[GRASS-SVN] r41770 - in grass-addons/ossim_grass: r.planet v.planet
svn_grass at osgeo.org
Sat Apr 10 06:49:41 EDT 2010
Author: epifanio
Date: 2010-04-10 06:49:41 -0400 (Sat, 10 Apr 2010)
New Revision: 41770
grass-addons/ossim_grass/r.planet/r.planet.py
grass-addons/ossim_grass/v.planet/v.planet.py
adjusted indentation, added check for overview files (if no present make it, this avoid a possible crash when ossimplanet tries to build overview itself), fixed units parametres in the zoom-to action.
Modified: grass-addons/ossim_grass/r.planet/r.planet.py
--- grass-addons/ossim_grass/r.planet/r.planet.py 2010-04-10 10:46:16 UTC (rev 41769)
+++ grass-addons/ossim_grass/r.planet/r.planet.py 2010-04-10 10:49:41 UTC (rev 41770)
@@ -42,7 +42,7 @@
#%end
#%option
#% key: dport
-#% type: double
+#% type: integer
#% key_desc: dport
#% answer: 8000
#% description: Data Port
@@ -50,7 +50,7 @@
#%end
#%option
#% key: pport
-#% type: double
+#% type: integer
#% key_desc: port
#% answer: 7000
#% description: Position Port
@@ -84,242 +84,250 @@
import osgeo.gdal as gdal
def main():
- add = flags['a']
- remove = flags['r']
- orthoigen = flags['d']
- host = options['host']
- dport = options['dport']
- pport = options['pport']
- tile = options['tile']
- grassenv = grass.gisenv()
- mappa = options['map'].replace("@"," ")
- mappa = mappa.split()
- nflags = len(filter(None, [add, remove, orthoigen]))
- if nflags > 1:
- grass.run_command('g.message' , message = 'Cannot add & remove a map or use orthoigen at the same time.')
- if nflags < 1:
- grass.run_command('g.message' , message = 'No action requested , please choose one from "-a : add" or "-r : remove" flags.')
- try :
- rasterpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'cellhd')
- mapfile = os.path.join(rasterpath, mappa[0])
- vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vrt/raster/')
- #print vrtdir
- except :
- rasterpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'cellhd')
- vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'vrt/raster/')
- #print vrtdir
- d = os.path.dirname(vrtdir)
- if not os.path.exists(d):
- os.makedirs(d)
- #os.makedirs(d)
- vrtfilename = mappa[0] + '.vrt'
- output = os.path.join(vrtdir, vrtfilename)
- if not os.path.exists(output):
- gdal.GetDriverByName('VRT').CreateCopy(output,gdal.Open(mapfile))
- #grass.run_command('r.out.gdal', format = 'VRT', type = 'Float64', input = mappa[0] , output = '%s' % (output))
- proj_info = projinfo()
- unit = proj_info['units']
- if unit.lower() == 'meters':
- zoom_position = setCPRJ(options['map'])
- if unit == 'Degrees':
- zoom_position = setCLL(options['map'])
- lat = zoom_position[0]
- lon = zoom_position[1]
- distance = zoom_position[2]
- if nflags == 1:
- if add :
- try :
- addzoom(output,lon,lat,distance,host,dport,pport)
- print 'Added raster file :', mappa[0]
- print 'Camera positioned to : '
- print 'Longitude = ',lon
- print 'Latitude = ', lat
- print 'Altitude = ' , distance
- except :
- print "conecction error"
- if remove :
- removefile(output,host,dport)
- print 'Removed raster file :', mappa[0]
- if orthoigen :
- if tile != '':
- path = os.path.dirname(output)
- elevdir = os.path.join(path,'elevation',mappa[0]+'/')
- if not os.path.exists(elevdir):
- os.makedirs(elevdir)
- elev = mappa[0]+'.tiff'
- exportiff(output,elev)
- instr = make3d(tile, elev, elevdir)
- os.system(instr)
- if tile == '':
- print 'please set the tile dimension'
+ add = flags['a']
+ remove = flags['r']
+ orthoigen = flags['d']
+ host = options['host']
+ dport = options['dport']
+ pport = options['pport']
+ tile = options['tile']
+ grassenv = grass.gisenv()
+ mappa = options['map'].replace("@"," ")
+ mappa = mappa.split()
+ nflags = len(filter(None, [add, remove, orthoigen]))
+ if nflags > 1:
+ grass.run_command('g.message' , message = 'Cannot add & remove a map or use orthoigen at the same time.')
+ if nflags < 1:
+ grass.run_command('g.message' , message = 'No action requested , please choose one from "-a : add" or "-r : remove" flags.')
+ try :
+ rasterpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'cellhd')
+ mapfile = os.path.join(rasterpath, mappa[0])
+ vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vrt/raster/')
+ #print vrtdir
+ except :
+ rasterpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'cellhd')
+ vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'vrt/raster/')
+ #print vrtdir
+ d = os.path.dirname(vrtdir)
+ if not os.path.exists(d):
+ os.makedirs(d)
+ #os.makedirs(d)
+ vrtfilename = mappa[0] + '.vrt'
+ output = os.path.join(vrtdir, vrtfilename)
+ if not os.path.exists(output):
+ gdal.GetDriverByName('VRT').CreateCopy(output,gdal.Open(mapfile))
+ #grass.run_command('r.out.gdal', format = 'VRT', type = 'Float64', input = mappa[0] , output = '%s' % (output))
+ proj_info = projinfo()
+ unit = proj_info['units']
+ if unit.lower() == 'meters':
+ zoom_position = setCPRJ(options['map'])
+ if unit.lower() == 'metres':
+ if unit.lower() == 'degrees':
+ zoom_position = setCLL(options['map'])
+ lat = zoom_position[0]
+ lon = zoom_position[1]
+ distance = zoom_position[2]
+ if nflags == 1:
+ if add :
+ try :
+ addzoom(output,lon,lat,distance,host,dport,pport)
+ print 'Added raster file :', mappa[0]
+ print 'Camera positioned to : '
+ print 'Longitude = ',lon
+ print 'Latitude = ', lat
+ print 'Altitude = ' , distance
+ except :
+ print "conecction error"
+ if remove :
+ removefile(output,host,dport)
+ print 'Removed raster file :', mappa[0]
+ if orthoigen :
+ if tile != '':
+ path = os.path.dirname(output)
+ elevdir = os.path.join(path,'elevation',mappa[0]+'/')
+ if not os.path.exists(elevdir):
+ os.makedirs(elevdir)
+ elev = mappa[0]+'.tiff'
+ exportiff(output,elev)
+ instr = make3d(tile, elev, elevdir)
+ os.system(instr)
+ if tile == '':
+ print 'please set the tile dimension'
def exportiff(infile,outfile):
- gdal.GetDriverByName('GTiff').CreateCopy(outfile,gdal.Open(infile))
+ gdal.GetDriverByName('GTiff').CreateCopy(outfile,gdal.Open(infile))
def addfile(output,host,dport):
- ossim_data_xml = "<Add target=':idolbridge'><Image groupType='groundTexture'><filename>%s</filename> <id>%s</id><name>%s</name></Image></Add>" % (output,output,output)
- ossimdata = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
- ossimdata.connect((host, int(dport)))
- ossimdata.send(ossim_data_xml)
- ossimdata.close()
+ overview = output.replace('.vrt','.ovr')
+ if not os.path.isfile(overview):
+ makeoverview(output)
+ ossim_data_xml = "<Add target=':idolbridge'><Image groupType='groundTexture'><filename>%s</filename> <id>%s</id><name>%s</name></Image></Add>" % (output,output,output)
+ ossimdata = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
+ ossimdata.connect((host, int(dport)))
+ ossimdata.send(ossim_data_xml)
+ ossimdata.close()
def zoomto(lon,lat,distance,host,pport):
- ossim_zoom_xml = '<Set target=":navigator" vref="wgs84"><Camera><longitude>%s</longitude><latitude>%s</latitude><altitude>%s</altitude><heading>0</heading><pitch>0</pitch><roll>0</roll><altitudeMode>absolute</altitudeMode><range>%s</range></Camera></Set>' % (lon, lat, distance, distance)
- ossimposition = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
- ossimposition.connect((host, int(pport)))
- ossimposition.send(ossim_zoom_xml)
- ossimposition.close()
+ ossim_zoom_xml = '<Set target=":navigator" vref="wgs84"><Camera><longitude>%s</longitude><latitude>%s</latitude><altitude>%s</altitude><heading>0</heading><pitch>0</pitch><roll>0</roll><altitudeMode>absolute</altitudeMode><range>%s</range></Camera></Set>' % (lon, lat, distance, distance)
+ ossimposition = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
+ ossimposition.connect((host, int(pport)))
+ ossimposition.send(ossim_zoom_xml)
+ ossimposition.close()
def removefile(output,host,dport):
- ossim_data_xml = "<Remove target=':idolbridge' id='%s' />" % (output)
- ossimdata.close()
+ ossim_data_xml = "<Remove target=':idolbridge' id='%s' />" % (output)
+ ossimdata.close()
def addzoom(output,lon,lat,distance,host,dport,pport):
- addfile(output,host,dport)
- zoomto(lon,lat,distance,host,pport)
+ addfile(output,host,dport)
+ zoomto(lon,lat,distance,host,pport)
def projinfo():
- units = grass.read_command("g.proj", flags='p')
- units = units.replace('-','')
- units = grass.parse_key_val(units, ':')
- units_key = units.keys()
- for i in units_key :
- key_value = str(units[i]).strip()
- units[i] = key_value
- return units
+ units = grass.read_command("g.proj", flags='p')
+ units = units.replace('-','')
+ units = grass.parse_key_val(units, ':')
+ units_key = units.keys()
+ for i in units_key :
+ key_value = str(units[i]).strip()
+ units[i] = key_value
+ return units
def setCLL(map):
- center = []
- info_region = grass.read_command('g.region', flags = 'cael', rast = '%s' % (map))
- dict_region = grass.parse_key_val(info_region, ':')
- lon = dict_region['east-west center']
- lat = dict_region['north-south center']
- lon = str(lon)
- lat = str(lat)
- lon = lon.replace(':', " ")
- lat = lat.replace(':', " ")
- if lat[-1] == 'N':
- signlat = 1
- if lat[-1] == 'S':
- signlat = -1
- if lon[-1] == 'E':
- signlon = 1
- if lon[-1] == 'W':
- signlon = -1
- lat = lat[:-1]
- lon = lon[:-1]
- lat = [float(i) for i in lat.split()]
- lon = [float(i) for i in lon.split()]
- lat = (lat[0] + (lat[1] / 60) + lat[2] / 3600) * float(signlat)
- lon = (lon[0] + (lon[1] / 60) + lon[2] / 3600) * float(signlon)
- ns = float(dict_region['north-south extent'])
- we = float(dict_region['east-west extent'])
- distance = (ns + we) / 2
- center.append(lat)
- center.append(lon)
- center.append(distance)
- return center
+ center = []
+ info_region = grass.read_command('g.region', flags = 'cael', rast = '%s' % (map))
+ dict_region = grass.parse_key_val(info_region, ':')
+ lon = dict_region['east-west center']
+ lat = dict_region['north-south center']
+ lon = str(lon)
+ lat = str(lat)
+ lon = lon.replace(':', " ")
+ lat = lat.replace(':', " ")
+ if lat[-1] == 'N':
+ signlat = 1
+ if lat[-1] == 'S':
+ signlat = -1
+ if lon[-1] == 'E':
+ signlon = 1
+ if lon[-1] == 'W':
+ signlon = -1
+ lat = lat[:-1]
+ lon = lon[:-1]
+ lat = [float(i) for i in lat.split()]
+ lon = [float(i) for i in lon.split()]
+ lat = (lat[0] + (lat[1] / 60) + lat[2] / 3600) * float(signlat)
+ lon = (lon[0] + (lon[1] / 60) + lon[2] / 3600) * float(signlon)
+ ns = float(dict_region['north-south extent'])
+ we = float(dict_region['east-west extent'])
+ distance = (ns + we) / 2
+ center.append(lat)
+ center.append(lon)
+ center.append(distance)
+ return center
def setCPRJ(map):
- center = []
- info_region = grass.read_command('g.region', flags = 'ael', rast = '%s' % (map))
- lon = dict_region['center longitude']
- lat = dict_region['center latitude']
- lon = str(lon)
- lat = str(lat)
- signlat = 1
- signlat = -1
- signlon = 1
- signlon = -1
- lat = lat[:-1]
- lon = lon[:-1]
- return center
+ center = []
+ info_region = grass.read_command('g.region', flags = 'ael', rast = '%s' % (map))
+ lon = dict_region['center longitude']
+ lat = dict_region['center latitude']
+ lon = str(lon)
+ lat = str(lat)
+ signlat = 1
+ signlat = -1
+ signlon = 1
+ signlon = -1
+ lat = lat[:-1]
+ lon = lon[:-1]
+ return center
def makedir(path):
- d = os.path.dirname(path)
- os.makedirs(d)
+ d = os.path.dirname(path)
+ os.makedirs(d)
def make3d(tile, elev, outdir):
- makedir(outdir)
- kwl = 'elev.kwl'
- template = 'igen.slave_tile_buffers: 5 \n'
- template += 'igen.tiling.type: ossimTiling \n'
- template += 'igen.tiling.tiling_distance: 1 1 \n'
- template += 'igen.tiling.tiling_distance_type: degrees \n'
- template += 'igen.tiling.delta: %s %s \n' % (tile,tile)
- template += 'igen.tiling.delta_type: total_pixels \n'
- template += 'igen.tiling.padding_size_in_pixels: 0 0 \n'
- template += 'object1.description: \n'
- template += 'object1.enabled: 1 \n'
- template += 'object1.id: 1 \n'
- template += 'object1.object1.description: \n'
- template += 'object1.object1.enabled: 1 \n'
- template += 'object1.object1.id: 2 \n'
- template += 'object1.object1.resampler.magnify_type: bilinear \n'
- template += 'object1.object1.resampler.minify_type: bilinear \n'
- template += 'object1.object1.type: ossimImageRenderer \n'
- template += 'object1.object2.type: ossimCastTileSourceFilter \n'
- template += 'object1.object2.scalar_type: ossim_sint16 \n'
- template += 'object1.type: ossimImageChain \n'
- template += 'object2.type: ossimGeneralRasterWriter \n'
- template += 'object2.byte_order: big_endian \n'
- template += 'object2.create_overview: false \n'
- template += 'object2.create_histogram: false \n'
- template += 'object2.create_external_geometry: false \n'
- template += 'product.projection.type: ossimEquDistCylProjection \n'
- open(kwl,'w').write(template)
- instr = 'export DYLD_FRAMEWORK_PATH=/Users/sasha/OssimBuilds/Release/ ; '
- instr += '/Users/sasha/OssimBuilds/Release/ossim-orthoigen'
- instr += ' --tiling-template '
- instr += kwl
- instr +=' --view-template '
- instr += kwl
- instr +=' --writer-template '
- instr += kwl
- instr +=' --chain-template '
- instr += kwl
- instr += ' %s ' % elev
- instr += '%s' % outdir
- instr +='/%SRTM%'
- return instr
+ makedir(outdir)
+ kwl = 'elev.kwl'
+ template = 'igen.slave_tile_buffers: 5 \n'
+ template += 'igen.tiling.type: ossimTiling \n'
+ template += 'igen.tiling.tiling_distance: 1 1 \n'
+ template += 'igen.tiling.tiling_distance_type: degrees \n'
+ template += 'igen.tiling.delta: %s %s \n' % (tile,tile)
+ template += 'igen.tiling.delta_type: total_pixels \n'
+ template += 'igen.tiling.padding_size_in_pixels: 0 0 \n'
+ template += 'object1.description: \n'
+ template += 'object1.enabled: 1 \n'
+ template += 'object1.id: 1 \n'
+ template += 'object1.object1.description: \n'
+ template += 'object1.object1.enabled: 1 \n'
+ template += 'object1.object1.id: 2 \n'
+ template += 'object1.object1.resampler.magnify_type: bilinear \n'
+ template += 'object1.object1.resampler.minify_type: bilinear \n'
+ template += 'object1.object1.type: ossimImageRenderer \n'
+ template += 'object1.object2.type: ossimCastTileSourceFilter \n'
+ template += 'object1.object2.scalar_type: ossim_sint16 \n'
+ template += 'object1.type: ossimImageChain \n'
+ template += 'object2.type: ossimGeneralRasterWriter \n'
+ template += 'object2.byte_order: big_endian \n'
+ template += 'object2.create_overview: false \n'
+ template += 'object2.create_histogram: false \n'
+ template += 'object2.create_external_geometry: false \n'
+ template += 'product.projection.type: ossimEquDistCylProjection \n'
+ open(kwl,'w').write(template)
+ instr = 'export DYLD_FRAMEWORK_PATH=/Users/sasha/OssimBuilds/Release/ ; '
+ instr += '/Users/sasha/OssimBuilds/Release/ossim-orthoigen'
+ instr += ' --tiling-template '
+ instr += kwl
+ instr +=' --view-template '
+ instr += kwl
+ instr +=' --writer-template '
+ instr += kwl
+ instr +=' --chain-template '
+ instr += kwl
+ instr += ' %s ' % elev
+ instr += '%s' % outdir
+ instr +='/%SRTM%'
+ return instr
+def makeoverview(input):
+ os.system("ossim-img2rr %s" % input)
if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
+ options, flags = grass.parser()
+ sys.exit(main())
Modified: grass-addons/ossim_grass/v.planet/v.planet.py
--- grass-addons/ossim_grass/v.planet/v.planet.py 2010-04-10 10:46:16 UTC (rev 41769)
+++ grass-addons/ossim_grass/v.planet/v.planet.py 2010-04-10 10:49:41 UTC (rev 41770)
@@ -107,173 +107,185 @@
import string
try:
- from osgeo import osr, ogr, gdal
+ from osgeo import osr, ogr, gdal
except ImportError:
- import osr, ogr, gdal
+ import osr, ogr, gdal
from ogrTovrt import ogrvrt, makestile
def main():
- add = flags['a']
- nflags = len(filter(None, [add, remove]))
- if nflags > 1:
- grass.run_command('g.message' , message = 'Cannot add & remove a map at same time.')
- if nflags < 1:
- try :
- vectorpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vector' , mappa[0] )
- mapfile = os.path.join(vectorpath, 'head')
- vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vrt', 'vector/')
- except :
- vectorpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], mappa[0] )
- mapfile = os.path.join(vectorpath, 'head' )
- vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'vrt', 'vector/')
- os.makedirs(d)
- ogrvrt(mapfile,output)
- makestile(output, options['brush'], options['pen'], options['size'], options['fill'], options['thickness'])
- if add :
- print 'Added vector file :', mappa[0]
- if remove :
- print 'Removed vector file :', mappa[0]
+ add = flags['a']
+ nflags = len(filter(None, [add, remove]))
+ if nflags > 1:
+ grass.run_command('g.message' , message = 'Cannot add & remove a map at same time.')
+ if nflags < 1:
+ try :
+ vectorpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vector' , mappa[0] )
+ mapfile = os.path.join(vectorpath, 'head')
+ vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], mappa[1], 'vrt', 'vector/')
+ except :
+ vectorpath = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], mappa[0] )
+ mapfile = os.path.join(vectorpath, 'head' )
+ vrtdir = os.path.join(grassenv['GISDBASE'], grassenv['LOCATION_NAME'], grassenv['MAPSET'], 'vrt', 'vector/')
+ os.makedirs(d)
+ ogrvrt(mapfile,output)
+ makestile(output, options['brush'], options['pen'], options['size'], options['fill'], options['thickness'])
+ if unit == 'Degrees':
+ if add :
+ try:
+ print 'Added vector file :', mappa[0]
+ except :
+ if remove :
+ print 'Removed vector file :', mappa[0]
- ossimdata.close()
+ ossimdata.close()
- ossimdata.close()
+ ossimdata.close()
def projinfo():
- return units
+ return units
def setCLL(map):
- center = []
- info_region = grass.read_command('g.region', flags = 'cael', vect = '%s' % (map))
- lon = str(lon)
- lat = str(lat)
- signlat = 1
- signlat = -1
- signlon = 1
- signlon = -1
- lat = lat[:-1]
- lon = lon[:-1]
- return center
+ center = []
+ info_region = grass.read_command('g.region', flags = 'cael', vect = '%s' % (map))
+ lon = str(lon)
+ lat = str(lat)
+ signlat = 1
+ signlat = -1
+ signlon = 1
+ signlon = -1
+ lat = lat[:-1]
+ lon = lon[:-1]
+ return center
def setCPRJ(map):
- center = []
- info_region = grass.read_command('g.region', flags = 'ael', vect = '%s' % (map))
- lon = str(lon)
- lat = str(lat)
- signlat = 1
- signlat = -1
- signlon = 1
- signlon = -1
- lat = lat[:-1]
- lon = lon[:-1]
- return center
+ center = []
+ info_region = grass.read_command('g.region', flags = 'ael', vect = '%s' % (map))
+ lon = str(lon)
+ lat = str(lat)
+ signlat = 1
+ signlat = -1
+ signlon = 1
+ signlon = -1
+ lat = lat[:-1]
+ lon = lon[:-1]
+ return center
- sys.exit(main())
+ sys.exit(main())
