[GRASS-SVN] r42016 - grass-addons/gui/wxpython/data_catalog
Sat Apr 24 07:54:58 EDT 2010
Author: rashadkm
Date: 2010-04-24 07:54:57 -0400 (Sat, 24 Apr 2010)
New Revision: 42016
   grass-addons/gui/wxpython/data_catalog/LayerTree.py
   grass-addons/gui/wxpython/data_catalog/mapdisplay.py
added layer select and deselect
Modified: grass-addons/gui/wxpython/data_catalog/LayerTree.py
--- grass-addons/gui/wxpython/data_catalog/LayerTree.py	2010-04-24 11:19:54 UTC (rev 42015)
+++ grass-addons/gui/wxpython/data_catalog/LayerTree.py	2010-04-24 11:54:57 UTC (rev 42016)
@@ -1,3 +1,24 @@
+ at package LayerTree.py
+GRASS LayerTree.
+ at breif A MapTree to display maps based on the selected location and mapset
+MapTree provides functionss such as view,copy,rename and delete mapset
+Classes:
+ - DataCatalog
+ - CatalogApp
+(C) 2007 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Mohammed Rashad K.M <rashadkm at gmail dot com>
 import os
 import sys
 import wx
Modified: grass-addons/gui/wxpython/data_catalog/mapdisplay.py
--- grass-addons/gui/wxpython/data_catalog/mapdisplay.py	2010-04-24 11:19:54 UTC (rev 42015)
+++ grass-addons/gui/wxpython/data_catalog/mapdisplay.py	2010-04-24 11:54:57 UTC (rev 42016)
@@ -5,14 +5,13 @@
 management functions, and additional toolbars (vector digitizer, 3d
 view).
-Can be used either from Layer Manager or as p.mon backend.
 Classes:
+- Command
+- MapWindow
+- BufferedWindow
 - MapFrame
-- MapApp
-Usage:
-python mapdisp.py monitor-identifier /path/to/command/file
 (C) 2006-2009 by the GRASS Development Team
@@ -4574,47 +4573,4 @@
 # end of class MapFrame
-class MapApp(wx.App):
-    MapApp class
-    def OnInit(self):
-        wx.InitAllImageHandlers()
-        if __name__ == "__main__":
-            Map = render.Map() # instance of Map class to render GRASS display output to PPM file
-        else:
-            Map = None
-        self.mapFrm = MapFrame(parent=None, id=wx.ID_ANY, Map=Map,
-                               size=globalvar.MAP_WINDOW_SIZE)
-        #self.SetTopWindow(Map)
-        self.mapFrm.Show()
-            # redraw map, if new command appears
-            self.redraw = False
-        return 1
-# end of class MapApp
-if __name__ == "__main__":
-    ###### SET command variable
-    title = "title"
-    cmdfilename = "cmdfilename"
-    gm_map = MapApp(0)
-    # set title
-    gm_map.mapFrm.SetTitle(_("GRASS GIS Map Display: " +   title +   " - Location: " + grass.gisenv()["LOCATION_NAME"]))
-    gm_map.MainLoop()
-    sys.exit(0)
