[GRASS-SVN] r41800 - in grass/trunk/gui/wxpython: . gui_modules
Sun Apr 11 11:49:09 EDT 2010
Author: martinl
Date: 2010-04-11 11:49:08 -0400 (Sun, 11 Apr 2010)
New Revision: 41800
   grass/trunk/gui/wxpython/gui_modules/gdialogs.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI: cosmetics in splitter
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2010-04-11 13:23:27 UTC (rev 41799)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2010-04-11 15:49:08 UTC (rev 41800)
@@ -944,7 +944,7 @@
         if self.inputType == 'dxf':
             self.inputTitle = _("Input DXF file")
         else:
-            self.inputTitle = _("Input directory")
+            self.inputTitle = _("Source name")
         self.inputBox = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
                                      label=" %s " % self.inputTitle)
@@ -964,22 +964,88 @@
                                                      changeCallback=self.OnSetInput,
                                                      fileMask="*.dxf")
         else:
-            self.inputText = wx.StaticText(self.panel, id=wx.ID_ANY, label=_("Choose directory:"))
-            self.input = filebrowse.DirBrowseButton(parent=self.panel, id=wx.ID_ANY,
-                                                     size=globalvar.DIALOG_GSELECT_SIZE, labelText='',
-                                                     dialogTitle=_('Choose input directory'),
-                                                     buttonText=_('Browse'),
-                                                     startDirectory=os.getcwd(),
-                                                     changeCallback=self.OnSetInput)
-            self.formatText = wx.StaticText(self.panel, id=wx.ID_ANY, label=_("Select file extension:"))
-            self.format = wx.TextCtrl(parent=self.panel, id=wx.ID_ANY, size=(100, -1),
-                                      value="")
+            self.typeRadio = wx.RadioBox(parent = self.panel, id = wx.ID_ANY,
+                                         label = _('Source type'),
+                                         style = wx.RA_SPECIFY_COLS,
+                                         choices = [_("File"),
+                                                    _("Directory"),
+                                                    _("Database"),
+                                                    _("Protocol")])
+            self.typeRadio.SetSelection(0)
+            self.Bind(wx.EVT_RADIOBOX, self.OnChangeType)
+            # input widgets
+            inputFile = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
+                                                    size=globalvar.DIALOG_GSELECT_SIZE, labelText='',
+                                                    dialogTitle=_('Choose input directory'),
+                                                    buttonText=_('Browse'),
+                                                    startDirectory=os.getcwd(),
+                                                    changeCallback=self.OnSetInput)
+            inputDir = filebrowse.DirBrowseButton(parent=self.panel, id=wx.ID_ANY,
+            inputDir.Hide()
+            inputDb = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
+            inputDb.Hide()
+            inputPro = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
+            inputPro.Hide()
+            # format widget
+            self.formatText = wx.StaticText(self.panel, id=wx.ID_ANY, label=_("Format:"))
+            self.format = wx.Choice(parent = self.panel, id = wx.ID_ANY, size=(200, -1))
+            self.format.Bind(wx.EVT_TEXT, self.OnSetInput)
+            if self.inputType == 'gdal':
+                ret = gcmd.RunCommand('r.in.gdal',
+                                      quiet = True, read = True,
+                                      flags = 'f')
+            else: # ogr
+                ret = gcmd.RunCommand('v.in.ogr',
+                                      flags = 'f')
+            self.input = { 'file' : [_("File:"),
+                                     inputFile,
+                                     list()],
+                           'dir'  : [_("Directory:"),
+                                     inputDir,
+                                     list()],
+                           'db'   : [_("Database:"),
+                                     inputDb,
+                                     list()],
+                           'pro'  : [_("Protocol:"),
+                                     inputPro,
+                                     list()] }
+            if ret:
+                for line in ret.splitlines():
+                    format = line.strip().rsplit(' ', 1)[0]
+                    if format in ('PostgreSQL', 'SQLite',
+                                  'ODBC', 'ESRI Personal GeoDatabase'):
+                        self.input['db'][2].append(format)
+                    elif format in ('GeoJSON'):
+                        self.input['pro'][2].append(format)
+                    else:
+                        self.input['file'][2].append(format)
+                        self.input['dir'][2].append(format)
+            self.inputType = 'file'
+            self.inputText = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
+                                           label = self.input[self.inputType][0],
+                                           size = (75, -1))
+            self.format.SetItems(self.input[self.inputType][2])
-                self.format.SetValue('tif')
-            else: # ogr
-                self.format.SetValue('shp')
-            self.format.Bind(wx.EVT_TEXT, self.OnSetInput)
+                self.format.SetStringSelection('GTIFF')
+            else:
+                self.format.SetStringSelection('ESRI Shapefile')
         # list of layers
@@ -1037,7 +1103,11 @@
         gridSizer.Add(item=self.inputText,
                       flag=wx.ALIGN_CENTER_VERTICAL)
         gridSizer.AddGrowableCol(1)
-        gridSizer.Add(item=self.input,
+        self.inputTypeSizer = wx.BoxSizer(wx.HORIZONTAL)
+        self.inputTypeSizer.Add(item=self.input[self.inputType][1], proportion = 1,
+                                flag = wx.ALIGN_CENTER_VERTICAL)
+        gridSizer.Add(item=self.inputTypeSizer,
                       flag=wx.EXPAND | wx.ALL)
         if self.inputType != 'dxf':
@@ -1047,7 +1117,9 @@
         inputSizer.Add(item=gridSizer, proportion=1,
+        dialogSizer.Add(item=self.typeRadio, proportion=0,
+                        flag=wx.ALL | wx.EXPAND, border=5)
         dialogSizer.Add(item=inputSizer, proportion=0,
@@ -1099,6 +1171,46 @@
         width = self.GetSize()[0]
         self.list.SetColumnWidth(col=1, width=width/2 - 50)
+    def OnChangeType(self, event):
+        """!Datasource type changed"""
+        sel = event.GetSelection()
+        win = self.input[self.inputType][1]
+        self.inputTypeSizer.Remove(win)
+        win.Hide()
+        if sel == 0:   # file
+            format = self.input[self.inputType][2][0]
+            if format == 'ESRI Shapefile':
+                format += ' (*.shp)|*.shp'
+            else:
+                format += ' (*.*)|*.*'
+            win = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
+                                              dialogTitle=_('Choose file'),
+                                              changeCallback=self.OnSetInput,
+                                              fileMask = format)
+            self.input[self.inputType][1] = win
+        elif sel == 1: # directory
+            self.inputType = 'dir'
+        elif sel == 2: # database
+            self.inputType = 'db'
+        elif sel == 3: # protocol
+            self.inputType = 'pro'
+        self.inputTypeSizer.Add(item = win, proportion = 1,
+        win.Show()
+        self.inputText.SetLabel(self.input[self.inputType][0])
+        self.format.SetSelection(0)
+        self.inputTypeSizer.Layout()
     def OnCancel(self, event=None):
         """!Close dialog"""
         self.Close()
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2010-04-11 13:23:27 UTC (rev 41799)
+++ grass/trunk/gui/wxpython/wxgui.py	2010-04-11 15:49:08 UTC (rev 41800)
@@ -992,26 +992,26 @@
     def OnImportGdalLayers(self, event):
         """!Convert multiple GDAL layers to GRASS raster map layers"""
         dlg = gdialogs.MultiImportDialog(parent=self, type='gdal',
-                                         title=_("Import GDAL layers"))
+                                         title=_("Import raster data"))
         dlg.ShowModal()
     def OnLinkGdalLayers(self, event):
         """!Link multiple GDAL layers to GRASS raster map layers"""
-                                         title=_("Link GDAL layers"),
+                                         title=_("Link raster data"),
                                          link = True)
         dlg.ShowModal()
     def OnImportOgrLayers(self, event):
         """!Convert multiple OGR layers to GRASS vector map layers"""
         dlg = gdialogs.MultiImportDialog(parent=self, type='ogr',
-                                         title=_("Import OGR layers"))
+                                         title=_("Import vector data"))
         dlg.ShowModal()
     def OnLinkOgrLayers(self, event):
         """!Links multiple OGR layers to GRASS vector map layers"""
-                                         title=_("Link OGR layers"),
+                                         title=_("Link vector data"),
                                          link = True)
         dlg.ShowModal()
