[GRASS-SVN] r41969 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Apr 22 04:37:07 EDT 2010
Author: martinl
Date: 2010-04-22 04:36:47 -0400 (Thu, 22 Apr 2010)
New Revision: 41969
grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
wxGUI: add layer when import is finished
(merge r41964, r41966 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2010-04-22 08:34:47 UTC (rev 41968)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2010-04-22 08:36:47 UTC (rev 41969)
@@ -714,7 +714,7 @@
wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=title, style=style)
self.parent = parent # GMFrame
# dialog body
@@ -934,8 +934,10 @@
self.importType = type
- self.link = link # Link or import data (only for GDAL/OGR)
+ self.link = link # Link or import data (only for GDAL/OGR)
+ self.commandId = -1 # id of running command
wx.Dialog.__init__(self, parent, id, title, style=style)
self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
@@ -1378,35 +1380,42 @@
cmd.append('--overwrite')
# run in Layer Manager
- self.parent.goutput.RunCmd(cmd, switchPage=True)
- if self.add.IsChecked():
- maptree = self.parent.curr_page.maptree
- for layer, output in data:
- if '@' not in output:
- name = output + '@' + grass.gisenv()['MAPSET']
- else:
- name = output
- # add imported layers into layer tree
- if self.importType == 'gdal':
- cmd = ['d.rast',
- 'map=%s' % name]
- if UserSettings.Get(group='cmd', key='rasterOverlay', subkey='enabled'):
- cmd.append('-o')
- maptree.AddLayer(ltype='raster',
- lname=name,
- lcmd=cmd)
- else:
- maptree.AddLayer(ltype='vector',
- lname=name,
- lcmd=['d.vect',
- 'map=%s' % name])
+ self.parent.goutput.RunCmd(cmd, switchPage=True,
+ onDone = self._addLayers)
- ### wx.CallAfter(self.parent.notebook.SetSelection, 0)
self.OnCancel()
+ def _addLayers(self, returncode):
+ """!Add imported/linked layers into layer tree"""
+ self.commandId += 1
+ if not self.add.IsChecked():
+ return
+ maptree = self.parent.curr_page.maptree
+ layer, output = self.list.GetLayers()[self.commandId]
+ if '@' not in output:
+ name = output + '@' + grass.gisenv()['MAPSET']
+ else:
+ name = output
+ # add imported layers into layer tree
+ if self.importType == 'gdal':
+ cmd = ['d.rast',
+ 'map=%s' % name]
+ if UserSettings.Get(group='cmd', key='rasterOpaque', subkey='enabled'):
+ cmd.append('-n')
+ maptree.AddLayer(ltype='raster',
+ lname=name,
+ lcmd=cmd)
+ else:
+ maptree.AddLayer(ltype='vector',
+ lname=name,
+ lcmd=['d.vect',
+ 'map=%s' % name])
def OnAbort(self, event):
"""!Abort running import
