[GRASS-SVN] r41945 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Apr 21 06:21:34 EDT 2010
Author: martinl
Date: 2010-04-21 06:21:33 -0400 (Wed, 21 Apr 2010)
New Revision: 41945
grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
wxGUI: various fixes in bulk dialog import
(merge r41943 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2010-04-21 10:13:11 UTC (rev 41944)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2010-04-21 10:21:33 UTC (rev 41945)
@@ -974,12 +974,17 @@
self.Bind(wx.EVT_RADIOBOX, self.OnChangeType)
# input widgets
+ if self.importType == 'gdal':
+ filemask = 'GeoTIFF (*.tif)|*.tif'
+ else:
+ filemask = 'ESRI Shapefile (*.shp)|*.shp'
inputFile = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
size=globalvar.DIALOG_GSELECT_SIZE, labelText='',
- dialogTitle=_('Choose input directory'),
+ dialogTitle=_('Choose input file'),
buttonText=_('Browse'),
startDirectory=os.getcwd(),
- changeCallback=self.OnSetInput)
+ changeCallback=self.OnSetInput,
+ fileMask=filemask)
inputDir = filebrowse.DirBrowseButton(parent=self.panel, id=wx.ID_ANY,
@@ -991,15 +996,17 @@
inputDb = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
inputDb.Hide()
+ inputDb.Bind(wx.EVT_TEXT, self.OnSetInput)
inputPro = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
inputPro.Hide()
+ inputPro.Bind(wx.EVT_TEXT, self.OnSetInput)
# format widget
self.formatText = wx.StaticText(self.panel, id=wx.ID_ANY, label=_("Format:"))
self.format = wx.Choice(parent = self.panel, id = wx.ID_ANY, size=(300, -1))
- self.format.Bind(wx.EVT_TEXT, self.OnSetInput)
+ self.format.Bind(wx.EVT_CHOICE, self.OnSetFormat)
ret = gcmd.RunCommand('r.in.gdal',
quiet = True, read = True,
@@ -1021,14 +1028,83 @@
'pro' : [_("Protocol:"),
inputPro,
list()] }
+ self.formatToExt = {
+ # raster
+ 'GeoTIFF' : 'tif',
+ 'Erdas Imagine Images (.img)' : '.img',
+ 'Ground-based SAR Applications Testbed File Format (.gff)' : '.gff',
+ 'Arc/Info Binary Grid' : 'adf',
+ 'Portable Network Graphics' : 'png',
+ 'JPEG JFIF' : 'jpg',
+ 'Japanese DEM (.mem)' : 'mem',
+ 'Graphics Interchange Format (.gif)' : 'gif',
+ 'X11 PixMap Format' : 'xpm',
+ 'MS Windows Device Independent Bitmap' : 'bmp',
+ 'SPOT DIMAP' : '.dim',
+ 'RadarSat 2 XML Product' : 'xml',
+ 'EarthWatch .TIL' : '.til',
+ 'ERMapper .ers Labelled' : '.ers',
+ 'ERMapper Compressed Wavelets' : 'ecw',
+ 'GRIdded Binary (.grb)' : 'grb',
+ 'EUMETSAT Archive native (.nat)' : '.nat',
+ 'Idrisi Raster A.1' : 'rst',
+ 'Golden Software ASCII Grid (.grd)' : '.grd',
+ 'Golden Software Binary Grid (.grd)' : 'grd',
+ 'Golden Software 7 Binary Grid (.grd)' : 'grd',
+ 'R Object Data Store' : 'r',
+ 'USGS DOQ (Old Style)' : 'doq',
+ 'USGS DOQ (New Style)' : 'doq',
+ 'ENVI .hdr Labelled' : 'hdr',
+ 'ESRI .hdr Labelled' : 'hdr',
+ 'Generic Binary (.hdr Labelled)' : 'hdr',
+ 'PCI .aux Labelled' : 'aux',
+ 'EOSAT FAST Format' : 'fst',
+ 'VTP .bt (Binary Terrain) 1.3 Format' : 'bt',
+ 'FARSITE v.4 Landscape File (.lcp)' : 'lcp',
+ 'Swedish Grid RIK (.rik)' : 'rik',
+ 'USGS Optional ASCII DEM (and CDED)' : '.dem',
+ 'Northwood Numeric Grid Format .grd/.tab' : '',
+ 'Northwood Classified Grid Format .grc/.tab' : '',
+ 'ARC Digitized Raster Graphics' : 'arc',
+ 'Magellan topo (.blx)' : 'blx',
+ 'SAGA GIS Binary Grid (.sdat)' : 'sdat',
+ # vector
+ 'ESRI Shapefile' : 'shp',
+ 'UK .NTF' : 'ntf',
+ 'SDTS' : 'ddf',
+ 'DGN' : 'dgn',
+ 'VRT' : 'vrt',
+ 'REC' : 'rec',
+ 'BNA' : 'bna',
+ 'CSV' : 'csv',
+ 'GML' : 'gml',
+ 'GPX' : 'gpx',
+ 'KML' : 'kml',
+ 'GMT' : 'gmt',
+ 'PGeo' : 'mdb',
+ 'XPlane' : 'dat',
+ 'AVCBin' : 'adf',
+ 'AVCE00' : 'e00',
+ 'DXF' : 'dxf',
+ 'Geoconcept' : 'gxt',
+ 'GeoRSS' : 'xml',
+ 'GPSTrackMaker' : 'gtm',
+ 'VFK' : 'vfk' }
if ret:
for line in ret.splitlines():
format = line.strip().rsplit(':', -1)[1].strip()
+ if format in ('Memory', 'Virtual Raster', 'In Memory Raster'):
+ continue
if format in ('PostgreSQL', 'SQLite',
- 'ODBC', 'ESRI Personal GeoDatabase'):
+ 'ODBC', 'ESRI Personal GeoDatabase',
+ 'Rasterlite',
+ 'PostGIS WKT Raster driver'):
self.input['db'][2].append(format)
- elif format in ('GeoJSON'):
+ elif format in ('GeoJSON',
+ 'OGC Web Coverage Service',
+ 'OGC Web Map Service',
+ 'HTTP Fetching Wrapper'):
self.input['pro'][2].append(format)
else:
self.input['file'][2].append(format)
@@ -1182,13 +1258,17 @@
if sel == 0: # file
self.inputType = 'file'
format = self.input[self.inputType][2][0]
- if format == 'ESRI Shapefile':
- format += ' (*.shp)|*.shp'
- else:
+ try:
+ ext = self.formatToExt[format]
+ if not ext:
+ raise KeyError
+ format += ' (*.%s)|*.%s' % (ext, ext)
+ except KeyError:
format += ' (*.*)|*.*'
win = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
- dialogTitle=_('Choose file'),
@@ -1204,6 +1284,8 @@
win = self.input[self.inputType][1]
self.inputTypeSizer.Add(item = win, proportion = 1,
flag = wx.ALIGN_CENTER_VERTICAL)
+ win.SetValue('')
+ self.list.DeleteAllItems()
win.Show()
self.inputText.SetLabel(self.input[self.inputType][0])
@@ -1223,33 +1305,41 @@
# hide dialog
self.Hide()
+ if self.importType == 'dxf':
+ inputDxf = self.input[self.inputType][1].GetValue()
+ else:
+ if self.inputType == 'file':
+ dsn = os.path.dirname(self.input[self.inputType][1].GetValue())
+ else:
+ dsn = self.input[self.inputType][1].GetValue()
+ ext = self.formatToExt[self.format.GetStringSelection()]
for layer, output in data:
cmd = ['v.in.dxf',
- 'input=%s' % self.input.GetValue(),
+ 'input=%s' % inputDxf,
'layers=%s' % layer,
'output=%s' % output]
elif self.importType == 'ogr':
if self.link:
cmd = ['v.external',
- 'dsn=%s' % os.path.join(self.input.GetValue()),
+ 'dsn=%s' % dsn,
'output=%s' % output,
- 'layer=%s' % layer.rstrip('.' + self.format.GetValue())
+ 'layer=%s' % layer.rstrip('.' + ext)]
else:
cmd = ['v.in.ogr',
- 'dsn=%s' % (os.path.join(self.input.GetValue(), layer)),
+ 'dsn=%s' % (os.path.join(dsn, layer)),
else: # gdal
if self.link:
cmd = ['r.external',
- 'input=%s' % (os.path.join(self.input.GetValue(), layer)),
+ 'input=%s' % (os.path.join(dsn, layer)),
else:
cmd = ['r.in.gdal',
if self.overwrite.IsChecked():
cmd.append('--overwrite')
@@ -1296,10 +1386,43 @@
pass
+ def OnSetFormat(self, event):
+ """!Format changed"""
+ if self.inputType != 'file':
+ return
+ win = self.input[self.inputType][1]
+ self.inputTypeSizer.Remove(win)
+ win.Destroy()
+ format = event.GetString()
+ try:
+ if not ext:
+ raise KeyError
+ except KeyError:
+ format += ' (*.*)|*.*'
+ win = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
+ size=globalvar.DIALOG_GSELECT_SIZE, labelText='',
+ dialogTitle=_('Choose file'),
+ buttonText=_('Browse'),
+ startDirectory=os.getcwd(),
+ fileMask = format)
+ self.input[self.inputType][1] = win
+ self.inputTypeSizer.Add(item = win, proportion = 1,
+ flag = wx.ALIGN_CENTER_VERTICAL)
+ self.inputTypeSizer.Layout()
def OnSetInput(self, event):
"""!Input DXF file/OGR dsn defined, update list of layer widget"""
path = event.GetString()
+ if not path:
+ return
ret = gcmd.RunCommand('v.in.dxf',
quiet = True,
@@ -1312,7 +1435,7 @@
self.btn_run.Enable(False)
return
- data = []
+ data = list()
layerId = line.split(':')[0].split(' ')[1]
@@ -1322,12 +1445,22 @@
else: # gdal/ogr (for ogr maybe to use v.in.ogr -l)
layerId = 1
- for file in glob.glob(os.path.join(self.input.GetValue(), "*.%s") % self.format.GetValue()):
- baseName = os.path.basename(file)
+ baseName = os.path.basename(dsn)
grassName = utils.GetValidLayerName(baseName.split('.', -1)[0])
data.append((layerId, baseName, grassName))
- layerId += 1
+ elif self.inputType == 'dir':
+ try:
+ except KeyError:
+ ext = ''
+ for file in glob.glob(os.path.join(dsn, "*.%s") % ext):
+ baseName = os.path.basename(file)
+ grassName = utils.GetValidLayerName(baseName.split('.', -1)[0])
+ data.append((layerId, baseName, grassName))
+ layerId += 1
self.list.LoadData(data)
if len(data) > 0:
self.btn_run.Enable(True)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-04-21 10:13:11 UTC (rev 41944)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-04-21 10:21:33 UTC (rev 41945)
@@ -1417,6 +1417,11 @@
popupMenu.Append(self.popupID1, text=_('Remove'))
self.frame.Bind(wx.EVT_MENU, self.OnRemove, id = self.popupID1)
+ if isinstance(shape, ModelRelation):
+ popupMenu.AppendSeparator()
+ popupMenu.Append(self.popupID2, text=_('Add control point'))
+ self.frame.Bind(wx.EVT_MENU, self.OnAddPoint, id = self.popupID2)
if isinstance(shape, ModelData) and '@' not in shape.GetValue():
popupMenu.Append(self.popupID3, text=_('Intermediate'),
@@ -1435,6 +1440,10 @@
self.frame.PopupMenu(popupMenu)
popupMenu.Destroy()
+ def OnAddPoint(self, event):
+ """!Add control point"""
+ print event.GetPos()
def OnIntermediate(self, event):
"""!Mark data as intermediate"""
self.frame.ModelChanged()
