padcv/padcv.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.padcv/padcv.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -41,14 +41,17 @@
     conf->key = "conf";
     conf->description = _("Configuration file");
     conf->gisprompt = "old_file,file,input";
     conf->type = TYPE_STRING;
     conf->required = YES;
     output = G_define_standard_option(G_OPT_R_OUTPUT);
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     return calculateIndex(conf->answer, patchAreaDistributionCV, NULL,
Modified: grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html
--- grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -23,7 +23,7 @@
-r.li.padcv map=my_map conf=my_conf output=my_out
+r.li.padcv input=my_map conf=my_conf output=my_out
 </pre></div>
Modified: grass/trunk/raster/r.li/r.li.padrange/padrange.c
--- grass/trunk/raster/r.li/r.li.padrange/padrange.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.padrange/padrange.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -43,14 +43,17 @@
     conf->key = "conf";
 	exit(EXIT_FAILURE);
     return calculateIndex(conf->answer, patchAreaDistributionRANGE, NULL,
Modified: grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html
--- grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -14,7 +14,7 @@
-r.li.padrange map=my_map conf=my_conf output=my_out
+r.li.padrange input=my_map conf=my_conf output=my_out
 </pre></div>
Modified: grass/trunk/raster/r.li/r.li.padsd/padsd.c
--- grass/trunk/raster/r.li/r.li.padsd/padsd.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.padsd/padsd.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -41,14 +41,17 @@
     conf->key = "conf";
 	exit(EXIT_FAILURE);
     return calculateIndex(conf->answer, patchAreaDistributionSD, NULL,
Modified: grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html
--- grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -13,14 +13,14 @@
-r.li.padsd map=my_map conf=my_conf output=my_out
+r.li.padsd input=my_map conf=my_conf output=my_out
 </pre></div>
 <h2>NOTES</h2>
 moving window disposition was selected, otherwise they are in
 ~/.r.li/output folder.<br>
-If input raster is not full of null values r.li.padsd returns a value >=0 that is PADsd. <br>
+If input raster is not full of null values r.li.padsd returns a value &gt;=0 that is PADsd. <br>
 If input raster is full of null values r.li.padsd returns -1. <br>
Modified: grass/trunk/raster/r.li/r.li.patchdensity/main.c
--- grass/trunk/raster/r.li/r.li.patchdensity/main.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.patchdensity/main.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -37,7 +37,7 @@
     conf->key = "conf";
Modified: grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
--- grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -15,7 +15,7 @@
 results in the raster map <em>my_out</em>, run:
-r.li.patchdensity map=my_map conf=my_conf out=my_out
+r.li.patchdensity input=my_map conf=my_conf out=my_out
 </pre></div>
 <p>
Modified: grass/trunk/raster/r.li/r.li.patchnum/main.c
--- grass/trunk/raster/r.li/r.li.patchnum/main.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.patchnum/main.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -38,7 +38,7 @@
     conf->key = "conf";
Modified: grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html
--- grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -9,7 +9,7 @@
 <em>my_conf</em> configuration file and saving results in
 my_out file run:
-r.li.patchnumber map=my_map conf=my_conf out=my_out
+r.li.patchnumber input=my_map conf=my_conf out=my_out
 </pre></div>
 <H2>NOTES</H2>
Modified: grass/trunk/raster/r.li/r.li.richness/r.li.richness.html
--- grass/trunk/raster/r.li/r.li.richness/r.li.richness.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.richness/r.li.richness.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -10,7 +10,7 @@
 To calculate richness's diversity index on map my_map, using
-r.li.richness map=my_map conf=my_conf output=my_out
+r.li.richness input=my_map conf=my_conf output=my_out
 </pre></div>
 <h2>NOTES</h2>
Modified: grass/trunk/raster/r.li/r.li.richness/richness.c
--- grass/trunk/raster/r.li/r.li.richness/richness.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.richness/richness.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -44,7 +44,7 @@
     conf->key = "conf";
Modified: grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html
--- grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -18,7 +18,7 @@
 To calculate shannon's diversity index on map my_map, using
-r.li.shannon map=my_map conf=my_conf output=my_out
+r.li.shannon input=my_map conf=my_conf output=my_out
 </pre></div>
 <h2>NOTES</h2>
Modified: grass/trunk/raster/r.li/r.li.shannon/shannon.c
--- grass/trunk/raster/r.li/r.li.shannon/shannon.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.shannon/shannon.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -43,7 +43,7 @@
     conf->key = "conf";
Modified: grass/trunk/raster/r.li/r.li.shape/main.c
--- grass/trunk/raster/r.li/r.li.shape/main.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.shape/main.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -38,7 +38,7 @@
     conf->key = "conf";
Modified: grass/trunk/raster/r.li/r.li.shape/r.li.shape.html
--- grass/trunk/raster/r.li/r.li.shape/r.li.shape.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.shape/r.li.shape.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -8,7 +8,7 @@
 my_out file run:
-r.li.shape map=my_map conf=my_conf out=my_out
+r.li.shape input=my_map conf=my_conf out=my_out
 </pre></div>
 <H2>SEE ALSO</H2>
Modified: grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html
--- grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html	2010-04-08 08:24:34 UTC (rev 41753)
@@ -19,7 +19,7 @@
 To calculate simpson's diversity index on map my_map, using
-r.li.simpson map=my_map conf=my_conf output=my_out
+r.li.simpson input=my_map conf=my_conf output=my_out
 </pre></div>
 <h2>NOTES</h2>
Modified: grass/trunk/raster/r.li/r.li.simpson/simpson.c
--- grass/trunk/raster/r.li/r.li.simpson/simpson.c	2010-04-08 08:24:01 UTC (rev 41752)
+++ grass/trunk/raster/r.li/r.li.simpson/simpson.c	2010-04-08 08:24:34 UTC (rev 41753)
@@ -44,7 +44,7 @@
     conf->key = "conf";
