[GRASS-SVN] r41956 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Apr 21 12:53:40 EDT 2010
Author: martinl
Date: 2010-04-21 12:53:40 -0400 (Wed, 21 Apr 2010)
New Revision: 41956
grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
wxGUI: enable PostgreSQL in bulk link/import
(merge r41955 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2010-04-21 16:51:10 UTC (rev 41955)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2010-04-21 16:53:40 UTC (rev 41956)
@@ -1330,7 +1330,10 @@
if self.inputType == 'file':
dsn = os.path.dirname(self.input[self.inputType][1].GetValue())
else:
- dsn = self.input[self.inputType][1].GetValue()
+ if self.format.GetStringSelection() == 'PostgreSQL':
+ dsn = 'PG:dbname=%s' % self.input[self.inputType][1].GetStringSelection()
+ else:
+ dsn = self.input[self.inputType][1].GetValue()
try:
ext = '.' + self.formatToExt[self.format.GetStringSelection()]
except KeyError:
@@ -1444,7 +1447,23 @@
if format == 'SQLite':
win = self.input['db-win']['file']
elif format == 'PostgreSQL':
- win = self.input['db-win']['choice']
+ if grass.find_program('psql'):
+ win = self.input['db-win']['choice']
+ if not win.GetItems():
+ p = grass.Popen(['psql', '-ltA'], stdout = grass.PIPE)
+ ret = p.communicate()[0]
+ if ret:
+ db = list()
+ for line in ret.splitlines():
+ sline = line.split('|')
+ if len(sline) < 2:
+ continue
+ dbname = sline[0]
+ if dbname:
+ db.append(dbname)
+ win.SetItems(db)
+ else:
+ win = self.input['db-win']['text']
else:
@@ -1482,7 +1501,10 @@
else: # gdal/ogr (for ogr maybe to use v.in.ogr -l)
layerId = 1
+ else:
baseName = os.path.basename(dsn)
grassName = utils.GetValidLayerName(baseName.split('.', -1)[0])
@@ -1498,24 +1520,22 @@
data.append((layerId, baseName, grassName))
layerId += 1
elif self.inputType == 'db':
- format = self.format.GetStringSelection()
- if format == 'SQLite':
- ret = gcmd.RunCommand('v.in.ogr',
- quiet = True,
- parent = self,
- read = True,
- flags = 'l',
- dsn = dsn)
- if not ret:
- self.list.LoadData()
- self.btn_run.Enable(False)
- return
- layerId = 1
- for line in ret.splitlines():
- layerName = line.strip()
- grassName = utils.GetValidLayerName(layerName)
- data.append((layerId, layerName.strip(), grassName.strip()))
- layerId += 1
+ ret = gcmd.RunCommand('v.in.ogr',
+ quiet = True,
+ parent = self,
+ read = True,
+ flags = 'l',
+ dsn = dsn)
+ if not ret:
+ self.list.LoadData()
+ self.btn_run.Enable(False)
+ return
+ layerId = 1
+ layerName = line.strip()
+ grassName = utils.GetValidLayerName(layerName)
+ data.append((layerId, layerName.strip(), grassName.strip()))
+ layerId += 1
self.list.LoadData(data)
if len(data) > 0:
