[GRASS-SVN] r41764 - in grass/trunk: lib/gis raster/r.flow
raster/r.topmodel raster/simwe/r.sim.sediment
raster/simwe/r.sim.water
svn_grass at osgeo.org
Thu Apr 8 16:09:10 EDT 2010
Author: martinl
Date: 2010-04-08 16:09:09 -0400 (Thu, 08 Apr 2010)
New Revision: 41764
grass/trunk/lib/gis/parser_standard_options.c
grass/trunk/raster/r.flow/main.c
grass/trunk/raster/r.topmodel/main.c
grass/trunk/raster/simwe/r.sim.sediment/main.c
grass/trunk/raster/simwe/r.sim.water/main.c
more options standardization
http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Renamedoptions
Modified: grass/trunk/lib/gis/parser_standard_options.c
--- grass/trunk/lib/gis/parser_standard_options.c 2010-04-08 19:59:21 UTC (rev 41763)
+++ grass/trunk/lib/gis/parser_standard_options.c 2010-04-08 20:09:09 UTC (rev 41764)
@@ -212,7 +212,7 @@
Opt->key_desc = "name";
Opt->required = YES;
Opt->gisprompt = "old,cell,raster";
- Opt->description = _("Name of input raster map");
+ Opt->description = _("Name of raster map");
break;
case G_OPT_R_MAPS:
Opt->key = "map";
@@ -221,7 +221,7 @@
Opt->multiple = YES;
- Opt->description = _("Name of input raster map(s)");
+ Opt->description = _("Name of raster map(s)");
break;
case G_OPT_R_BASE:
Opt->key = "base";
@@ -245,7 +245,7 @@
- Opt->description = _("Name of elevation raster map");
+ Opt->description = _("Name of input elevation raster map");
break;
case G_OPT_R_ELEVS:
Opt->key = "elevation";
@@ -254,7 +254,7 @@
- Opt->description = _("Name of elevation raster map(s)");
+ Opt->description = _("Name of input elevation raster map(s)");
break;
/*g3d maps */
Modified: grass/trunk/raster/r.flow/main.c
--- grass/trunk/raster/r.flow/main.c 2010-04-08 19:59:21 UTC (rev 41763)
+++ grass/trunk/raster/r.flow/main.c 2010-04-08 20:09:09 UTC (rev 41764)
@@ -427,6 +427,7 @@
"map.");
pelevin = G_define_standard_option(G_OPT_R_ELEV);
+ pelevin->key = "elevation_input";
paspin = G_define_standard_option(G_OPT_R_INPUT);
paspin->key = "aspect_input";
Modified: grass/trunk/raster/r.topmodel/main.c
--- grass/trunk/raster/r.topmodel/main.c 2010-04-08 19:59:21 UTC (rev 41763)
+++ grass/trunk/raster/r.topmodel/main.c 2010-04-08 20:09:09 UTC (rev 41764)
@@ -65,6 +65,11 @@
_("Simulates TOPMODEL which is a physically based hydrologic model.");
/* Parameter definitions */
+ param.elev = G_define_standard_option(G_OPT_R_ELEV);
+ param.elev->key = "elevation_input";
+ param.elev->required = NO;
+ param.elev->guisection = _("Input");
param.basin = G_define_standard_option(G_OPT_R_INPUT);
param.basin->key = "basin_input";
param.basin->label =
@@ -73,12 +78,8 @@
param.basin->required = NO;
param.basin->guisection = _("Input");
- param.elev = G_define_standard_option(G_OPT_R_ELEV);
- param.elev->required = NO;
- param.elev->guisection = _("Input");
param.fill = G_define_standard_option(G_OPT_R_OUTPUT);
- param.fill->key = "dep_output";
+ param.fill->key = "delevation_output";
param.fill->description = _("Name for output depressionless elevation raster map");
param.fill->required = NO;
param.fill->guisection = _("Output");
Modified: grass/trunk/raster/simwe/r.sim.sediment/main.c
--- grass/trunk/raster/simwe/r.sim.sediment/main.c 2010-04-08 19:59:21 UTC (rev 41763)
+++ grass/trunk/raster/simwe/r.sim.sediment/main.c 2010-04-08 20:09:09 UTC (rev 41764)
@@ -119,7 +119,8 @@
"using path sampling method (SIMWE).");
parm.elevin = G_define_standard_option(G_OPT_R_ELEV);
+ parm.elevin->key = "elevation_input";
parm.wdepth = G_define_standard_option(G_OPT_R_INPUT);
parm.wdepth->key = "wdepth_input";
parm.wdepth->description = _("Name of water depth raster map [m]");
@@ -154,7 +155,7 @@
parm.manin->guisection = _("Input");
parm.maninval = G_define_option();
- parm.maninval->key = "maninval";
+ parm.maninval->key = "man_value";
parm.maninval->type = TYPE_DOUBLE;
parm.maninval->answer = MANINVAL;
parm.maninval->required = NO;
Modified: grass/trunk/raster/simwe/r.sim.water/main.c
--- grass/trunk/raster/simwe/r.sim.water/main.c 2010-04-08 19:59:21 UTC (rev 41763)
+++ grass/trunk/raster/simwe/r.sim.water/main.c 2010-04-08 20:09:09 UTC (rev 41764)
@@ -123,7 +123,8 @@
"path sampling method (SIMWE).");
parm.dxin = G_define_standard_option(G_OPT_R_INPUT);
parm.dxin->key = "dx_input";
parm.dxin->description = _("Name of x-derivatives raster map [m/m]");
@@ -140,7 +141,7 @@
parm.rain->guisection = _("Input");
parm.rainval = G_define_option();
- parm.rainval->key = "rain_val";
+ parm.rainval->key = "rain_value";
parm.rainval->type = TYPE_DOUBLE;
parm.rainval->answer = RAINVAL;
parm.rainval->required = NO;
@@ -156,7 +157,7 @@
parm.infil->guisection = _("Input");
parm.infilval = G_define_option();
- parm.infilval->key = "infil_val";
+ parm.infilval->key = "infil_value";
parm.infilval->type = TYPE_DOUBLE;
parm.infilval->answer = INFILVAL;
parm.infilval->required = NO;
@@ -171,7 +172,7 @@
- parm.maninval->key = "man_val";
