[GRASS-SVN] r41803 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Apr 11 12:23:55 EDT 2010
Author: martinl
Date: 2010-04-11 12:23:55 -0400 (Sun, 11 Apr 2010)
New Revision: 41803
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
wxGUI:fix dxf dialog
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2010-04-11 16:12:03 UTC (rev 41802)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2010-04-11 16:23:55 UTC (rev 41803)
@@ -16,7 +16,7 @@
- LayersList (used by MultiImport)
- SetOpacityDialog
-(C) 2008-2009 by the GRASS Development Team
+(C) 2008-2010 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
@@ -934,35 +934,35 @@
style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
self.parent = parent # GMFrame
- self.inputType = type
+ self.importType = type
self.link = link # Link or import data (only for GDAL/OGR)
wx.Dialog.__init__(self, parent, id, title, style=style)
self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
- if self.inputType == 'dxf':
- self.inputTitle = _("Input DXF file")
- else:
- self.inputTitle = _("Source name")
+ self.inputTitle = _("Source name")
self.inputBox = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
label=" %s " % self.inputTitle)
self.layerBox = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
- label=_(" List of %s layers ") % self.inputType.upper())
+ label=_(" List of %s layers ") % self.importType.upper())
# input
- self.inputText = wx.StaticText(self.panel, id=wx.ID_ANY, label=_("Choose DXF file:"))
- self.input = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
+ if self.importType == 'dxf':
+ inputFile = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
size=globalvar.DIALOG_GSELECT_SIZE, labelText='',
dialogTitle=_('Choose DXF file to import'),
buttonText=_('Browse'),
startDirectory=os.getcwd(), fileMode=0,
changeCallback=self.OnSetInput,
- fileMask="*.dxf")
+ fileMask="DXF File (*.dxf)|*.dxf")
+ self.input = { 'file' : [_("DXF file:"),
+ inputFile,
+ list()] }
+ self.inputType = 'file'
else:
self.typeRadio = wx.RadioBox(parent = self.panel, id = wx.ID_ANY,
label = _('Source type'),
@@ -998,10 +998,10 @@
# format widget
self.formatText = wx.StaticText(self.panel, id=wx.ID_ANY, label=_("Format:"))
- self.format = wx.Choice(parent = self.panel, id = wx.ID_ANY, size=(200, -1))
+ self.format = wx.Choice(parent = self.panel, id = wx.ID_ANY, size=(300, -1))
self.format.Bind(wx.EVT_TEXT, self.OnSetInput)
- if self.inputType == 'gdal':
+ if self.importType == 'gdal':
ret = gcmd.RunCommand('r.in.gdal',
quiet = True, read = True,
flags = 'f')
@@ -1025,7 +1025,7 @@
if ret:
for line in ret.splitlines():
- format = line.strip().rsplit(' ', 1)[0]
+ format = line.strip().rsplit(':', -1)[1].strip()
if format in ('PostgreSQL', 'SQLite',
'ODBC', 'ESRI Personal GeoDatabase'):
self.input['db'][2].append(format)
@@ -1037,16 +1037,17 @@
- self.inputText = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
- label = self.input[self.inputType][0],
- size = (75, -1))
self.format.SetItems(self.input[self.inputType][2])
- self.format.SetStringSelection('GTIFF')
- else:
+ self.format.SetStringSelection('GeoTIFF')
+ elif self.importType == 'ogr':
self.format.SetStringSelection('ESRI Shapefile')
+ self.inputText = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
+ label = self.input[self.inputType][0],
+ size = (75, -1))
# list of layers
@@ -1059,7 +1060,7 @@
else:
self.add.SetLabel(_("Add imported layers into layer tree"))
- if not link and self.inputType in ('gdal', 'ogr'):
+ if not link and self.importType in ('gdal', 'ogr'):
self.overrideCheck = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
label=_("Override projection (use location's projection)"))
self.overrideCheck.SetValue(True)
@@ -1110,7 +1111,7 @@
gridSizer.Add(item=self.inputTypeSizer,
flag=wx.EXPAND | wx.ALL)
- if self.inputType != 'dxf':
+ if self.importType != 'dxf':
gridSizer.Add(item=self.formatText,
flag=wx.ALIGN_CENTER_VERTICAL)
gridSizer.Add(item=self.format)
@@ -1118,8 +1119,9 @@
inputSizer.Add(item=gridSizer, proportion=1,
- dialogSizer.Add(item=self.typeRadio, proportion=0,
- flag=wx.ALL | wx.EXPAND, border=5)
+ dialogSizer.Add(item=self.typeRadio, proportion=0,
+ flag=wx.ALL | wx.EXPAND, border=5)
dialogSizer.Add(item=inputSizer, proportion=0,
@@ -1223,12 +1225,12 @@
self.Hide()
for layer, output in data:
cmd = ['v.in.dxf',
'input=%s' % self.input.GetValue(),
'layers=%s' % layer,
'output=%s' % output]
- elif self.inputType == 'ogr':
if self.link:
cmd = ['v.external',
'dsn=%s' % os.path.join(self.input.GetValue()),
@@ -1269,7 +1271,7 @@
else:
name = output
# add imported layers into layer tree
cmd = ['d.rast',
'map=%s' % name]
if UserSettings.Get(group='cmd', key='rasterOverlay', subkey='enabled'):
@@ -1299,7 +1301,7 @@
"""!Input DXF file/OGR dsn defined, update list of layer widget"""
path = event.GetString()
ret = gcmd.RunCommand('v.in.dxf',
quiet = True,
parent = self,
@@ -1312,7 +1314,7 @@
return
data = []
layerId = line.split(':')[0].split(' ')[1]
layerName = line.split(':')[1].strip()
