[GRASS-SVN] r41860 - in grass/trunk/gui/wxpython: . gui_modules xml
svn_grass at osgeo.org
Wed Apr 14 10:03:57 EDT 2010
Author: martinl
Date: 2010-04-14 10:03:56 -0400 (Wed, 14 Apr 2010)
New Revision: 41860
grass/trunk/gui/wxpython/Makefile
grass/trunk/gui/wxpython/gui_modules/menudata.py
grass/trunk/gui/wxpython/xml/menudata_modeler.xml
wxGUI: enable i18n for modeler menu
Modified: grass/trunk/gui/wxpython/Makefile
--- grass/trunk/gui/wxpython/Makefile 2010-04-14 11:40:14 UTC (rev 41859)
+++ grass/trunk/gui/wxpython/Makefile 2010-04-14 14:03:56 UTC (rev 41860)
@@ -21,9 +21,11 @@
$(ETCDIR)/%: % | $(DSTDIRS)
$(INSTALL_DATA) $< $@
-menustrings.py: gui_modules/menudata.py $(ETCDIR)/xml/menudata.xml
+menustrings.py: gui_modules/menudata.py $(ETCDIR)/xml/menudata.xml $(ETCDIR)/xml/menudata_modeler.xml
GISBASE="$(GISBASE)" \
$(PYTHON) $< > $@
+ GISBASE="$(GISBASE)" \
+ $(PYTHON) $< "modeler" >> $@
$(DSTDIRS): %: | $(ETCDIR)
$(MKDIR) $@
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py 2010-04-14 11:40:14 UTC (rev 41859)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py 2010-04-14 14:03:56 UTC (rev 41860)
@@ -10,7 +10,7 @@
Usage:
@code
-python menudata.py action [file]
+python menudata.py [action] [manager|modeler]
@endcode
where <i>action</i>:
@@ -116,7 +116,8 @@
"""!Print menu strings to file (used for localization)
@param fh file descriptor"""
- fh.write('menustrings = [\n')
+ className = str(self.__class__).split('.', 1)[1]
+ fh.write('menustrings_%s = [\n' % className)
for node in self.tree.getiterator():
if node.tag in ['label', 'help']:
fh.write(' _(%r),\n' % node.text)
@@ -236,18 +237,19 @@
import gettext
gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
- file = None
- if len(sys.argv) == 1:
- action = 'strings'
- elif len(sys.argv) > 1:
- action = sys.argv[1]
- if len(sys.argv) > 2:
- file = sys.argv[2]
- if file:
- data = ManagerData(file)
+ action = 'strings'
+ menu = 'manager'
+ for arg in sys.argv:
+ if arg in ('strings', 'tree', 'commands', 'dump'):
+ action = arg
+ elif arg in ('manager', 'modeler'):
+ menu = arg
+ if menu == 'manager':
+ data = ManagerData()
else:
- data = ManagerData()
+ data = ModelerData()
if action == 'strings':
data.PrintStrings(sys.stdout)
Modified: grass/trunk/gui/wxpython/xml/menudata_modeler.xml
--- grass/trunk/gui/wxpython/xml/menudata_modeler.xml 2010-04-14 11:40:14 UTC (rev 41859)
+++ grass/trunk/gui/wxpython/xml/menudata_modeler.xml 2010-04-14 14:03:56 UTC (rev 41860)
@@ -39,7 +39,7 @@
</menuitem>
<separator />
<menuitem>
- <label>Close modeler</label>
+ <label>Quit modeler</label>
<help>Close modeler window</help>
<handler>OnCloseWindow</handler>
<shortcut>Ctrl+W</shortcut>
