[GRASS-SVN] r41792 - in grass/branches/develbranch_6/vector: v.net.allpairs v.net.bridge v.net.centrality v.net.components v.net.connectivity v.net.distance v.net.flow v.net.spanningtree v.net.timetable
Sat Apr 10 15:47:40 EDT 2010
Author: martinl
Date: 2010-04-10 15:47:39 -0400 (Sat, 10 Apr 2010)
New Revision: 41792
   grass/branches/develbranch_6/vector/v.net.allpairs/
   grass/branches/develbranch_6/vector/v.net.allpairs/Makefile
   grass/branches/develbranch_6/vector/v.net.bridge/
   grass/branches/develbranch_6/vector/v.net.centrality/
   grass/branches/develbranch_6/vector/v.net.centrality/Makefile
   grass/branches/develbranch_6/vector/v.net.components/
   grass/branches/develbranch_6/vector/v.net.components/Makefile
   grass/branches/develbranch_6/vector/v.net.connectivity/
   grass/branches/develbranch_6/vector/v.net.connectivity/Makefile
   grass/branches/develbranch_6/vector/v.net.distance/
   grass/branches/develbranch_6/vector/v.net.distance/Makefile
   grass/branches/develbranch_6/vector/v.net.flow/
   grass/branches/develbranch_6/vector/v.net.flow/Makefile
   grass/branches/develbranch_6/vector/v.net.spanningtree/
   grass/branches/develbranch_6/vector/v.net.spanningtree/Makefile
   grass/branches/develbranch_6/vector/v.net.timetable/
   grass/branches/develbranch_6/vector/v.net.timetable/Makefile
   grass/branches/develbranch_6/vector/v.net.timetable/main.c
more grass6 fixes
Property changes on: grass/branches/develbranch_6/vector/v.net.allpairs
___________________________________________________________________
Modified: svn:ignore
   - OBJ.*
   + OBJ.*
*.tmp.html
Modified: grass/branches/develbranch_6/vector/v.net.allpairs/Makefile
--- grass/branches/develbranch_6/vector/v.net.allpairs/Makefile	2010-04-10 19:44:12 UTC (rev 41791)
+++ grass/branches/develbranch_6/vector/v.net.allpairs/Makefile	2010-04-10 19:47:39 UTC (rev 41792)
@@ -2,7 +2,7 @@
 PGM=v.net.allpairs
-LIBES = $(VECTORLIB) $(GISLIB) $(NETALIB)
+LIBES = $(VECTRLIB) $(GISLIB) $(NETALIB)
 DEPENDENCIES = $(VECTORDEP) $(GISDEP)
 EXTRA_INC = $(VECT_INC)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
Property changes on: grass/branches/develbranch_6/vector/v.net.bridge
   - OBJ.*
   + OBJ.*
*.tmp.html
Property changes on: grass/branches/develbranch_6/vector/v.net.centrality
   - OBJ.*
   + OBJ.*
*.tmp.html
Modified: grass/branches/develbranch_6/vector/v.net.centrality/Makefile
--- grass/branches/develbranch_6/vector/v.net.centrality/Makefile	2010-04-10 19:44:12 UTC (rev 41791)
+++ grass/branches/develbranch_6/vector/v.net.centrality/Makefile	2010-04-10 19:47:39 UTC (rev 41792)
@@ -2,7 +2,7 @@
 PGM=v.net.centrality
+LIBES = $(VECRLIB) $(GISLIB) $(NETALIB)
Property changes on: grass/branches/develbranch_6/vector/v.net.components
   - OBJ.*
   + OBJ.*
*.tmp.html
Modified: grass/branches/develbranch_6/vector/v.net.components/Makefile
--- grass/branches/develbranch_6/vector/v.net.components/Makefile	2010-04-10 19:44:12 UTC (rev 41791)
+++ grass/branches/develbranch_6/vector/v.net.components/Makefile	2010-04-10 19:47:39 UTC (rev 41792)
@@ -2,7 +2,7 @@
 PGM=v.net.components
Property changes on: grass/branches/develbranch_6/vector/v.net.connectivity
   - OBJ.*
   + OBJ.*
*.tmp.html
Modified: grass/branches/develbranch_6/vector/v.net.connectivity/Makefile
--- grass/branches/develbranch_6/vector/v.net.connectivity/Makefile	2010-04-10 19:44:12 UTC (rev 41791)
+++ grass/branches/develbranch_6/vector/v.net.connectivity/Makefile	2010-04-10 19:47:39 UTC (rev 41792)
@@ -2,7 +2,7 @@
 PGM=v.net.connectivity
Property changes on: grass/branches/develbranch_6/vector/v.net.distance
   - OBJ*
   + OBJ*
*.tmp.html
Modified: grass/branches/develbranch_6/vector/v.net.distance/Makefile
--- grass/branches/develbranch_6/vector/v.net.distance/Makefile	2010-04-10 19:44:12 UTC (rev 41791)
+++ grass/branches/develbranch_6/vector/v.net.distance/Makefile	2010-04-10 19:47:39 UTC (rev 41792)
@@ -2,7 +2,7 @@
 PGM=v.net.distance
Property changes on: grass/branches/develbranch_6/vector/v.net.flow
   - OBJ.*
   + OBJ.*
*.tmp.html
Modified: grass/branches/develbranch_6/vector/v.net.flow/Makefile
--- grass/branches/develbranch_6/vector/v.net.flow/Makefile	2010-04-10 19:44:12 UTC (rev 41791)
+++ grass/branches/develbranch_6/vector/v.net.flow/Makefile	2010-04-10 19:47:39 UTC (rev 41792)
@@ -2,7 +2,7 @@
 PGM=v.net.flow
Property changes on: grass/branches/develbranch_6/vector/v.net.spanningtree
   - OBJ.*
   + OBJ.*
*.tmp.html
Modified: grass/branches/develbranch_6/vector/v.net.spanningtree/Makefile
--- grass/branches/develbranch_6/vector/v.net.spanningtree/Makefile	2010-04-10 19:44:12 UTC (rev 41791)
+++ grass/branches/develbranch_6/vector/v.net.spanningtree/Makefile	2010-04-10 19:47:39 UTC (rev 41792)
@@ -2,7 +2,7 @@
 PGM=v.net.spanningtree
Property changes on: grass/branches/develbranch_6/vector/v.net.timetable
   - OBJ.*
   + OBJ.*
*.tmp.html
Modified: grass/branches/develbranch_6/vector/v.net.timetable/Makefile
--- grass/branches/develbranch_6/vector/v.net.timetable/Makefile	2010-04-10 19:44:12 UTC (rev 41791)
+++ grass/branches/develbranch_6/vector/v.net.timetable/Makefile	2010-04-10 19:47:39 UTC (rev 41792)
@@ -2,7 +2,7 @@
 PGM=v.net.timetable
Modified: grass/branches/develbranch_6/vector/v.net.timetable/main.c
--- grass/branches/develbranch_6/vector/v.net.timetable/main.c	2010-04-10 19:44:12 UTC (rev 41791)
+++ grass/branches/develbranch_6/vector/v.net.timetable/main.c	2010-04-10 19:47:39 UTC (rev 41792)
@@ -260,13 +260,13 @@
     map_out = G_define_standard_option(G_OPT_V_OUTPUT);
-    walk_layer_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
+    walk_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
     walk_layer_opt->key = "walk_layer";
     walk_layer_opt->answer = "-1";
     walk_layer_opt->label =
 	_("Layer number or name with walking connections or -1");
-    path_layer_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
+    path_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
     path_layer_opt->key = "path_layer";
     path_layer_opt->answer = "-1";
     path_layer_opt->label = _("Layer number or name with route paths or -1");
