[GRASS-SVN] r41755 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Thu Apr 8 07:04:15 EDT 2010
Author: neteler
Date: 2010-04-08 07:04:14 -0400 (Thu, 08 Apr 2010)
New Revision: 41755
grass/branches/develbranch_6/locale/po/grasswxpy_it.po
Luca Delucchi: cont'ed
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_it.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_it.po 2010-04-08 11:04:05 UTC (rev 41754)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_it.po 2010-04-08 11:04:14 UTC (rev 41755)
@@ -2,20 +2,20 @@
# This file is distributed under the same license as the GRASS package.
# Copyright (C) 2009, 2010 GRASS Development Team
-# Luca Delucchi <lucadeluge at gmail.com>, 2009.
+# Luca Delucchi <lucadeluge at gmail.com>, 2009, 2010.
msgid ""
msgstr ""
"Project-Id-Version: grasswxpy_it\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2010-02-25 12:23+0100\n"
-"PO-Revision-Date: 2009-12-17 17:30+0100\n"
-"Last-Translator: luca delucchi\n"
-"Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
+"PO-Revision-Date: 2010-04-07 16:15+0100\n"
+"Last-Translator: Cristina Castellani <castellani.cristina at gmail.com>\n"
+"Language-Team: American English <kde-i18n-doc at kde.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"Plural-Forms: nplurals=2; plural=(n != 1);\n"
-"X-Generator: Lokalize 0.2\n"
+"X-Generator: Lokalize 1.0\n"
#: ../gui/wxpython/icons/icon.py:81
msgid "Unable to load icon theme..."
@@ -62,9 +62,8 @@
msgstr "Finestra"
#: ../gui/wxpython/icons/icon.py:157
-#, fuzzy
msgid "Drag with mouse to pan"
-msgstr "Trascina con il mouse per area"
+msgstr "Trascina mouse per effetuare pan"
#: ../gui/wxpython/icons/icon.py:159
msgid "Query raster/vector map(s)"
@@ -116,34 +115,28 @@
msgstr "Apri nuovo display"
#: ../gui/wxpython/icons/icon.py:181
-#, fuzzy
msgid "Create new workspace file (Ctrl+N)"
-msgstr "Crea nuovo ambiente di lavoro"
+msgstr "Crea nuovo ambiente di lavoro (Ctrl+N)"
#: ../gui/wxpython/icons/icon.py:183
-#, fuzzy
msgid "Load map layers into workspace (Ctrl+L)"
-msgstr "Carica layers nell'ambiente di lavoro"
+msgstr "Carica layers nell'ambiente di lavoro (Ctrl+L)"
#: ../gui/wxpython/icons/icon.py:185
-#, fuzzy
msgid "Open existing workspace file (Ctrl+O)"
-msgstr "Apri un esistente file d'ambiente di lavoro"
+msgstr "Apri un esistente file d'ambiente di lavoro (Ctrl+O)"
#: ../gui/wxpython/icons/icon.py:187
-#, fuzzy
msgid "Save current workspace to file (Ctrl+S)"
-msgstr "Salva il corrente ambiente di lavoro in un file"
+msgstr "Salva corrente ambiente di lavoro in un file (Ctrl+S)"
#: ../gui/wxpython/icons/icon.py:190
-#, fuzzy
msgid "Add raster map layer (Ctrl+R)"
-msgstr "Aggiungi raster (Alt+R)"
+msgstr "Aggiungi raster (Ctrl+R)"
#: ../gui/wxpython/icons/icon.py:192
-#, fuzzy
msgid "Add vector map layer (Ctrl+V)"
-msgstr "Aggiungi vettore (Alt+V)"
+msgstr "Aggiungi vettore (Ctrl+V)"
#: ../gui/wxpython/icons/icon.py:194
msgid "Add command layer"
@@ -354,9 +347,8 @@
msgstr "Crea istogramma di immagini o file raster"
#: ../gui/wxpython/icons/icon.py:302
-#, fuzzy
msgid "Select font"
-msgstr "Seleziona font"
+msgstr "Seleziona font "
#: ../gui/wxpython/icons/icon.py:304
msgid "Select color"
@@ -511,9 +503,8 @@
msgstr "Parametro %(name)s (%(desc)s) manca.\n"
#: ../gui/wxpython/gui_modules/menuform.py:678
-#, fuzzy
msgid "Enter parameters for '"
-msgstr "Inserisci parametro per"
+msgstr "Inserisci parametro per '"
#: ../gui/wxpython/gui_modules/menuform.py:689
msgid "Close this window without executing the command (Ctrl+Q)"
@@ -612,6 +603,7 @@
#, python-format
msgid "Unable to fetch interface description for command '%s'."
msgstr ""
+"Impossibile trovare l'interfaccia della descrizione per il comando '%s'"
#: ../gui/wxpython/gui_modules/menuform.py:1794
#, python-format
@@ -625,7 +617,7 @@
#: ../gui/wxpython/gui_modules/location_wizard.py:141
msgid "Define GRASS Database and Location Name"
-msgstr "Definisci il nome del GRASS Databse e della Location"
+msgstr "Definisci il nome del GRASS Database e della Location"
#: ../gui/wxpython/gui_modules/location_wizard.py:155
#: ../gui/wxpython/gis_set.py:105
@@ -638,7 +630,7 @@
#: ../gui/wxpython/gui_modules/location_wizard.py:209
msgid "Choose GRASS data directory:"
-msgstr "Scegli la directory dei dati GRASS:"
+msgstr "Scegli la cartella dei dati GRASS:"
#: ../gui/wxpython/gui_modules/location_wizard.py:220
#: ../gui/wxpython/gui_modules/location_wizard.py:1957
@@ -792,13 +784,12 @@
msgstr "Inserisci parametro per la proiezione %s"
#: ../gui/wxpython/gui_modules/location_wizard.py:804
-#, fuzzy
msgid "No"
-msgstr "N"
+msgstr "No"
msgid "Yes"
-msgstr ""
+msgstr "Si"
#: ../gui/wxpython/gui_modules/location_wizard.py:859
msgid "Specify geodetic datum"
@@ -921,13 +912,13 @@
msgstr "Location <%s> creata!"
#: ../gui/wxpython/gui_modules/location_wizard.py:1861
-#, fuzzy, python-format
+#, python-format
msgid ""
"Unable to create new location. Location <%(loc)s> not created.\n"
"\n"
"Details: %(err)s"
msgstr ""
-"Impossibile creare nuova location. Location <%s> non è stata creata.\n"
+"Impossibile creare nuova location. Location <%(loc)s> non è stata creata.\n"
"\n"
"Dettagli: %(err)s"
@@ -951,8 +942,8 @@
"Location <%(loc)s> will be created in GIS data directory <%(dir)s>.You will "
"need to change the default GIS data directory in the GRASS startup screen."
msgstr ""
-"Location <%(loc)s> sarà creata nella directory dei dati GIS <%(dir)s>. "
-"Dovrai cambiare la directory dei dati GIS nella schermata di avvio di GRASS"
+"Location <%(loc)s> sarà creata nella cartella dei dati GIS <%(dir)s>. Dovrai "
+"cambiare la cartella dei dati GIS nella schermata di avvio di GRASS"
#: ../gui/wxpython/gui_modules/location_wizard.py:1983
msgid "New GIS data directory"
@@ -1170,9 +1161,8 @@
msgstr ""
#: ../gui/wxpython/gui_modules/gdialogs.py:730
-#, fuzzy
msgid "&Load"
-msgstr "Carica"
+msgstr "&Carica"
#: ../gui/wxpython/gui_modules/gdialogs.py:759
msgid "Map layer type:"
@@ -1220,7 +1210,7 @@
#: ../gui/wxpython/gui_modules/gdialogs.py:946
msgid "Input directory"
-msgstr "Directory di input"
+msgstr "Cartella di input"
#: ../gui/wxpython/gui_modules/gdialogs.py:951
#, python-format
@@ -1237,11 +1227,11 @@
#: ../gui/wxpython/gui_modules/gdialogs.py:966
msgid "Choose directory:"
-msgstr "Scegli directory:"
+msgstr "Scegli cartella:"
#: ../gui/wxpython/gui_modules/gdialogs.py:969
msgid "Choose input directory"
-msgstr "Scegli directory di input"
+msgstr "Scegli cartella di input"
#: ../gui/wxpython/gui_modules/gdialogs.py:973
msgid "Select file extension:"
@@ -1336,7 +1326,7 @@
#: ../gui/wxpython/gui_modules/mapdisp.py:175
msgid "Show computational extent"
-msgstr ""
+msgstr "Mostra l'estensione computazionale"
#: ../gui/wxpython/gui_modules/mapdisp.py:180
msgid ""
@@ -1344,30 +1334,38 @@
"drawn as a blue box inside the computational region, computational region "
"inside a display region as a red box)."
msgstr ""
+"Mostra/nascondi l'estensione della region computazionale (impostata con g."
+"region). Visualizza in blu la regione interna alla region computazionale, in "
+"rosso la regione esterna). "
#: ../gui/wxpython/gui_modules/mapdisp.py:188
#: ../gui/wxpython/gui_modules/preferences.py:1141
msgid "Constrain display resolution to computational settings"
msgstr ""
+"Forza la risoluzione del display all'impostazione del region computazionale"
#: ../gui/wxpython/gui_modules/mapdisp.py:192
msgid ""
"Constrain display resolution to computational region settings. Default value "
"for new map displays can be set up in 'User GUI settings' dialog."
msgstr ""
+"Forza la risoluzione del display all'impostazione del region computazionale. "
+"Il valore di default della nuova mappa visualizzata può essere impostato "
+"nella finestra di dialogo 'Impostazioni GUI utente'."
#: ../gui/wxpython/gui_modules/mapdisp.py:220
#: ../gui/wxpython/gui_modules/mapdisp.py:1118
#: ../gui/wxpython/gui_modules/mapdisp.py:1121
-#, fuzzy
msgid "Use defined projection"
-msgstr "Scegli la proiezione"
+msgstr "Usa proiezione definita"
#: ../gui/wxpython/gui_modules/mapdisp.py:224
msgid ""
"Reproject coordinates displayed in the statusbar. Projection can be defined "
"in GUI preferences dialog (tab 'Display')"
msgstr ""
+"Riproietta le coordinate visualizzate nella barra di stato. La proiezione "
+"può essere definita nella GUI preferenze (tab 'Display')"
#: ../gui/wxpython/gui_modules/mapdisp.py:319
msgid "Map Toolbar"
@@ -1383,6 +1381,11 @@
"\n"
"Details: %s"
msgstr ""
+"Impossibile avviare il digitalizzatore di vettore.\n"
+"L'estensione python VDigit non è stato trovato o caricato correttamente.\n"
+"Si tornerà alla visualizzazione 2D.\n"
+"\n"
+"Dettagli: %s"
#: ../gui/wxpython/gui_modules/mapdisp.py:335
#: ../gui/wxpython/gui_modules/mapdisp.py:392
@@ -1395,11 +1398,11 @@
#: ../gui/wxpython/gui_modules/mapdisp.py:352
msgid "Vector digitizer toolbar"
-msgstr ""
+msgstr "Barra degli strumenti per il digitalizzatore"
#: ../gui/wxpython/gui_modules/mapdisp.py:370
msgid "Georectification toolbar"
-msgstr ""
+msgstr "Barra degli strumenti del georettificatore"
#: ../gui/wxpython/gui_modules/mapdisp.py:382
#, python-format
@@ -1410,6 +1413,11 @@
"\n"
"Details: %s"
msgstr ""
+"Impossibile cambiare nella visualizzazione 3D.\n"
+"La classe GLCanvas non è stato incluso in questo pacchetto di wxPython!\n"
+"Si ritornera alla visualizzazione 2D.\n"
+"\n"
+"Dettagli: %s"
#: ../gui/wxpython/gui_modules/mapdisp.py:387
#, python-format
@@ -1420,6 +1428,11 @@
"\n"
"Details: %s"
msgstr ""
+"L'estensione python Nviz non è stata trovata o caricata correttamente!\n"
+"Si ritornerà alla visualizzazione 2D.\n"
+"\n"
+"Dettagli: %s"
#: ../gui/wxpython/gui_modules/mapdisp.py:421
msgid "Please wait, loading data..."
@@ -1476,8 +1489,7 @@
#: ../gui/wxpython/gui_modules/mapdisp.py:1452
msgid "Only vector map from the current mapset can be modified."
-msgstr ""
-"Solo le mappe vettoriali del mapset corrente possono essere modificate."
+msgstr "Solo i vettori del mapset corrente possono essere modificati."
#: ../gui/wxpython/gui_modules/mapdisp.py:1522
msgid "Query raster/vector map(s) (display mode)"
@@ -1531,23 +1543,23 @@
#: ../gui/wxpython/gui_modules/mapdisp.py:1955
msgid "Zoom to computational region (set with g.region)"
-msgstr ""
+msgstr "Zoom alla region computazionale (impostata con g.region)"
#: ../gui/wxpython/gui_modules/mapdisp.py:1959
msgid "Zoom to default region"
-msgstr "Zoom sulla regione di defult"
+msgstr "Zoom alla region di defult"
#: ../gui/wxpython/gui_modules/mapdisp.py:1963
msgid "Zoom to saved region"
-msgstr "Zoom alla regione salvata"
+msgstr "Zoom alla region salvata"
#: ../gui/wxpython/gui_modules/mapdisp.py:1967
msgid "Set computational region from display"
-msgstr ""
+msgstr "Imposta la region computazionale dal display"
#: ../gui/wxpython/gui_modules/mapdisp.py:1971
msgid "Save display geometry to named region"
-msgstr "salva le geometrie del display alla regione denominata"
+msgstr "Salva le geometrie del display alla regione denominata"
#: ../gui/wxpython/gui_modules/mapdisp.py:2069
msgid "GRASS GIS Map Display: "
@@ -1555,7 +1567,7 @@
#: ../gui/wxpython/gui_modules/preferences.py:411
msgid "Segment break"
-msgstr ""
+msgstr "Rompi segmento"
#: ../gui/wxpython/gui_modules/preferences.py:544
msgid "Collapse all except PERMANENT and current"
@@ -1604,11 +1616,11 @@
#: ../gui/wxpython/gui_modules/preferences.py:580
msgid "dtree"
-msgstr ""
+msgstr "dtree"
#: ../gui/wxpython/gui_modules/preferences.py:581
msgid "ctree"
-msgstr ""
+msgstr "ctree"
#: ../gui/wxpython/gui_modules/preferences.py:582
msgid "aster"
@@ -1739,9 +1751,8 @@
msgstr "Font di default per i display di GRASS:"
#: ../gui/wxpython/gui_modules/preferences.py:1047
-#, fuzzy
msgid "Font for command output:"
-msgstr "output del comando"
+msgstr "Font per output del comando:"
#: ../gui/wxpython/gui_modules/preferences.py:1061
msgid "Default display settings"
@@ -1753,7 +1764,7 @@
#: ../gui/wxpython/gui_modules/preferences.py:1102
msgid "Statusbar mode:"
-msgstr ""
+msgstr "Barra di stato:"
#: ../gui/wxpython/gui_modules/preferences.py:1122
#: ../gui/wxpython/gui_modules/nviz_tools.py:262
@@ -1774,7 +1785,7 @@
#: ../gui/wxpython/gui_modules/preferences.py:1192
msgid "Command dialog settings"
-msgstr ""
+msgstr "Impostazioni finestre di dialogo"
#: ../gui/wxpython/gui_modules/preferences.py:1234
msgid "Verbosity level:"
@@ -1789,9 +1800,8 @@
msgstr "Overlay mappe raster"
#: ../gui/wxpython/gui_modules/preferences.py:1275
-#, fuzzy
msgid "Default color table"
-msgstr "Imposta il colore della tabella"
+msgstr "Tabella dei colori di default"
#: ../gui/wxpython/gui_modules/preferences.py:1301
msgid "Vector settings"
@@ -1808,7 +1818,7 @@
#: ../gui/wxpython/gui_modules/preferences.py:1337
msgid "Highlighting"
-msgstr ""
+msgstr "Evidenziazione"
#: ../gui/wxpython/gui_modules/preferences.py:1343
#: ../gui/wxpython/gui_modules/georect.py:1691
@@ -1821,7 +1831,7 @@
#: ../gui/wxpython/gui_modules/preferences.py:1376
msgid "Data browser"
-msgstr ""
+msgstr "Naviga nei dati"
#: ../gui/wxpython/gui_modules/preferences.py:1381
msgid "Left mouse double click:"
@@ -1850,7 +1860,7 @@
#: ../gui/wxpython/gui_modules/preferences.py:1465
msgid "Projection statusbar settings"
-msgstr ""
+msgstr "Impostazioni della proiezione nella barra di stato"
#: ../gui/wxpython/gui_modules/preferences.py:1491
msgid "Proj.4 string (required):"
@@ -1943,9 +1953,8 @@
msgstr "Seleziona il font di default"
#: ../gui/wxpython/gui_modules/preferences.py:1801
-#, fuzzy
msgid "Select output font"
+msgstr "Seleziona font di output"
#: ../gui/wxpython/gui_modules/preferences.py:1844
#, python-format
@@ -1954,7 +1963,7 @@
#: ../gui/wxpython/gui_modules/preferences.py:1850
msgid "Settings applied to current session but not saved"
-msgstr ""
+msgstr "Impostazioni applicate alla sessione corrente ma non salvate"
#: ../gui/wxpython/gui_modules/preferences.py:1908
msgid "Key column cannot be empty string."
@@ -1966,7 +1975,7 @@
#: ../gui/wxpython/gui_modules/preferences.py:2110
msgid "Set/unset access to mapsets in current location"
-msgstr ""
+msgstr "Seleziona/deseleziona l'accesso ai mapset nella location attuale "
#: ../gui/wxpython/gui_modules/preferences.py:2124
#, python-format
@@ -1974,6 +1983,8 @@
"Check mapset to make it accessible, uncheck it to hide it.%sNote: PERMANENT "
"and current mapset are always accessible."
msgstr ""
+"Marca mapset per renderlo accessibile, demarca per nasconderlo.%sNote: "
+"PERMANENT e mapset corrente sono sembre accessibili"
#: ../gui/wxpython/gui_modules/preferences.py:2191
msgid "Mapset"
@@ -2060,15 +2071,15 @@
#: ../gui/wxpython/gui_modules/sqlbuilder.py:78
#, python-format
msgid "GRASS SQL Builder (%(type)s): vector map <%(map)s>"
-msgstr ""
+msgstr "GRASS SQL Builder (%(type)s): vettore <%(map)s>"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:85
msgid "SQL statement not verified"
-msgstr ""
+msgstr "Istruzione SQL non verificata"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:91
msgid "Set SQL statement to default"
-msgstr ""
+msgstr "Imposta istruzione SQL a quella di default"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:93
msgid "Verify"
@@ -2076,11 +2087,11 @@
#: ../gui/wxpython/gui_modules/sqlbuilder.py:94
msgid "Verify SQL statement"
-msgstr ""
+msgstr "Verifica istruzione SQL"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:99
msgid "Apply SQL statement and close the dialog"
-msgstr ""
+msgstr "Applica istruzione SQL e chiudi finestra di dialog"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:101
msgid "Close the dialog"
@@ -2088,11 +2099,11 @@
#: ../gui/wxpython/gui_modules/sqlbuilder.py:103
msgid "Get all values"
-msgstr ""
+msgstr "Ottieni tutti i valori"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:106
msgid "Get sample"
-msgstr ""
+msgstr "Ottieni un esempio"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:149
msgid "Add on double-click"
@@ -2130,7 +2141,7 @@
#: ../gui/wxpython/gui_modules/sqlbuilder.py:425
msgid "SQL statement is not valid"
-msgstr ""
+msgstr "Istruzione SQL non valida"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:427
#, python-format
@@ -2139,6 +2150,9 @@
"\n"
"%s"
msgstr ""
+"Istruzione SQL non è valida.\n"
+"\n"
+"%s"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:428
#: ../gui/wxpython/gui_modules/mapdisp_window.py:2731
@@ -2148,13 +2162,13 @@
#: ../gui/wxpython/gui_modules/sqlbuilder.py:430
msgid "SQL statement is valid"
-msgstr ""
+msgstr "Istruzione SQL valida"
#: ../gui/wxpython/gui_modules/sqlbuilder.py:453
#: ../gui/wxpython/gui_modules/dbm.py:744
#: ../gui/wxpython/gui_modules/dbm.py:2009
msgid "SQL Builder"
-msgstr ""
+msgstr "Generatore SQL"
#: ../gui/wxpython/gui_modules/gcmd.py:102
#, python-format
@@ -2167,11 +2181,11 @@
#: ../gui/wxpython/gui_modules/gcmd.py:117
msgid "Vector digitizer error"
-msgstr ""
+msgstr "Errore nel digitalizzatore di vettori"
#: ../gui/wxpython/gui_modules/gcmd.py:124
msgid "Attribute table manager error"
-msgstr ""
+msgstr "Errore nel manager degli attributi della tabella"
#: ../gui/wxpython/gui_modules/gcmd.py:131
msgid "Nviz error"
@@ -2198,16 +2212,16 @@
#: ../gui/wxpython/gui_modules/prompt.py:392
#, python-format
msgid "Warning: flag <%s> not found in '%s'"
-msgstr ""
+msgstr "Attenzione: opzione <%s> non trovata in '%s'"
#: ../gui/wxpython/gui_modules/prompt.py:395
+#, python-format
msgid "Warning: option <%s> not found in '%s'"
-msgstr "ERROR: Location <%s> non trovata"
#: ../gui/wxpython/gui_modules/prompt.py:598
msgid "Type GRASS command and run by pressing ENTER"
-msgstr ""
+msgstr "Digita un comando di GRASS e avvialo premendo ENTER"
#: ../gui/wxpython/gui_modules/wxgui_utils.py:107
#, python-format
@@ -2237,7 +2251,7 @@
#: ../gui/wxpython/gui_modules/wxgui_utils.py:271
msgid "Set computational region from selected map(s)"
-msgstr ""
+msgstr "Imposta la region computazionale dalla/e mappa/e selezionata/e"
#: ../gui/wxpython/gui_modules/wxgui_utils.py:287
msgid "Show attribute data"
@@ -2267,6 +2281,7 @@
#: ../gui/wxpython/gui_modules/wxgui_utils.py:348
msgid "Set computational region from selected map(s) (ignore NULLs)"
msgstr ""
+"Imposta la region computazionale dalla/e mappa/e selezionata/e (ignora nulli)"
#: ../gui/wxpython/gui_modules/wxgui_utils.py:351
msgid "Set color table"
@@ -2344,9 +2359,8 @@
#: ../gui/wxpython/gui_modules/wxgui_utils.py:701
#: ../gui/wxpython/menustrings.py:304
-#, fuzzy
msgid "Shaded relief"
-msgstr "Mappa rilievo ombreggiata"
+msgstr "Mappa rilievo ombreggiato"
#: ../gui/wxpython/gui_modules/wxgui_utils.py:704
msgid "raster cell numbers"
@@ -2375,7 +2389,7 @@
#: ../gui/wxpython/gui_modules/wxgui_utils.py:722
msgid "geodesic line"
-msgstr ""
+msgstr "linea geodetica"
#: ../gui/wxpython/gui_modules/wxgui_utils.py:725
msgid "rhumbline"
@@ -2409,7 +2423,7 @@
#: ../gui/wxpython/gui_modules/mapdisp_window.py:1527
msgid "Vector digitizer"
-msgstr ""
+msgstr "Digitalizzatore di vettori"
#: ../gui/wxpython/gui_modules/mapdisp_window.py:2205
msgid "Z bulk-labeling dialog"
@@ -2464,7 +2478,7 @@
#: ../gui/wxpython/gui_modules/toolbars.py:819
msgid "Flip selected lines/boundaries"
-msgstr ""
+msgstr "Inverti le linee/confini selezionati"
#: ../gui/wxpython/gui_modules/toolbars.py:827
msgid "Merge selected lines/boundaries"
@@ -2476,7 +2490,7 @@
#: ../gui/wxpython/gui_modules/toolbars.py:843
msgid "Snap selected lines/boundaries (only to nodes)"
-msgstr ""
+msgstr "Scollega linee/perimetri selezionati (solo nei nodi)"
#: ../gui/wxpython/gui_modules/toolbars.py:851
msgid "Connect selected lines/boundaries"
@@ -2516,6 +2530,8 @@
"Unable to initialize display driver of vector digitizer. See 'Command "
"output' for details."
msgstr ""
+"Impossibile avvira il monitor per il digitalizzatore di vettori. Vedi "
+"'Command output' per i dettagli"
#: ../gui/wxpython/gui_modules/toolbars.py:1159
#, python-format
@@ -2591,12 +2607,12 @@
#: ../gui/wxpython/gui_modules/help.py:181
msgid "You must run this command from the menu or command line"
-msgstr ""
+msgstr "Devi eseguire questo comando dal menu o da linea di di comano"
#: ../gui/wxpython/gui_modules/help.py:261
#, python-format
msgid "%d items match"
-msgstr ""
+msgstr "%d oggetti che combaciano"
#: ../gui/wxpython/gui_modules/help.py:313
msgid "Menu tree"
@@ -2633,56 +2649,52 @@
msgstr "Autori"
#: ../gui/wxpython/gui_modules/help.py:425
-#, fuzzy
msgid "Contributors"
-msgstr "Attributi"
+msgstr "Contributori"
#: ../gui/wxpython/gui_modules/help.py:426
-#, fuzzy
msgid "Translators"
-msgstr "Trasparente"
+msgstr "Traduttori"
#: ../gui/wxpython/gui_modules/help.py:459
#: ../gui/wxpython/gui_modules/help.py:484
#: ../gui/wxpython/gui_modules/help.py:508
#: ../gui/wxpython/gui_modules/help.py:544
#: ../gui/wxpython/gui_modules/help.py:585
+#, python-format
msgid "%s file missing"
-msgstr "File COPYING mancante"
+msgstr "File %s mancante"
#: ../gui/wxpython/gui_modules/help.py:531
#: ../gui/wxpython/gui_modules/help.py:593
-#, fuzzy
msgid "Name"
-msgstr "Rinomina"
+msgstr "Nome"
#: ../gui/wxpython/gui_modules/help.py:595
msgid "E-mail"
-msgstr ""
+msgstr "E-mail"
msgid "Country"
-msgstr ""
+msgstr "Stato"
msgid "OSGeo_ID"
-msgstr ""
+msgstr "OSGeo_ID"
#: ../gui/wxpython/gui_modules/help.py:597
-#, fuzzy
msgid "Language"
-msgstr "Gestione"
+msgstr "Linguaggio"
#: ../gui/wxpython/gui_modules/georect.py:114
msgid "Setup for georectification"
-msgstr ""
+msgstr "Impostazioni per la georettifica"
#: ../gui/wxpython/gui_modules/georect.py:147
#: ../gui/wxpython/gui_modules/georect.py:153
msgid "Georectifying setup canceled."
-msgstr ""
+msgstr "Impostazioni per la georettifica cancellate."
#: ../gui/wxpython/gui_modules/georect.py:191
msgid "Set ground control points (GCPs)"
@@ -2742,7 +2754,7 @@
#: ../gui/wxpython/gui_modules/georect.py:519
msgid "You must enter an map name extension in order to continue"
-msgstr ""
+msgstr "Per poter continuare devi inserire il nome dell'estensione della mappa"
#: ../gui/wxpython/gui_modules/georect.py:581
msgid "Select image/map to display for ground control point (GCP) creation"
@@ -2763,7 +2775,6 @@
msgstr "Crea & gestisci punti di controllo sul terreno"
#: ../gui/wxpython/gui_modules/georect.py:760
-#, fuzzy
msgid "Select rectification method for rasters"
msgstr "Seleziona metodo di rettificazione per raster"
@@ -2772,18 +2783,16 @@
msgstr "I grado"
#: ../gui/wxpython/gui_modules/georect.py:761
-#, fuzzy
msgid "2nd order"
msgstr "II grado"
-#, fuzzy
msgid "3rd order"
msgstr "III grado"
#: ../gui/wxpython/gui_modules/georect.py:767
msgid "clip to computational region in target location"
-msgstr ""
+msgstr "adatta la region computazionale nella location di destinazione"
#: ../gui/wxpython/gui_modules/georect.py:772
msgid "Ground Control Points"
@@ -2878,11 +2887,11 @@
#: ../gui/wxpython/gui_modules/georect.py:1324
msgid "Forward error"
-msgstr ""
+msgstr "Errore successivo"
#: ../gui/wxpython/gui_modules/georect.py:1325
msgid "Backward error"
-msgstr ""
+msgstr "Errore precedente"
#: ../gui/wxpython/gui_modules/georect.py:1426
#: ../gui/wxpython/gui_modules/georect.py:1568
@@ -2969,19 +2978,19 @@
#: ../gui/wxpython/gui_modules/rules.py:62
msgid "Recode raster map using rules"
-msgstr ""
+msgstr "Ricampiona raster usando regole"
#: ../gui/wxpython/gui_modules/rules.py:63
msgid "Raster map to recode:"
-msgstr ""
+msgstr "Raster da ricampionare:"
#: ../gui/wxpython/gui_modules/rules.py:64
msgid "Recoded raster map:"
-msgstr ""
+msgstr "Raster ricampionato:"
#: ../gui/wxpython/gui_modules/rules.py:65
msgid "Enter recoding rules"
-msgstr ""
+msgstr "Inserisci regole per il ricampionamento"
#: ../gui/wxpython/gui_modules/rules.py:68
msgid "Reclassify vector map using SQL rules"
@@ -3012,6 +3021,11 @@
"\n"
"Number of skipped lines: %(line)d"
msgstr ""
+"Alcune linee sono state saltate durante la lettura delle impostazioni dal "
+"file <%(file)s>.\n"
+"Controllare la finestra 'Output del comando' per dettagli.\n"
+"\n"
+"Numero delle linee saltate: %(line)d"
#: ../gui/wxpython/gui_modules/workspace.py:1209
#, python-format
@@ -3034,7 +3048,7 @@
#: ../gui/wxpython/gui_modules/profile.py:165
msgid "Distance along transect"
-msgstr ""
+msgstr "Distanza lungo il transetto"
#: ../gui/wxpython/gui_modules/profile.py:166
msgid "Cell values"
@@ -3052,10 +3066,11 @@
#: ../gui/wxpython/gui_modules/profile.py:476
msgid "You must draw a transect to profile in the map display window."
msgstr ""
+"Devi disegnare un transetto per il profilo nella finestra di visualizzazione."
#: ../gui/wxpython/gui_modules/profile.py:477
msgid "Nothing to profile"
-msgstr ""
+msgstr "Nessun elemento per creare il profilo"
#: ../gui/wxpython/gui_modules/profile.py:687
msgid "Profile text settings"
@@ -3067,7 +3082,7 @@
#: ../gui/wxpython/gui_modules/profile.py:776
msgid "Select raster map to profile"
-msgstr ""
+msgstr "Seleziona raster per creare il profilo"
#: ../gui/wxpython/gui_modules/profile.py:811
msgid "Select raster map 1 (required):"
@@ -3129,9 +3144,8 @@
#: ../gui/wxpython/gui_modules/profile.py:1166
#: ../gui/wxpython/gui_modules/vdigit.py:1243
-#, fuzzy
msgid "Line width"
-msgstr "Grandezza Linea"
+msgstr "Grandezza linea"
#: ../gui/wxpython/gui_modules/profile.py:1176
msgid "Line style"
@@ -3262,29 +3276,31 @@
"\n"
"Details: %(detail)s"
msgstr ""
+"Errore caricando i dati degli attributi. Numero dei record: %(rec)d. "
+"Impossibile convertire il valore '%(val)s' nella colonna chiave (%(key)s) in "
+"intero.\n"
+"\n"
+"Dettagli: %(detail)s"
#: ../gui/wxpython/gui_modules/dbm.py:407
-#, fuzzy
msgid "Sort ascending"
-msgstr "Incomincia l'editing"
+msgstr "Ordina in ordine decrescente"
#: ../gui/wxpython/gui_modules/dbm.py:408
-#, fuzzy
msgid "Sort descending"
+msgstr "Ordina in modo decrescente"
#: ../gui/wxpython/gui_modules/dbm.py:411
msgid "Calculate (only numeric columns)"
-msgstr ""
+msgstr "Calcola (solo colonne numeriche)"
#: ../gui/wxpython/gui_modules/dbm.py:417
msgid "Area size"
-msgstr ""
+msgstr "Dimensione dell'area"
#: ../gui/wxpython/gui_modules/dbm.py:418
-#, fuzzy
msgid "Line length"
-msgstr "lunghezza"
+msgstr "Lunghezza della linea"
#: ../gui/wxpython/gui_modules/dbm.py:419
msgid "Compactness of an area"
@@ -3296,30 +3312,28 @@
#: ../gui/wxpython/gui_modules/dbm.py:421
msgid "Perimeter length of an area"
-msgstr ""
+msgstr "Lunghezza del perimetro di un'area"
#: ../gui/wxpython/gui_modules/dbm.py:422
msgid "Number of features for each category"
-msgstr ""
+msgstr "Numero di elementi per ogni categoria"
#: ../gui/wxpython/gui_modules/dbm.py:423
msgid "Slope steepness of 3D line"
msgstr ""
#: ../gui/wxpython/gui_modules/dbm.py:424
-#, fuzzy
msgid "Line sinuousity"
-msgstr "Stile della linea"
+msgstr "Sinuosità della linea"
#: ../gui/wxpython/gui_modules/dbm.py:425
-#, fuzzy
msgid "Line azimuth"
-msgstr "Spessore della linea"
+msgstr ""
#: ../gui/wxpython/gui_modules/dbm.py:577
#: ../gui/wxpython/gui_modules/dbm.py:3059
msgid "GRASS GIS Attribute Table Manager"
-msgstr ""
+msgstr "GRASS GIS Manager della Tabella degli Attributi"
#: ../gui/wxpython/gui_modules/dbm.py:607
#, python-format
@@ -3335,7 +3349,6 @@
msgstr "Gestione della tabella degli attributi"
#: ../gui/wxpython/gui_modules/dbm.py:642
-#, fuzzy
msgid "Browse data"
msgstr "Naviga dati"
@@ -3373,7 +3386,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:742
msgid "Apply SELECT statement and reload data records"
-msgstr ""
+msgstr "Applica l'istruzione SELECT e ricarica i record dei dati"
#: ../gui/wxpython/gui_modules/dbm.py:748
msgid "Simple"
@@ -3829,11 +3842,11 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:214
msgid "Look at:"
-msgstr ""
+msgstr "Zoom a:"
#: ../gui/wxpython/gui_modules/nviz_tools.py:218
msgid "top"
-msgstr ""
+msgstr "sopra"
#: ../gui/wxpython/gui_modules/nviz_tools.py:219
msgid "north"
@@ -3868,7 +3881,6 @@
msgstr "sud-ovest"
#: ../gui/wxpython/gui_modules/nviz_tools.py:233
-#, fuzzy
msgid "Reset"
msgstr "Resetta"
@@ -3878,12 +3890,11 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:258
msgid "Image Appearance"
-msgstr ""
+msgstr "Aspetto dell'Immagine"
#: ../gui/wxpython/gui_modules/nviz_tools.py:282
-#, fuzzy
msgid "Saved NVIZ Settings"
-msgstr "Impostazioni server"
+msgstr "Salva impostazioni NVIZ"
#: ../gui/wxpython/gui_modules/nviz_tools.py:285
msgid "Load"
@@ -3894,10 +3905,9 @@
msgstr "Default"
#: ../gui/wxpython/gui_modules/nviz_tools.py:290
-#, fuzzy
msgid "Load and apply settings from user settings file"
msgstr ""
-"Chiudi dialogo e salva cambiamenti nel file per le impostazione dell'utente "
+"Carica e applica le impostazioni da un file delle impostazione dell'utente"
#: ../gui/wxpython/gui_modules/nviz_tools.py:292
msgid "Restore default settings"
@@ -3941,7 +3951,7 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:350
#: ../gui/wxpython/gui_modules/nviz_tools.py:999
msgid "unset"
-msgstr ""
+msgstr "deseleziona"
#: ../gui/wxpython/gui_modules/nviz_tools.py:355
#: ../gui/wxpython/gui_modules/nviz_tools.py:1004
@@ -3995,9 +4005,8 @@
msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:456
-#, fuzzy
msgid "Coarse:"
-msgstr "Chiudi"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:460
#: ../gui/wxpython/gui_modules/nviz_tools.py:509
@@ -4005,7 +4014,6 @@
msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:478
-#, fuzzy
msgid "style"
msgstr "Stile"
@@ -4018,14 +4026,12 @@
msgstr "superficie"
#: ../gui/wxpython/gui_modules/nviz_tools.py:491
-#, fuzzy
msgid "wire color"
-msgstr "Colore della linea"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:504
-#, fuzzy
msgid "Fine:"
-msgstr "Linea"
+msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:541
msgid "Mask zeros:"
@@ -4033,7 +4039,7 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:545
msgid "by elevation"
-msgstr ""
+msgstr "dall'elevazione"
#: ../gui/wxpython/gui_modules/nviz_tools.py:550
msgid "by color"
@@ -4052,23 +4058,19 @@
msgstr "Linee vettoriali"
#: ../gui/wxpython/gui_modules/nviz_tools.py:647
-#, fuzzy
msgid "Line:"
-msgstr "Linea"
+msgstr "Linea:"
#: ../gui/wxpython/gui_modules/nviz_tools.py:650
-#, fuzzy
msgid "width"
-msgstr "larghezza:"
+msgstr "larghezza"
#: ../gui/wxpython/gui_modules/nviz_tools.py:668
#: ../gui/wxpython/gui_modules/nviz_tools.py:771
-#, fuzzy
msgid "color"
-msgstr "colore:"
+msgstr "colore"
#: ../gui/wxpython/gui_modules/nviz_tools.py:684
-#, fuzzy
msgid "display"
msgstr "Visualizza"
@@ -4090,19 +4092,16 @@
msgstr "Punti vettoriale"
#: ../gui/wxpython/gui_modules/nviz_tools.py:750
-#, fuzzy
msgid "Icon:"
-msgstr "Dimensione dell'icona:"
+msgstr "Icona:"
#: ../gui/wxpython/gui_modules/nviz_tools.py:753
-#, fuzzy
msgid "size"
-msgstr "Dimensione"
+msgstr "dimensione"
#: ../gui/wxpython/gui_modules/nviz_tools.py:804
-#, fuzzy
msgid "symbol"
-msgstr "simbolo:"
+msgstr "simbolo"
#: ../gui/wxpython/gui_modules/nviz_tools.py:881
msgid "isosurfaces"
@@ -4162,24 +4161,20 @@
msgstr "Descrizione"
#: ../gui/wxpython/gui_modules/goutput.py:213
-#, fuzzy
msgid "C&lear output"
+msgstr "P&ulisci output"
#: ../gui/wxpython/gui_modules/goutput.py:215
-#, fuzzy
msgid "&Clear command"
-msgstr "Comando"
+msgstr ""
#: ../gui/wxpython/gui_modules/goutput.py:219
-#, fuzzy
msgid "&Save output"
+msgstr "&Salva output"
#: ../gui/wxpython/gui_modules/goutput.py:221
-#, fuzzy
msgid "&Abort command"
-msgstr "comando"
+msgstr "&Interrompi programma"
#: ../gui/wxpython/gui_modules/goutput.py:223
msgid "Abort the running command"
@@ -4187,7 +4182,7 @@
#: ../gui/wxpython/gui_modules/goutput.py:250
msgid "Find module:"
-msgstr ""
+msgstr "Trova modulo:"
#: ../gui/wxpython/gui_modules/goutput.py:450
#, python-format
@@ -4195,6 +4190,8 @@
"Command '%s' not yet implemented in the GUI. Try adding it as a command "
"layer instead."
msgstr ""
+"Comando '%s' non è ancora implementato nella GUI. Piuttosto prova "
+"utilizzando la barra dei comandi. "
#: ../gui/wxpython/gui_modules/goutput.py:536
msgid "Save file as..."
@@ -4208,7 +4205,7 @@
#: ../gui/wxpython/gui_modules/goutput.py:666
msgid ""
"Please note that the data are left in incosistent stage and can be corrupted"
-msgstr ""
+msgstr "Attenzione i dati sono inconistenti e possono essere corrotti"
#: ../gui/wxpython/gui_modules/goutput.py:669
msgid "Command aborted"
@@ -4234,19 +4231,19 @@
#: ../gui/wxpython/gui_modules/globalvar.py:103
msgid "Comp. region"
-msgstr ""
+msgstr "Region computazionale"
#: ../gui/wxpython/gui_modules/globalvar.py:104
msgid "Show comp. extent"
-msgstr ""
+msgstr "Mostra region computazionale"
#: ../gui/wxpython/gui_modules/globalvar.py:105
msgid "Display mode"
-msgstr ""
+msgstr "Modalità di visualizzazione"
#: ../gui/wxpython/gui_modules/globalvar.py:106
msgid "Display geometry"
-msgstr "Viasualizza geometrie"
+msgstr "Visualizza geometrie"
#: ../gui/wxpython/gui_modules/globalvar.py:107
msgid "Map scale"
@@ -4258,24 +4255,23 @@
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:33
msgid "No GRASS-python library found."
-msgstr ""
+msgstr "Nessuna librerie GRASS-python trovata."
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:69
msgid "Input Data"
-msgstr ""
+msgstr "Dati di input"
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:75
msgid "Point dataset:"
-msgstr ""
+msgstr "Dataset puntuale:"
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:87
-#, fuzzy
msgid "Numeric column:"
-msgstr "Chiave della colonna:"
+msgstr "Colonna numerica:"
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:98
msgid "Kriging"
-msgstr ""
+msgstr "Kriging"
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:119
#: ../gui/wxpython/menustrings.py:359
@@ -4283,23 +4279,20 @@
msgstr "Uscita"
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:123
-#, fuzzy
msgid "Name for the output raster map:"
-msgstr "Nome per il nuovo vettore:"
+msgstr "Nome per la mappa raster di output:"
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:131
-#, fuzzy
msgid "Export variance map as well: "
-msgstr "Esporta raster"
+msgstr "Esporta mappa della varianza come: "
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:272
msgid "Kriging Module"
-msgstr ""
+msgstr "Modulo Kriging"
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:276
-#, fuzzy
msgid "Ready."
-msgstr "Ricarica"
+msgstr "Pronto."
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:300
msgid "Variogram fitting"
@@ -4310,31 +4303,28 @@
msgstr ""
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:321
-#, fuzzy
msgid ":"
-msgstr "X:"
+msgstr ":"
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:346
msgid "Kriging techniques"
-msgstr ""
+msgstr "Tecniche di Kriging"
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:360
-#, fuzzy
msgid "Block size:"
+msgstr ""
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:393
msgid "Auto-fit variogram"
msgstr ""
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:417
-#, fuzzy
msgid "Model: "
-msgstr "Tipologia:"
+msgstr "Modello:"
#: ../gui/wxpython/gui_modules/v_krige_wxGUI.py:501
msgid "Work in progress! No functionality provided."
-msgstr ""
+msgstr "Lavori in corso! Non esiste ancora la funzione."
#: ../gui/wxpython/gui_modules/ogc_services.py:38
msgid "Import data from WMS server"
@@ -4440,6 +4430,10 @@
"\n"
"Details:"
msgstr ""
+"Impossibile avviare il monitor per il digitalizzatore di vettori. Guardare "
+"'Command output' per i dettagli.\n"
+"\n"
+"Dettagli:"
#: ../gui/wxpython/gui_modules/vdigit.py:134
#: ../gui/wxpython/gui_modules/vdigit.py:141
@@ -4453,8 +4447,7 @@
"Impossibile aprire vettore <%s> per l'editing.\n"
"\n"
"I dati sono probabilmente corrotti, prova ad eseguire v.build per "
-"ricostruire la topologia (Vettoriali->Sviluppo vectoriali->Crea/ricrea "
-"topologia)"
+"ricostruire la topologia (Vettori->Sviluppo vettori->Crea/ricrea topologia)"
#: ../gui/wxpython/gui_modules/vdigit.py:700
msgid "Undo failed, data corrupted."
@@ -4475,15 +4468,15 @@
#: ../gui/wxpython/gui_modules/vdigit.py:1261
msgid "Snapping"
-msgstr ""
+msgstr "Snap"
#: ../gui/wxpython/gui_modules/vdigit.py:1267
msgid "Snapping threshold"
-msgstr ""
+msgstr "Soglia di snap"
#: ../gui/wxpython/gui_modules/vdigit.py:1283
msgid "Snap also to vertex"
-msgstr ""
+msgstr "Snap ai vertici"
#: ../gui/wxpython/gui_modules/vdigit.py:1288
#: ../gui/wxpython/gui_modules/vdigit.py:1733
@@ -4491,7 +4484,7 @@
#: ../gui/wxpython/gui_modules/vdigit.py:1750
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s"
-msgstr ""
+msgstr "La soglia di snap è %(value).1f %(units)s"
#: ../gui/wxpython/gui_modules/vdigit.py:1301
msgid "Select vector features"
@@ -4499,7 +4492,7 @@
#: ../gui/wxpython/gui_modules/vdigit.py:1318
msgid "Select threshold"
-msgstr ""
+msgstr "Seleziona soglia"
#: ../gui/wxpython/gui_modules/vdigit.py:1331
msgid "Select only features inside of selection bounding box"
@@ -4590,11 +4583,11 @@
#: ../gui/wxpython/gui_modules/vdigit.py:1487
msgid "Category number"
-msgstr ""
+msgstr "Numero di categoria"
#: ../gui/wxpython/gui_modules/vdigit.py:1497
msgid "Category mode"
-msgstr ""
+msgstr "Tipologia di categoria"
#: ../gui/wxpython/gui_modules/vdigit.py:1499
msgid "Manual entry"
@@ -4641,6 +4634,8 @@
"Note: These settings are stored in the workspace not in the vector "
"digitizer preferences."
msgstr ""
+"Nota: Queste impostazioni sono salvate nell'ambiente di lavoro e non nelle "
+"preferenze del digitalizzatore di vettori."
#: ../gui/wxpython/gui_modules/vdigit.py:1649
msgid "Highlight"
@@ -4704,17 +4699,19 @@
#: ../gui/wxpython/gui_modules/vdigit.py:1726
msgid "Snapping disabled"
-msgstr ""
+msgstr "Snap disabilitato"
#: ../gui/wxpython/gui_modules/vdigit.py:1728
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
msgstr ""
+"La soglia di snap è %(value).1f %(units)s (basata sulla risoluzione "
+"computazionale)"
#: ../gui/wxpython/gui_modules/vdigit.py:1781
#, python-format
msgid "Vector digitizer settings saved to file <%s>."
-msgstr "Impostazione del digitalizzatore dei vettoriali salvato nel file <%s>."
+msgstr "Impostazione del digitalizzatore dei vettori salvato nel file <%s>."
#: ../gui/wxpython/gui_modules/vdigit.py:1970
msgid "List of categories - right-click to delete"
@@ -4775,7 +4772,7 @@
#: ../gui/wxpython/gui_modules/vdigit.py:2496
msgid "Step"
-msgstr ""
+msgstr "Step"
#: ../gui/wxpython/gui_modules/vdigit.py:2529
msgid "List of duplicates"
@@ -4790,9 +4787,8 @@
msgstr "Layer (Categorie)"
#: ../gui/wxpython/menustrings.py:2
-#, fuzzy
msgid "&File"
-msgstr "File"
+msgstr "&File"
#: ../gui/wxpython/menustrings.py:4
msgid "New"
@@ -5035,13 +5031,12 @@
msgstr "Crea un vettore da file ASCI points o ASCII vector"
#: ../gui/wxpython/menustrings.py:60
-#, fuzzy
msgid "ASCII points as a vector lines"
-msgstr "Importa vettore ASCII points/GRASS ASCII"
+msgstr "Punti ASCII come vettore lineare"
#: ../gui/wxpython/menustrings.py:61
msgid "Import ASCII x,y[,z] coordinates as a series of lines."
-msgstr ""
+msgstr "Importa coordinati in ASCII x,y[,z] con serie di linee."
#: ../gui/wxpython/menustrings.py:62
msgid "Old GRASS vector import"
@@ -5106,7 +5101,7 @@
#: ../gui/wxpython/menustrings.py:75
msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr ""
+msgstr "Importa file di stati da geonames.org in vettore puntuale di GRASS."
#: ../gui/wxpython/menustrings.py:76
msgid "GEOnet import"
@@ -5117,6 +5112,8 @@
"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
"points map."
msgstr ""
+"Importa file di stati US-NGA GEOnet Names Server (GNS) in un vettore "
+"puntuale di GRASS."
#: ../gui/wxpython/menustrings.py:78
msgid "Matlab array and MapGen import"
@@ -5405,20 +5402,20 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:147
-#, fuzzy
msgid "List"
-msgstr "Usa lista"
+msgstr "Lista"
#: ../gui/wxpython/menustrings.py:148 ../gui/wxpython/menustrings.py:150
msgid ""
"Lists available GRASS data base files of the user-specified data type to "
"standard output."
msgstr ""
+"Lista dei file del database di GRASS disponibili secondo il tipo specificato "
+"dall'utente."
#: ../gui/wxpython/menustrings.py:149
-#, fuzzy
msgid "List filtered"
-msgstr "Lista drivers"
+msgstr "Lista filtrata"
#: ../gui/wxpython/menustrings.py:152
msgid "Renames data base element files in the user's current mapset."
@@ -5433,9 +5430,8 @@
msgstr "Rimuove i file degli elementi nel corrente mapset nel database"
#: ../gui/wxpython/menustrings.py:155
-#, fuzzy
msgid "Delete filtered"
-msgstr "Elimina livello"
+msgstr "Elimina filtro"
#: ../gui/wxpython/menustrings.py:157
msgid "Map type conversions"
@@ -5450,18 +5446,16 @@
msgstr "Converte un raster in un vettore"
#: ../gui/wxpython/menustrings.py:160
-#, fuzzy
msgid "Raster series to volume"
-msgstr "Serie Mappe Raster a volume"
+msgstr "Serie mappe Raster a volume"
#: ../gui/wxpython/menustrings.py:161
msgid "Converts 2D raster map slices to one 3D raster volume map."
msgstr ""
#: ../gui/wxpython/menustrings.py:162
-#, fuzzy
msgid "Raster 2.5D to volume"
+msgstr "Raster 2.5D a volume"
#: ../gui/wxpython/menustrings.py:163
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
@@ -5494,18 +5488,16 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:170
-#, fuzzy
msgid "Sites to vector"
-msgstr "Sites (GRASS 5.x)a vettore"
+msgstr "Sites a vettore"
#: ../gui/wxpython/menustrings.py:171
msgid "Converts a GRASS site_lists file into a vector map."
msgstr ""
#: ../gui/wxpython/menustrings.py:172
-#, fuzzy
msgid "Volume to raster series"
-msgstr "Volumi a serie mappe raster"
+msgstr "Da volumi a serie raster"
#: ../gui/wxpython/menustrings.py:173
msgid "Converts 3D raster maps to 2D raster maps"
@@ -5524,9 +5516,8 @@
msgstr "nviz - Strumento per la visualizzazione e l'animazione per dati GRASS"
#: ../gui/wxpython/menustrings.py:178
-#, fuzzy
msgid "Bearing/distance to coordinates"
-msgstr "Converti tra bearing/distanza e coordinate"
+msgstr ""
#: ../gui/wxpython/menustrings.py:179
msgid ""
@@ -5536,24 +5527,23 @@
#: ../gui/wxpython/menustrings.py:180
msgid "Postscript plot"
-msgstr ""
+msgstr "Stampa Postscript"
#: ../gui/wxpython/menustrings.py:181
msgid "Hardcopy PostScript map output utility."
-msgstr ""
+msgstr "Strumento per stampare la mappa su PostScript"
#: ../gui/wxpython/menustrings.py:182
-#, fuzzy
msgid "Launch script"
-msgstr "Descrizione dei layer"
+msgstr "Lancia script"
#: ../gui/wxpython/menustrings.py:183
msgid "Launches script file."
-msgstr ""
#: ../gui/wxpython/menustrings.py:184
msgid "Exit GUI"
-msgstr ""
+msgstr "Esci dalla GUI"
#: ../gui/wxpython/menustrings.py:185
msgid "Quit wxGUI session"
@@ -5568,9 +5558,8 @@
msgstr "Esci dalla sessione di GRASS includendo wxGUI"
#: ../gui/wxpython/menustrings.py:188
-#, fuzzy
msgid "C&onfig"
-msgstr "Configurazione"
+msgstr "C&onfigurazione"
#: ../gui/wxpython/menustrings.py:189
msgid "Region"
@@ -5582,7 +5571,7 @@
#: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:193
msgid "Manages the boundary definitions for the geographic region."
-msgstr ""
+msgstr "Gestisci i confini per la region."
#: ../gui/wxpython/menustrings.py:192
msgid "Set region"
@@ -5599,6 +5588,7 @@
#: ../gui/wxpython/menustrings.py:196
msgid "Set/unset access to other mapsets in current location"
msgstr ""
+"Seleziona/deseleziona l'accesso ad altri mapset nelle location corrente"
#: ../gui/wxpython/menustrings.py:197
msgid "User access"
@@ -5606,7 +5596,7 @@
#: ../gui/wxpython/menustrings.py:198
msgid "Controls access to the current mapset for other users on the system."
-msgstr ""
+msgstr "Controlla l'accesso di altri utenti al mapset corrente."
#: ../gui/wxpython/menustrings.py:199
msgid "Change working environment"
@@ -5621,9 +5611,8 @@
msgstr "Cambia location e mapset"
#: ../gui/wxpython/menustrings.py:202
-#, fuzzy
msgid "Change current location and mapset."
-msgstr "Cambia location e mapset"
+msgstr "Cambia i correnti location e mapset"
#: ../gui/wxpython/menustrings.py:203
msgid "Change mapset"
@@ -5643,7 +5632,7 @@
#: ../gui/wxpython/menustrings.py:209
msgid "Change default GUI"
-msgstr ""
+msgstr "Cambia la GUI di default"
#: ../gui/wxpython/menustrings.py:210
msgid "Changes the default GRASS graphical user interface (GUI) setting."
@@ -5695,9 +5684,8 @@
msgstr "Preferenze della GUI (font del display, comandi ecc)"
#: ../gui/wxpython/menustrings.py:222
-#, fuzzy
msgid "&Raster"
-msgstr "Raster"
+msgstr "&Raster"
#: ../gui/wxpython/menustrings.py:223
msgid "Develop raster map"
@@ -5738,9 +5726,8 @@
msgstr "Gestisci valori nulli di un raster"
#: ../gui/wxpython/menustrings.py:232
-#, fuzzy
msgid "Quantization"
-msgstr "Animazione"
+msgstr ""
#: ../gui/wxpython/menustrings.py:233
msgid "Produces the quantization file for a floating-point map."
@@ -5755,36 +5742,32 @@
msgstr "Stampa/aggiungi/rimuovi un timestamp di un raster"
#: ../gui/wxpython/menustrings.py:236
-#, fuzzy
msgid "Resample using aggregate statistics"
-msgstr "Statistica univariata"
+msgstr ""
#: ../gui/wxpython/menustrings.py:237
msgid "Resamples raster map layers to a coarser grid using aggregation."
-msgstr ""
+msgstr "Ricampiona il raster ad una griglia meno fitta usando aggregazione."
#: ../gui/wxpython/menustrings.py:238
-#, fuzzy
msgid "Resample using multiple methods"
-msgstr "Ricampiona (cambia risoluzione) usando il metodo dei punti più vicini"
+msgstr "Ricampiona usando diversi metodi"
#: ../gui/wxpython/menustrings.py:239
msgid "Resamples raster map layers to a finer grid using interpolation."
-msgstr ""
+msgstr "Ricampiona il raster ad una griglia più fitta usando interpolazione."
#: ../gui/wxpython/menustrings.py:240
-#, fuzzy
msgid "Resample using nearest neighbor"
+msgstr "Ricampiona usando il metodo dei punti più vicini"
#: ../gui/wxpython/menustrings.py:241
msgid "GRASS raster map layer data resampling capability."
msgstr ""
#: ../gui/wxpython/menustrings.py:242
-#, fuzzy
msgid "Resample using spline tension"
-msgstr "Ricampiona (cambia risoluzione) usando tensione spline regolarizzata"
+msgstr "Ricampiona usando tensione spline"
#: ../gui/wxpython/menustrings.py:243
msgid ""
@@ -5794,9 +5777,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:244 ../gui/wxpython/menustrings.py:526
-#, fuzzy
msgid "Support file maintenance"
-msgstr "Supporto creazione file e mantenimento"
+msgstr ""
#: ../gui/wxpython/menustrings.py:245
msgid "Allows creation and/or modification of raster map layer support files."
@@ -5820,7 +5802,7 @@
#: ../gui/wxpython/menustrings.py:250
msgid "Tiling"
-msgstr ""
+msgstr "Tiling"
#: ../gui/wxpython/menustrings.py:251
msgid ""
@@ -5847,6 +5829,8 @@
#: ../gui/wxpython/menustrings.py:256
msgid "Set color rules based on stddev from a map's mean value."
msgstr ""
+"Stabilisci le regole di colore sulla base della stddev del valore medio "
+"della mappa. "
#: ../gui/wxpython/menustrings.py:257 ../gui/wxpython/menustrings.py:531
msgid "Color rules"
@@ -5854,11 +5838,11 @@
#: ../gui/wxpython/menustrings.py:259
msgid "Blend 2 color rasters"
-msgstr ""
+msgstr "Fondi i colori di 2 raster"
#: ../gui/wxpython/menustrings.py:260
msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
+msgstr "Fonde i colori di due raster secondo un rapporto stabilito."
#: ../gui/wxpython/menustrings.py:261
msgid "Create RGB"
@@ -5878,30 +5862,28 @@
"Generates red, green and blue raster map layers combining hue, intensity and "
"saturation (HIS) values from user-specified input raster map layers."
msgstr ""
+"Genera un raster rosso, verde e blu combinando i valori di colore, intensità "
+"e saturazione (HIS) da un raster di input specificato dall'utente. "
#: ../gui/wxpython/menustrings.py:265
-#, fuzzy
msgid "Query raster maps"
-msgstr "Overlay mappe raster"
+msgstr "Interroga mappe raster"
#: ../gui/wxpython/menustrings.py:266
-#, fuzzy
msgid "Query values by coordinates"
msgstr "Interroga utilizzando coordinate"
#: ../gui/wxpython/menustrings.py:267
msgid "Queries raster map layers on their category values and category labels."
-msgstr ""
+msgstr "Interroga il raster sui suoi valori ed etichette."
#: ../gui/wxpython/menustrings.py:268
-#, fuzzy
msgid "Query colors by value"
+msgstr "Interroga colori dal valore"
#: ../gui/wxpython/menustrings.py:269
-#, fuzzy
msgid "Queries colors for a raster map layer."
-msgstr "Statistiche per raster"
+msgstr "Interroga colori per raster"
#: ../gui/wxpython/menustrings.py:270
msgid "Buffer rasters"
@@ -5921,7 +5903,7 @@
#: ../gui/wxpython/menustrings.py:273
msgid "Locates the closest points between objects in two raster maps."
-msgstr ""
+msgstr "Localizza i punti più vicini degli oggetti in due raster."
#: ../gui/wxpython/menustrings.py:275
msgid "Creates a mask for limiting raster operation."
@@ -5933,7 +5915,7 @@
#: ../gui/wxpython/menustrings.py:277
msgid "Map calculator for raster map algebra"
-msgstr ""
+msgstr "Calcolatore di map algebra per i raster"
#: ../gui/wxpython/menustrings.py:278
msgid "Neighborhood analysis"
@@ -5963,7 +5945,7 @@
#: ../gui/wxpython/menustrings.py:283
msgid "Overlay rasters"
-msgstr ""
+msgstr "Sovrapponi raster"
#: ../gui/wxpython/menustrings.py:284
msgid "Cross product"
@@ -5973,7 +5955,7 @@
msgid ""
"Creates a cross product of the category values from multiple raster map "
"layers."
-msgstr ""
+msgstr "Crea un prodotto incrociato dai valori delle categorie di più raster. "
#: ../gui/wxpython/menustrings.py:286
msgid "Raster series"
@@ -6016,9 +5998,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:295
-#, fuzzy
msgid "Shadows map"
-msgstr "Mostra dati"
+msgstr ""
#: ../gui/wxpython/menustrings.py:296
msgid ""
@@ -6136,9 +6117,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:321
-#, fuzzy
msgid "Grow"
-msgstr "Naviga"
+msgstr ""
#: ../gui/wxpython/menustrings.py:322
msgid "Generates a raster map layer with contiguous areas grown by one cell."
@@ -6167,9 +6147,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:328
-#, fuzzy
msgid "Fill lake"
-msgstr "Riempi aree:"
+msgstr "Riempi aree"
#: ../gui/wxpython/menustrings.py:329
msgid "Fills lake from seed at given level."
@@ -6194,9 +6173,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:334
-#, fuzzy
msgid "Flow lines"
-msgstr "linee"
+msgstr ""
#: ../gui/wxpython/menustrings.py:335
msgid ""
@@ -6263,9 +6241,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:713
-#, fuzzy
msgid "Groundwater modeling"
-msgstr "Punto di controllo sul terreno"
+msgstr ""
#: ../gui/wxpython/menustrings.py:351
msgid ""
@@ -6289,7 +6266,7 @@
#: ../gui/wxpython/menustrings.py:355
msgid "Analyze landscape"
-msgstr ""
+msgstr "Analizza territorio"
#: ../gui/wxpython/menustrings.py:356
msgid ""
@@ -6378,9 +6355,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:376
-#, fuzzy
msgid "Patch density"
-msgstr "Combina mappe"
+msgstr ""
#: ../gui/wxpython/menustrings.py:377
msgid ""
@@ -6388,9 +6364,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:378
-#, fuzzy
msgid "Patch number"
+msgstr "Combina numero"
#: ../gui/wxpython/menustrings.py:379
msgid ""
@@ -6407,7 +6382,7 @@
#: ../gui/wxpython/menustrings.py:382
msgid "Shannon's diversity"
-msgstr ""
+msgstr "Diversità di Shannon"
#: ../gui/wxpython/menustrings.py:383
msgid "Calculates Shannon's diversity index on a raster map"
@@ -6415,7 +6390,7 @@
#: ../gui/wxpython/menustrings.py:384
msgid "Simpson's diversity"
-msgstr ""
+msgstr "Diversità di Simpson"
#: ../gui/wxpython/menustrings.py:385
msgid "Calculates Simpson's diversity index on a raster map"
@@ -6423,25 +6398,23 @@
#: ../gui/wxpython/menustrings.py:386
msgid "Richness"
-msgstr ""
+msgstr "Ricchezza"
#: ../gui/wxpython/menustrings.py:388
-#, fuzzy
msgid "Shape index"
-msgstr "Salva e esci"
+msgstr "Indice shape"
#: ../gui/wxpython/menustrings.py:389
msgid "Calculates shape index on a raster map"
-msgstr ""
+msgstr "Calcola l'indice shape su un raster"
#: ../gui/wxpython/menustrings.py:390
msgid "Wildfire modeling"
msgstr ""
#: ../gui/wxpython/menustrings.py:391
-#, fuzzy
msgid "Rate of spread"
-msgstr "Raster da visualizzare"
+msgstr ""
#: ../gui/wxpython/menustrings.py:392
msgid ""
@@ -6479,9 +6452,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:398
-#, fuzzy
msgid "Interactively edit category values"
-msgstr "Range di tutti i valori di categoria"
+msgstr "Modifica i valori interattivamente"
#: ../gui/wxpython/menustrings.py:399
msgid "Interactively edit cell values in a raster map."
@@ -6500,9 +6472,8 @@
"specifica dall'utente (in ettaari)."
#: ../gui/wxpython/menustrings.py:402
-#, fuzzy
msgid "Reclassify interactively"
-msgstr "Riclassifica le caratteristiche usando un file di regole"
+msgstr "Riclassifica intarattivamente"
#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:405
msgid ""
@@ -6541,9 +6512,8 @@
msgstr "Riscala il range dei valori elle categorie in un raster."
#: ../gui/wxpython/menustrings.py:412
-#, fuzzy
msgid "Rescale with histogram"
-msgstr "Raster a istogramma: "
+msgstr "Ricampiona con istogramma "
#: ../gui/wxpython/menustrings.py:413
msgid ""
@@ -6572,9 +6542,8 @@
msgstr "Genera valori di celle casuali con dipendenza spaziale"
#: ../gui/wxpython/menustrings.py:419
-#, fuzzy
msgid "Random cells and vector points"
-msgstr "Random location perturbations di punti"
+msgstr "Celle e punti vettoriale random"
#: ../gui/wxpython/menustrings.py:420
msgid ""
@@ -6588,9 +6557,8 @@
msgstr "Genera superfici"
#: ../gui/wxpython/menustrings.py:422
-#, fuzzy
msgid "Fractal surface"
-msgstr "Genera superfici frattali"
+msgstr "Superfici frattali"
#: ../gui/wxpython/menustrings.py:423
msgid "Creates a fractal surface of a given fractal dimension."
@@ -6608,9 +6576,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:426
-#, fuzzy
msgid "Gaussian deviates surface"
-msgstr "Genera superfici derivate gaussiane"
+msgstr "Superfici derivate gaussiane"
#: ../gui/wxpython/menustrings.py:427
msgid ""
@@ -6630,9 +6597,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:430
-#, fuzzy
msgid "Random deviates surface"
+msgstr "Superfici derivate casuali"
#: ../gui/wxpython/menustrings.py:431
msgid ""
@@ -6641,9 +6607,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:432
-#, fuzzy
msgid "Random surface with spatial dependence"
-msgstr "Genera superfice casuale con dipendenza spaziale"
+msgstr "Superfice casuale con dipendenza spaziale"
#: ../gui/wxpython/menustrings.py:433
msgid "Generates random surface(s) with spatial dependence."
@@ -6671,9 +6636,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:439
-#, fuzzy
msgid "Bilinear and bicubic from vector points"
-msgstr "Interpola volume da punti vettoriali usando splines"
+msgstr "Bilineare e bicubica da vettore puntuale"
#: ../gui/wxpython/menustrings.py:440
msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
@@ -6693,9 +6657,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:444
-#, fuzzy
msgid "Surface generation program."
-msgstr "Comando per la generazione di superfice da contorni rasterizzati"
+msgstr "Comando per la generazione di superfice."
#: ../gui/wxpython/menustrings.py:445
msgid "IDW from vector points"
@@ -6710,18 +6673,16 @@
"delle distanze al quadrato IDW"
#: ../gui/wxpython/menustrings.py:447
-#, fuzzy
msgid "Raster contours"
-msgstr "Raster a vettoriale"
+msgstr "Raster contorni"
#: ../gui/wxpython/menustrings.py:448
msgid "Surface generation program from rasterized contours."
#: ../gui/wxpython/menustrings.py:449
-#, fuzzy
msgid "Regularized spline tension"
+msgstr ""
#: ../gui/wxpython/menustrings.py:450
msgid ""
@@ -6740,7 +6701,7 @@
#: ../gui/wxpython/menustrings.py:453
msgid "Fill NULL cells"
-msgstr ""
+msgstr "Riempi celle nulle"
#: ../gui/wxpython/menustrings.py:454
msgid ""
@@ -6761,9 +6722,8 @@
msgstr "Stampa informazioni basi di un raster."
#: ../gui/wxpython/menustrings.py:458
-#, fuzzy
msgid "Manage category information"
-msgstr "Informazione file report di base"
+msgstr "Gestisci le informazioni delle categorie"
#: ../gui/wxpython/menustrings.py:459
msgid ""
@@ -6790,23 +6750,20 @@
msgstr "Calcola quantili utilizzando due raster."
#: ../gui/wxpython/menustrings.py:464
-#, fuzzy
msgid "Range of category values"
+msgstr "Range dei valori della categoria"
#: ../gui/wxpython/menustrings.py:465
msgid "Prints terse list of category values found in a raster map layer."
msgstr "Stampa lista concisa dei valori delle categorie trovate nel raster"
#: ../gui/wxpython/menustrings.py:466
-#, fuzzy
msgid "Sum category values"
-msgstr "Valori del raster"
+msgstr "Somma valori della categoria"
#: ../gui/wxpython/menustrings.py:467
-#, fuzzy
msgid "Sums up the raster cell values."
-msgstr "numeri delle celle raster"
+msgstr "Somma valori delle celle raster"
#: ../gui/wxpython/menustrings.py:468
msgid "Sum area by raster map and category"
@@ -6846,16 +6803,14 @@
msgstr "Calcola le statistiche univariate per le celle non nulle di un raster"
#: ../gui/wxpython/menustrings.py:476
-#, fuzzy
msgid "Sample transects"
-msgstr "Valori campione lungo i transetti"
+msgstr "Transetto semplice"
#: ../gui/wxpython/menustrings.py:477
msgid "Outputs the raster map layer values lying on user-defined line(s)."
msgstr ""
#: ../gui/wxpython/menustrings.py:478
-#, fuzzy
msgid "Sample transects (bearing/distance)"
msgstr "Valori campione lungo i transetti (uss azimuth, distanza)"
@@ -6877,9 +6832,8 @@
"dall'utente."
#: ../gui/wxpython/menustrings.py:482
-#, fuzzy
msgid "Linear regression"
-msgstr "Regressione lineare tra 2 mappe"
+msgstr "Regressione lineare"
#: ../gui/wxpython/menustrings.py:483
msgid "Calculates linear regression from two raster maps: y = a + b*x"
@@ -6896,9 +6850,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:486
-#, fuzzy
msgid "&Vector"
-msgstr "Vettore"
+msgstr "&Vettore"
#: ../gui/wxpython/menustrings.py:487
msgid "Develop vector map"
@@ -6913,9 +6866,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:491
-#, fuzzy
msgid "Interactive editing and digitization of vector maps."
-msgstr "Modifica interattivamente i valori delle celle in un raster."
+msgstr "Modifica e digitalizzazione interattiva di vettori."
#: ../gui/wxpython/menustrings.py:492
msgid "Edit vector map (non-interactively)"
@@ -6954,9 +6906,8 @@
msgstr "Generalizzazione vettoriale"
#: ../gui/wxpython/menustrings.py:500
-#, fuzzy
msgid "Convert object types"
-msgstr "Tipo interrogazione oggetto non valido"
+msgstr "Converti tipologia d'oggetto"
#: ../gui/wxpython/menustrings.py:501
#, fuzzy
@@ -6980,9 +6931,8 @@
msgstr "Crea polilinee da linee o confini."
#: ../gui/wxpython/menustrings.py:506
-#, fuzzy
msgid "Split lines"
-msgstr "Dividi polilinee"
+msgstr "Dividi linee"
#: ../gui/wxpython/menustrings.py:507
msgid "Split lines to shorter segments."
@@ -7005,9 +6955,8 @@
msgstr "Crea linee parallele di un vettore lineare di input."
#: ../gui/wxpython/menustrings.py:512
-#, fuzzy
msgid "Dissolve boundaries"
-msgstr "confini"
+msgstr "Dissolvi confini"
#: ../gui/wxpython/menustrings.py:513
msgid ""
@@ -7034,19 +6983,16 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:518
-#, fuzzy
msgid "Create labels"
-msgstr "Crea tabella"
+msgstr "Crea label"
#: ../gui/wxpython/menustrings.py:519
-#, fuzzy
msgid "Create optimally placed labels for vector map(s)"
-msgstr "Crea nuova tavola dei colori per vettoriale"
+msgstr "Crea label posizionate ottimalmente per vettori"
#: ../gui/wxpython/menustrings.py:520
-#, fuzzy
msgid "Create optimally placed labels"
-msgstr "Crea etichette"
+msgstr "Crea label posizionate ottimalmente"
#: ../gui/wxpython/menustrings.py:521
msgid "Creates paint labels for a vector map from attached attributes."
@@ -7066,16 +7012,15 @@
#: ../gui/wxpython/menustrings.py:524
msgid "Reproject vector map"
-msgstr "Riproietta vettoriali"
+msgstr "Riproietta vettori"
#: ../gui/wxpython/menustrings.py:525
msgid "Allows projection conversion of vector maps."
-msgstr "Permette la conversione di proiezione per vettoriali"
+msgstr "Permette la conversione di proiezione per vettori"
#: ../gui/wxpython/menustrings.py:527
-#, fuzzy
msgid "Updates vector map metadata."
-msgstr "Metadati basilari per vettoriale"
+msgstr "Aggiorna metadati per vettoriale"
#: ../gui/wxpython/menustrings.py:530
msgid ""
@@ -7161,9 +7106,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:548
-#, fuzzy
msgid "Linear referencing"
-msgstr "Riferimento lineare per i vettori"
+msgstr "Riferimento lineare"
#: ../gui/wxpython/menustrings.py:549
msgid "Create LRS"
@@ -7174,9 +7118,8 @@
msgstr "Crea sistema di riferimento lineare"
#: ../gui/wxpython/menustrings.py:551
-#, fuzzy
msgid "Create stationing"
-msgstr "Visualizza impostazione regione"
+msgstr ""
#: ../gui/wxpython/menustrings.py:552
msgid "Create stationing from input lines, and linear reference system"
@@ -7205,9 +7148,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:557
-#, fuzzy
msgid "Nearest features"
-msgstr "Caratteristiche lineare sottili"
+msgstr "Elemento più vicino"
#: ../gui/wxpython/menustrings.py:558
msgid ""
@@ -7238,9 +7180,8 @@
msgstr "Esegue la manutenzione della rete."
#: ../gui/wxpython/menustrings.py:564
-#, fuzzy
msgid "Visibility network"
-msgstr "Visibilità/linea di vista"
+msgstr ""
#: ../gui/wxpython/menustrings.py:565
msgid "Visibility graph construction."
@@ -7263,9 +7204,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:570
-#, fuzzy
msgid "Split net"
-msgstr "Rompi linea"
+msgstr "Dividi linea"
#: ../gui/wxpython/menustrings.py:571
msgid "Splits net by cost isolines."
@@ -7290,15 +7230,15 @@
#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:577
msgid "Overlay vector maps"
-msgstr "Overlay vettoriali"
+msgstr "Overlay vettori"
#: ../gui/wxpython/menustrings.py:578
msgid "Overlays two vector maps."
-msgstr "Overlay due vettoriali."
+msgstr "Overlay due vettori."
#: ../gui/wxpython/menustrings.py:579
msgid "Patch vector maps"
-msgstr "Unisci vettoriali"
+msgstr "Unisci vettori"
#: ../gui/wxpython/menustrings.py:580
msgid "Create a new vector map layer by combining other vector map layers."
@@ -7309,18 +7249,16 @@
msgstr "Cambia campi"
#: ../gui/wxpython/menustrings.py:582
-#, fuzzy
msgid "Manage or report categories"
-msgstr "Collega, elimina, o vedi categorie"
+msgstr "Gestisce o visualizza categorie"
#: ../gui/wxpython/menustrings.py:583
msgid "Attach, delete or report vector categories to map geometry."
msgstr "Attacca, elimina o visualizza le categorie per geometrie della mappa."
#: ../gui/wxpython/menustrings.py:584
-#, fuzzy
msgid "Reclassify objects interactively"
-msgstr "Classifica image"
+msgstr "Riclassifica oggetti interattivamente"
#: ../gui/wxpython/menustrings.py:585 ../gui/wxpython/menustrings.py:587
msgid ""
@@ -7336,9 +7274,8 @@
msgstr "Riclassifica oggetti usando file di regole"
#: ../gui/wxpython/menustrings.py:588
-#, fuzzy
msgid "Generate area for current region"
-msgstr "Genera caratteristiche area per estendere la regione corrente"
+msgstr "Genera area per la regione corrente"
#: ../gui/wxpython/menustrings.py:589
msgid "Create a new vector from the current region."
@@ -7350,7 +7287,7 @@
#: ../gui/wxpython/menustrings.py:591
msgid "Convex hull"
-msgstr ""
+msgstr "Poligoni convessi"
#: ../gui/wxpython/menustrings.py:592
msgid "Uses a GRASS vector points map to produce a convex hull vector map."
@@ -7358,9 +7295,8 @@
"Usa un vettoriale di punti per produrre un vettoriale di poligoni convessi."
#: ../gui/wxpython/menustrings.py:593
-#, fuzzy
msgid "Delaunay triangles"
-msgstr "Genera triangoli Delaunay per punti impostati"
+msgstr "Triangoli di Delaunay"
#: ../gui/wxpython/menustrings.py:594
msgid ""
@@ -7371,9 +7307,8 @@
"centroidi."
#: ../gui/wxpython/menustrings.py:595
-#, fuzzy
msgid "Voronoi diagram/Thiessen polygons"
-msgstr "Genera diagramma Voronoi/poligoni Thiessen per point set"
+msgstr "Diagramma Voronoi/poligoni Thiessen"
#: ../gui/wxpython/menustrings.py:596
msgid ""
@@ -7420,18 +7355,16 @@
msgstr "Genera casualmente un mappa puntuale 2D/3D"
#: ../gui/wxpython/menustrings.py:606
-#, fuzzy
msgid "Perturb points"
-msgstr "Genera punti"
+msgstr "Perturba punti"
#: ../gui/wxpython/menustrings.py:607
msgid "Random location perturbations of GRASS vector points"
msgstr "Disturbo casuale del posizionamento di punti vettoriali"
#: ../gui/wxpython/menustrings.py:608
-#, fuzzy
msgid "Remove outliers in point sets"
+msgstr ""
#: ../gui/wxpython/menustrings.py:609
msgid "Removes outliers from vector point data."
@@ -7502,17 +7435,16 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:624
-#, fuzzy
msgid "Classify attribute data"
-msgstr "Mostra gli attributi dei dati"
+msgstr "Classifica attributi dei dati"
#: ../gui/wxpython/menustrings.py:625
msgid "Classifies attribute data, e.g. for thematic mapping"
-msgstr ""
+msgstr "Classifica i dati degli attributi, es. per mappe tematiche"
#: ../gui/wxpython/menustrings.py:626
msgid "Report topology by category"
-msgstr ""
+msgstr "Visualizza topologia per categoria"
#: ../gui/wxpython/menustrings.py:627
msgid "Reports geometry statistics for vectors."
@@ -7524,12 +7456,11 @@
#: ../gui/wxpython/menustrings.py:629
msgid "Populates database values from vector features."
-msgstr "Popola i valori del database da features vettoriali"
+msgstr "Popola i valori del database da elementi vettoriali"
#: ../gui/wxpython/menustrings.py:630
-#, fuzzy
msgid "Univariate attribute statistics for points"
-msgstr "Statistiche univariate attributi"
+msgstr "Statistiche univariate attributi per punti"
#: ../gui/wxpython/menustrings.py:631
msgid ""
@@ -7540,16 +7471,16 @@
"standard è calcolate solo per punti se specificato."
#: ../gui/wxpython/menustrings.py:632
-#, fuzzy
msgid "Univariate statistics for attribute columns"
+msgstr "Statistiche univariate attributi delle colonne"
#: ../gui/wxpython/menustrings.py:633
-#, fuzzy
msgid ""
"Calculates univariate statistics on selected table column for a GRASS vector "
"map."
-msgstr "Calcola le statistiche univariate per le celle non nulle di un raster"
+msgstr ""
+"Calcola statistiche univariate per un vettore GRASS sulla colonna della "
+"tabella seleziona"
#: ../gui/wxpython/menustrings.py:634
msgid "Quadrat indices"
@@ -7560,18 +7491,16 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:636
-#, fuzzy
msgid "Test normality"
-msgstr "normale"
+msgstr "Test di normalità"
#: ../gui/wxpython/menustrings.py:637
msgid "Tests for normality for points."
msgstr ""
#: ../gui/wxpython/menustrings.py:638
-#, fuzzy
msgid "&Imagery"
-msgstr "Immagini"
+msgstr "&Immagini"
#: ../gui/wxpython/menustrings.py:639
msgid "Develop images and groups"
@@ -7586,18 +7515,16 @@
msgstr "Crea, modifica e visualizza gruppi e sottogruppi di file di immagini."
#: ../gui/wxpython/menustrings.py:642
-#, fuzzy
msgid "Target group"
-msgstr "Obiettivo gruppo imagery"
+msgstr ""
#: ../gui/wxpython/menustrings.py:643
msgid "Targets an imagery group to a GRASS location and mapset."
msgstr ""
#: ../gui/wxpython/menustrings.py:644
-#, fuzzy
msgid "Mosaic images"
-msgstr "Mosaico fino a 4 images adiacenti"
+msgstr "Mosaica immagine"
#: ../gui/wxpython/menustrings.py:645
msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
@@ -7664,17 +7591,19 @@
#: ../gui/wxpython/menustrings.py:660
msgid "Clustering input for unsupervised classification"
-msgstr ""
+msgstr "Input di clustering per classificazione non guidata"
#: ../gui/wxpython/menustrings.py:661
msgid ""
"Generates spectral signatures for land cover types in an image using a "
"clustering algorithm."
msgstr ""
+"Genera firme spettrali per copertura del suolo in un'immagine usando "
+"algoritmi di clustering"
#: ../gui/wxpython/menustrings.py:662
msgid "Maximum likelihood classification (MLC)"
-msgstr ""
+msgstr "Classificazione maximum likelihood (MLC)"
#: ../gui/wxpython/menustrings.py:663
msgid "Classifies the cell spectral reflectances in imagery data."
@@ -7682,13 +7611,15 @@
#: ../gui/wxpython/menustrings.py:664
msgid "Sequential maximum a posteriori classification (SMAP)"
-msgstr ""
+msgstr "Classificazione sequential maximum a posteriori (SMAP)"
#: ../gui/wxpython/menustrings.py:665
msgid ""
"Performs contextual image classification using sequential maximum a "
"posteriori (SMAP) estimation."
msgstr ""
+"Esegue classificazione contestuale di immagini usando la stima sequential "
+"maximum a posteriori (SMAP)."
#: ../gui/wxpython/menustrings.py:666
msgid "Interactive input for supervised classification (requires Xterm)"
@@ -7702,7 +7633,7 @@
#: ../gui/wxpython/menustrings.py:668
msgid "Input for supervised MLC"
-msgstr ""
+msgstr "Input per MLC controllato"
#: ../gui/wxpython/menustrings.py:669
msgid "Generates statistics for i.maxlik from raster map."
@@ -7710,7 +7641,7 @@
#: ../gui/wxpython/menustrings.py:670
msgid "Input for supervised SMAP"
-msgstr ""
+msgstr "Input per SMAP controllato"
#: ../gui/wxpython/menustrings.py:671
msgid "Generates statistics for i.smap from raster map."
@@ -7721,9 +7652,8 @@
msgstr "Filtra image"
#: ../gui/wxpython/menustrings.py:673
-#, fuzzy
msgid "Edge detection"
-msgstr "Usa la Selezione"
+msgstr "Rilevamento dei bordi"
#: ../gui/wxpython/menustrings.py:674
msgid "Zero-crossing \"edge detection\" raster function for image processing."
@@ -7735,11 +7665,11 @@
#: ../gui/wxpython/menustrings.py:676
msgid "Raster map matrix filter."
-msgstr ""
+msgstr "Filtra raster attraverso matrice"
#: ../gui/wxpython/menustrings.py:678
msgid "Generate histogram of image"
-msgstr ""
+msgstr "Genera istogramma dell'immagine"
#: ../gui/wxpython/menustrings.py:679
msgid "Spectral response"
@@ -7752,24 +7682,25 @@
#: ../gui/wxpython/menustrings.py:681
msgid "Tasseled cap vegetation index"
-msgstr ""
+msgstr "Indice di vegetazione Tasseled cap"
#: ../gui/wxpython/menustrings.py:682
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-msgstr ""
+msgstr "Trasformazione Tasseled cap (Kauth Thomas) per dati LANDSAT-TM"
#: ../gui/wxpython/menustrings.py:683
msgid "Transform image"
msgstr "Trasforma image"
#: ../gui/wxpython/menustrings.py:684
-#, fuzzy
msgid "Canonical correlation"
-msgstr "Componente canonica"
+msgstr "Correlazione canonica"
#: ../gui/wxpython/menustrings.py:685
msgid "Canonical components analysis (cca) program for image processing."
msgstr ""
+"Programma per l'Analisi dei Componenti Standard (cca) per il processamento "
+"di immagini"
#: ../gui/wxpython/menustrings.py:686
msgid "Principal components"
@@ -7778,24 +7709,25 @@
#: ../gui/wxpython/menustrings.py:687
msgid "Principal components analysis (pca) program for image processing."
msgstr ""
+"Programma per l'Analisi dei Principali Componenti (pca) per il processamento "
+"di immagini"
#: ../gui/wxpython/menustrings.py:688
-#, fuzzy
msgid "Fast Fourier"
-msgstr "Fast Fourier Transform"
+msgstr "Fast Fourier"
#: ../gui/wxpython/menustrings.py:689
msgid "Fast Fourier Transform (FFT) for image processing."
-msgstr ""
+msgstr "Trasformazione Fast Fourier IFFT) per il processamento di immagini"
#: ../gui/wxpython/menustrings.py:690
-#, fuzzy
msgid "Inverse Fast Fourier"
-msgstr "Fast Fourier Transform Inversa"
+msgstr "Fast Fourier inversa"
#: ../gui/wxpython/menustrings.py:691
msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
msgstr ""
+"Trasformazione Fast Fourier inversa (IFFT) per il processamento di immagini"
#: ../gui/wxpython/menustrings.py:692
msgid "Atmospheric correction"
@@ -7814,29 +7746,30 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:697
-#, fuzzy
msgid "Kappa analysis"
-msgstr "Analisi terreno"
+msgstr "Analisi Kappa"
#: ../gui/wxpython/menustrings.py:698
msgid ""
"Calculate error matrix and kappa parameter for accuracy assessment of "
"classification result."
msgstr ""
+"Calcola la matrice d'errore e il parametro kappa per valutare la precisione "
+"della classificazione risultante."
#: ../gui/wxpython/menustrings.py:699
-#, fuzzy
msgid "OIF for LandSat TM"
-msgstr "Fattore indice ottimale per LandSat TM"
+msgstr "Fattore Indice Ottimale per LandSat TM"
#: ../gui/wxpython/menustrings.py:700
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
msgstr ""
+"Calcolate la tabella Fattore Indice Ottimale per le bande 1-5 e 7 per i "
+"LANDSAT TM"
#: ../gui/wxpython/menustrings.py:701
-#, fuzzy
msgid "V&olumes"
-msgstr "Volumi"
+msgstr "V&olumi"
#: ../gui/wxpython/menustrings.py:702
msgid "Develop volumes"
@@ -7876,13 +7809,15 @@
#: ../gui/wxpython/menustrings.py:711
msgid "Cross section"
-msgstr ""
+msgstr "Sezione trasversale"
#: ../gui/wxpython/menustrings.py:712
msgid ""
"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
"map"
msgstr ""
+"Crea una sezione trasversale 2D da un raster 3D e una mappa dell'elevazione "
+"2D"
#: ../gui/wxpython/menustrings.py:714
msgid ""
@@ -7906,38 +7841,35 @@
#: ../gui/wxpython/menustrings.py:718
msgid "Basic volume metadata"
-msgstr ""
+msgstr "Metadati sul volume"
#: ../gui/wxpython/menustrings.py:719
msgid "Outputs basic information about a user-specified 3D raster map layer."
msgstr ""
+"Visualizza le informazioni basilari su un raster 3D specificato dall'utente"
#: ../gui/wxpython/menustrings.py:720
-#, fuzzy
msgid "Voxel statistics"
-msgstr "Statistiche generali"
+msgstr "Statistiche voxel"
#: ../gui/wxpython/menustrings.py:721
-#, fuzzy
msgid "Generates volume statistics for raster3d maps."
-msgstr "Genera statistiche per layer raster"
+msgstr "Genera statistiche volumetriche per raster 3D."
#: ../gui/wxpython/menustrings.py:722
-#, fuzzy
msgid "Univariate statistics for volumes"
-msgstr "Statistiche univariate raster"
+msgstr "Statistiche univariate per volumi"
#: ../gui/wxpython/menustrings.py:723
-#, fuzzy
msgid ""
"Calculates univariate statistics from the non-null 3d cells of a raster3d "
"map."
+msgstr ""
+"Calcola le statistiche univariate per le celle 3D non nulle di un raster 3D"
#: ../gui/wxpython/menustrings.py:724
-#, fuzzy
msgid "&Database"
-msgstr "Database"
+msgstr "&Database"
#: ../gui/wxpython/menustrings.py:725
msgid "Database information"
@@ -8009,13 +7941,12 @@
msgstr "Nuova tabella"
#: ../gui/wxpython/menustrings.py:742
-#, fuzzy
msgid ""
"Creates and connects a new attribute table to a given layer of an existing "
"vector map."
msgstr ""
-"Crea e aggiunge una nuova tabella degli attributi per un certo layer di una "
-"mappa vettoriale esistente"
+"Crea e connette una nuova tabella degli attributi per un certo layer di una "
+"mappa vettoriale esistente."
#: ../gui/wxpython/menustrings.py:743
msgid "Remove table"
@@ -8056,9 +7987,8 @@
"vettoriale"
#: ../gui/wxpython/menustrings.py:751
-#, fuzzy
msgid "Test"
-msgstr "Testo"
+msgstr "Test"
#: ../gui/wxpython/menustrings.py:752
msgid "Test database driver, database must exist and set by db.connect."
@@ -8072,7 +8002,7 @@
#: ../gui/wxpython/menustrings.py:755
msgid "Selects data from attribute table (performs SQL query statement(s))."
-msgstr ""
+msgstr "Seleziona dati dalla tabella degli attributi (esegue istruzione SQL)."
#: ../gui/wxpython/menustrings.py:756
msgid "Query vector attribute data"
@@ -8088,7 +8018,7 @@
#: ../gui/wxpython/menustrings.py:759
msgid "Executes any SQL statement."
-msgstr ""
+msgstr "Esegui ogni istruzione SQL."
#: ../gui/wxpython/menustrings.py:760
msgid "Vector database connections"
@@ -8175,7 +8105,7 @@
"(directories of GIS files)"
msgstr ""
"Mapsets accessibile\n"
-"(directory dei file GIS)"
+"(cartella dei file GIS)"
#: ../gui/wxpython/gis_set.py:113
msgid ""
@@ -8323,11 +8253,11 @@
#: ../gui/wxpython/gis_set.py:714
msgid "GRASS Quickstart"
-msgstr ""
+msgstr "GRASS Quickstart"
#: ../gui/wxpython/gis_set.py:791
msgid "Starting GRASS for the first time"
-msgstr ""
+msgstr "Si sta avviando GRASS per la prima volta"
#: ../gui/wxpython/gis_set.py:792
msgid ""
@@ -8335,22 +8265,21 @@
"have not already done so. A popular choice is \"grassdata\", located in your "
"home directory."
msgstr ""
-"GRASS necessita di una directory dove immagazzinare i dati. Creane una ora "
-"se non lo hai gi? fatto. Una scelta popolare ? \"grassdata\", situata nella "
-"tua home"
+"GRASS necessita di una cartella dove immagazzinare i dati. Creane una ora se "
+"non lo hai gi? fatto. Una scelta popolare ? \"grassdata\", situata nella tua "
+"home"
#: ../gui/wxpython/wxgui.py:102
msgid "GRASS GIS Layer Manager"
-msgstr ""
+msgstr "GRASS GIS Layer Manager"
#: ../gui/wxpython/wxgui.py:264
msgid "Map layers for each display"
msgstr "Layers per ogni display"
#: ../gui/wxpython/wxgui.py:268 ../gui/wxpython/wxgui.py:359
-#, fuzzy
msgid "Command console"
-msgstr "Comando terminato"
+msgstr "Console dei programmi"
#: ../gui/wxpython/wxgui.py:373 ../gui/wxpython/wxgui.py:1565
msgid "Do you want to save changes in the workspace?"
@@ -8366,23 +8295,22 @@
msgstr "Chiudi map display %d"
#: ../gui/wxpython/wxgui.py:457
-#, fuzzy
msgid "Choose script file"
-msgstr "Scegli il file dell'ambiente di lavoro"
+msgstr "Scegli file degli script"
#: ../gui/wxpython/wxgui.py:458
msgid "Bash script (*.sh)|*.sh|Python script (*.py)|*.py"
-msgstr ""
+msgstr "Bash script (*.sh)|*.sh|Python script (*.py)|*.py"
#: ../gui/wxpython/wxgui.py:469
-#, fuzzy, python-format
+#, python-format
msgid "Script file '%s' doesn't exist. Operation cancelled."
-msgstr "Vettore non è 3D. Operazione cancellata"
+msgstr "File '%s' non esiste. Operazione cancellata."
#: ../gui/wxpython/wxgui.py:473
#, python-format
msgid "Launching script '%s'..."
-msgstr ""
+msgstr "Si sta lanciando lo script '%s'..."
#: ../gui/wxpython/wxgui.py:488
#, python-format
@@ -8426,7 +8354,7 @@
#: ../gui/wxpython/wxgui.py:608 ../gui/wxpython/wxgui.py:811
msgid "GRASS Workspace File (*.gxw)|*.gxw"
-msgstr ""
+msgstr "FIle ambiente di lavoro di GRASS (*.gxw)|*.gxw"
#: ../gui/wxpython/wxgui.py:642
#, python-format
@@ -8452,7 +8380,7 @@
#: ../gui/wxpython/wxgui.py:772
msgid "Old GRASS Workspace File (*.grc)|*.grc"
-msgstr ""
+msgstr "Vecchi file d'ambiente di lavoro di GRASS (*.grc)|*.grc"
#: ../gui/wxpython/wxgui.py:810
msgid "Choose file to save current workspace"
@@ -8535,7 +8463,7 @@
#: ../gui/wxpython/wxgui.py:1550
msgid "WARNING: Unable to quit GRASS, uknown GIS_LOCK"
-msgstr ""
+msgstr "Attenzione: impossibile uscira da GRASS, GIS_LOCK sconosciuto"
#: ../gui/wxpython/wxgui.py:1574
msgid "Quit GRASS GUI"
@@ -8599,35 +8527,26 @@
msgid "Datums:"
msgstr "Datum:"
-#, fuzzy
msgid "Vector map <%s> georectified successfully"
-msgstr "nnome"
+msgstr "Vettoriale <%s> georettificato correttamente"
-#, fuzzy
msgid "Copying attributes..."
-msgstr "Mostra attributi"
+msgstr "Copia attributi..."
-#, fuzzy
msgid "Output vector map name"
-msgstr "nnome"
+msgstr "Nome del vettoriale di output"
-#, fuzzy
msgid "Digitize raster map"
-msgstr "Stampa"
+msgstr "Digitalizza raster"
-#, fuzzy
msgid "Reclassify vector objects interactively by entering SQL rules"
-msgstr "vettoriale"
+msgstr "Riclassifica vettoriale interattivamente inserendo regole SQL"
-#, fuzzy
msgid "Ortho Photo rectification"
-msgstr "Esci"
+msgstr "Rettificazione ortofoto"
-#, fuzzy
msgid "GRASS GIS Layer Manager (Experimental Prototype)"
-msgstr ""
-"Layer: %d\n"
-"categoria: %d\n"
+msgstr "GRASS GIS Manager dei layer (Prototipo esperimentale)"
msgid "Parameter element '%(element)s' not found: '%(value)s'"
msgstr "Parametro dell'elemento '%(element)s' non trovato: '%(value)s'"
@@ -8857,3 +8776,365 @@
#~ msgstr ""
#~ "Crea e aggiunge una nuova tabella degli attributi per un certo layer di "
#~ "una mappa vettoriale esistente"
+#~ msgid "GRASS_PYCMDFILE - File not found. Run p.mon."
+#~ msgstr "GRASS_PYCMDFILE - File non trovato. Eseguire p.mon."
+#~ msgid "Add thematic area (choropleth) map layer"
+#~ msgstr "Aggiungi layer tematico (choropleth)"
+#~ msgid "Cannot create directory for settings [home]/.grass7"
+#~ msgstr ""
+#~ "Non è possibile creare la cartella per le impostazioni [home]/.grass7"
+#~ msgid "Error saving preferences"
+#~ msgstr "Errore nel salvataggio delle preferenze"
+#~ msgid "thematic area (choropleth) map"
+#~ msgstr "mappa tematica (choropleth)"
+#~ msgid "Import raster data"
+#~ msgstr "Importa mappe raster"
+#~ msgid "Import raster data into a GRASS map layer using GDAL."
+#~ msgstr "Importa raster in GRASS usando GDAL"
+#~ msgid "Converts multiple GDAL supported layers to GRASS raster maps."
+#~ msgstr "Converti layer GDAL supportati in una mappa raster GRASS."
+#~ msgid "Link to external raster map"
+#~ msgstr "Collega a raster esterno"
+#~ msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
+#~ msgstr "Collega file raster supportato da GDAL in un layer raster di GRASS."
+#~ msgid ""
+#~ "Link multiple GDAL supported raster maps as pseudo GRASS raster map "
+#~ "layers."
+#~ msgstr "Collega diversi raster GDAL supportati come pseudo GRASS raster"
+#~ msgid "Converts a GRASS ASCII raster file to binary raster map."
+#~ msgstr "Converte un file raster GRASS ASCII in un raster binario."
+#~ msgid "ASCII polygons, lines, and point import"
+#~ msgstr "Importa poligoni, linee e punti ASCII"
+#~ msgid "Raw binary array import"
+#~ msgstr "Importa array binary"
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster "
+#~ "map."
+#~ msgstr ""
+#~ "Converte un file raster ESRI ARC/INFO ascii (GRID) in un raster GRASS."
+#~ msgid "Imports SPOT VGT NDVI data into a raster map."
+#~ msgstr "Importa dati SPOT VGT NDVI in un raster."
+#~ msgid "Imports SRTM HGT files into raster map."
+#~ msgstr "Importa file SRTM HGT in un raster"
+#~ msgid ""
+#~ "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
+#~ "using gdalwarp."
+#~ msgstr ""
+#~ "Georeferenzia, rettifica e importa immagine Terra-ASTER e relativo DEM "
+#~ "usando gdalwarp."
+#~ msgid "Download and import data from WMS servers."
+#~ msgstr "Scarica e importa dati da server WMS"
+#~ msgid "Import vector data"
+#~ msgstr "Importa mappa vettore"
+#~ msgid "Converts vector layers into a GRASS vector map using OGR."
+#~ msgstr "Converte layer vettoriali in vettori GRASS usando OGR."
+#~ msgid "Converts multiple OGR supported layers into GRASS vector maps."
+#~ msgstr "Converte diversi layer supportati da OGR in vettori GRASS."
+#~ msgid "Link to external vector map"
+#~ msgstr "Collega a un vettore esterno"
+#~ msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
+#~ msgstr ""
+#~ "Crea nuovo pseudo-vettore come link in a un layer supportato da OGR."
+#~ msgid ""
+#~ "Creates multiple new pseduo-vector maps as a read-only links using OGR."
+#~ msgstr ""
+#~ "Crea diversi nuovi pseudo-vettori come link in sola lettura usando OGR."
+#~ msgid "ASCII points or GRASS ASCII format"
+#~ msgstr "Formato punti ASCII o GRASS ASCII"
+#~ msgid "Creates a vector map from an ASCII points file or ASCII vector file."
+#~ msgstr "Crea un vettore da file ASCII points o ASCII vector."
+#~ msgid "Historical GRASS vector import"
+#~ msgstr "Import vecchi GRASS vector"
+#~ msgid "Converts multiple DXF layers to GRASS vector maps."
+#~ msgstr "Converte più layer DXF in vettori GRASS."
+#~ msgid "GPS data import"
+#~ msgstr "Importa dati GPS"
+#~ msgid ""
+#~ "Import waypoints, routes, and tracks from a GPS receiver or many common "
+#~ "GPS file formats."
+#~ msgstr ""
+#~ "Scarica punti di interesse, rotte e tracce da un GPS o dai più comuni "
+#~ "formati di file GPS"
+#~ msgid "Matlab array or Mapgen format import"
+#~ msgstr "Importa array Matlab o formato MapGen"
+#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
+#~ msgstr ""
+#~ "Converte un file testuale raster ASCII 3D in un layer raster 3D (binario)."
+#~ msgid "Import 3-dimensional Vis5D files."
+#~ msgstr "Importa file Vis5D tridimensionale."
+#~ msgid "Common export formats"
+#~ msgstr "Formati comuni di esportazione"
+#~ msgid "Converts a raster map layer into a GRASS ASCII text file."
+#~ msgstr "Converte un raster in un file di testo GRASS ASCII."
+#~ msgid "ASCII x,y,z points export"
+#~ msgstr "Esporta punti x,y,z in ASCII"
+#~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
+#~ msgstr "Esporta raster GRASS in un file GRIDATB.FOR (TOPMODEL)."
+#~ msgid "Raw binary array export"
+#~ msgstr "Esporta array binari"
+#~ msgid "Raster file series to MPEG movie conversion program."
+#~ msgstr "Programma di conversione per serie di file raster in MPEG."
+#~ msgid "Export a GRASS raster map as non-georeferenced PNG image format."
+#~ msgstr "Esporta raster GRASS in un'immagine PNG non georeferenziata."
+#~ msgid "Converts a GRASS raster map to a PPM image file."
+#~ msgstr "Converte un raster GRASS in un immagine PPM"
+#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
+#~ msgstr "Converte 3 raster GRASS (R,G,B) in un'immagine PPM."
+#~ msgid "Converts a raster map layer into a height-field file for POV-Ray."
+#~ msgstr "Converte un raster in un file otto campi POV-Ray."
+#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
+#~ msgstr "Esporta a raster GRASS in un immagine TIFF 8/24 bitt"
+#~ msgid ""
+#~ "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
+#~ msgstr "Esporta raster in Virtual Reality Modeling Language (VRML)."
+#~ msgid "Converts raster maps into the VTK-ASCII format."
+#~ msgstr "Converte un raster in formato VTK-ASCII."
+#~ msgid "Converts a vector map to any of the supported OGR vector formats."
+#~ msgstr "Converte in uno dei formati vettoriali supportati da OGR."
+#~ msgid "ASCII points or GRASS ASCII vector export"
+#~ msgstr "Esporta vettore in ASCII points o GRASS ASCII"
+#~ msgid "Exports a vector map to a GRASS ASCII vector representation."
+#~ msgstr "Esporta un vettore in un vettore GRASS ASCII."
+#~ msgid "Exports vector map to DXF file format."
+#~ msgstr "Esporta vettore GRASS in file formato DXF."
+#~ msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
+#~ msgstr "Converte punti x,y,z di GRASS x,y,z nel formato POV-Ray x,z,y"
+#~ msgid "Exports a vector map to SVG file."
+#~ msgstr "Esporta vettore GRASS in file SVG."
+#~ msgid "Converts a vector map to VTK ASCII output."
+#~ msgstr "Converte un vettore in un VTK ASCII"
+#~ msgid "Converts a 3D raster map layer into a ASCII text file."
+#~ msgstr "Converte un raster 3D in un file di testo ASCII."
+#~ msgid "Converts a 3D raster map into a 3-dimensional Vis5D file."
+#~ msgstr "Converte raster 3D in un file Vis5D tridimensionale."
+#~ msgid "Converts 3D raster maps into the VTK-ASCII format."
+#~ msgstr "Converte un raster 3D in formato VTK-ASCII."
+#~ msgid "Common export formats using OGR"
+#~ msgstr "Esporta diversi formati usando OGR"
+#~ msgid "Lists available GIS elements of the user-specified data type."
+#~ msgstr ""
+#~ "Lista degli elementi GIS disponibili secondo il tipo specificato "
+#~ "dall'utente."
+#~ msgid "Converts a vector map into a raster map."
+#~ msgstr "Converte un vettore in un raster."
+#~ msgid "Converts a vector map (only points) into a 3D raster map."
+#~ msgstr "Converte un vettore (solo puntuale) in un raster 3D"
+#~ msgid "Export color table"
+#~ msgstr "Esporta tabella dei colori"
+#~ msgid "Exports the color table associated with a raster map layer."
+#~ msgstr "Esporta la tabella dei colori associata a un raster."
+#~ msgid "Compute category quantiles using two passes."
+#~ msgstr "Calcola le categorie dei quantili utilizzando due raster."
+#~ msgid "USLE K-factor"
+#~ msgstr "USLE K-factor"
+#~ msgid "USLE R-factor"
+#~ msgstr "USLE R-factor"
+#~ msgid "Groundwater flow"
+#~ msgstr "Punto di controllo sul terreno"
+#~ msgid "Generates rate of spread raster map layers."
+#~ msgstr "Genera statistiche per layer raster."
+#~ msgid "Creates topology for vector map."
+#~ msgstr "Crea topologia per un vettore."
+#~ msgid "Change the type of geometry elements"
+#~ msgstr "Cambia la tipologia della geometrie degli elementi"
+#~ msgid "Queries a vector map at given locations."
+#~ msgstr "Interroga un vettore in posizioni date."
+#~ msgid "Creates a buffer around vector features of given type."
+#~ msgstr "Crea un buffer intorno agli elementi di un dato tipo."
+#~ msgid "Creates a new vector map by combining other vector maps."
+#~ msgstr "Crea un nuovo vettori combinando altri vettori."
+#~ msgid "Attaches, deletes or reports vector categories to map geometry."
+#~ msgstr ""
+#~ "Attacca, elimina o visualizza le categorie di un vettore per geometrie "
+#~ "della mappa."
+#~ msgid "Creates convex hull for vector point map."
+#~ msgstr "Crea poligoni convessi da un vettore puntuale"
+#~ msgid "Creates a vector map of a user-defined grid."
+#~ msgstr "Crea un vettore di una griglia definita dall'utente."
+#~ msgid "Creates points along input lines in new vector map with 2 layers."
+#~ msgstr ""
+#~ "Crea punti lungo una linea di input in un nuovo vettore con 2 layer."
+#~ msgid "Generates randomly 2D/3D vector points map."
+#~ msgstr "Genera casualmente un vettore puntuale 2D/3D."
+#~ msgid "Random location perturbations of vector points."
+#~ msgstr "Disturbo casuale del posizionamento di punti vettoriali."
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "Calcola statistiche univariate per un raster basandosi su poligoni "
+#~ "vettoriale e carica le statistiche in una nuova colonna della tabella "
+#~ "degli attributi."
+#~ msgid "Reports geometry statistics for vector maps."
+#~ msgstr "Visualizza le statistiche delle geometrie per i vettori."
+#~ msgid "Report or upload vector features to DB"
+#~ msgstr "Visualizza o aggiorna gli elementi nel DB per un vettore"
+#~ msgid "Calculates univariate statistics for attribute."
+#~ msgstr "Calcola statistiche univariate per attributi"
+#~ msgid "Tests for normality for vector points."
+#~ msgstr "Test di normalità per punti vettoriali"
+#~ msgid "Evapotranspiration calculation"
+#~ msgstr "Calcola evapotraspirazione"
+#~ msgid "Evapotranspiration"
+#~ msgstr "Evapotraspirazione"
+#~ msgid "Albedo"
+#~ msgstr "Albedo"
+#~ msgid "Evaporative fraction"
+#~ msgstr "Frazione di evaporazioneu"
+#~ msgid "Sensible heat flux"
+#~ msgstr "Flusso di calore sensibile"
+#~ msgid "Computes sensible heat flux iteration SEBAL 01."
+#~ msgstr "Calcola flusso di calore sensibile con iterazione SEBAL 01."
+#~ msgid "Soil heat flux"
+#~ msgstr "Flusso di calore del suolo"
+#~ msgid "Soil heat flux approximation (Bastiaanssen, 1995)"
+#~ msgstr "Approssimazione del flusso di calore del suolo (Bastiaanssen, 1995)"
+#~ msgid "Emissivity"
+#~ msgstr "Emissività"
+#~ msgid "Temporal integration of ETa"
+#~ msgstr "Integrazione temporale ETa"
+#~ msgid ""
+#~ "Computes temporal integration of satellite ET actual (ETa) following the "
+#~ "daily ET reference (ETo) from meteorological station(s)"
+#~ msgstr ""
+#~ "Calcola l'integrazione temporale del satellite ET actual (ETa) seguento "
+#~ "il ET reference (ETo) giornaliero per stazione(i) meteo"
+#~ msgid "LatLong map"
+#~ msgstr "Mappa LatLong"
+#~ msgid "creates a latitude/longitude map"
+#~ msgstr "Crea una mappa latitudine/longitudine"
+#~ msgid "Vegetation indices"
+#~ msgstr "Indici vegetazionali"
+#~ msgid "Calculates different types of vegetation indices."
+#~ msgstr "Calcola differenti tipologie di indici vegetazionali"
+#~ msgid "Biomass growth"
+#~ msgstr "Crescita biomassa"
+#~ msgid "Modis quality control"
+#~ msgstr "Controllo qualità Modis"
+#~ msgid "Extract quality control parameters from Modis QC layers"
+#~ msgstr "Estrai i parametri di controllo di qualità da layer Modis Qc"
+#~ msgid "Sunshine hours"
+#~ msgstr "Ore di sole"
+#~ msgid "Add various vector-based map layers"
+#~ msgstr "Aggiungi diversi layer vettoriali"
+#~ msgid "Converts selected GDAL layers to GRASS raster maps using r.in.gdal."
+#~ msgstr ""
+#~ "Converti i layer GDAL selezionati in una mappa raster GRASS usando r.in."
+#~ "gdal"
+#~ msgid "Converts selected OGR layers to GRASS vector maps using v.in.ogr."
+#~ msgstr "Converte i layer OGR selezionati in vettori GRASS usando v.in.ogr"
+#~ msgid "Converts selected DXF layers to GRASS vector maps (using v.in.dxf)."
+#~ msgstr "Converte i layer DXF selezionati in vettori GRASS (usando v.in.dxf)"
+#~ msgid "Query by coordinates"
+#~ msgstr "Interroga utilizzando coordinate"
+#~ msgid "Univariate attribute statistics"
+#~ msgstr "Statistiche univariate attributi"
