[GRASS-SVN] r41911 - in grass/branches/develbranch_6/doc: . python
svn_grass at osgeo.org
Sat Apr 17 08:08:30 EDT 2010
Author: neteler
Date: 2010-04-17 08:08:29 -0400 (Sat, 17 Apr 2010)
New Revision: 41911
Added:
grass/branches/develbranch_6/doc/python/
grass/branches/develbranch_6/doc/python/example_ctypes.py
glynn: ctypes Python example; with small additions
Added: grass/branches/develbranch_6/doc/python/example_ctypes.py
--- grass/branches/develbranch_6/doc/python/example_ctypes.py (rev 0)
+++ grass/branches/develbranch_6/doc/python/example_ctypes.py 2010-04-17 12:08:29 UTC (rev 41911)
@@ -0,0 +1,49 @@
+#!/usr/bin/env python
+import os, sys, subprocess
+from ctypes import *
+grass = CDLL("libgrass_gis.so")
+if not os.environ.has_key("GISBASE"):
+ print "You must be in GRASS GIS to run this program."
+ sys.exit(1)
+if len(sys.argv)==2:
+ input = sys.argv[1]
+else:
+ input = raw_input("Raster Map Name? ")
+# initialize
+s = subprocess.Popen(['g.version','-r'], stdout=subprocess.PIPE).communicate()[0]
+for line in s.splitlines():
+ if line.startswith('Revision:'):
+ version = '$' + line + '$'
+grass.G__gisinit(version, '')
+# find map in search path
+mapset = grass.G_find_cell2(input, '')
+mapset = c_char_p(mapset).value
+# determine the inputmap type (CELL/FCELL/DCELL) */
+data_type = grass.G_raster_map_type(input, mapset)
+if data_type == 0:
+ ptype = POINTER(c_int)
+elif data_type == 1:
+ ptype = POINTER(c_float)
+elif data_type == 2:
+ ptype = POINTER(c_double)
+infd = grass.G_open_cell_old(input, mapset)
+inrast = grass.G_allocate_raster_buf(data_type)
+inrast = cast(c_void_p(inrast), ptype)
+rows = grass.G_window_rows()
+cols = grass.G_window_cols()
+for rown in xrange(rows):
+ grass.G_get_raster_row(infd, inrast, rown, data_type)
+ print rown, inrast[0:cols]
+grass.G_close_cell(infd)
+grass.G_free(inrast)
