[GRASS-SVN] r42009 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Apr 23 12:06:32 EDT 2010
Author: martinl
Date: 2010-04-23 12:06:32 -0400 (Fri, 23 Apr 2010)
New Revision: 42009
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
wxGUI: SubGroup widget imlemented
(merge r42004 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py 2010-04-23 16:01:07 UTC (rev 42008)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py 2010-04-23 16:06:32 UTC (rev 42009)
@@ -11,10 +11,11 @@
- DriverSelect
- DatabaseSelect
- ColumnSelect
+ - SubGroupSelect
-(C) 2007-2008 by the GRASS Development Team This program is free
-software under the GNU General Public License (>=v2). Read the file
-COPYING that comes with GRASS for details.
+(C) 2007-2010 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
@author Michael Barton
@author Martin Landa <landa.martin gmail.com>
@@ -684,3 +685,30 @@
# columnchoices.sort()
self.SetItems(columnchoices)
+class SubGroupSelect(wx.ComboBox):
+ """!Widget for selecting subgroups"""
+ def __init__(self, parent, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
+ **kwargs):
+ super(SubGroupSelect, self).__init__(parent, id, size = size,
+ style = wx.CB_READONLY, **kwargs)
+ self.SetName("SubGroupSelect")
+ def Insert(self, group):
+ """!Insert subgroups for defined group"""
+ if not group:
+ return
+ gisenv = grass.gisenv()
+ try:
+ name, mapset = group.split('@', 1)
+ except ValueError:
+ name = group
+ mapset = gisenv['MAPSET']
+ path = os.path.join(gisenv['GISDBASE'], gisenv['LOCATION_NAME'], mapset,
+ 'group', name, 'subgroup')
+ try:
+ self.SetItems(os.listdir(path))
+ except OSError:
+ self.SetItems([])
+ self.SetValue('')
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py 2010-04-23 16:01:07 UTC (rev 42008)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py 2010-04-23 16:06:32 UTC (rev 42009)
@@ -201,7 +201,7 @@
pType = p.get('prompt', '')
if not pType:
return
# check for map/input parameter
pMap = self.task.get_param('map', raiseError=False)
if not pMap:
@@ -261,7 +261,12 @@
'database' : db }
else:
self.data[win.InsertTableColumns] = { 'table' : pTable.get('value') }
+ elif name == 'SubGroupSelect':
+ pGroup = self.task.get_param('group', element='element', raiseError=False)
+ if pGroup:
+ self.data[win.Insert] = { 'group' : pGroup.get('value', '')}
def UpdateDialog(parent, event, eventId, task):
return UpdateThread(parent, event, eventId, task)
@@ -1318,6 +1323,7 @@
# GIS element entry
if p.get('prompt','') not in ('color',
'color_none',
+ 'subgroup',
'dbdriver',
'dbname',
'dbtable',
@@ -1334,7 +1340,6 @@
mapsets = [grassenv.GetGRASSVariable('MAPSET'),]
else:
mapsets = None
selection = gselect.Select(parent=which_panel, id=wx.ID_ANY,
size=globalvar.DIALOG_GSELECT_SIZE,
type=p.get('element', ''),
@@ -1349,9 +1354,18 @@
# we target the textctl here
p['wxId'] = selection.GetChildren()[0].GetId()
selection.GetChildren()[0].Bind(wx.EVT_TEXT, self.OnSetValue)
- if p.get('prompt', '') == 'vector':
+ if p.get('prompt', '') in ('vector', 'group'):
selection.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
+ # subgroup
+ elif p.get('prompt', '') == 'subgroup':
+ selection = gselect.SubGroupSelect(parent = which_panel)
+ p['wxId'] = [ selection.GetId() ]
+ selection.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
+ which_sizer.Add(item = selection, proportion = 0,
+ flag = wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.TOP | wx.ALIGN_CENTER_VERTICAL,
+ border = 5)
# layer, dbdriver, dbname, dbcolumn, dbtable entry
elif p.get('prompt', '') in ('dbdriver',
'dbname',
@@ -1501,6 +1515,8 @@
pDatabase = None
pTable = None
pColumn = []
+ pGroup = None
+ pSubGroup = None
for p in self.task.params:
if p.get('gisprompt', False) == False:
continue
@@ -1521,6 +1537,10 @@
pDatabase = p
elif prompt == 'dbtable':
pTable = p
+ elif prompt == 'group':
+ pGroup = p
+ elif prompt == 'subgroup':
+ pSubGroup = p
pColumnIds = []
for p in pColumn:
@@ -1546,6 +1566,9 @@
if pTable and pColumnIds:
pTable['wxId-bind'] = pColumnIds
+ if pGroup and pSubGroup:
+ pGroup['wxId-bind'] = pSubGroup['wxId']
# determine panel size
@@ -1698,9 +1721,8 @@
event.Skip()
def OnUpdateSelection(self, event):
+ """!Update dialog (layers, tables, columns, etc.)
- Update dialog (layers, tables, columns, etc.)
if event:
self.parent.updateThread.Update(UpdateDialog,
self,
