[GRASS-SVN] r41761 - grass/branches/develbranch_6/lib/python
Thu Apr 8 15:57:31 EDT 2010
Author: neteler
Date: 2010-04-08 15:57:31 -0400 (Thu, 08 Apr 2010)
New Revision: 41761
   grass/branches/develbranch_6/lib/python/core.py
backport docs
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py	2010-04-08 19:56:00 UTC (rev 41760)
+++ grass/branches/develbranch_6/lib/python/core.py	2010-04-08 19:57:31 UTC (rev 41761)
@@ -219,6 +219,11 @@
     @code
     parse_command(..., parse = (grass.parse_key_val, { 'sep' : ':' }))
     @endcode
+    @param args
+    @param kwargs
+    @return parsed module output
     parse = None
     if kwargs.has_key('parse'):
@@ -744,6 +749,8 @@
 def try_rmdir(path):
     """!Attempt to remove a directory; no exception is generated if the
     attempt fails.
+    @param path path
     try:
 	os.rmdir(path)
