[GRASS-SVN] r42003 - in grass/trunk: gui/wxpython/scripts
scripts/v.krige
svn_grass at osgeo.org
Fri Apr 23 11:44:11 EDT 2010
Author: aghisla
Date: 2010-04-23 11:44:11 -0400 (Fri, 23 Apr 2010)
New Revision: 42003
grass/trunk/gui/wxpython/scripts/vkrige.py
grass/trunk/scripts/v.krige/v.krige.py
Merge with devbr6, but spgrass6 not working, so the module is still broken.
Modified: grass/trunk/gui/wxpython/scripts/vkrige.py
--- grass/trunk/gui/wxpython/scripts/vkrige.py 2010-04-23 15:26:58 UTC (rev 42002)
+++ grass/trunk/gui/wxpython/scripts/vkrige.py 2010-04-23 15:44:11 UTC (rev 42003)
@@ -398,7 +398,7 @@
self.VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
self.VariogramCheckBox.SetValue(state = True) # check it by default
- ModelFactor = robjects.r.vgm().r['long']
+ ModelFactor = robjects.r.vgm().rx('long')
ModelList = robjects.r.levels(ModelFactor[0])
#@FIXME: no other way to let the Python pick it up..
# and this is te wrong place where to load this list. should be at the very beginning.
Modified: grass/trunk/scripts/v.krige/v.krige.py
--- grass/trunk/scripts/v.krige/v.krige.py 2010-04-23 15:26:58 UTC (rev 42002)
+++ grass/trunk/scripts/v.krige/v.krige.py 2010-04-23 15:44:11 UTC (rev 42003)
@@ -149,15 +149,17 @@
if "x" not in robjects.r.names(Rpointmap):
# extract coordinates with S4 method
coordinatesPreDF = robjects.r['as.data.frame'](robjects.r.coordinates(Rpointmap))
- coordinatesDF = robjects.r['data.frame'](x = coordinatesPreDF.r['coords.x1'][0],
- y = coordinatesPreDF.r['coords.x2'][0])
+ coordinatesDF = robjects.r['data.frame'](x = coordinatesPreDF.rx('coords.x1')[0],
+ y = coordinatesPreDF.rx('coords.x2')[0])
# match coordinates with data slot of SpatialPointsDataFrame - maptools function
# match is done on row.names
Rpointmap = robjects.r.spCbind(Rpointmap, coordinatesDF)
# GRASS checks for null values in the chosen column. R can hardly handle column as a variable,
# looks for a hardcoded string.
+ logger.message("Got here")
cols = grass.vector_columns(map=map, layer=1)
+ logger.message("Not here:")
nulls = int(grass.parse_command('v.univar',
map=map,
column=column,
@@ -176,8 +178,8 @@
# addition of coordinates columns into dataframe.
coordinatesDF = robjects.r['as.data.frame'](robjects.r.coordinates(Grid))
- data = robjects.r['data.frame'](x = coordinatesDF.r['s1'][0],
- y = coordinatesDF.r['s2'][0],
+ data = robjects.r['data.frame'](x = coordinatesDF.rx('s1')[0],
+ y = coordinatesDF.rx('s2')[0],
k = robjects.r.rep(1, Region['cols']*Region['rows']))
GridPredicted = robjects.r.SpatialGridDataFrame(Grid,
data,
@@ -189,7 +191,7 @@
predictor = 'x+y'
else:
predictor = 1
- Formula = robjects.r['as.formula'](robjects.r.paste(column, "~", predictor))
+ Formula = robjects.Formula(column + "~" + predictor)
#print Formula
return Formula
@@ -207,12 +209,12 @@
VariogramModel = robjects.r.autofitVariogram(formula, inputdata, **DottedParams)
#print robjects.r.warnings()
- Variograms['datavariogram'] = VariogramModel.r['exp_var'][0]
- Variograms['variogrammodel'] = VariogramModel.r['var_model'][0]
+ Variograms['datavariogram'] = VariogramModel.rx('exp_var')[0]
+ Variograms['variogrammodel'] = VariogramModel.rx('var_model')[0]
# obtain the model name. *Too* complicated to get the string instead of level, unlike R does.
- VariogramAsDF = robjects.r['as.data.frame'](VariogramModel.r['var_model'][0]) # force conversion
- ModelDF = VariogramAsDF.r['model'][0]
- Variograms['model'] = robjects.r.levels(ModelDF).subset(ModelDF[1])[0]
+ VariogramAsDF = robjects.r['as.data.frame'](VariogramModel.rx('var_model')[0]) # force conversion
+ ModelDF = VariogramAsDF.rx('model')[0]
+ Variograms['model'] = ModelDF.levels[ModelDF[1] - 1]
else:
DataVariogram = robjects.r['variogram'](formula, inputdata)
VariogramModel = robjects.r['fit.variogram'](DataVariogram,
@@ -317,6 +319,7 @@
else:
#CLI
options, flags = argv
#@TODO: Work on verbosity. Sometimes it's too verbose (R), sometimes not enough.
if grass.find_file(options['input'], element = 'vector')['fullname'] is '':
grass.fatal(_("option: <input>: Vector map not found.")) #TODO cosmetics, insert real map name
@@ -355,7 +358,6 @@
if v is not '':
notnulloptions[k] = v
command = command.join("%s=%s " % (k, v) for k, v in notnulloptions.items())
- #print command
# re-cast integers from strings, as parser() cast everything to string.
for each in ("sill","nugget","range"):
