[GRASS-SVN] r41774 - grass-addons/ossim_grass/v.planet
Sat Apr 10 07:36:21 EDT 2010
Author: epifanio
Date: 2010-04-10 07:36:20 -0400 (Sat, 10 Apr 2010)
New Revision: 41774
   grass-addons/ossim_grass/v.planet/v.planet.py
fixed somew bugs, now should works as aspected :-)
Modified: grass-addons/ossim_grass/v.planet/v.planet.py
--- grass-addons/ossim_grass/v.planet/v.planet.py	2010-04-10 11:31:07 UTC (rev 41773)
+++ grass-addons/ossim_grass/v.planet/v.planet.py	2010-04-10 11:36:20 UTC (rev 41774)
@@ -98,6 +98,7 @@
 #% key_desc: thickness
 #% description: thickness
 #% required : no
+#% answer: 1
 #%end
 import sys
@@ -143,7 +144,8 @@
     output = os.path.join(vrtdir, vrtfilename)
     if not os.path.exists(output):
         ogrvrt(mapfile,output)
-        makestile(output, options['brush'], options['pen'], options['size'], options['fill'], options['thickness'])
+    print 'try to make omd'
+    makestile(output, options['brush'], options['pen'], options['size'], options['fill'], options['thickness'])
     proj_info = projinfo()
     unit = proj_info['units']
     if unit.lower() == 'meters':
@@ -280,13 +282,15 @@
     return center
 def makeoverview(input):
-    os.system("ossim-img2rr %s" % input)
+    print 'vector object should alredy have internal preview, make overview skipped'
+    #os.system("ossim-img2rr %s" % input)
 def makestile(outfile, brush, pen, size, fill, thickness):
     brush = brush.split(',')
     pen = pen.split(',')
     size = size.split(',')
+    print brush, pen, size
     outfile = outfile.replace('.vrt','')
     outfile = outfile+'.omd'
     omd = '// vector file rendering options\n'
