[GRASS-SVN] r41806 - in grass/trunk/gui: icons/grass2
wxpython/gui_modules wxpython/icons wxpython/xml
svn_grass at osgeo.org
Sun Apr 11 15:16:33 EDT 2010
Author: martinl
Date: 2010-04-11 15:16:32 -0400 (Sun, 11 Apr 2010)
New Revision: 41806
Added:
grass/trunk/gui/icons/grass2/move.png
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/icons/grass2_icons.py
grass/trunk/gui/wxpython/icons/grass_icons.py
grass/trunk/gui/wxpython/icons/icon.py
grass/trunk/gui/wxpython/icons/silk_icons.py
grass/trunk/gui/wxpython/xml/menudata_modeler.xml
wxGUI: modeler in progress
Added: grass/trunk/gui/icons/grass2/move.png
(Binary files differ)
Property changes on: grass/trunk/gui/icons/grass2/move.png
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
+ application/octet-stream
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-04-11 16:46:09 UTC (rev 41805)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-04-11 19:16:32 UTC (rev 41806)
@@ -69,6 +69,11 @@
self.modelFile = None # loaded model
self.modelChanged = False
+ self.cursors = {
+ "default" : wx.StockCursor(wx.CURSOR_ARROW),
+ "cross" : wx.StockCursor(wx.CURSOR_CROSS),
wx.Frame.__init__(self, parent = parent, id = id, title = title, **kwargs)
self.SetName("Modeler")
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
@@ -88,7 +93,8 @@
self.canvas = ModelCanvas(self)
self.canvas.SetBackgroundColour(wx.WHITE)
+ self.canvas.SetCursor(self.cursors["default"])
self.goutput = goutput.GMConsole(parent = self, pageid = 1)
self.modelPage = self.notebook.AddPage(self.canvas, text=_('Model'))
@@ -121,6 +127,23 @@
evthandler.SetPreviousHandler(item.GetEventHandler())
item.SetEventHandler(evthandler)
+ def FindAction(self, id):
+ """!Find action by id"""
+ for action in self.actions:
+ if action.GetId() == id:
+ return action
+ return None
+ def FindData(self, value, prompt):
+ """!Find data by value, and prompt"""
+ for data in self.data:
+ if data.GetValue() == value and \
+ data.GetPrompt() == prompt:
+ return data
+ return None
def ModelChanged(self):
"""!Update window title"""
if not self.modelChanged:
@@ -292,6 +315,10 @@
"""!Remove item from model"""
pass
+ def OnDefineRelation(self, event):
+ """!Define relation between data and action items"""
+ self.canvas.SetCursor(self.cursors["cross"])
def OnAddAction(self, event):
"""!Add action to model"""
if self.searchDialog is None:
@@ -366,18 +393,36 @@
def GetOptData(self, dcmd, layer, params, propwin):
"""!Process action data"""
layer.SetProperties(dcmd, params, propwin)
if params: # add data items
width, height = self.canvas.GetSize()
x = [width/2 + 200, width/2 - 200]
for p in params['params']:
- if p.get('value', None) and \
- p.get('prompt', '') in ('raster', 'vector', 'raster3d'):
+ if p.get('prompt', '') in ('raster', 'vector', 'raster3d') and \
+ (p.get('value', None) or \
+ p.get('age', 'old') != 'old'):
# create data item
+ data = layer.FindData(p.get('name', ''))
+ if data:
+ data.SetValue(p.get('value', ''))
+ continue
+ data = self.FindData(p.get('value', ''),
+ p.get('prompt', ''))
+ if data:
+ if p.get('age', 'old') == 'old':
+ self._addLine(data, layer)
+ data.AddAction(layer, direction = 'from')
+ else:
+ self._addLine(layer, data)
+ data.AddAction(layer, direction = 'to')
+ continue
data = ModelData(self, name = p.get('name', ''),
value = p.get('value', ''),
prompt = p.get('prompt', ''),
x = x.pop(), y = height/2)
+ layer.AddData(data)
self.canvas.diagram.AddShape(data)
data.Show(True)
@@ -391,10 +436,20 @@
+ # valid ?
+ valid = True
+ for p in params['params']:
+ if p.get('value', '') == '' and \
+ p.get('default', '') == '':
+ valid = False
+ break
+ layer.SetValid(valid)
self.canvas.Refresh()
self.SetStatusText(layer.GetLog(), 0)
def _addLine(self, fromShape, toShape):
"""!Add connection
@@ -446,11 +501,22 @@
width = action['size'][0],
height = action['size'][1],
cmd = action['cmd'])
+ actionShape.SetId(action['id'])
self.canvas.diagram.AddShape(actionShape)
actionShape.Show(True)
self._addEvent(actionShape)
self.actions.append(actionShape)
+ task = menuform.GUI().ParseCommand(cmd = actionShape.GetLog(string = False),
+ show = None)
+ valid = True
+ for p in task.get_options()['params']:
+ valid = False
+ break
+ actionShape.SetValid(valid)
# load data & connections
for data in gxmXml.data:
@@ -467,14 +533,17 @@
self._addEvent(dataShape)
self.data.append(dataShape)
+ for idx in range(len(data['id'])):
+ actionShape = self.FindAction(data['id'][idx])
+ if data['from'][idx] is True:
+ self._addLine(dataShape, actionShape)
+ dataShape.AddAction(actionShape, direction = 'from')
+ elif data['from'][idx] is False:
+ self._addLine(actionShape, dataShape)
+ dataShape.AddAction(actionShape, direction = 'to')
- actionShape = self.actions[0]
- if data['from'] is True:
- self._addLine(dataShape, actionShape)
- dataShape.AddAction(actionShape, direction = 'from')
- elif data['from'] is False:
- self._addLine(actionShape, dataShape)
- dataShape.AddAction(actionShape, direction = 'to')
+ actionShape.AddData(dataShape)
self.canvas.Refresh(True)
@@ -526,7 +595,15 @@
self.cmd = cmd
self.params = None
self.propWin = None
+ self.id = -1 # used for gxm file
+ self.data = list() # list of connected data items
+ # colors
+ self.colors = dict()
+ self.colors['valid'] = wx.LIGHT_GREY_BRUSH
+ self.colors['invalid'] = wx.WHITE_BRUSH
ogl.RectangleShape.__init__(self, width, height)
# self.Draggable(True)
@@ -534,12 +611,20 @@
self.SetX(x)
self.SetY(y)
self.SetPen(wx.BLACK_PEN)
- self.SetBrush(wx.LIGHT_GREY_BRUSH)
+ self.SetBrush(self.colors['invalid'])
if self.cmd and len(self.cmd) > 0:
self.AddText(self.cmd[0])
else:
self.AddText('<<module>>')
+ def GetId(self):
+ """!Get id"""
+ return self.id
+ def SetId(self, id):
+ """!Set id"""
+ self.id = id
def SetProperties(self, dcmd, params, propwin):
"""!Record properties dialog"""
self.cmd = dcmd
@@ -575,7 +660,27 @@
"""!Set dictionary of parameters"""
self.params = params
self.cmd = cmd
+ def SetValid(self, isvalid):
+ """!Set instance to be valid/invalid"""
+ if isvalid:
+ self.SetBrush(self.colors['valid'])
+ else:
+ def AddData(self, item):
+ """!Register new data item"""
+ if item not in self.data:
+ self.data.append(item)
+ def FindData(self, name):
+ """!Find data item by name"""
+ for d in self.data:
+ if d.GetName() == name:
+ return d
+ return None
class ModelData(ogl.EllipseShape):
"""!Data item class"""
def __init__(self, parent, x, y, name = '', value = '', prompt = '', width = 175, height = 50):
@@ -603,9 +708,13 @@
if name:
self.AddText(name)
+ else:
+ self.AddText(_('unknown'))
+ if value:
self.AddText(value)
else:
- self.AddText(_('unknown'))
+ self.AddText('\n')
def GetLog(self, string = True):
"""!Get logging info"""
@@ -631,7 +740,10 @@
self.value = value
self.ClearText()
self.AddText(self.name)
- self.AddText(self.value)
+ if value:
+ self.AddText(self.value)
+ else:
for direction in ('from', 'to'):
for action in self.actions[direction]:
task = menuform.GUI().ParseCommand(cmd = action.GetLog(string = False),
@@ -921,7 +1033,10 @@
"""!Get node text"""
p = node.find(tag)
if p is not None:
- return utils.normalize_whitespace(p.text)
+ if p.text:
+ return utils.normalize_whitespace(p.text)
+ else:
+ return ''
return default
@@ -935,10 +1050,13 @@
cmd = self._processTask(task)
else:
cmd = None
+ aId = int(action.get('id', -1))
self.actions.append({ 'pos' : pos,
'size': size,
- 'cmd' : cmd })
+ 'cmd' : cmd,
+ 'id' : aId })
def _getDim(self, node):
"""!Get position and size of shape"""
@@ -972,14 +1090,14 @@
prompt = param.get('prompt', None)
value = self._filterValue(self._getNodeText(param, 'value'))
- action = data.find('action')
- aId = fromDir = None
- if action is not None:
- aId = int(action.get('id', None))
+ aId = list()
+ fromDir = list()
+ for action in data.findall('action'):
+ aId.append(int(action.get('id', None)))
if action.get('dir', 'to') == 'to':
- fromDir = False
+ fromDir.append(False)
else:
- fromDir = True
+ fromDir.append(True)
self.data.append({ 'pos' : pos,
'size': size,
@@ -1048,6 +1166,7 @@
id = 1
self.indent += 4
+ action.SetId(id)
self.fd.write('%s<action id="%d" name="%s" pos="%d,%d" size="%d,%d">\n' % \
(' ' * self.indent, id, action.GetName(), action.GetX(), action.GetY(),
action.GetWidth(), action.GetHeight()))
@@ -1096,11 +1215,13 @@
self.fd.write('%s</parameter>\n' % (' ' * self.indent))
self.indent -= 4
for action in data.GetActions('from'):
- self.fd.write('%s<action id="1" dir="from" />\n' % \
- (' ' * self.indent))
+ id = action.GetId()
+ self.fd.write('%s<action id="%d" dir="from" />\n' % \
+ (' ' * self.indent, id))
for action in data.GetActions('to'):
- self.fd.write('%s<action id="1" dir="to" />\n' % \
+ self.fd.write('%s<action id="%d" dir="to" />\n' % \
self.fd.write('%s</data>\n' % (' ' * self.indent))
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2010-04-11 16:46:09 UTC (rev 41805)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2010-04-11 19:16:32 UTC (rev 41806)
@@ -77,9 +77,10 @@
if label:
Debug.msg(3, "CreateTool(): tool=%d, label=%s bitmap=%s" % \
(tool, label, bitmap))
toolWin = self.AddLabelTool(tool, label, bitmap,
- bmpDisabled, kind,
- shortHelp, longHelp)
+ bmpDisabled, kind,
+ shortHelp, longHelp)
self.Bind(wx.EVT_TOOL, handler, toolWin)
else: # separator
self.AddSeparator()
@@ -1393,6 +1394,7 @@
self.save = wx.NewId()
self.action = wx.NewId()
self.data = wx.NewId()
+ self.relation = wx.NewId()
self.run = wx.NewId()
self.validate = wx.NewId()
self.quit = wx.NewId()
@@ -1415,6 +1417,9 @@
(self.action, 'action', Icons['modelActionAdd'].GetBitmap(),
wx.ITEM_NORMAL, Icons['modelActionAdd'].GetLabel(), Icons['modelActionAdd'].GetDesc(),
self.parent.OnAddAction),
+ (self.relation, 'relation', Icons['modelRelation'].GetBitmap(),
+ wx.ITEM_NORMAL, Icons['modelRelation'].GetLabel(), Icons['modelRelation'].GetDesc(),
+ self.parent.OnDefineRelation),
(self.run, 'run', Icons['modelRun'].GetBitmap(),
wx.ITEM_NORMAL, Icons['modelRun'].GetLabel(), Icons['modelRun'].GetDesc(),
Modified: grass/trunk/gui/wxpython/icons/grass2_icons.py
--- grass/trunk/gui/wxpython/icons/grass2_icons.py 2010-04-11 16:46:09 UTC (rev 41805)
+++ grass/trunk/gui/wxpython/icons/grass2_icons.py 2010-04-11 19:16:32 UTC (rev 41806)
@@ -107,7 +107,7 @@
# modeler
"modelActionAdd" : 'layer-add.png',
"modelDataAdd" : 'map-add.png',
+ "modelRelation" : 'move.png',
"modelRun" : 'redo.png',
"modelValidate" : 'tools.png',
Modified: grass/trunk/gui/wxpython/icons/grass_icons.py
--- grass/trunk/gui/wxpython/icons/grass_icons.py 2010-04-11 16:46:09 UTC (rev 41805)
+++ grass/trunk/gui/wxpython/icons/grass_icons.py 2010-04-11 19:16:32 UTC (rev 41806)
@@ -109,7 +109,7 @@
# modeler
"modelActionAdd" : wx.ART_ERROR,
"modelDataAdd" : wx.ART_ERROR,
+ "modelRelation" : wx.ART_ERROR,
"modelRun" : wx.ART_ERROR,
"modelValidate" : wx.ART_ERROR,
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py 2010-04-11 16:46:09 UTC (rev 41805)
+++ grass/trunk/gui/wxpython/icons/icon.py 2010-04-11 19:16:32 UTC (rev 41806)
@@ -347,6 +347,8 @@
label=_("Add action (GRASS module) to model")),
"modelDataAdd" : MetaIcon (img=Icons["modelDataAdd"],
label=_("Add data item to model")),
+ "modelRelation" : MetaIcon (img=Icons["modelRelation"],
+ label=_("Define relation between data and action items")),
"modelRun" : MetaIcon (img=Icons["modelRun"],
label=_("Run entire model")),
"modelValidate" : MetaIcon (img=Icons["modelValidate"],
Modified: grass/trunk/gui/wxpython/icons/silk_icons.py
--- grass/trunk/gui/wxpython/icons/silk_icons.py 2010-04-11 16:46:09 UTC (rev 41805)
+++ grass/trunk/gui/wxpython/icons/silk_icons.py 2010-04-11 19:16:32 UTC (rev 41806)
@@ -110,6 +110,7 @@
# modeler
Modified: grass/trunk/gui/wxpython/xml/menudata_modeler.xml
--- grass/trunk/gui/wxpython/xml/menudata_modeler.xml 2010-04-11 16:46:09 UTC (rev 41805)
+++ grass/trunk/gui/wxpython/xml/menudata_modeler.xml 2010-04-11 19:16:32 UTC (rev 41806)
@@ -56,6 +56,11 @@
<shortcut>Ctrl+A</shortcut>
</menuitem>
<menuitem>
+ <label>Define relation</label>
+ <help>Define relation between data and action items</help>
+ <handler>OnDefineRelation</handler>
+ </menuitem>
+ <menuitem>
<label>Remove item</label>
<help>Remove action/data from model</help>
<handler>OnRemoveItem</handler>
