[GRASS-SVN] r41936 - grass-addons/gui/wxpython/data_catalog
svn_grass at osgeo.org
Tue Apr 20 13:09:15 EDT 2010
Author: rashadkm
Date: 2010-04-20 13:09:14 -0400 (Tue, 20 Apr 2010)
New Revision: 41936
Added:
grass-addons/gui/wxpython/data_catalog/menudata.py
Added: grass-addons/gui/wxpython/data_catalog/menudata.py
--- grass-addons/gui/wxpython/data_catalog/menudata.py (rev 0)
+++ grass-addons/gui/wxpython/data_catalog/menudata.py 2010-04-20 17:09:14 UTC (rev 41936)
@@ -0,0 +1,80 @@
+ at package menudata.py
+ at brief Complex list for main menu entries for GRASS wxPython GUI.
+Classes:
+ - Data
+COPYRIGHT: (C) 2007-2008 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Michael Barton (Arizona State University)
+ at author Yann Chemin <yann.chemin gmail.com>
+ at author Martin Landa <landa.martin gmail.com>
+ at author Glynn Clements
+import os
+try:
+ import xml.etree.ElementTree as etree
+except ImportError:
+ import elementtree.ElementTree as etree # Python <= 2.4
+class Data:
+ '''Data object that returns menu descriptions to be used in wxgui.py.'''
+ def __init__(self, gisbase=None):
+ if not gisbase:
+ gisbase = os.getenv('GISBASE')
+ filename = gisbase + '/etc/wxpython/xml/menudata.xml'
+ self.tree = etree.parse(filename)
+ def getMenuItem(self, mi):
+ if mi.tag == 'separator':
+ return ('', '', '', '')
+ elif mi.tag == 'menuitem':
+ label = _(mi.find('label').text)
+ help = _(mi.find('help').text)
+ handler = mi.find('handler').text
+ gcmd = mi.find('command')
+ if gcmd != None:
+ gcmd = gcmd.text
+ else:
+ gcmd = ""
+ return (label, help, handler, gcmd)
+ elif mi.tag == 'menu':
+ return self.getMenu(mi)
+ else:
+ raise Exception()
+ def getMenu(self, m):
+ label = _(m.find('label').text)
+ items = m.find('items')
+ return (label, tuple(map(self.getMenuItem, items)))
+ def getMenuBar(self, mb):
+ return tuple(map(self.getMenu, mb.findall('menu')))
+ def getMenuData(self, md):
+ return list(map(self.getMenuBar, md.findall('menubar')))
+ def GetMenu(self):
+ return self.getMenuData(self.tree.getroot())
+ def PrintStrings(self, fh):
+ fh.write('menustrings = [\n')
+ for node in self.tree.getiterator():
+ if node.tag in ['label', 'help']:
+ fh.write(' _(%r),\n' % node.text)
+ fh.write(' \'\']\n')
+if __name__ == "__main__":
+ import sys
+ if len(sys.argv) < 2:
+ sys.exit(1)
+ Data(sys.argv[1]).PrintStrings(sys.stdout)
+ sys.exit(0)
