[GRASS-SVN] r41781 - in grass/trunk/vector: v.net.allpairs
v.net.bridge v.net.centrality v.net.components
v.net.connectivity v.net.distance v.net.flow
v.net.spanningtree v.net.timetable
svn_grass at osgeo.org
Sat Apr 10 13:08:11 EDT 2010
Author: martinl
Date: 2010-04-10 13:08:11 -0400 (Sat, 10 Apr 2010)
New Revision: 41781
grass/trunk/vector/v.net.allpairs/main.c
grass/trunk/vector/v.net.bridge/main.c
grass/trunk/vector/v.net.centrality/main.c
grass/trunk/vector/v.net.components/main.c
grass/trunk/vector/v.net.connectivity/main.c
grass/trunk/vector/v.net.distance/main.c
grass/trunk/vector/v.net.flow/main.c
grass/trunk/vector/v.net.spanningtree/main.c
grass/trunk/vector/v.net.timetable/main.c
run grass_indent.sh
Modified: grass/trunk/vector/v.net.allpairs/main.c
--- grass/trunk/vector/v.net.allpairs/main.c 2010-04-10 17:01:48 UTC (rev 41780)
+++ grass/trunk/vector/v.net.allpairs/main.c 2010-04-10 17:08:11 UTC (rev 41781)
@@ -71,9 +71,10 @@
afcol = G_define_standard_option(G_OPT_DB_COLUMN);
afcol->key = "afcolumn";
afcol->required = NO;
- afcol->description = _("Name of arc forward/both direction(s) cost column");
+ afcol->description =
+ _("Name of arc forward/both direction(s) cost column");
afcol->guisection = _("Cost");
abcol = G_define_standard_option(G_OPT_DB_COLUMN);
abcol->key = "abcolumn";
abcol->required = NO;
@@ -104,8 +105,7 @@
Vect_set_open_level(2);
if (1 > Vect_open_old(&In, map_in->answer, ""))
- G_fatal_error(_("Unable to open vector map <%s>"),
- map_in->answer);
+ G_fatal_error(_("Unable to open vector map <%s>"), map_in->answer);
with_z = Vect_is_3d(&In);
@@ -187,11 +187,13 @@
max_cat = 0;
for (i = 1; i <= nlines; i++) {
int type = Vect_read_line(&In, Points, Cats, i);
for (j = 0; j < Cats->n_cats; j++)
if (Cats->cat[j] > max_cat)
max_cat = Cats->cat[j];
if (type == GV_POINT) {
int node;
Vect_get_line_nodes(&In, i, &node, NULL);
Vect_cat_get(Cats, layer, &cats[node]);
if (cats[node] != -1) {
Modified: grass/trunk/vector/v.net.bridge/main.c
--- grass/trunk/vector/v.net.bridge/main.c 2010-04-10 17:01:48 UTC (rev 41780)
+++ grass/trunk/vector/v.net.bridge/main.c 2010-04-10 17:08:11 UTC (rev 41781)
@@ -45,7 +45,8 @@
G_add_keyword(_("vector"));
G_add_keyword(_("network"));
G_add_keyword(_("articulation points"));
- module->description = _("Computes bridges and articulation points in the network.");
+ module->description =
+ _("Computes bridges and articulation points in the network.");
/* Define the different options as defined in gis.h */
map_in = G_define_standard_option(G_OPT_V_INPUT);
@@ -78,8 +79,7 @@
- map_in->answer);
@@ -119,6 +119,7 @@
for (i = 0; i < articulations; i++) {
double x, y, z;
Vect_get_node_coor(&In, articulation_list->value[i], &x, &y, &z);
Vect_reset_line(Points);
Vect_append_point(Points, x, y, z);
Modified: grass/trunk/vector/v.net.centrality/main.c
--- grass/trunk/vector/v.net.centrality/main.c 2010-04-10 17:01:48 UTC (rev 41780)
+++ grass/trunk/vector/v.net.centrality/main.c 2010-04-10 17:08:11 UTC (rev 41781)
@@ -27,6 +27,7 @@
/*Global variables */
struct Option *deg_opt, *close_opt, *betw_opt, *eigen_opt;
double *deg, *close, *betw, *eigen;
/* Attribute table */
dbString sql, tmp;
dbDriver *driver;
@@ -42,6 +43,7 @@
void append_double(dbString * string, double d)
char buf[50];
sprintf(buf, ",%f", d);
db_append_string(string, buf);
@@ -49,6 +51,7 @@
void process_node(int node, int cat)
char buf[2000];
sprintf(buf, "INSERT INTO %s VALUES(%d", Fi->table, cat);
db_set_string(&sql, buf);
if (deg_opt->answer)
@@ -92,8 +95,9 @@
G_add_keyword(_("centrality measures"));
- module->description = _("Computes degree, centrality, betweeness, closeness and eigenvector "
- "cetrality measures in the network.");
+ _("Computes degree, centrality, betweeness, closeness and eigenvector "
+ "cetrality measures in the network.");
@@ -109,7 +113,8 @@
@@ -117,7 +122,7 @@
abcol->description = _("Name of arc backward direction cost column");
abcol->guisection = _("Cost");
deg_opt = G_define_standard_option(G_OPT_DB_COLUMN);
deg_opt->key = "degree";
deg_opt->required = NO;
@@ -182,8 +187,7 @@
- map_in->answer);
@@ -292,8 +296,7 @@
NetA_degree_centrality(graph, deg);
if (betw_opt->answer || close_opt->answer) {
- G_message(_
- ("Computing betweenness and/or closeness centrality measure"));
+ G_message(_("Computing betweenness and/or closeness centrality measure"));
NetA_betweenness_closeness(graph, betw, close);
if (close)
for (i = 1; i <= nnodes; i++)
@@ -312,8 +315,10 @@
G_percent(i, nlines, 1);
if (type == GV_POINT && (!chcat || varray->c[i])) {
int cat, node;
if (!Vect_cat_get(Cats, layer, &cat))
continue;
Vect_write_line(&Out, type, Points, Cats);
Modified: grass/trunk/vector/v.net.components/main.c
--- grass/trunk/vector/v.net.components/main.c 2010-04-10 17:01:48 UTC (rev 41780)
+++ grass/trunk/vector/v.net.components/main.c 2010-04-10 17:08:11 UTC (rev 41781)
@@ -24,10 +24,11 @@
#include <grass/dbmi.h>
#include <grass/neta.h>
-int insert_new_record(dbDriver * driver, struct field_info *Fi, dbString * sql,
- int cat, int comp)
+int insert_new_record(dbDriver * driver, struct field_info *Fi,
+ dbString * sql, int cat, int comp)
char buf[2000];
sprintf(buf, "insert into %s values (%d, %d)", Fi->table, cat, comp);
db_set_string(sql, buf);
G_debug(3, db_get_string(sql));
@@ -70,7 +71,7 @@
G_add_keyword(_("components"));
_("Computes strongly and weakly connected components in the network.");
field_opt = G_define_standard_option(G_OPT_V_FIELD);
@@ -106,8 +107,7 @@
- map_in->answer);
@@ -172,11 +172,13 @@
nlines = Vect_get_num_lines(&In);
int comp, cat;
continue;
if (type == GV_LINE || type == GV_BOUNDARY) {
int node1, node2;
Vect_get_line_nodes(&In, i, &node1, &node2);
if (component[node1] == component[node2]) {
comp = component[node1];
@@ -187,6 +189,7 @@
else if (type == GV_POINT) {
int node;
comp = component[node];
covered[node] = 1;
Modified: grass/trunk/vector/v.net.connectivity/main.c
--- grass/trunk/vector/v.net.connectivity/main.c 2010-04-10 17:01:48 UTC (rev 41780)
+++ grass/trunk/vector/v.net.connectivity/main.c 2010-04-10 17:08:11 UTC (rev 41781)
@@ -76,7 +76,7 @@
catset1_opt->key = "set1_cats";
catset1_opt->label = _("Set1 category values");
catset1_opt->guisection = _("Set1");
whereset1_opt = G_define_standard_option(G_OPT_DB_WHERE);
whereset1_opt->key = "set1_where";
whereset1_opt->label =
@@ -87,12 +87,12 @@
fieldset2_opt->key = "set2_layer";
fieldset2_opt->description = _("Set2 layer number or name");
fieldset2_opt->guisection = _("Set2");
catset2_opt = G_define_standard_option(G_OPT_V_CATS);
catset2_opt->key = "set2_cats";
catset2_opt->description = _("Set2 category values");
catset2_opt->guisection = _("Set2");
whereset2_opt = G_define_standard_option(G_OPT_DB_WHERE);
whereset2_opt->key = "set2_where";
whereset2_opt->label =
@@ -114,8 +114,7 @@
- map_in->answer);
Modified: grass/trunk/vector/v.net.distance/main.c
--- grass/trunk/vector/v.net.distance/main.c 2010-04-10 17:01:48 UTC (rev 41780)
+++ grass/trunk/vector/v.net.distance/main.c 2010-04-10 17:08:11 UTC (rev 41781)
@@ -62,9 +62,10 @@
G_add_keyword(_("shortest path"));
module->label = _("Computes shortest distance via the network between "
"the given sets of features.");
- module->description = _("Finds the shortest paths from a feature 'to' to every feature 'from' "
- "and various information about this realtion are uploaded to the attribute table.");
+ _("Finds the shortest paths from a feature 'to' to every feature 'from' "
+ "and various information about this realtion are uploaded to the attribute table.");
map_out = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -73,7 +74,7 @@
fieldf_opt->key = "from_layer";
fieldf_opt->label = _("From layer number or name");
fieldf_opt->guisection = _("From");
catf_opt = G_define_standard_option(G_OPT_V_CATS);
catf_opt->key = "from_cats";
catf_opt->label = _("From category values");
@@ -107,7 +108,7 @@
to_type_opt->answer = "point";
to_type_opt->description = _("To feature type");
to_type_opt->guisection = _("To");
afcol->required = YES;
@@ -134,12 +135,11 @@
Vect_check_input_output_name(map_in->answer, map_out->answer,
GV_FATAL_EXIT);
- map_in->answer);
@@ -230,6 +230,7 @@
int node, tcat, cat;
double cost;
dglInt32_t *vertex, vertex_id;
if (!Vect_cat_get(Cats, flayer, &cat))
continue;
@@ -262,6 +263,7 @@
if (on_path[i]->n_cats > 0) {
int type = Vect_read_line(&In, Points, NULL, i);
Vect_write_line(&Out, type, Points, on_path[i]);
Modified: grass/trunk/vector/v.net.flow/main.c
--- grass/trunk/vector/v.net.flow/main.c 2010-04-10 17:01:48 UTC (rev 41780)
+++ grass/trunk/vector/v.net.flow/main.c 2010-04-10 17:08:11 UTC (rev 41781)
@@ -69,12 +69,14 @@
cut_out = G_define_standard_option(G_OPT_V_OUTPUT);
cut_out->key = "cut";
- cut_out->description = _("Name for output vector map containing a minimum cut");
+ cut_out->description =
+ _("Name for output vector map containing a minimum cut");
- afcol->description = _("Name of arc forward/both direction(s) capacity column");
+ _("Name of arc forward/both direction(s) capacity column");
@@ -129,8 +131,7 @@
- map_in->answer);
@@ -182,8 +183,8 @@
sink_list = Vect_new_list();
if (NetA_initialise_varray
- (&In, atoi(fieldsource_opt->answer), GV_POINT, wheresource_opt->answer,
- catsource_opt->answer, &varray_source) == 2)
+ (&In, atoi(fieldsource_opt->answer), GV_POINT,
+ wheresource_opt->answer, catsource_opt->answer, &varray_source) == 2)
G_fatal_error(_("Neither %s nor %s was given"), catsource_opt->key,
wheresource_opt->key);
@@ -227,9 +228,11 @@
if (type == GV_LINE) {
int cat;
Vect_cat_get(Cats, layer, &cat);
if (cat == -1)
continue; /*TODO: warning? */
@@ -249,6 +252,7 @@
if (find_cut) {
for (i = 0; i < cut->n_values; i++) {
int type = Vect_read_line(&In, Points, Cats, cut->value[i]);
Vect_write_line(&cut_map, type, Points, Cats);
Vect_destroy_list(cut);
Modified: grass/trunk/vector/v.net.spanningtree/main.c
--- grass/trunk/vector/v.net.spanningtree/main.c 2010-04-10 17:01:48 UTC (rev 41780)
+++ grass/trunk/vector/v.net.spanningtree/main.c 2010-04-10 17:08:11 UTC (rev 41781)
@@ -46,7 +46,8 @@
G_add_keyword(_("spanning tree"));
- module->description = _("Computes minimum spanning tree for the network.");
+ _("Computes minimum spanning tree for the network.");
@@ -79,8 +80,7 @@
- map_in->answer);
@@ -112,7 +112,8 @@
edges = NetA_spanning_tree(graph, tree_list);
G_debug(3, "Edges: %d", edges);
for (i = 0; i < edges; i++) {
- int type = Vect_read_line(&In, Points, Cats, abs(tree_list->value[i]));
+ int type =
+ Vect_read_line(&In, Points, Cats, abs(tree_list->value[i]));
Vect_destroy_list(tree_list);
Modified: grass/trunk/vector/v.net.timetable/main.c
--- grass/trunk/vector/v.net.timetable/main.c 2010-04-10 17:01:48 UTC (rev 41780)
+++ grass/trunk/vector/v.net.timetable/main.c 2010-04-10 17:08:11 UTC (rev 41781)
@@ -45,8 +45,10 @@
if (result.prev_stop[connection][stop] == -1)
return;
- struct segment *seg = (struct segment *)G_calloc(1, sizeof(struct segment));
+ struct segment *seg =
+ (struct segment *)G_calloc(1, sizeof(struct segment));
int prev_conn = result.prev_conn[connection][stop];
seg->next = head.next;
head.next = seg;
seg->route = result.prev_route[connection][stop];
@@ -80,10 +82,11 @@
dbString sql;
char buf[2000];
/* Create table */
*Fi = Vect_default_field_info(Out, layer, NULL, GV_MTABLE);
- Vect_map_add_dblink(Out, layer, NULL, (*Fi)->table, "cat", (*Fi)->database,
- (*Fi)->driver);
+ Vect_map_add_dblink(Out, layer, NULL, (*Fi)->table, "cat",
+ (*Fi)->database, (*Fi)->driver);
db_init_string(&sql);
*driver = db_start_driver_open_database((*Fi)->driver, (*Fi)->database);
if (*driver == NULL)
@@ -104,18 +107,22 @@
G_warning(_("Cannot create index"));
if (db_grant_on_table
- (*driver, (*Fi)->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK)
- G_fatal_error(_("Cannot grant privileges on table <%s>"), (*Fi)->table);
+ (*driver, (*Fi)->table, DB_PRIV_SELECT,
+ DB_GROUP | DB_PUBLIC) != DB_OK)
+ G_fatal_error(_("Cannot grant privileges on table <%s>"),
+ (*Fi)->table);
db_free_string(&sql);
db_begin_transaction(*driver);
void insert_point(dbDriver * driver, char *table, int cat, int path,
- int stop_id, int index, int arrival_time, int departure_time)
+ int stop_id, int index, int arrival_time,
+ int departure_time)
char buf[2000];
dbString sql;
sprintf(buf, "insert into %s values (%d, %d, %d, %d, %d, %d)", table, cat,
@@ -130,11 +137,13 @@
-void insert_line(dbDriver * driver, char *table, int cat, int path, int from_id,
- int to_id, int route_id, int index, int from_time, int to_time)
+void insert_line(dbDriver * driver, char *table, int cat, int path,
+ int from_id, int to_id, int route_id, int index,
+ int from_time, int to_time)
char buf[2000];
dbString sql;
sprintf(buf, "insert into %s values (%d, %d, %d, %d, %d, %d, %d, %d)",
@@ -154,6 +163,7 @@
int i, mini = -1;
double mind, d;
for (i = 0; i < timetable.stops; i++) {
if (!found[i])
continue;
@@ -173,6 +183,7 @@
struct line_pnts *Points;
struct line_cats *Cats;
struct ilist *list;
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -199,6 +210,7 @@
stop_node[timetable.route_stops[r][i + 1]], edges, list) != -1) {
for (j = 0; j < list->n_values; j++) {
int type = Vect_read_line(&In, Points, NULL, list->value[j]);
@@ -223,8 +235,8 @@
*stop_time_opt, *to_stop_opt, *walk_length_opt;
int with_z;
int layer, mask_type, path_layer;
- int from_stop, to_stop, start_time, min_change, max_changes, walking_change,
- ret;
+ int from_stop, to_stop, start_time, min_change, max_changes,
+ walking_change, ret;
int *stop_pnt, i, nlines, point_counter, *route_pnt;
int line_counter, index, j;
struct segment *cur;
@@ -253,7 +265,8 @@
walk_layer_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
walk_layer_opt->key = "walk_layer";
walk_layer_opt->answer = "-1";
- walk_layer_opt->label = _("Layer number or name with walking connections or -1");
+ walk_layer_opt->label =
+ _("Layer number or name with walking connections or -1");
path_layer_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
path_layer_opt->key = "path_layer";
@@ -270,7 +283,8 @@
stop_time_opt->key = "stop_time";
stop_time_opt->required = YES;
stop_time_opt->answer = "stop_time";
- stop_time_opt->description = _("Name of column name with stop timestamps");
+ stop_time_opt->description =
+ _("Name of column name with stop timestamps");
to_stop_opt = G_define_standard_option(G_OPT_DB_COLUMN);
to_stop_opt->key = "to_stop";
@@ -283,7 +297,7 @@
walk_length_opt->required = YES;
walk_length_opt->answer = "length";
walk_length_opt->description = _("Name of column name with walk lengths");
/* options and flags parser */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -302,8 +316,7 @@
- map_in->answer);
@@ -345,15 +358,16 @@
nnodes = Vect_get_num_nodes(&In);
stop_node = (int *)G_calloc(timetable.stops, sizeof(int));
lines =
- (struct ilist **)G_calloc(timetable.routes, sizeof(struct ilist *));
+ (struct ilist **)G_calloc(timetable.routes,
+ sizeof(struct ilist *));
edges = (int *)G_calloc(nnodes + 1, sizeof(int));
if (!edges || !stop_node || !lines)
G_fatal_error(_("Out of memory"));
for (i = 0; i < timetable.routes; i++)
lines[i] = Vect_new_list();
- Vect_net_build_graph(&In, mask_type, path_layer, 0, NULL, NULL, NULL, 0,
- 0);
+ Vect_net_build_graph(&In, mask_type, path_layer, 0, NULL, NULL, NULL,
+ 0, 0);
graph = &(In.graph);
@@ -361,15 +375,17 @@
int cat, stop, node;
for (j = 0; j < Cats->n_cats; j++) {
if (Cats->field[j] != layer)
continue;
cat = Cats->cat[j];
stop_pnt =
- (int *)bsearch(&cat, stop_ids, timetable.stops, sizeof(int),
- int_cmp);
+ (int *)bsearch(&cat, stop_ids, timetable.stops,
+ sizeof(int), int_cmp);
if (!stop_pnt)
continue;
@@ -387,6 +403,7 @@
else if (type == GV_LINE && path_layer > 0) {
int cat;
if (Cats->field[j] != path_layer)
continue;
@@ -409,6 +426,7 @@
while (1) {
double fx, fy, tx, ty;
int path_id;
if (fgets(buf, sizeof(buf), stdin) == NULL)
break;
ret =
@@ -438,8 +456,8 @@
from_stop = stop_pnt - stop_ids;
stop_pnt =
- (int *)bsearch(&to_stop, stop_ids, timetable.stops, sizeof(int),
- int_cmp);
+ (int *)bsearch(&to_stop, stop_ids, timetable.stops,
if (!stop_pnt) {
G_warning(_("No stop with category: %d"), to_stop);
continue;
@@ -474,12 +492,14 @@
Vect_cat_set(Cats, 1, point_counter);
Vect_write_line(&Out, GV_POINT, Cur, Cats);
insert_point(point_driver, point_Fi->table, point_counter, path_id,
- stop_ids[from_stop], 1, start_time, head.next->from_time);
+ stop_ids[from_stop], 1, start_time,
+ head.next->from_time);
point_counter++;
Vect_append_points(Prev, Cur, GV_FORWARD);
index = 1;
for (cur = head.next; cur; cur = cur->next) {
int dept_time, route_id;
if (cur->route == -2) {
printf("Walk ");
route_id = -1;
