[GRASS-SVN] r42019 -
grass/branches/develbranch_6/scripts/g.extension
svn_grass at osgeo.org
Sat Apr 24 10:01:48 EDT 2010
Author: martinl
Date: 2010-04-24 10:01:48 -0400 (Sat, 24 Apr 2010)
New Revision: 42019
grass/branches/develbranch_6/scripts/g.extension/g.extension
g.extension: fix install procedure
replace 'a' flag by 'prefix' parameter
Modified: grass/branches/develbranch_6/scripts/g.extension/g.extension
--- grass/branches/develbranch_6/scripts/g.extension/g.extension 2010-04-24 13:14:17 UTC (rev 42018)
+++ grass/branches/develbranch_6/scripts/g.extension/g.extension 2010-04-24 14:01:48 UTC (rev 42019)
@@ -4,9 +4,9 @@
# MODULE: g.extension
# AUTHOR(S): Markus Neteler
-# PURPOSE: tool to download and install extensions from GRASS Addons SVN into
+# PURPOSE: Tool to download and install extensions from GRASS Addons SVN into
# local GRASS installation
-# COPYRIGHT: (C) 2009 by the Markus Neteler, GRASS Development Team
+# COPYRIGHT: (C) 2009-2010 by the Markus Neteler, GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -18,8 +18,7 @@
#%Module
#% label: Tool to maintain GRASS extensions in local GRASS installation.
#% description: Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions.
-#% keywords: installation
-#% keywords: extensions
+#% keywords: general, extensions
#%End
#%option
@@ -35,7 +34,7 @@
#% key_desc: name
#% description: Operation to be performed
#% required: no
-#% options: add
+#% options: add,remove
#% answer: add
#%end
#%option
@@ -51,14 +50,10 @@
#% type: string
#% key_desc: path
#% description: Prefix where to install extension
-#% answer: ${GISBASE}
+#% answer: $GRASS_ADDON_PATH
#% required: yes
#%end
#%flag
-#% key: a
-#% description: Install to $GRASS_ADDON_PATH instead of using prefix option
-#%end
-#%flag
#% key: l
#% description: List available modules in the GRASS Addons SVN repository
#% guisection: Print
@@ -77,22 +72,9 @@
# definitions
SVNURL_ADDONS=${GIS_OPT_SVNURL}
+MODULE="$GIS_OPT_EXTENSION"
+PREFIX="$GIS_OPT_PREFIX"
-if [ $GIS_FLAG_A -eq 0 ] ; then
- if [ "$GIS_OPT_PREFIX" = '${GISBASE}' ] ; then
- MYINST_DIR=${GISBASE}
- else
- MYINST_DIR=${GIS_OPT_PREFIX}
- fi
-else
- if [ -d "$GRASS_ADDON_PATH" ] ; then
- MYINST_DIR="$GRASS_ADDON_PATH"
- else
- g.message -e '$GRASS_ADDON_PATH does not exist'
- exit 1
- fi
-fi
#make a temporary directory
TMPDIR="`g.tempfile pid=$$`"
if [ $? -ne 0 ] || [ -z "$TMPDIR" ] ; then
@@ -158,8 +140,6 @@
fi
-MODULE="$GIS_OPT_EXTENSION"
if [ `echo "$MODULE" | grep -c '/'` -eq 0 ] ; then
CLASSCHAR=`echo $MODULE | cut -d'.' -f1`
MODULECLASS=`expand_module_class_name $CLASSCHAR`
@@ -211,6 +191,37 @@
exit 1
fi
+if [ "$PREFIX" == '$GRASS_ADDON_PATH' ] ; then
+ if [ -z "$GRASS_ADDON_PATH" ] ; then
+ g.message -e "GRASS_ADDON_PATH is not defined"
+ exit 1
+ fi
+ PREFIX=$GRASS_ADDON_PATH
+fi
+if [ -d "$PREFIX" ] ; then
+ MYINST_DIR="$PREFIX"
+else
+ g.message -e "'$PREFIX' does not exist"
+ exit 1
+fi
+if [ "$GIS_OPT_OPERATION" == "remove" ] ; then
+ g.message message="Removing <$MODULE>..."
+ if test -f "${MYINST_DIR}/bin/${MODULE}" ; then
+ rm -f "${MYINST_DIR}/bin/${MODULE}"
+ fi
+ if test -f "${MYINST_DIR}/docs/html/${MODULE}.html" ; then
+ rm -f "${MYINST_DIR}/docs/html/${MODULE}.html"
+ fi
+ if test -f "${MYINST_DIR}/man/man1/${MODULE}.1" ; then
+ rm -f "${MYINST_DIR}/man/man1/${MODULE}.1"
+ fi
+ exit 0
+fi
g.message -d "svn co [$SVNURL_ADDONS]/[$MODULECLASS]/[$MODULE]"
cd "$TMPDIR"
@@ -223,7 +234,7 @@
fi
cd "$TMPDIR/$MODULE"
-g.message message="Compiling ${MODULE}..."
+g.message message="Compiling <${MODULE}>..."
make MODULE_TOPDIR="$GISBASE"
if [ $? -ne 0 ] ; then
g.message -e message="Compilation failed, sorry. Please check above error messages."
@@ -253,7 +264,7 @@
fi
- make MODULE_TOPDIR="$GISBASE" INST_DIR="$MYINST_DIR"
+ make MODULE_TOPDIR="$GISBASE" INST_DIR="$MYINST_DIR" install
g.message -e message="Installation failed, sorry. Please check above error messages."
cleanup
@@ -264,10 +275,6 @@
cleanup
exit 1
fi
- if [ $GIS_FLAG_A -eq 1 ] ; then
- \mv "${MYINST_DIR}/bin/${MODULE}" "$MYINST_DIR"/
- rmdir "${MYINST_DIR}/bin"
- fi
fi
fi
