[GRASS-SVN] r41856 - grass/trunk/lib/init
svn_grass at osgeo.org
Wed Apr 14 06:14:30 EDT 2010
Author: martinl
Date: 2010-04-14 06:14:29 -0400 (Wed, 14 Apr 2010)
New Revision: 41856
grass/trunk/lib/init/grass.py
grass.py: i18n
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2010-04-14 09:45:37 UTC (rev 41855)
+++ grass/trunk/lib/init/grass.py 2010-04-14 10:14:29 UTC (rev 41856)
@@ -47,6 +47,10 @@
gisbase = os.path.normpath(gisbase)
+### i18N
+import gettext
+gettext.install('grasslibs', os.path.join(gisbase, 'locale'), unicode=True)
tmpdir = None
lockfile = None
location = None
@@ -108,38 +112,61 @@
return os.path.join(gisbase, *args)
help_text = r"""
-Usage:
+%s:
$CMD_NAME [-h | -help | --help] [-v | --version] [-c]
[-text | -gui | -wxpython | -wx]
[[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]
-Flags:
- -h or -help or --help print this help message
- -v or --version show version information and exit
- -c create given mapset if it doesn\'t exist
- -text use text based interface
- and set as default
- -gui use graphical user interface ($DEFAULT_GUI by default)
- -wxpython or -wx use wxPython based graphical user interface
+%s:
+ -h or -help or --help %s
+ -v or --version %s
+ -c %s
+ -text %s
+ %s
+ -gui %s
+ %s
+ -wxpython or -wx %s
+ %s
-Parameters:
- GISDBASE initial database (path to GIS data)
- LOCATION_NAME initial location
- MAPSET initial mapset
+%s:
+ GISDBASE %s
+ LOCATION_NAME %s
+ MAPSET %s
- GISDBASE/LOCATION_NAME/MAPSET fully qualified initial mapset directory
+ GISDBASE/LOCATION_NAME/MAPSET %s
-Environment variables relevant for startup:
- GRASS_GUI select GUI (text, gui, wxpython)
- GRASS_WISH set wish shell name to override 'wish'
- GRASS_HTML_BROWSER set html web browser for help pages
- GRASS_ADDON_PATH set additional path(s) to local GRASS modules
- GRASS_BATCH_JOB shell script to be processed as batch job
- GRASS_PYTHON set python shell name to override 'python'
+%s:
+ GRASS_GUI %s
+ GRASS_WISH %s
+ GRASS_HTML_BROWSER %s
+ GRASS_ADDON_PATH %s
+ GRASS_BATCH_JOB %s
+ GRASS_PYTHON %s
+""" % (_("Usage"),
+ _("Flags"),
+ _("print this help message"),
+ _("show version information and exit"),
+ _("create given mapset if it doesn't exist"),
+ _("use text based interface"),
+ _("and set as default"),
+ _("use graphical user interface ($DEFAULT_GUI by default)"),
+ _("use wxPython based graphical user interface"),
+ _("Parameters"),
+ _("initial database (path to GIS data)"),
+ _("initial location"),
+ _("initial mapset"),
+ _("fully qualified initial mapset directory"),
+ _("Environment variables relevant for startup"),
+ _("select GUI (text, gui, wxpython)"),
+ _("set wish shell name to override 'wish'"),
+ _("set html web browser for help pages"),
+ _("set additional path(s) to local GRASS modules"),
+ _("shell script to be processed as batch job"),
+ _("set python shell name to override 'python'"))
def help_message():
t = string.Template(help_text)
s = t.substitute(CMD_NAME = cmd_name, DEFAULT_GUI = default_gui)
@@ -157,7 +184,7 @@
try:
os.mkdir(tmpdir, 0700)
except:
- fatal("Cannot create temporary directory! Exiting.")
+ fatal(_("Unable to create temporary directory! Exiting."))
def create_gisrc():
global gisrc, gisrcrc
@@ -327,7 +354,7 @@
os.environ['GRASS_HTML_BROWSER_MACOSX'] = "-b com.apple.helpviewer"
if not browser:
- message("WARNING: Searched for a web browser, but none found.")
+ warning(_("Searched for a web browser, but none found"))
# even so we set konqueror to make lib/gis/parser.c happy:
browser = "konqueror"
@@ -346,7 +373,7 @@
f.close()
sys.stderr.write("\n")
- sys.stderr.write("Hit RETURN to continue")
+ sys.stderr.write(_("Hit RETURN to continue"))
sys.stdin.readline()
#for convenience, define pwd as GISDBASE:
@@ -375,13 +402,11 @@
wxpython_base = gfile("etc", "gui", "wxpython")
else:
# Python was not found - switch to text interface mode
- message(
-r"""WARNING: The python command does not work as expected!
-Please check your GRASS_PYTHON environment variable.
-Use the -help option for details.
-Switching to text based interface mode.
-Hit RETURN to continue.""")
+ warning(_("The python command does not work as expected!\n"
+ "Please check your GRASS_PYTHON environment variable.\n"
+ "Use the -help option for details.\n"
+ "Switching to text based interface mode.\n\n"
+ "Hit RETURN to continue.\n"))
grass_gui = 'text'
@@ -389,12 +414,10 @@
# Display a message if a graphical interface was expected
if grass_gui != 'text':
# Set the interface mode to text
- message(
-r"""WARNING: It appears that the X Windows system is not active.
-A graphical based user interface is not supported.
-Hit RETURN to continue""")
+ warning(_("It appears that the X Windows system is not active.\n"
+ "A graphical based user interface is not supported.\n"
+ "Hit RETURN to continue"""))
grass_gui = 'text'
@@ -433,20 +456,20 @@
if not os.access(os.path.join(location, "WIND"), os.R_OK):
if location_name == "PERMANENT":
- fatal("%s: Not a valid GRASS location" % location)
+ fatal(_("<%s> is not a valid GRASS location") % location)
else:
# the user wants to create mapset on the fly
if create_new:
if not os.access(os.path.join(os.path.join(gisdbase, location_name, "PERMANENT", "DEFAULT_WIND")), os.F_OK):
- fatal("The LOCATION \"%s\" does not exist. Please create it first" % location_name)
+ fatal(_("The location <%s> does not exist. Please create it first.") % location_name)
else:
os.mkdirs(location)
# copy PERMANENT/DEFAULT_WIND to <mapset>/WIND
s = readfile(os.path.join(gisdbase, location_name, "PERMANENT", "DEFAULT_WIND"))
writefile(os.path.join(location, "WIND"), s)
- message("Missing WIND file fixed")
+ message(_("Missing WIND file fixed"))
else:
if os.access(gisrc, os.R_OK):
kv = read_gisrc()
@@ -458,8 +481,8 @@
kv['MAPSET'] = mapset
write_gisrc(kv)
else:
- fatal("GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n" +
- "Interactive startup needed.")
+ fatal(_("GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
+ "Interactive startup needed."))
def set_data():
# User selects LOCATION and MAPSET if not set
@@ -472,8 +495,8 @@
gui_startup()
else:
# Shouldn't need this but you never know
- fatal("ERROR: Invalid user interface specified - <%s>.\n" % grass_gui +
- "Use the --help option to see valid interface names.")
+ fatal(_("Invalid user interface specified - <%s>.\n"
+ "Use the --help option to see valid interface names.") % grass_gui)
def gui_startup():
if grass_gui == 'wxpython':
@@ -484,24 +507,21 @@
elif thetest == 1:
# The startup script printed an error message so wait
# for user to read it
- message(
-r"""
-Error in GUI startup. If necessary, please
-report this error to the GRASS developers.
-Switching to text mode now.
-Hit RETURN to continue...""")
+ message(_("Error in GUI startup. If necessary, please "
+ "report this error to the GRASS developers.\n"
+ "Switching to text mode now.\n\n"
+ "Hit RETURN to continue..."))
os.execlp(cmd_name, "-text")
sys.exit(1)
elif thetest == 2:
# User wants to exit from GRASS
- message("Received EXIT message from GUI.\n" + "GRASS is not started. Bye.")
+ message(_("Received EXIT message from GUI.\nGRASS is not started. Bye."))
sys.exit(0)
else:
- fatal("ERROR: Invalid return code from GUI startup script.\n" +
- "Please advise GRASS developers of this error.")
+ fatal(_("Invalid return code from GUI startup script.\n"
+ "Please advise GRASS developers of this error."))
def load_gisrc():
global gisdbase, location_name, mapset, location
@@ -510,15 +530,14 @@
location_name = kv.get('LOCATION_NAME')
mapset = kv.get('MAPSET')
if not gisdbase or not location_name or not mapset:
- message(
-r"""ERROR: Reading data path information from g.gisenv.
-GISDBASE=[%s]
-LOCATION_NAME=[%s]
-MAPSET=[%s]
-Check the <%s> file.""" % (gisdbase, location_name, mapset, gisrcrc))
- sys.exit(1)
+ fatal(_("Error reading data path information from g.gisenv.\n"
+ "GISDBASE=%(gisbase)s\n"
+ "LOCATION_NAME=%(location)s\n"
+ "MAPSET=%(mapset)s\n\n"
+ "Check the <%s(file)> file." % \
+ { 'gisbase' : gisdbase, 'location' : location_name,
+ 'mapset' : mapset, 'file' : gisrcrc }))
location = os.path.join(gisdbase, location_name, mapset)
def check_lock():
@@ -532,12 +551,11 @@
if ret == 0:
msg = None
elif ret == 2:
- msg = "%s is currently running GRASS in selected mapset (file %s found). " \
- "Concurrent use not allowed." % \
- (user, lockfile)
+ msg = _("%(user)s is currently running GRASS in selected mapset (file %(file)s found). "
+ "Concurrent use not allowed." % \
+ { 'user' : user, 'file' : lockfile })
else:
- msg = "Unable to properly access \"%s\"\n" % \
- lockfile + "Please notify system personel."
+ msg = _("Unable to properly access \"%s\"\nPlease notify system personel.") % lockfile
if msg:
if grass_gui == "wxpython":
@@ -548,7 +566,7 @@
def make_fontcap():
fc = os.getenv('GRASS_FONT_CAP')
if fc and not os.access(fc, os.R_OK):
- message("Building user fontcap ...")
+ message(_("Building user fontcap..."))
call(["g.mkfontcap"])
def check_shell():
@@ -577,7 +595,7 @@
# check for SHELL
if not os.getenv('SHELL'):
- fatal("ERROR: The SHELL variable is not set")
+ fatal(_("The SHELL variable is not set"))
def check_batch_job():
global batch_job
@@ -587,24 +605,21 @@
# defined, but ...
if not os.access(batch_job, os.F_OK):
# wrong file
- fatal(
-r"""Job file '%s' has been defined in
-the 'GRASS_BATCH_JOB' variable but not found. Exiting.
-Use 'unset GRASS_BATCH_JOB' to disable batch job processing.
-""" % batch_job)
+ fatal(_("Job file '%s' has been defined in "
+ "the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n\n"
+ "Use 'unset GRASS_BATCH_JOB' to disable batch job processing.") % batch_job)
elif not os.access(batch_job, os.X_OK):
# right file, but ...
- fatal("ERROR: change file permission to 'executable' for '%s'" % batch_job)
+ fatal(_("Change file permission to 'executable' for '%s'") % batch_job)
else:
- message("Executing '$GRASS_BATCH_JOB' ...")
+ message(_("Executing '%s' ...") % batch_job)
grass_gui = "text"
shell = batch_job
def start_gui():
# Start the chosen GUI but ignore text
if grass_debug:
- message("GRASS GUI should be %s" % grass_gui)
+ message(_("GRASS GUI should be '%s'") % grass_gui)
# Check for gui interface
@@ -644,18 +659,22 @@
def show_info():
sys.stderr.write(
r"""
-GRASS homepage: http://grass.osgeo.org/
-This version running through: %s (%s)
-Help is available with the command: g.manual -i
-See the licence terms with: g.version -c
-""" % (shellname, os.getenv('SHELL')))
+%-41shttp://grass.osgeo.org
+%-41s%s (%s)
+%-41sg.manual -i
+%-41sg.version -c
+""" % (_("GRASS homepage:"),
+ _("This version running through:"),
+ shellname, os.getenv('SHELL'),
+ _("Help is available with the command:"),
+ _("See the licence terms with:")))
- message("If required, restart the GUI with: g.gui wxpython")
+ message("%-41sg.gui wxpython" % _("If required, restart the GUI with:"))
else:
- message("Start the GUI with: g.gui %s" % default_gui)
+ message("%-41sg.gui %s" % (_("Start the GUI with:"), default_gui))
- message("When ready to quit enter: exit")
+ message("%-41sexit" % _("When ready to quit enter:"))
message("")
def csh_startup():
@@ -759,17 +778,17 @@
def done_message():
if batch_job and os.access(batch_job, os.X_OK):
- message("Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed." % batch_job)
- message("Goodbye from GRASS GIS")
+ message(_("Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed.") % batch_job)
+ message(_("Goodbye from GRASS GIS"))
sys.exit(exit_val)
else:
- message("Done.")
+ message(_("Done."))
message("")
message("")
def clean_temp():
- message("Cleaning up temporary files ...")
+ message(_("Cleaning up temporary files..."))
nul = open(os.devnull, 'w')
call([gfile("etc", "clean_temp")], stdout = nul, stderr = nul)
nul.close()
@@ -913,7 +932,7 @@
else:
clean_temp()
-message("Starting GRASS ...")
+message(_("Starting GRASS GIS..."))
# Check that the GUI works
check_gui()
