[GRASS-SVN] r41952 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Apr 21 11:20:07 EDT 2010
Author: martinl
Date: 2010-04-21 11:20:06 -0400 (Wed, 21 Apr 2010)
New Revision: 41952
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
wxGUI: import/link - support for sqlite
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2010-04-21 13:46:02 UTC (rev 41951)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2010-04-21 15:20:06 UTC (rev 41952)
@@ -994,11 +994,23 @@
startDirectory=os.getcwd(),
changeCallback=self.OnSetInput)
inputDir.Hide()
+ inputDbFile = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
+ size=globalvar.DIALOG_GSELECT_SIZE, labelText='',
+ dialogTitle=_('Choose file'),
+ buttonText=_('Browse'),
+ startDirectory=os.getcwd(),
+ changeCallback=self.OnSetInput)
+ inputDbFile.Hide()
- inputDb = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
- inputDb.Hide()
- inputDb.Bind(wx.EVT_TEXT, self.OnSetInput)
+ inputDbText = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
+ inputDbText.Hide()
+ inputDbText.Bind(wx.EVT_TEXT, self.OnSetInput)
+ inputDbChoice = wx.Choice(parent = self.panel, id = wx.ID_ANY)
+ inputDbChoice.Hide()
+ inputDbChoice.Bind(wx.EVT_CHOICE, self.OnSetInput)
inputPro = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
inputPro.Hide()
inputPro.Bind(wx.EVT_TEXT, self.OnSetInput)
@@ -1024,11 +1036,16 @@
inputDir,
list()],
'db' : [_("Database:"),
- inputDb,
+ inputDbFile,
list()],
'pro' : [_("Protocol:"),
inputPro,
- list()] }
+ list()],
+ 'db-win' : { 'file' : inputDbFile,
+ 'text' : inputDbText,
+ 'choice' : inputDbChoice },
self.formatToExt = {
# raster
'GeoTIFF' : 'tif',
@@ -1245,7 +1262,9 @@
self.Layout()
# auto-layout seems not work here - FIXME
- self.SetMinSize((globalvar.DIALOG_GSELECT_SIZE[0] + 175, 400))
+ size = wx.Size(globalvar.DIALOG_GSELECT_SIZE[0] + 175, 400)
+ self.SetMinSize(size)
+ self.SetSize((size.width, size.height + 100))
width = self.GetSize()[0]
self.list.SetColumnWidth(col=1, width=width/2 - 50)
@@ -1281,7 +1300,7 @@
self.inputType = 'db'
elif sel == 3: # protocol
self.inputType = 'pro'
win = self.input[self.inputType][1]
self.inputTypeSizer.Add(item = win, proportion = 1,
flag = wx.ALIGN_CENTER_VERTICAL)
@@ -1313,7 +1332,10 @@
dsn = os.path.dirname(self.input[self.inputType][1].GetValue())
else:
dsn = self.input[self.inputType][1].GetValue()
- ext = self.formatToExt[self.format.GetStringSelection()]
+ try:
+ ext = '.' + self.formatToExt[self.format.GetStringSelection()]
+ except KeyError:
+ ext = ''
for layer, output in data:
if self.importType == 'dxf':
@@ -1326,10 +1348,11 @@
cmd = ['v.external',
'dsn=%s' % dsn,
'output=%s' % output,
- 'layer=%s' % layer.rstrip('.' + ext)]
+ 'layer=%s' % layer.rstrip(ext)]
else:
cmd = ['v.in.ogr',
- 'dsn=%s' % (os.path.join(dsn, layer)),
+ 'dsn=%s' % dsn,
+ 'layer=%s' % layer.rstrip(ext),
'output=%s' % output]
else: # gdal
if self.link:
@@ -1389,31 +1412,46 @@
def OnSetFormat(self, event):
"""!Format changed"""
- if self.inputType != 'file':
+ if self.inputType not in ['file', 'db']:
return
self.inputTypeSizer.Remove(win)
- win.Destroy()
+ if self.inputType == 'file':
+ win.Destroy()
+ else: # database
+ win.Hide()
format = event.GetString()
- try:
- ext = self.formatToExt[format]
- if not ext:
- raise KeyError
- format += ' (*.%s)|*.%s' % (ext, ext)
- except KeyError:
- format += ' (*.*)|*.*'
+ try:
+ ext = self.formatToExt[format]
+ if not ext:
+ raise KeyError
+ format += ' (*.%s)|*.%s' % (ext, ext)
+ except KeyError:
+ format += ' (*.*)|*.*'
- win = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
- size=globalvar.DIALOG_GSELECT_SIZE, labelText='',
- dialogTitle=_('Choose file'),
- buttonText=_('Browse'),
- startDirectory=os.getcwd(),
- changeCallback=self.OnSetInput,
- fileMask = format)
+ win = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
+ changeCallback=self.OnSetInput,
+ fileMask = format)
+ else: # database
+ if format == 'SQLite':
+ win = self.input['db-win']['file']
+ elif format == 'PostgreSQL':
+ win = self.input['db-win']['choice']
+ else:
+ win = self.input['db-win']['text']
self.input[self.inputType][1] = win
+ if not win.IsShown():
+ win.Show()
self.inputTypeSizer.Layout()
@@ -1423,7 +1461,8 @@
path = event.GetString()
if not path:
return
+ data = list()
ret = gcmd.RunCommand('v.in.dxf',
quiet = True,
@@ -1435,15 +1474,13 @@
self.list.LoadData()
self.btn_run.Enable(False)
return
- data = list()
- if self.importType == 'dxf':
for line in ret.splitlines():
layerId = line.split(':')[0].split(' ')[1]
layerName = line.split(':')[1].strip()
grassName = utils.GetValidLayerName(layerName)
data.append((layerId, layerName.strip(), grassName.strip()))
else: # gdal/ogr (for ogr maybe to use v.in.ogr -l)
layerId = 1
@@ -1461,6 +1498,25 @@
grassName = utils.GetValidLayerName(baseName.split('.', -1)[0])
data.append((layerId, baseName, grassName))
layerId += 1
+ elif self.inputType == 'db':
+ format = self.format.GetStringSelection()
+ ret = gcmd.RunCommand('v.in.ogr',
+ quiet = True,
+ parent = self,
+ read = True,
+ flags = 'l',
+ dsn = dsn)
+ if not ret:
+ self.list.LoadData()
+ self.btn_run.Enable(False)
+ return
+ layerId = 1
+ for line in ret.splitlines():
+ layerName = line.strip()
+ grassName = utils.GetValidLayerName(layerName)
+ data.append((layerId, layerName.strip(), grassName.strip()))
+ layerId += 1
self.list.LoadData(data)
if len(data) > 0:
