[GRASS-SVN] r41972 - grass/branches/releasebranch_6_4/lib/python
Thu Apr 22 05:37:51 EDT 2010
Author: martinl
Date: 2010-04-22 05:37:46 -0400 (Thu, 22 Apr 2010)
New Revision: 41972
   grass/branches/releasebranch_6_4/lib/python/core.py
   grass/branches/releasebranch_6_4/lib/python/db.py
   grass/branches/releasebranch_6_4/lib/python/raster.py
   grass/branches/releasebranch_6_4/lib/python/vector.py
libpython synchronized with trunk
Modified: grass/branches/releasebranch_6_4/lib/python/core.py
--- grass/branches/releasebranch_6_4/lib/python/core.py	2010-04-22 08:53:15 UTC (rev 41971)
+++ grass/branches/releasebranch_6_4/lib/python/core.py	2010-04-22 09:37:46 UTC (rev 41972)
@@ -55,6 +55,8 @@
 PIPE = subprocess.PIPE
 STDOUT = subprocess.STDOUT
+fatal_exit = True # abort on fatal()
 def call(*args, **kwargs):
     return Popen(*args, **kwargs).wait()
@@ -335,20 +337,42 @@
     @return g.message's exit code
     error(msg)
-    sys.exit(1)
+    global fatal_exit
+    if fatal_exit:
+        sys.exit(1)
+def set_fatal_exit(exit = True):
+    """!Set fatal_exit variable
+    @param exit True to abort on fatal() otherwise just error message
+    is printed"""
+    global fatal_exit
+    fatal_exit = exit
 # interface to g.parser
-def _parse_env():
+def _parse_opts(lines):
     options = {}
     flags = {}
-    for var, val in os.environ.iteritems():
-	if var.startswith("GIS_OPT_"):
-	    opt = var.replace("GIS_OPT_", "", 1).lower()
-	    options[opt] = val;
-	if var.startswith("GIS_FLAG_"):
-	    flg = var.replace("GIS_FLAG_", "", 1).lower()
-	    flags[flg] = bool(int(val));
+    for line in lines:
+	line = line.rstrip('\r\n')
+	if not line:
+	    break
+	try:
+	    [var, val] = line.split('=', 1)
+	except:
+	    raise SyntaxError("invalid output from g.parser: %s" % line)
+	if var.startswith('flag_'):
+	    flags[var[5:]] = bool(int(val))
+	elif var.startswith('opt_'):
+	    options[var[4:]] = val
+	elif var in ['GRASS_OVERWRITE', 'GRASS_VERBOSE']:
+	    os.environ[var] = val
+	else:
     return (options, flags)
 def parser():
@@ -369,9 +393,6 @@
         print >> sys.stderr, "You must be in GRASS GIS to run this program."
         sys.exit(1)
-    if len(sys.argv) > 1 and sys.argv[1] == "@ARGS_PARSED@":
-	return _parse_env()
     cmdline = [basename(sys.argv[0])]
     cmdline += ['"' + arg + '"' for arg in sys.argv[1:]]
     os.environ['CMDLINE'] = ' '.join(cmdline)
@@ -384,12 +405,16 @@
 	else:
 	    argv[0] = os.path.join(sys.path[0], name)
-    if sys.platform == "win32":
-       os.execvp("g.parser.exe", [name] + argv)
-    else:
-       os.execvp("g.parser", [name] + argv)
-    raise OSError("error executing g.parser")
+    p = Popen(['g.parser', '-s'] + argv, stdout = PIPE)
+    s = p.communicate()[0]
+    lines = s.splitlines()
+    if not lines or lines[0].rstrip('\r\n') != "@ARGS_PARSED@":
+	sys.stdout.write(s)
+	sys.exit()
+    return _parse_opts(lines[1:])
 # interface to g.tempfile
 def tempfile():
@@ -471,7 +496,10 @@
     @return dictionary of region values
     s = read_command("g.region", flags='g')
-    return parse_key_val(s, val_type = float)
+    reg = parse_key_val(s, val_type = float)
+    for k in ['rows', 'cols']:
+	reg[k] = int(reg[k])
+    return reg
 def use_temp_region():
     """!Copies the current region to a temporary region with "g.region save=",
@@ -742,3 +770,68 @@
     @return float value
     return sum(float(x) / 60 ** n for (n, x) in enumerate(s.split(':')))
+def command_info(cmd):
+    """!Returns 'help' information for any command as dictionary with entries
+    for description, keywords, usage, flags, and parameters"""
+    cmdinfo = {}
+    s = start_command(cmd, 'help', stdout = subprocess.PIPE, stderr = subprocess.PIPE)
+    out, err = s.communicate()
+    sections = err.split('\n\n')
+    #Description
+    first, desc = sections[0].split(':\n', 1)
+    desclines = desc.splitlines()
+    for line in desclines:
+        line = line.strip()+' '
+    # Keywords
+    first, keywords = sections[1].split(':\n', 1)
+    keylines = keywords.splitlines()
+    list = []
+    list = keywords.strip().split(',')
+    cmdinfo['keywords'] = list
+    cmdinfo['description'] = ''.join(desclines).strip()
+    # Usage
+    first, usage = sections[2].split(':\n', 1)
+    usagelines = usage.splitlines()
+    list = []
+    for line in usagelines:
+        if line == '': continue
+        line = line+' '
+        list.append(line)
+    cmdinfo['usage'] = ''.join(list).strip()
+    # Flags
+    first, flags = sections[3].split(':\n', 1)
+    flaglines = flags.splitlines()
+    dict = {}
+    for line in flaglines:
+        item = line.split(' ',1)[0].strip()
+        val = line.split(' ',1)[1].strip()
+        dict[item] = val
+    cmdinfo['flags'] = dict
+    # Parameters
+    first, params = err.rsplit(':\n', 1)
+    paramlines = params.splitlines()
+    dict = {}
+    for line in paramlines:
+        dict[item] = val
+    cmdinfo['parameters'] = dict
+    return cmdinfo
Modified: grass/branches/releasebranch_6_4/lib/python/db.py
--- grass/branches/releasebranch_6_4/lib/python/db.py	2010-04-22 08:53:15 UTC (rev 41971)
+++ grass/branches/releasebranch_6_4/lib/python/db.py	2010-04-22 09:37:46 UTC (rev 41972)
@@ -25,12 +25,10 @@
 from core import *
-# run "db.describe -c ..." and parse output
 def db_describe(table, **args):
     """!Return the list of columns for a database table
     (interface to `db.describe -c'). Example:
     \code
     >>> grass.db_describe('lakes')
     {'nrows': 15279, 'cols': [['cat', 'INTEGER', '11'], ['AREA', 'DOUBLE PRECISION', '20'],
@@ -78,4 +76,3 @@
     s = read_command('db.connect', flags = 'p')
     return parse_key_val(s, sep = ':')
Modified: grass/branches/releasebranch_6_4/lib/python/raster.py
--- grass/branches/releasebranch_6_4/lib/python/raster.py	2010-04-22 08:53:15 UTC (rev 41971)
+++ grass/branches/releasebranch_6_4/lib/python/raster.py	2010-04-22 09:37:46 UTC (rev 41972)
@@ -34,6 +34,8 @@
     """!Set the command history for a raster map to the command used to
     invoke the script (interface to `r.support').
+    @param map map name
     @return True on success
     @return False on failure
@@ -82,6 +84,5 @@
     t = string.Template(exp)
     e = t.substitute(**kwargs)
     if write_command('r.mapcalc', stdin = e) != 0:
 	fatal("An error occurred while running r.mapcalc")
Modified: grass/branches/releasebranch_6_4/lib/python/vector.py
--- grass/branches/releasebranch_6_4/lib/python/vector.py	2010-04-22 08:53:15 UTC (rev 41971)
+++ grass/branches/releasebranch_6_4/lib/python/vector.py	2010-04-22 09:37:46 UTC (rev 41972)
@@ -41,6 +41,7 @@
     \endcode
     @param map vector map
+    @param args
     @return dictionary { layer : { 'layer', 'table, 'database', 'driver', 'key' }
@@ -72,7 +73,13 @@
 def vector_layer_db(map, layer):
     """!Return the database connection details for a vector map layer.
-    If db connection for given layer is not defined, fatal() is called."""
+    If db connection for given layer is not defined, fatal() is called.
+    @param layer layer number
+    @return parsed output
     try:
         f = vector_db(map)[int(layer)]
     except KeyError:
@@ -86,7 +93,7 @@
     """!Return a dictionary (or a list) of the columns for the
     database table connected to a vector map (interface to `v.info
     -c').
     @code
     >>> vector_columns(urbanarea, getDict = True)
     {'UA_TYPE': {'index': 4, 'type': 'CHARACTER'}, 'UA': {'index': 2, 'type': 'CHARACTER'}, 'NAME': {'index': 3, 'type': 'CHARACTER'}, 'OBJECTID': {'index': 1, 'type': 'INTEGER'}, 'cat': {'index': 0, 'type': 'INTEGER'}}
@@ -124,6 +131,10 @@
 def vector_history(map):
     """!Set the command history for a vector map to the command used to
     invoke the script (interface to `v.support').
+    @param map mapname
+    @return v.support output
     run_command('v.support', map = map, cmdhist = os.environ['CMDLINE'])
