[GRASS-SVN] r41818 -
grass/branches/develbranch_6/vector/v.net.centrality
svn_grass at osgeo.org
Mon Apr 12 09:52:54 EDT 2010
Author: martinl
Date: 2010-04-12 09:52:53 -0400 (Mon, 12 Apr 2010)
New Revision: 41818
grass/branches/develbranch_6/vector/v.net.centrality/main.c
v.net.centarality: variable renamed due to compilation problems on MS Windows
Modified: grass/branches/develbranch_6/vector/v.net.centrality/main.c
--- grass/branches/develbranch_6/vector/v.net.centrality/main.c 2010-04-12 06:55:07 UTC (rev 41817)
+++ grass/branches/develbranch_6/vector/v.net.centrality/main.c 2010-04-12 13:52:53 UTC (rev 41818)
@@ -26,7 +26,7 @@
/*Global variables */
struct Option *deg_opt, *close_opt, *betw_opt, *eigen_opt;
-double *deg, *close, *betw, *eigen;
+double *deg, *closeness, *betw, *eigen;
/* Attribute table */
dbString sql, tmp;
@@ -57,7 +57,7 @@
if (deg_opt->answer)
append_double(&sql, deg[node]);
if (close_opt->answer)
- append_double(&sql, close[node]);
+ append_double(&sql, closeness[node]);
if (betw_opt->answer)
append_double(&sql, betw[node]);
if (eigen_opt->answer)
@@ -258,7 +258,7 @@
graph = &(In.graph);
nnodes = dglGet_NodeCount(graph);
- deg = close = betw = eigen = NULL;
+ deg = closeness = betw = eigen = NULL;
covered = (char *)G_calloc(nnodes + 1, sizeof(char));
if (!covered)
@@ -271,8 +271,8 @@
if (close_opt->answer) {
- close = (double *)G_calloc(nnodes + 1, sizeof(double));
- if (!close)
+ closeness = (double *)G_calloc(nnodes + 1, sizeof(double));
+ if (!closeness)
G_fatal_error(_("Out of memory"));
@@ -295,10 +295,10 @@
if (betw_opt->answer || close_opt->answer) {
G_message(_("Computing betweenness and/or closeness centrality measure"));
- NetA_betweenness_closeness(graph, betw, close);
- if (close)
+ NetA_betweenness_closeness(graph, betw, closeness);
+ if (closeness)
for (i = 1; i <= nnodes; i++)
- close[i] /= (double)In.cost_multip;
+ closeness[i] /= (double)In.cost_multip;
if (eigen_opt->answer) {
G_message(_("Computing eigenvector centrality measure"));
@@ -352,8 +352,8 @@
G_free(covered);
if (deg)
G_free(deg);
- if (close)
- G_free(close);
+ if (closeness)
+ G_free(closeness);
if (betw)
G_free(betw);
if (eigen)
