[GRASS-SVN] r41909 - in grass/trunk/doc: . python
svn_grass at osgeo.org
Sat Apr 17 08:06:25 EDT 2010
Author: neteler
Date: 2010-04-17 08:06:21 -0400 (Sat, 17 Apr 2010)
New Revision: 41909
Added:
grass/trunk/doc/python/
grass/trunk/doc/python/example_ctypes.py
glynn: ctypes Python example; with small additions
Added: grass/trunk/doc/python/example_ctypes.py
--- grass/trunk/doc/python/example_ctypes.py (rev 0)
+++ grass/trunk/doc/python/example_ctypes.py 2010-04-17 12:06:21 UTC (rev 41909)
@@ -0,0 +1,50 @@
+#!/usr/bin/env python
+import os, sys, subprocess
+from ctypes import *
+grass = CDLL("libgrass_gis.so")
+rast = CDLL("libgrass_raster.so")
+if not os.environ.has_key("GISBASE"):
+ print "You must be in GRASS GIS to run this program."
+ sys.exit(1)
+if len(sys.argv)==2:
+ input = sys.argv[1]
+else:
+ input = raw_input("Raster Map Name? ")
+# initialize
+s = subprocess.Popen(['g.version','-r'], stdout=subprocess.PIPE).communicate()[0]
+for line in s.splitlines():
+ if line.startswith('Revision:'):
+ version = '$' + line + '$'
+grass.G__gisinit(version, '')
+# find map in search path
+mapset = grass.G_find_raster2(input, '')
+mapset = c_char_p(mapset).value
+# determine the inputmap type (CELL/FCELL/DCELL) */
+data_type = rast.Rast_map_type(input, mapset)
+if data_type == 0:
+ ptype = POINTER(c_int)
+elif data_type == 1:
+ ptype = POINTER(c_float)
+elif data_type == 2:
+ ptype = POINTER(c_double)
+infd = rast.Rast_open_old(input, mapset)
+inrast = rast.Rast_allocate_buf(data_type)
+inrast = cast(c_void_p(inrast), ptype)
+rows = rast.Rast_window_rows()
+cols = rast.Rast_window_cols()
+for rown in xrange(rows):
+ rast.Rast_get_row(infd, inrast, rown, data_type)
+ print rown, inrast[0:cols]
+rast.Rast_close(infd)
+grass.G_free(inrast)
